Dayco is releasing the newest addition to its Ela serpentine belt lineup in North America. Part No. 6PK1742EE was developed specifically for a number of full-size pickup trucks and SUVs with an advantage over the OE design, according to Dayco.
Performance and Tension Decay
Based on SAE laboratory testing, the
Ela belt is engineered for less tension decay than OEM counterparts. Results show it kept the belt tighter and more efficient for longer periods — a factor in maintaining accessory drive system performance over time.
Executive Perspective
“We’re excited to bring this latest advancement in belt technology to the aftermarket,” said Jerry Reeves, head of product management,
North America. “This isn’t just a new part number — It’s the longest ela belt on the market. And because of its length and complexity, it took significant development from our engineering team to create a new construction that would outperform the OEM belt.”
Application and Coverage
With coverage for over 2.8 million vehicles in operation (VIO), it represents a high-volume opportunity for distributors and repair shops. Ela belts, also known as “stretch” belts, are designed for systems that do not utilize a tensioner, making belt elasticity and tension retention critical to maintaining accessory function, reducing slip and avoiding premature failure.
Features of Dayco ela belt Part No. 6PK1742EE
  • Design — Built for GM trucks with 5.3-liter and 6.2-liter engines, this Ela stretch belt is a main drive belt, which means it drives more than one accessory. It is the first Ela belt to drive more than a single accessory.
  • Durability and stretch — A wear-resistant EPDM rib material, along with a highly elastic EPDM cushion rubber, surrounds a polyamide tensile cord, which allows for the proper tension maintenance properties needed to transmit the exact accessory load demanded for the drive.
  • Tension decay performance — Engineered to stay taut longer, the belt delivers consistent performance and reduced noise.
  • Exceeds OE specifications — Designed to perform better and last longer than the original belt.
In Stock Through Dayco’s Distribution Network
Part No. 6PK1742EE is now in stock through Dayco’s distribution network. With growing demand for Ela belt replacements and a performance advantage over OEM, this belt enables channel partners to meet rising technician demand for alternatives.
For more information about Dayco’s line of serpentine belts and other aftermarket products, technicians and distributors should log on to na.daycoaftermarket.com.
      link hidden, please login to view introduces a new line of Transtar Brand 100% all New Components Torque Converters which it said are engineered specifically for 2011-up Ford Trucks and Vans equipped with 6R140 transmissions. Designed to meet the demands of modern gas and diesel powertrains, these converters deliver consistent, dependable performance for today’s rebuilders and come with a 12-month/unlimited mileage warranty.
      Developed by an engineering team with decades of experience supporting global automotive programs, all converters are manufactured to OE specifications and designed to meet or exceed factory performance standards,
      link hidden, please login to view said. Applications & Coverage
      2011-Up Ford F250, F350 and F450 with 6r140 transmission.  2016-Up Ford E350 and E450 with 6R140 transmission.  Available Part Numbers
      TS-FM1261 (6.2L; 6.8L Gas Engines)  TS-FM1262 (6.7L Diesel Engine, 6 Mounting Studs)  TS-FM1265 (7.3L Gas Engine) For optimal performance, pair with Transtar Low Viscosity Fluid.
    • By GreenGears Auto Limited
      Published by GreenGears Auto  |  9 minute read  |  Budget SUV Repair & OEM Parts Guide
      SUV ownership comes with higher repair costs than most drivers expect. Larger components, heavier drivetrains, and AWD or 4WD systems that sedans simply don't have push repair bills significantly higher — especially when dealers quote new OEM pricing. The good news: used OEM parts for SUVs represent some of the highest-value purchases in the entire auto parts market. SUVs are sold in enormous volumes, generate abundant salvage supply from accident-damaged donors, and use overbuilt drivetrain components that retain exceptional service life at mid-range mileage. At GreenGears Auto, we source quality-inspected OEM used SUV parts across every major platform — at 50–70% less than new OEM dealer pricing. This guide covers the best budget-friendly used OEM parts for every major SUV repair category. budget OEM SUV parts cheap used SUV parts affordable SUV repair parts used OEM SUV differential cheap SUV transfer case used SUV suspension parts discount OEM SUV drivetrain GreenGears Auto Why SUV Repairs Are More Expensive — and How Used OEM Changes That
      SUVs cost more to repair than passenger cars for three compounding reasons: larger, heavier components cost more to manufacture and therefore more to buy new; AWD and 4WD drivetrains add entire component categories that cars don't have; and dealer service departments markup OEM parts significantly on high-demand SUV platforms. Used OEM changes all three equations simultaneously.
