AmazonBasics High Mileage Motor Oil - Synthetic Blend
AmazonBasics high-mileage synthetic-blend motor oil offers an enhanced level of protection for engines over 75,000 miles. Its synthetic blend combines conventional oil with synthetic for cost efficiency with some of the benefits of a full synthetic. An important part of routine maintenance, the motor oil works well for anything from topping off levels to complete oil changes. Whether it’s a beloved older vehicle or one with an uncertain maintenance history, help protect its engine with AmazonBasics high-mileage, synthetic-blend motor oil.
API SN and ILSAC GF-5 approved, AmazonBasics high-mileage motor oil offers exceptional quality and convenience.
Note: Always follow vehicle manual recommendations.
Friction-Reducing Formula
AmazonBasics high-mileage motor oil creates a protective coating that helps reduce wear on engine components. By minimizing friction from in-contact moving engine parts (which wastes otherwise useful power), the motor oil helps enhance fuel economy and promotes better power output and performance.
Reliable Protection
The high-mileage motor oil helps keep the engine clean by minimizing unwanted build-up that can cause damaging rust and corrosion. The motor oil offers a resistance to viscosity and thermal breakdown, plus it helps fight volatility burn-off, which can reduce engine deposits and exhaust emissions.
Available Viscosity Grades
The motor oil’s grade, as established by the Society of Automotive Engineers (SAE), reflects its viscosity characteristics. The first number(s)—5W and 10W—indicate cold-temperature performance (W for winter), while the end numbers—20, 30, and 40—indicate high-temperature performance (at 100 degrees C).
Depending on driving conditions and needs, choose from the following AmazonBasics high-mileage synthetic-blend motor oil grades (shown in chart below; each sold separately):
  • 6 months later...
  • 1 month later...
      Internal email from Autozone regarding an oil shortage coming across the US
      Fuchs Lubricants Co. recently highlighted its Titan GT1 Flex 5 SAE 0W-20. It’s an engine oil that meets the demanding needs of today’s highly stressed, downsized, and hybrid passenger car engines. As OEMs continue to engineer vehicles for higher efficiency and fuel economy, Titan GT1 Flex 5 SAE 0W-20 delivers a low-viscosity formulation that supports fuel-saving characteristics, reduced CO2 emissions and reliable performance under severe operating conditions.
      OEM Approvals and Requirements
      Selected BMW, Mercedes-Benz, and Jaguar Land Rover models approve the use of Titan GT1 Flex 5 SAE 0W-20. It also meets the engine oil requirements of Ford, Chrysler, Volvo and other manufacturers specifying ILSAC GF-6A and API SP. The product also carries key OEM approvals, including BMW Longlife-17 FE+, Jaguar Land Rover STJLR.03.5006, MB-Approval 229.71, MB-Approval 229.72 and OV 040 1547. It aligns with additional recommendations such as Chrysler MS-12145, Fiat 9.55535-GSX, Ford WSS-M2C947-A, Ford WSS-M2C947-B1, Ford WSS-M2C962-A1, ILSAC GF-5, Jaguar Land Rover STJLR.51.5122, Volvo VCC RBS0-2AE and VWC 53057. This broad coverage allows distributors, workshops and fleets to simplify inventory. It also enables servicing of a wide mix of European, Asian and American vehicles.
      Engineered for Modern Engines and Operating Conditions
      Titan GT1 Flex 5 SAE 0W-20 is tailored for vehicles with start-stop systems, downsized aggregates and extended high-speed operation in challenging temperature environments. Advanced formula with BluEV-Technology enhances aging stability. The goal is to help the oil maintain viscosity and protection even under high outside temperatures and during sustained highway driving.
      LSPI Protection and Extended Drain Intervals
      The oil also offers targeted protection against low-speed pre-ignition (LSPI). The company noted this is critical concern in modern turbocharged gasoline engines, supporting reliable combustion and engine durability.
      Browse our premium selection of Audi A6 engines, covering all generations and trim levels. Available configurations include the 2.0L TFSI, 3.0L TFSI supercharged, and TDI diesel variants. Every engine in our inventory is carefully sourced from verified suppliers and tested to meet or exceed OEM performance standards. We conduct thorough compression tests, oil pressure checks, and visual inspections on every unit before shipping. Our team of Audi specialists ensures compatibility guidance so you get the exact engine your vehicle requires. We provide clear mileage records, warranty documentation, and dedicated after-sale support. Whether you're a DIY mechanic or professional shop, trust us for reliable Audi A6 engines at honest prices.
