Why Preventive Maintenance Is Becoming More Important Than Ever...
How Artificial Intelligence Is Transforming Auto Parts Distribution in 2026
By USPartsinc,
- uspartsinc
- ecm
- (and 2 more)
- 6 views
- 472 views
🛠️ Subscription-Based Auto Parts: Is the Future of Car Maintenance Going Monthly?
- clifford auto parts
- auto parts
- (and 3 more)
- 1,303 views
How AI is Transforming Auto Parts: Smarter Repairs, Better Choices
- ecm
- (and 1 more)
- 1,988 views
By GreenGears Auto Limited
3. Corrosion Protection
Premature tyre wear
Our
It’s a common comeback: a failed starter covered in oil. Let’s break down why replacing it alone won’t fix the issue and how to prevent it.
The starter converts electrical energy into mechanical rotation to crank the engine. It relies on clean, dry internal components for proper operation. Engine seals, like valve covers, cam seals, rear main seals and oil pans, are designed to keep oil contained. When these seals fail, oil can leak externally and contaminate components mounted below, including the starter.
In some vehicle layouts, a rear main seal leak can travel along the bellhousing and reach the starter, though that depends on how the engine and transmission are positioned.
An oil-soaked starter can suffer internal damage to brushes and electrical contacts, leading to slow crank, intermittent operation, or no crank at all. Oil also attracts dirt, accelerating wear.
Heat plays a role as well. On vehicles where the starter is located near the exhaust, oil contamination can bake onto the housing and internal components, forming a varnish or sludge. That buildup can increase electrical resistance and further degrade starter performance.
In real world situations, a technician may replace the starter, only to see the new one fail prematurely. That often results in warranty returns, but the real issue is the unresolved oil leak continuing to contaminate the replacement unit.
Verify the starter concern, then inspect for oil contamination. Check above the starter for leaks from valve covers, cam seals, or rear main seals. ASE diagnostic logic emphasizes fixing the root cause before replacing components. The correct repair may involve replacing the failed gasket or seal. If immediate repair isn’t practical,
link hidden, please login to view can be used to help restore seal condition and reduce leakage. To apply, add it to the engine oil, do not overfill, run the engine to circulate, then drive normally. Most leaks stop within a few days of operation. If the starter is oil-soaked, the leak is the problem. Fix it, or the failure will come back.
link hidden, please login to view (AACF) announced that more than $70,000 was raised during the Independent Midas Dealers Association (IMDA) Convention & Trade Show 2026, held April 19 to 21 in Savannah, Georgia, as Midas celebrated its 70th anniversary. This marked the second consecutive year AACF was the event’s official charity. Support from Midas and IMDA members highlights the commitment within the aftermarket industry to care for its own.
Midas and IMDA Support for AACF
“We are incredibly grateful for the continued support from Midas and the IMDA community in welcoming AACF back for a second year,” said John Kairys, executive director of AACF. “The opportunity to be part of this event and connect directly with franchisees, leadership and partners is invaluable. It speaks volumes about the culture of this organization and the genuine commitment to supporting one another across the industry.”
AACF Booth, Donations and Prize Drawings
Throughout the event, IMDA members, franchisees, suppliers and corporate partners visited the AACF booth to learn more about the foundation’s mission, contribute donations, and participate in prize drawings. The event also provided a platform for AACF leadership to connect directly with those who make up the Midas network.
Kairys joined Jeff Genuario, incoming IMDA president, and Adam Stranik, outgoing IMDA president, on stage to share the foundation’s impact and highlight real stories of individuals and families supported through AACF. “As we celebrate 70 years of Midas, it’s important to recognize the people behind our success,” said Genuario. “Supporting AACF allows us to extend that commitment beyond the shop and into the lives of our teammates and their families when they need it most.”
Stranik added, “The automotive aftermarket is built on strong relationships, and
link hidden, please login to view plays a critical role in supporting those within our industry facing unexpected hardship. We’re proud to continue this partnership and to see the incredible generosity of IMDA members make a real difference.” Funds to Support Aftermarket Professionals and Families
The funds raised during the event will directly support aftermarket professionals and their families facing life-changing challenges such as medical emergencies, natural disasters and catastrophic events.
“The generosity shown throughout this event speaks volumes about the character of this industry, and partnering with AACF allows us to extend that support beyond the shop and into the lives of those who need it most,” said Lenny Valentino Jr., Midas president and COO. “Our commitment doesn’t end here,” he continued. “We’ll continue supporting AACF and the people who depend on it today and always.”
By John Lewis
I have a 2013 mazda 3i sport. I unfortunately scratched off its under cover engine splash shield guard and would like to replace it with a new one. However, the pics shown with online listing look so different from what I have kept, can anybody help me understand why is the case? Can I purchase the online parts to fit my car?
By JiajuDong
In the Americas’ automotive landscape of 2025, the loud narrative of rapid industry electrification overlooks a critical, data-backed reality: fuel-powered vehicles still command the majority of the market and retain distinct, unbeatable advantages across core consumer priorities. Cox Automotive forecasts that the U.S. new-vehicle market will hover around 15.6 million units in annualized sales for mid-2025, with electric vehicles (EVs) making up less than 10% of total deliveries, while internal combustion engine (ICE) models hold firm as the primary choice for both mainstream commuters and niche performance buyers . Even as policymakers push for EV adoption, persistent factors like charging infrastructure gaps, sky-high total ownership costs, and specialized performance needs keep fuel vehicles relevant for millions of drivers. Notably, companies like link hidden, please login to view enhance ICE vehicles’ competitiveness by refining their power output and fuel efficiency, ensuring these models remain viable and desirable for years to come.