      50–70% Average savings on used OEM SUV parts vs. new OEM dealer pricing at GreenGears Auto 2–3x Higher average repair cost for AWD/4WD SUVs vs. equivalent 2WD vehicles when buying new OEM parts 85% Lower carbon footprint per used OEM SUV part vs. new manufacturing — budget-friendly and sustainable The most important advantage of used OEM SUV parts beyond price: these are the actual factory components — engineered specifically for your SUV's weight, load ratings, towing capacity, and AWD system calibration. Aftermarket SUV parts are manufactured to approximate OEM specifications, which is why they produce a higher comeback rate on larger, heavier, and more electronically integrated vehicles than on compact cars.
      🔧 GreenGears Tip — Why SUV Drivetrains Favour Used OEM SUV drivetrain components — differentials, transfer cases, and transmissions — are significantly over-engineered relative to typical use. A Ford Explorer 8.8-inch rear differential or a Toyota 4Runner transfer case is built to handle loads that most SUV owners never approach. This over-engineering is what makes a quality used unit from a 60,000-mile donor a reliable long-term repair — the part has barely been stressed relative to its design capacity. SUV Categories — What Your Repair Budget Depends On
      Budget requirements and parts availability differ significantly between SUV types. Understanding your vehicle's category is the first step to finding the best affordable used OEM parts.
      🏔️ Body-on-Frame 4WD SUVs
      Toyota 4Runner, Chevrolet Tahoe / Suburban, Ford Expedition, Jeep Grand Cherokee, Nissan Armada. Largest repair bills but also highest-value used OEM finds — heavy-duty drivetrain components are dramatically over-engineered for typical use and retain enormous service life.
      🚙 Unibody Crossover SUVs
      Toyota RAV4, Honda CR-V, Ford Escape / Edge, Chevrolet Equinox, Subaru Outback / Forester. Highest used parts availability due to enormous sales volumes — lowest used OEM prices in the SUV market. AWD systems add component categories not found on 2WD crossovers.
      🇩🇪 European Luxury SUVs
      BMW X3 / X5, Mercedes GLE / GLC, Audi Q5 / Q7, Volvo XC60 / XC90. Highest new OEM prices — which makes used OEM savings most dramatic. Electronic AWD systems require OEM-only replacement for correct ECU integration. Excellent used availability from low-mileage European imports.
      💼 Full-Size American Luxury SUVs
      Lincoln Navigator, Cadillac Escalade, GMC Yukon Denali, Ford Expedition Limited. Share drivetrain architecture with mainstream truck platforms — allowing cross-reference sourcing from the much larger F-150 and Silverado donor fleets at significantly lower prices.
      Top Budget-Friendly Used OEM Parts for SUVs — By Category
      Here are the highest-value used OEM part categories for SUV owners — showing real price comparisons between new OEM and GreenGears Auto used OEM pricing, and the specific platforms where the savings are most compelling.
      💰 Biggest Per-Part SUV Savings Save $400–$2,000 vs. New Used OEM Rear Differentials for SUVs
      Used OEM: $180–$900 New OEM: $600–$2,700+ Save up to 70% The rear differential is one of the most expensive structural drivetrain replacements on any SUV — and one of the best used OEM value propositions in the entire market. SUV differentials are over-engineered for load and towing demands that most owners never approach, meaning a quality used unit from a low-mileage donor retains the vast majority of its design service life. New OEM rear differential pricing for common SUV platforms regularly reaches $800–$2,700 at the dealer — used OEM from GreenGears Auto cuts that to $180–$900 without any compromise in material quality or gear geometry.
