on_my_car_shield_guard.thumb.jpg.6da7b17ab82b6f44b5f3cb544f96175d.jpgonline_shield_guard.jpg.392442483ad23ee9066500fa131e9fe9.jpg
I have a 2013 mazda 3i sport. I unfortunately scratched off its under cover engine splash shield guard and would like to replace it with a new one. However, the pics shown with online listing look so different from what I have kept, can anybody help me understand why is the case? Can I purchase the online parts to fit my car?
Did you ever find this? I took a quick look and they all look like that and not what you have. Did you search by VIN #? I would say it's either a redesign or you have your model wrong.
What you’re seeing is actually pretty common with underbody splash shields on these cars.
The one currently on your Mazda looks like an OEM unit with additional insulation/sound-deadening material attached. Over time, those felt/foam sections get dirty, sag, or even tear off, which is why yours looks quite different.
Most of the ones you’re seeing online (including OEM listings) are either:
  • New replacements without the insulation layer, or
  • Updated/revised designs from Mazda that simplify the panel
As long as:
  • The part number matches your VIN, and
  • The mounting points/holes line up,
…it will fit your car just fine, even if the design looks a bit different.
Also worth noting:
Mazda (and most manufacturers) often revise these panels over time for cost, airflow, or durability reasons, so it’s not unusual for the replacement to not look identical to what originally came off the car.
👉 If you want to be 100% sure, share your VIN and we can help confirm the exact correct part for your setup.
Email us at: [email protected]
    • By juliaanderson
    • By juliaanderson
      Hey everyone,