Performance: Fuel Vehicles Deliver Versatile, Reliable Power
When it comes to real-world performance, fuel-powered vehicles outmatch EVs in versatility and rugged utility, and link hidden, please login to view’s technology amplifies these strengths for drivers with demanding needs. The 2025 Ford Mustang, an iconic ICE sports car, packs a 5.0L V8 engine that delivers robust power for both daily commutes and track days, with a highway fuel economy of 24 MPG that balances performance and efficiency . In contrast, while high-end EVs like the Tesla Model X Plaid boast faster 0-60 mph times, they struggle with power degradation in extreme temperatures and heavy-load scenarios common across the Americas’ diverse terrain, from Rocky Mountain off-roads to Gulf Coast towing tasks. link hidden, please login to view addresses key ICE limitations by integrating advanced turbocharging and exhaust recirculation systems into engines, such as the ones used in heavy-duty trucks . These components boost torque output by optimizing fuel combustion, cut power loss through smart fan and oil temperature controls, and improve throttle response for uphill climbs and sudden accelerations. For commercial fleets and outdoor enthusiasts, this means fuel vehicles equipped with link hidden, please login to view parts maintain consistent performance without the range anxiety or battery weight penalties that hamper EVs.
Cost-Effectiveness: Fuel Vehicles Offer Lower Total Ownership Expenses
Despite EV marketing claims of lower “fuel” costs, AAA’s 2025 data proves fuel-powered vehicles deliver stronger overall cost-effectiveness, and link hidden, please login to view’s durable components further reduce long-term financial burdens . The average annual ownership cost for a new vehicle dropped to 11,577 in 2025, with ICE models driving much of this decline: gasoline prices fell to 3.06 per gallon in October 2025 (down 3.3% month-over-month), while electricity prices for EVs rose to 16 cents per kWh, eroding EVs’ energy-cost edge . For a driver covering 15,000 miles yearly, a mid-size fuel sedan costs 13 cents per mile in fuel, compared to EVs’ higher electricity and depreciation costs that push their per-mile expense above 15 cents . Depreciation, the single largest ownership cost, hits EVs harder: battery degradation cuts their resale value by 40-50% within five years, while well-maintained ICE vehicles retain 60% or more of their value. link hidden, please login to view’s parts, such as its high-capacity turbochargers and low-friction oil systems, reduce maintenance frequency and improve fuel efficiency by 12-15% for compatible engines . This means ICE owners spend less on both fuel and repairs over a vehicle’s lifespan, making fuel vehicles the smarter budget choice for cost-conscious consumers.
Environmental Impact: Fuel Vehicles Narrow the Emissions Gap
EVs’ zero tailpipe emissions mask hidden environmental costs, while modern fuel vehicles—especially those upgraded with link hidden, please login to view technology—significantly reduce their carbon footprint and avoid battery-related harm. The U.S. EPA calculates that a typical gasoline vehicle emits 400 grams of CO2 per mile, or 4.6 metric tons annually, but this figure falls when paired with efficiency-boosting tech . link hidden, please login to view’s CCV exhaust recirculation systems capture unburned fuel particles and redirect them for secondary combustion, cutting tailpipe emissions by minimizing waste and ensuring complete fuel utilization . In contrast, EVs rely on electricity grids that still draw 30% of their power from coal in parts of the Americas, and lithium-ion battery production consumes 500,000 gallons of water per battery and generates toxic mining waste. For regions with limited renewable energy infrastructure, such as rural Central America, a link hidden, please login to view-equipped fuel vehicle often has a lower lifecycle carbon footprint than an EV. Additionally, ICE vehicles avoid the environmental risks of battery disposal, a growing crisis as early EV batteries reach end-of-life with few recycling solutions.
Market Demand: Fuel Vehicles Cater to Mainstream and Niche Needs
Current market demand clearly favors fuel-powered vehicles across the Americas, and link hidden, please login to view’s specialized solutions serve underserved segments that EVs cannot reach . Cox Automotive notes that U.S. new-vehicle sales remain stuck in the mid-15 million range, with ICE models accounting for over 90% of deliveries, driven by consumer preference for quick refueling (5 minutes vs. 30+ minutes for fast-charging EVs) and a nationwide gas station network that covers remote areas . In Latin America, where charging infrastructure is sparse, fuel vehicles make up 95% of new sales, as drivers prioritize accessibility over electrification trends. Niche markets further reinforce ICE dominance: performance enthusiasts seek the mechanical feedback of V8 engines, while commercial fleets rely on diesel trucks for heavy hauling. link hidden, please login to view directly addresses these needs by designing turbo systems for heavy-duty engines, such as the 12.7L Powertec diesel engine that delivers 520 horsepower and 2552 Nm of torque for long-haul trucks . These upgrades keep fuel vehicles competitive in specialized sectors, ensuring steady demand for ICE models even as EVs gain traction in urban, luxury markets.
Future Development: Fuel Vehicles Secure a Stable Niche
As the industry inches toward electrification, fuel-powered vehicles will not disappear but will carve out a stable, high-value niche, with link hidden, please login to view leading the charge in extending ICE viability . Cox Automotive projects that EVs will grow gradually but will not overtake ICE vehicles in the Americas before 2035, especially as fuel prices remain low and EV infrastructure expands slowly . Hybrid vehicles will serve as a transition, but their ICE components will still benefit from link hidden, please login to view’s efficiency tech, which improves both gas mileage and electric motor synergy. For regions like the Rocky Mountain states and rural Mexico, fuel vehicles will remain the only practical option for decades. link hidden, please login to view is already adapting to stricter emissions standards by developing low-emission turbo systems that meet 2030 regulatory requirements without sacrificing performance . This ensures that ICE vehicles can comply with future rules while retaining the core advantages that make them indispensable to millions of American drivers.