      Best budget used OEM rear differentials for SUVs:
      Toyota RAV4 AWD rear differential (2013–2022): $200–$420 — most affordable quality used SUV rear differential in the market; Toyota's over-engineering produces exceptional remaining service life Toyota 4Runner rear differential (2003–present): $280–$580 — Torsen LSD option on TRD and V8 trims; units from accident-damaged donors in excellent condition Ford Explorer AWD 8.8-inch rear differential (2006–2019): $220–$480 — one of the most robust OEM differentials ever fitted to a mass-market SUV; outstanding used availability Chevrolet Tahoe / Suburban 8.6-inch rear differential (2007–2019): $260–$560 — heavy-duty unit built for far more than typical SUV use; 14-bolt units available for maximum load capacity Honda CR-V / Pilot AWD rear differential (2012–2022): $180–$380 — most affordable used OEM AWD differential available; excellent reliability from Honda's high-volume sales Jeep Grand Cherokee Dana 44 rear differential (2011–2021): $240–$520 — preferred over Dana 35; Trac-Lok LSD available on WK2 Overland and Limited trims BMW X5 xDrive rear differential (2007–2018): $360–$780 — new OEM exceeds $2,000; used OEM makes BMW X5 rear differential repair viable rather than send the vehicle to auction Mercedes GLE / GLC 4MATIC rear differential (2016–present): $420–$860 — same story as BMW; used OEM is the only cost-viable repair option on these platforms 🔄 AWD/4WD Specific Savings Save $600–$2,500 vs. New Used OEM Transfer Cases for SUVs
      Used OEM: $240–$1,100 New OEM: $1,000–$3,500+ Save up to 70% Transfer case replacement is a uniquely SUV repair — passenger cars simply don't have them. New OEM transfer cases for popular SUV platforms cost $1,000–$3,500+ at the dealer, which frequently makes a functioning AWD or 4WD SUV an economically marginal repair proposition. Used OEM from GreenGears Auto at $240–$1,100 changes that calculation entirely — keeping vehicles on the road that would otherwise head to auction. And because SUV transfer cases are built for demanding use, a quality used unit from a highway-driven, low-mileage donor vehicle has retained the vast majority of its service life.
      Toyota RAV4 AWD Active Torque Control transfer case (2013–2022): $240–$480 — most affordable quality AWD transfer case for crossover SUVs; exceptional reliability track record Toyota 4Runner / FJ Cruiser 4WD transfer case (2003–2014): $320–$620 — gear-driven simplicity with Toyota reliability; used units from accident donors frequently in near-new condition Ford Expedition 4WD BorgWarner transfer case (2007–2019): $420–$780 — cross-references with F-150 transfer cases for expanded availability and competitive pricing Chevrolet Tahoe / Suburban NP246 / NP263 (1999–2014): $380–$720 — NP263 preferred for towing applications; heavy-duty chain-driven BorgWarner design Jeep Grand Cherokee Quadra-Trac II / Selec-Trac (2005–2021): $340–$760 — confirm exact system; Selec-Trac, Quadra-Trac II, and Quadra-Drive II are not interchangeable Subaru Outback / Forester AWD centre differential (2010–2022): $240–$540 — mechanically simple viscous LSD design; no electronics to fail; very long-lived when fluid maintained BMW X5 xDrive ATC transfer case (2007–2018): $420–$950 — requires BMW ISTA+ coding after installation; used OEM is the only sensible cost option vs. $2,500–$4,500 new 🔧 Budget Transfer Case Sourcing Tip For Ford Expedition owners: the Expedition and F-150 share transfer case architecture on most model years. The much larger F-150 donor pool means Expedition transfer cases are available at F-150 prices — one of the best cross-platform used OEM sourcing opportunities in the SUV market. 🔻 Highest Repair Frequency Save $80–$600 per component Used OEM Suspension Components for SUVs
      Used OEM: $30–$280 per component New OEM: $80–$700+ per component Save up to 65% Suspension components are the most frequently replaced parts on any SUV — and the category where OEM quality produces the most noticeable improvement over aftermarket. SUVs place greater demands on suspension than passenger cars: higher kerb weight, greater body roll, more frequent rough-road use, and towing or payload loading that regularly stresses struts, ball joints, and control arm bushings beyond their designed service intervals. OEM struts are calibrated to the exact damping rates your SUV was engineered around — aftermarket SUV struts are tuned for a generic profile that frequently produces handling imbalance and inadequate stability control integration on modern SUVs.
