    • By AutoZone
      MEMPHIS, Tenn., May 26, 2026 (GLOBE NEWSWIRE) -- AutoZone, Inc. (NYSE: AZO) today reported net sales of $4.8 billion for its third quarter (12 weeks) ended May 9, 2026, an increase of 8.4% from the third quarter of fiscal 2025 (12 weeks). Same store sales, or sales for our domestic and
      link hidden, please login to view is a strong option for sealing minor to moderate failures. If the issue is more severe, stepping up to a heavier-duty solution may be necessary. Bar’s Leaks Head Seal Blown Head Gasket Repair is designed to create a durable seal, helping restore system integrity when matched correctly to the condition. Head gasket issues come down to sealing failure and severity. Identify the condition, then match it with the right solution.
    • By GreenGears Auto Limited
      Published by GreenGears Auto  |  6 min read  |  Steering Parts Buying Guide
      A whining or groaning noise when you turn the wheel — especially at low speed or when parking — is the classic sign of a failing power steering pump. Left unaddressed, it leads to stiff, heavy steering and eventually complete loss of power assist. New OEM replacements cost $180–$600 before labour. A quality used OEM pump from a low-mileage donor vehicle delivers identical factory performance at 50–60% less. This guide covers exactly how to diagnose the problem, what to check in a used pump, and which platforms give you the best value. What Does a Power Steering Pump Do?
      The power steering pump is a belt-driven hydraulic pump that pressurises power steering fluid and delivers it to the rack and pinion or steering gearbox, providing the assist that makes low-speed steering feel light and effortless. Without it, steering becomes noticeably heavier — technically still functional, but significantly more effort, especially when manoeuvring at low speeds or parking.
      Power steering pumps are found on vehicles with hydraulic power steering (HPS) systems — typically those built before 2013, and many trucks and SUVs through to the present day. Vehicles with electric power steering (EPS) have no pump at all, using a motor integrated into the steering column or rack instead. If your vehicle has EPS, a power steering pump is not the component you need — check the rack, column motor, or steering control module.
      Symptoms of a Failing Power Steering Pump
      Whining or groaning noise when turning: The most common symptom. The noise is usually loudest at full steering lock — when parking or making tight turns — and may fade at highway speed when steering input is minimal. Stiff or heavy steering at low speeds: Reduced assist makes the wheel feel heavy, particularly during slow manoeuvres. If it comes and goes, low fluid level is often the cause before the pump itself fails completely. Steering fluid leak: A reddish-brown puddle under the front of the vehicle near the engine. Pump seal failure is a common source — and once a pump starts leaking externally, the internal pressure loss accelerates internal wear rapidly. Foamy or discoloured fluid in the reservoir: Foamy fluid indicates air contamination from a leak or failing reservoir cap. Dark brown or black fluid indicates oxidation and contamination — both accelerate pump wear and should be addressed immediately. Momentary loss of assist on cold starts: The pump works normally once warm but feels stiff for the first few minutes after a cold start. This is a classic sign of a pump with worn internal seals that haven't yet failed completely. ⚠️ Check the Fluid Level and Condition Before Replacing the Pump Low power steering fluid is the single most common cause of whining and stiff steering — and it costs nothing to check. Top up with the correct OEM-spec fluid and see if symptoms resolve before ordering parts. If the reservoir empties repeatedly, you have a leak somewhere in the system — identify the source before replacing the pump, or the new pump will fail for the same reason. Most Reliable OEM Power Steering Pump Platforms
      Toyota and Lexus — Best Overall Longevity
      Toyota's belt-driven hydraulic power steering pumps are among the most durable available. Camry, 4Runner, Tacoma, and Tundra pumps routinely reach 150,000–180,000 miles without failure when the correct fluid is used and the reservoir is kept clean. Lexus GX and LX V8 pumps are particularly robust. Used OEM Toyota pumps from low-mileage donors are the highest-value option in this category — and given Toyota's large US fleet, availability is excellent.
      Honda and Acura — Reliable, High Availability
      Honda's HPS pumps on Accord, CR-V, Pilot, and Odyssey are reliable and well-represented in the used market. The main failure mode is gradual seal wear causing slow fluid loss — pumps that show no external seepage and come from documented low-mileage donors have excellent remaining service life. Acura MDX and TL V6 pumps are slightly more complex but equally durable when fluid is maintained.
      Ford — Trucks Strong, Some Car Platforms Less So
      Ford's truck and SUV power steering pumps — F-150, Explorer, Expedition — are heavy-duty and long-lived. The Ford Focus and older Fusion HPS pumps have a shorter typical service life due to a smaller internal design, but used OEM units from low-mileage donors still represent strong value at used pricing. Always use Ford-spec Mercon power steering fluid on Ford applications — substituting generic fluid degrades internal seals faster on these platforms.
