turbocharger ICE vs. EV in the Americas: Why Fuel-Powered Vehicles Still Dominate the Road (and Will for Years to Come)
- 167 views
turbocharger Which Region’s Suppliers Are Globally Trusted?
By JiajuDong,
- powertec turbo
- chinese supplier
- (and 1 more)
- 137 views
turbocharger Booming Global Turbocharger Market: Seize Growth
By JiajuDong,
- turborepairkit
- turbochra
- (and 1 more)
- 252 views
turbocharger Fuel Power’s Irreplaceability: Turbo Tech, Safety, and Environmental Edge Over EV Motors
By JiajuDong,
- powertecturbo
- turbochra
- (and 1 more)
- 2 replies
- 292 views
- 1,889 views
By USPartsinc
In today's automotive market, more vehicle owners are focusing on preventive maintenance rather than waiting for major repairs. With the cost of new vehicles continuing to rise, drivers are looking for ways to extend the lifespan of their current cars, trucks, and SUVs.
This shift is creating new opportunities across the automotive aftermarket.
The Cost of Waiting Too Long
Many vehicle failures don't happen overnight. Worn brake pads, aging belts, failing water pumps, and deteriorating suspension components often show warning signs long before they cause serious problems.
Ignoring these signs can turn a relatively inexpensive repair into a costly breakdown. For example, replacing a worn timing belt is far less expensive than repairing engine damage caused by a belt failure.
As consumers become more aware of long-term ownership costs, preventive maintenance is gaining greater attention.
Technology Is Helping Drivers Stay Ahead
Modern vehicles are equipped with sensors and monitoring systems that can alert drivers to maintenance needs before a major issue develops. Oil life monitors, tire pressure sensors, battery monitoring systems, and diagnostic alerts help vehicle owners address problems early.
This has increased demand for replacement parts that support routine maintenance and scheduled service intervals.
Benefits for Vehicle Owners
Preventive maintenance offers several advantages:
Improved vehicle reliability Better fuel efficiency Reduced repair costs over time Increased resale value Enhanced safety on the road Many drivers are realizing that regular maintenance is one of the smartest investments they can make in their vehicles.
Growing Opportunities for the Aftermarket
As more consumers prioritize maintenance, demand continues to grow for filters, brake components, suspension parts, ignition components, cooling system parts, and other wear-and-tear items.
Repair shops and parts suppliers that educate customers about maintenance schedules can build stronger relationships while helping vehicle owners avoid unexpected breakdowns.
Looking Ahead
The trend toward longer vehicle ownership is unlikely to slow down anytime soon. As vehicles remain on the road for more years, preventive maintenance will play an even greater role in keeping them safe, reliable, and cost-effective.
For the automotive aftermarket, this represents a significant opportunity to support drivers through quality parts, expert advice, and reliable service.
Do you think today's drivers are becoming more proactive about maintenance, or are most still waiting until something breaks? Share your experience below.
By GreenGears Auto Limited
3. Corrosion Protection
Premature tyre wear
Our
It’s a common comeback: a failed starter covered in oil. Let’s break down why replacing it alone won’t fix the issue and how to prevent it.
The starter converts electrical energy into mechanical rotation to crank the engine. It relies on clean, dry internal components for proper operation. Engine seals, like valve covers, cam seals, rear main seals and oil pans, are designed to keep oil contained. When these seals fail, oil can leak externally and contaminate components mounted below, including the starter.
In some vehicle layouts, a rear main seal leak can travel along the bellhousing and reach the starter, though that depends on how the engine and transmission are positioned.
An oil-soaked starter can suffer internal damage to brushes and electrical contacts, leading to slow crank, intermittent operation, or no crank at all. Oil also attracts dirt, accelerating wear.
Heat plays a role as well. On vehicles where the starter is located near the exhaust, oil contamination can bake onto the housing and internal components, forming a varnish or sludge. That buildup can increase electrical resistance and further degrade starter performance.
In real world situations, a technician may replace the starter, only to see the new one fail prematurely. That often results in warranty returns, but the real issue is the unresolved oil leak continuing to contaminate the replacement unit.
Verify the starter concern, then inspect for oil contamination. Check above the starter for leaks from valve covers, cam seals, or rear main seals. ASE diagnostic logic emphasizes fixing the root cause before replacing components. The correct repair may involve replacing the failed gasket or seal. If immediate repair isn’t practical,
link hidden, please login to view can be used to help restore seal condition and reduce leakage. To apply, add it to the engine oil, do not overfill, run the engine to circulate, then drive normally. Most leaks stop within a few days of operation. If the starter is oil-soaked, the leak is the problem. Fix it, or the failure will come back.