      Front strut assemblies (crossover SUVs — RAV4, CR-V, Equinox, Escape): $80–$200 used OEM — $200–$480 new OEM; save $120–$280 per strut; replace in pairs always Front and rear shocks (body-on-frame SUVs — 4Runner, Tahoe, Expedition, Grand Cherokee): $60–$180 used OEM — $180–$420 new OEM; source from low-mileage highway-driven donors, not off-road examples Front lower control arms with OEM bushings: $60–$200 used OEM — $180–$450 new OEM; complete OEM arm eliminates need for a hydraulic press and delivers new OEM bushing quality Ball joints (upper and lower, body-on-frame SUVs): $45–$160 used OEM — $120–$380 new OEM; upper ball joints on Toyota 4Runner and FJ Cruiser are the most common single failure item on those platforms Wheel hub and bearing assemblies (AWD SUVs): $80–$200 used OEM — $200–$420 new OEM; OEM hub essential for correct ABS tone ring specification — aftermarket hubs trigger AWD and ABS fault codes on SUVs Sway bar end links (front and rear): $25–$65 used OEM — $60–$140 new OEM; most common SUV suspension noise source; replace all four simultaneously Strut top mounts and bearings: $45–$120 used OEM — $120–$280 new OEM; always replace alongside struts — labour is already invested and a worn mount on a new strut produces immediate noise recurrence ⚠️ Electronic Suspension SUVs — OEM Only SUVs equipped with adaptive or magnetic ride control suspension (Chevrolet Tahoe MRC, Land Rover air suspension, BMW X5 EDC) require OEM replacement units for correct electronic calibration. Aftermarket shocks for these applications trigger suspension fault codes and disable the adaptive system entirely. Used OEM units from low-mileage donors are the only cost-viable option. 🔩 Structural Repair Savings Save $500–$2,000 vs. New Used OEM Subframes & Engine Cradles for SUVs
      Used OEM: $180–$680 New OEM: $700–$2,400+ Save up to 72% Subframe and engine cradle replacement is almost exclusively a collision-driven repair on SUVs — but when it is needed, new OEM pricing routinely makes a structurally repairable vehicle feel like a write-off. A new OEM front subframe for a Honda CR-V lists at $900–$1,400 at the dealer. A used OEM unit from a low-mileage accident donor at GreenGears Auto costs $190–$370 — with factory-correct bushing sleeves, verified mounting surface integrity, and documented donor mileage. For European SUVs like the BMW X5 or Audi Q5, where new OEM subframe pricing routinely exceeds $1,800, the used OEM option is frequently the only economically viable repair pathway.