      GM — Good Availability, Fluid Specification Critical
      GM's Malibu, Impala, Silverado, and Tahoe HPS pumps are well-built and widely available used. The most common failure on GM pumps is contamination-related — using incorrect fluid or neglecting fluid changes causes internal scoring on the pump housing. Used OEM units from low-mileage accident-damaged donors with clean fluid history are consistently reliable.
      Dodge / Chrysler / Jeep — Durable Truck Units, Watch for Wear on High-Mileage Cars
      Jeep Grand Cherokee and Wrangler HPS pumps are heavy-duty and durable, well-suited to the off-road loads these vehicles encounter. Dodge Ram and Durango pumps are similarly robust. Chrysler car platform pumps (300, Charger, Challenger) are adequate but more susceptible to wear on higher-mileage examples — source from donors under 70,000 miles where possible.
      Used OEM vs. Remanufactured Power Steering Pump
      Option Typical Cost Core Charge Quality Notes GreenGears Used OEM $60–$220 None Factory assembly, mileage-documented, inspected for seal integrity and shaft play. 15-day warranty. Remanufactured $90–$280 $40–$120 Internal wear on pump housing may not be addressed in rebuild. Quality varies significantly by rebuilder. New OEM Dealer $180–$600+ None Highest quality. Rarely justified when a clean used OEM unit is available at 50–60% less. Budget Aftermarket $35–$120 None High noise rate on installation. Shorter service life. Seals often incompatible with OEM fluid spec. Budget aftermarket power steering pumps have a particularly poor track record — whining immediately after installation, premature seal failure, and noise that returns within 20,000 miles are common complaints. The issue is that aftermarket pump housings are often cast to lower tolerances than OEM, creating internal clearances that cause noise and accelerate wear from day one. A used OEM pump from a 55,000-mile donor has already proven its ability to run quietly and leak-free for real-world service. That is a track record no budget aftermarket unit can match.
      What to Check Before Buying Any Used Power Steering Pump
      Confirm the application — power steering pumps are engine-specific on many platforms, not just make and model. A 2.4L and 3.5L version of the same vehicle often use different pumps. Inspect the pulley — it should spin freely with no roughness, binding, or wobble. Bearing wear shows up as roughness when the pulley is rotated by hand. Check the shaft seal area for any dried fluid residue — a weeping shaft seal indicates the pump has been running low on fluid or has internal seal wear. Verify the inlet and outlet fittings are undamaged and thread-clean — stripped or cross-threaded fittings are a common problem on pulled-from-yard units. Ask for documented donor mileage — a pump from a 45,000-mile donor has a fundamentally longer remaining service life than one from an unknown-mileage vehicle. When installing, always flush the power steering system before connecting the new pump — contaminated fluid from the old failed pump will shorten the life of the replacement immediately. Use only the OEM-specified fluid for your vehicle — Toyota PSF, Honda PSF-S, Ford Mercon, GM Power Steering Fluid — never generic ATF as a substitute. 🔧 Always Flush the System on Pump Replacement When a power steering pump fails internally, it sends metal debris through the entire hydraulic circuit — contaminating the reservoir, hoses, and rack. Installing a clean used OEM pump into a contaminated system dramatically shortens its life. Flush the system with fresh OEM-spec fluid before connecting the new pump, and replace the reservoir filter if accessible. How to Order a Used OEM Power Steering Pump From GreenGears Auto
      1 Browse or Contact Us With Your Engine Size
      Search our
      link hidden, please login to view or link hidden, please login to view with your year, make, model, and engine size. Many platforms have engine-specific variants — providing the engine code ensures the right unit ships first time. 2 Fitment and Condition Verified Before Dispatch
      We check pulley condition, shaft seal integrity, fitting thread condition, and donor mileage on every pump before it leaves our facility. No units with evidence of seal weeping or bearing wear are listed or shipped.
      3 Free Shipping, 15-Day Warranty
      All orders ship free within the US. Processing 1–3 business days, transit 3–7 business days after dispatch. Power steering pumps carry a 15-day warranty from confirmed delivery. Use code GGA10 at checkout for an extra 10% off your entire order.
      Find a Used OEM Power Steering Pump for Your Vehicle
      Tell us your year, make, model, and engine size — we'll confirm the right unit and check current stock. Free US shipping on every order.
      🛡️ 15-Day Warranty  ·  🚚 Free US Shipping  ·  ↩️ 15-Day Returns  ·  📋 Mileage Verified
