    • By AutoZone
      MEMPHIS, Tenn., May 26, 2026 (GLOBE NEWSWIRE) -- AutoZone, Inc. (NYSE: AZO) today reported net sales of $4.8 billion for its third quarter (12 weeks) ended May 9, 2026, an increase of 8.4% from the third quarter of fiscal 2025 (12 weeks). Same store sales, or sales for our domestic and
      link hidden, please login to view is a strong option for sealing minor to moderate failures. If the issue is more severe, stepping up to a heavier-duty solution may be necessary. Bar’s Leaks Head Seal Blown Head Gasket Repair is designed to create a durable seal, helping restore system integrity when matched correctly to the condition. Head gasket issues come down to sealing failure and severity. Identify the condition, then match it with the right solution.