      Honda CR-V AWD front subframe (2012–2022): $190–$380 — most available and most affordable used OEM SUV subframe; exceptional condition from Honda's large accident-donor fleet Toyota RAV4 / Highlander front subframe (2013–2020): $220–$420 — Toyota's corrosion-resistant coating produces better-condition used subframes than most domestic equivalents Ford Explorer / Edge AWD front subframe (2011–2019): $220–$420 — high availability from large accident-donor fleet; AWD and FWD variants differ — confirm before ordering Jeep Grand Cherokee WK2 front subframe (2011–2021): $240–$480 — common collision replacement; sourcing from rear-impact donors provides undamaged front subframe units Chevrolet Equinox / Terrain front subframe (2010–2017): $180–$340 — excellent availability from high-volume GM crossover fleet; compact and lower shipping cost BMW X5 E70/F15 front subframe (2007–2018): $420–$780 — saves $1,200–$1,800 vs. new OEM; used OEM is the only viable option for most X5 subframe repairs 🎯 EPS Integration Critical Save $300–$1,400 vs. New Used OEM Steering Components for SUVs
      Used OEM: $30–$580 New OEM: $80–$1,800+ Save up to 68% Steering is uniquely OEM-critical on modern SUVs because of electric power steering (EPS) integration with ADAS systems — lane departure warning, automatic emergency braking, and adaptive cruise control all communicate through the EPS steering rack and column. An aftermarket EPS steering rack does not carry the factory-calibrated torque sensor and motor specification your SUV's safety systems were designed around. On body-on-frame trucks and SUVs, a used OEM steering gearbox from a low-mileage donor delivers results that remanufactured units consistently fail to match — factory-adjusted sector shaft preload with original housing geometry.
      Honda CR-V / Pilot EPS steering rack (2013–2022): $120–$280 used OEM — $600–$1,200 new OEM; save $480–$920; most available EPS SUV rack unit in the market Toyota RAV4 / 4Runner EPS rack (2014–2022): $150–$340 used OEM — $700–$1,400 new OEM; confirm column-assist vs. rack-assist design Ford Explorer / Expedition EPS rack (2011–2020): $180–$400 used OEM — $900–$1,800 new OEM; confirm 2WD vs. AWD rack specification Chevrolet Tahoe / Suburban / Silverado steering gearbox (2007–2019): $140–$380 used OEM — $500–$1,000 new OEM; OEM used gearboxes from low-mileage truck donors deliver significantly better results than remanufactured units Jeep Grand Cherokee WK2 steering rack (2011–2021): $180–$380 used OEM — $800–$1,600 new OEM; Quadra-Drive II integration requires OEM unit on electronically connected trims Outer tie rod ends (all SUV platforms): $30–$70 used OEM — $80–$180 new OEM; always OEM for correct ball joint preload; replace in pairs; alignment mandatory after replacement ⚙️ Highest Absolute Dollar Savings Save $1,200–$4,000+ vs. New Used OEM Transmission Assemblies for SUVs
      Used OEM: $480–$2,000 New OEM: $2,500–$6,500+ Save up to 70% No single repair category offers higher absolute dollar savings on SUVs than the used OEM transmission assembly. A new OEM Toyota Aisin 6-speed for the 4Runner or Sequoia costs $3,200–$5,000 at the dealer. A used OEM unit from a low-mileage 4Runner donor at GreenGears Auto costs $680–$1,200 — factory-assembled with correct clutch pack clearances and correct torque converter calibration, verified through real-world service in the donor vehicle. For many older SUVs, a dealer quote on a new OEM transmission effectively totals the vehicle. A quality used OEM assembly at 50–70% off changes the repair economics entirely.
      Toyota Aisin 6-speed (A760E/A760F) — 4Runner, Sequoia, Land Cruiser: $680–$1,200 — most reliable used automatic transmission in the entire SUV market Ford 6R80 — Expedition, Explorer (2011–2019): $580–$1,100 — highest availability of any full-size SUV transmission in the used market; confirm torque rating by engine GM 6L80 / 6L90 — Tahoe, Suburban, Escalade, Yukon: $620–$1,300 — 6L90 preferred for Escalade and heavy-duty applications; confirm by VIN Subaru CVT (TR580/TR690) — Outback, Forester AWD (2018+): $580–$1,060 — source from sub-60,000-mile donors; EyeSight calibration required on equipped models Honda CVT — CR-V, Pilot, Passport (2017–2022): $480–$920 — excellent availability from Honda's large US fleet; confirm AWD vs. FWD specification ZF 8HP 8-speed — BMW X3, X5 (2012–2019): $780–$1,700 — widely regarded as one of the best automatic transmissions ever produced; used units from low-mileage European imports are premium finds ⚡ Crossover-Specific AWD Savings Save $300–$900 vs. New Used OEM Power Transfer Units (PTU) & AWD Coupling Units for SUVs
      Used OEM: $160–$560 New OEM: $600–$1,400+ Save up to 65% Crossover SUVs with on-demand AWD systems use a Power Transfer Unit (PTU) or Rear Drive Unit (RDU) rather than a conventional transfer case — and these units are among the most commonly replaced AWD components in the market. Ford Escape, Edge, and Explorer AWD PTU failure is the most common AWD drivetrain repair on those platforms, driven primarily by seal failure leading to fluid loss. Honda CR-V and Pilot AWD rear drive units fail at predictable mileage intervals and are widely available as affordable used OEM units from GreenGears Auto's high-volume Honda donor inventory.
      Ford Escape AWD PTU (2013–2019): $180–$340 — most commonly replaced AWD component on this platform; always install a new seal kit alongside any used PTU Ford Edge / Explorer AWD PTU (2011–2019): $220–$460 — higher torque rating than Escape; sourcing from towing-spec donors recommended Honda CR-V AWD rear drive unit (2012–2022): $160–$300 — most affordable quality used AWD coupling unit in the crossover SUV market Honda Pilot AWD i-VTM4 rear unit (2016–present): $280–$480 — more sophisticated than CR-V unit; electronically controlled clutch pack; source from accident-damaged low-mileage donors Chevrolet Equinox / GMC Terrain AWD transfer case (2010–2017): $220–$460 — BorgWarner electronically controlled; shares architecture across Equinox, Terrain, and Captiva Toyota RAV4 Active Torque Control rear coupling (2013–2022): $180–$340 — exceptional reliability; most available and best-priced Toyota AWD coupling unit in the market Budget Savings by SUV Platform — Quick Reference
      Here are the SUV platforms offering the most accessible used OEM parts at GreenGears Auto, based on donor supply, parts availability, and typical savings versus new OEM pricing.
      🏆 Toyota 4Runner / RAV4 / Highlander
      Rear differential: $200–$580 (save up to 68%) Transfer case: $240–$620 (save up to 70%) EPS steering rack: $150–$340 (save up to 70%) Aisin transmission: $680–$1,200 (save up to 70%) Front subframe: $220–$420 (save up to 70%) 🔩 Ford Explorer / Expedition / Edge
      8.8" rear differential: $220–$480 (save up to 68%) Transfer case: $420–$780 (save up to 65%) EPS steering rack: $180–$400 (save up to 68%) 6R80 transmission: $580–$1,100 (save up to 70%) AWD PTU: $180–$460 (save up to 65%) 💪 Chevrolet Tahoe / Suburban / GMC Yukon
      8.6" rear differential: $260–$560 (save up to 70%) NP263 transfer case: $380–$720 (save up to 68%) Steering gearbox: $140–$380 (save up to 65%) 6L80 transmission: $620–$1,300 (save up to 70%) Front subframe: $200–$400 (save up to 68%) 🏔️ Jeep Grand Cherokee / Wrangler
      Dana 44 rear differential: $240–$520 (save up to 68%) Transfer case: $340–$760 (save up to 65%) EPS steering rack: $180–$380 (save up to 65%) Front subframe: $240–$480 (save up to 68%) Ball joints / control arms: $60–$200 (save up to 65%) Used OEM vs. Aftermarket for SUV Parts — Why It Matters More on SUVs
      🏭 Aftermarket SUV Parts
      Strut damping rates tuned for generic "similar vehicle" — not your SUV's specific weight and spring rate Ball joint preload differs — changes steering feel and may not meet SUV load rating AWD hub bearings often have different ABS tone ring pitch — triggers AWD and ABS fault codes EPS steering racks frequently fail ECU integration — stability control and lane-keeping faults common Adaptive suspension substitutes trigger system fault codes — MRC, Airmatic, KDSS incompatible 35–40% higher comeback rate on SUVs vs. passenger cars due to greater component integration complexity ♻️ OEM Used — GreenGears Auto
      Factory damping calibration for your exact SUV platform, weight, and spring rate OEM ball joint preload — load rating matches SUV specification precisely Correct ABS tone ring — zero fault codes; AWD integration maintained Factory EPS calibration — stability control, lane-keeping, and ADAS fully functional Factory adaptive suspension specification — all electronic systems preserved Mileage-verified, inspected, 90-day guaranteed — buy with total confidence How to Buy Used OEM SUV Parts the Right Way
      1 Always Specify Trim, Engine, and Drivetrain — Not Just Year and Model
      SUV parts vary more by trim level and configuration than any other vehicle category. A Toyota 4Runner SR5 with a V6 uses different differential gear ratios than a 4Runner V8. A Ford Explorer AWD uses a completely different front subframe from an Explorer FWD. A Tahoe with Magnetic Ride Control uses different shocks than a base Tahoe. Always provide full configuration details when ordering from GreenGears Auto.
      2 Prioritise Donor Use History — Not Just Mileage
      For SUVs specifically, how the donor vehicle was used matters as much as how many miles it covered. A 70,000-mile highway-driven Tahoe transfer case is a dramatically better purchase than a 45,000-mile unit from a Tahoe that towed 8,000 lb regularly or was used off-road. GreenGears Auto documents donor vehicle use context where available alongside mileage on all SUV drivetrain listings.
      3 Pull Fault Codes Before Ordering AWD and Electronic Components
      AWD warning lights, transfer case faults, and EPS warnings on SUVs frequently resolve to a $80–$160 wheel speed sensor, shift motor, or solenoid rather than requiring a $400–$900 assembly replacement. Always pull OBD-II codes before ordering any electronic AWD or steering component — a $20 scan can save hundreds in unnecessary parts purchases.
      4 Bundle Adjacent Repairs for Maximum Labour Efficiency
      SUV repair labour rates are high — $100–$180 per hour at most shops. Bundling adjacent component replacements in a single appointment maximises the value of each labour hour invested. A differential service is the right time to replace pinion seals, axle seals, and cover gasket. A strut job is the right time to replace end links, strut mounts, and bump stops. GreenGears Auto can source all adjacent parts in a single order.
      5 Account for Total Cost — Including Free Shipping and No Core Charge
      A remanufactured transfer case at $1,100 with a $400 core charge and $140 shipping costs $1,640 effective. A used OEM transfer case from GreenGears Auto at $760 with free shipping and no core charge costs $760 — a $880 difference that isn't visible in a headline price comparison. Always calculate total cost including shipping and any core charges when comparing options.
      Complete SUV Parts Budget Guide — Pricing at a Glance
      Component Used OEM Price New OEM Price Your Savings Top SUV Platforms Rear Differential $180–$900 $600–$2,700+ Up to 70% Explorer, 4Runner, Tahoe, CR-V Transfer Case $240–$1,100 $1,000–$3,500+ Up to 70% RAV4, 4Runner, Tahoe, Grand Cherokee Transmission Assembly $480–$2,000 $2,500–$6,500+ Up to 70% 4Runner, Expedition, Tahoe, X5 Front Subframe / Engine Cradle $180–$680 $700–$2,400+ Up to 72% CR-V, RAV4, Explorer, Grand Cherokee EPS Steering Rack $120–$580 $600–$1,800+ Up to 70% CR-V, RAV4, Explorer, Grand Cherokee PTU / AWD Coupling Unit $160–$560 $600–$1,400+ Up to 65% Escape, Edge, CR-V, Pilot, Equinox Front Struts (pair) $160–$400 $400–$960+ Up to 65% RAV4, CR-V, Equinox, Escape Front / Rear Shocks $60–$180 ea $180–$420 ea Up to 65% 4Runner, Tahoe, Expedition, Grand Cherokee Control Arms (with bushings) $60–$200 $180–$450+ Up to 65% All platforms Wheel Hub / Bearing $80–$200 $200–$420+ Up to 60% All AWD platforms Steering Gearbox (trucks/BOF) $120–$380 $400–$1,000+ Up to 65% Tahoe, Suburban, Tundra, Ram Sway Bar End Links (set of 4) $80–$220 $200–$480+ Up to 60% All platforms Why GreenGears Auto for Budget SUV Repairs?
      OEM-only inventory — no aftermarket, no rebuilt units; every component is a factory-original assembly from a documented donor vehicle SUV-specific sourcing expertise — we understand the trim-level, drivetrain, and electronic configuration differences that make SUV parts sourcing uniquely complex Mileage and use history documented on every listing — donor vehicle mileage verified and recorded; use context noted where available Pre-sale inspection — fluid condition (differentials, transfers, transmissions), housing integrity, boot and seal condition, and electronic connector status checked before listing Application verification — gear ratio, AWD configuration, trim-specific specification, and exact engine application confirmed by our parts specialists before your order ships Free continental US shipping on all orders — factor this into every price comparison; heavy SUV components have significant shipping value No core charge on all drivetrain components — no upfront deposit, no return shipping on heavy transfer cases and differentials 15 to 90-day satisfaction guarantee on every part — every used OEM SUV component we sell is backed unconditionally Find Budget-Friendly Used OEM Parts for Your SUV
      Tell us your year, make, model, trim, engine, and drivetrain — our SUV parts specialists will find the right used OEM component at the best available price and get it to you in 3–7 days with free US shipping.
      ✅ OEM Quality Guaranteed 🚚 Free US Shipping ↩️ 14-Day Returns 📋 No Core Charge
      The Auto Care Association announced the release of ACES 5.0 and PIES 8.0, the latest updates to the industry’s data standards, along with supporting reference database schema updates. The new versions follow a comprehensive, yearlong industry review and introduce enhanced capabilities designed to support more accurate, flexible and scalable data exchange across the automotive aftermarket. Updated schemas in this release include VCdb 2.0, Qdb 2.0, PCdb 2.0, PAdb 5.0 and Brand Table 2.0.
      Standardized data for evolving global and regulatory needs
      ACES (Aftermarket Catalog Exchange Standard) and PIES (Product Information Exchange Standard) serve as the industry’s standardized, machine-readable (XML) methods for exchanging product fitment and product information data across the Americas. These standards are used by manufacturers, distributors, retailers, e-commerce platforms and solution providers across multiple sectors.
      “ACES and PIES are foundational to how the aftermarket communicates product data,” said Jonathan Larsen, vice president, digital products and standards,
      link hidden, please login to view. “These updates are focused on helping the industry to deliver richer content, improve data accuracy and adapt to evolving global and regulatory needs.” New in ACES 5.0
      Support for vehicle- and part-specific non-diagram digital assets within the App Segment; Multiple descriptions for a single digital asset; and Expanded multilingual capabilities for the “MfrLabel” field. New in PIES 8.0
      Extended Producer Responsibility (EPR) packaging data to support regulatory compliance; Multiple package configurations at a single pack level; and Digital asset file hashing and record sequencing to improve data validation and organization. Increased accuracy and efficiency across the supply chain
      Together, these updates to ACES and PIES make it easier to deliver richer product content, improve data consistency across partners and better support compliance and evolving market demands. The result is more accurate product listings, fewer errors and a more efficient flow of data across the supply chain.
      Compatible with Catalog Assessment Reporting Tool
      In addition, the AutoCareVIP.com Catalog Assessment Reporting Tool now supports ACES 5.0 and PIES 8.0 files. This free tool helps users evaluate and improve the quality of their ACES and PIES data.
      Full details on the ACES and PIES release are provided in the Auto Care Association’s latest
      link hidden, please login to view To learn more about Auto Care Data Standards and book a complimentary meeting with an Auto Care data expert, click
