turbocharger Booming Global Turbocharger Market: Seize Growth
- 169 views
turbocharger Which Region’s Suppliers Are Globally Trusted?
By JiajuDong,
- powertec turbo
- chinese supplier
- (and 1 more)
- 138 views
turbocharger ICE vs. EV in the Americas: Why Fuel-Powered Vehicles Still Dominate the Road (and Will for Years to Come)
By JiajuDong,
- powertecturbo
- turbochra
- (and 1 more)
- 247 views
turbocharger Fuel Power’s Irreplaceability: Turbo Tech, Safety, and Environmental Edge Over EV Motors
By JiajuDong,
- powertecturbo
- turbochra
- (and 1 more)
- 2 replies
- 293 views
- 1,891 views
Plews & Edelmann has introduced a complete Electric Power Steering (EPS) repair category—Edelmann EPS drive belt kits, torque sensor replacements, couplings, and proprietary service tools—that eliminate the need for expensive full rack replacement on millions of modern vehicles. The company said the product line delivers more than 50 percent cost savings compared with rack replacement while restoring full power steering assist with a straightforward installation using common hand tools.
Electric power steering is now standard on most modern vehicles. Inside every belt-driven EPS rack is a rubber belt connecting the electric motor to the steering gear. When that belt wears or breaks, steering reverts to manual mode—heavy, unresponsive, and unsafe. Until now, the only fix was complete rack replacement: a repair that routinely exceeds $1,000 in parts alone, requires module reprogramming and realignment, and can leave vehicles out of commission for days.
Edelmann EPS Drive Belt Kits
According to the company, Edelmann EPS Drive Belt Kits provide everything needed for a complete repair in a single box, including a replacement drive belt, belt housing gasket, O-rings, inner and outer boot clamps, additional seals as needed and rack-specific video installation instructions. No module re-flash is required, no realignment and no specialized diagnostic equipment.
“The industry treated EPS failure as a rack problem,” said Dan Billie, CEO of Plews & Edelmann. “While others claim repair innovations, we looked at the root cause and realized, in many cases, it was a belt problem. That’s a fundamentally different repair—and it means professional technicians and DIYers now have a cost-effective option where one simply didn’t exist before.”
Couplings Expand Vehicle Coverage
Replacement couplings extend this repair-first philosophy to even broader vehicle coverage. The 9700 Pinion Driven Motor Coupling covers over 5.8 million vehicles in operation across Buick, GMC, and Chevrolet vehicles—where the alternative rack replacement costs average $1,750. The 9701 and 9702 Column Driven Motor Couplings cover 7.6 million Kia and Hyundai vehicles and Toyota and Lexus vehicles respectively—where unit replacement runs $1,100.
Torque Sensor Replacements
link hidden, please login to viewhas further expanded the EPS repair category with Edelmann Torque Sensor Replacements. The torque sensor is one of the most critical components in an electric power steering system—it measures steering wheel force and direction, sending real-time data to the EPS control module. When a torque sensor fails, drivers experience uneven steering effort, intermittent warning lights, or complete loss of power assist. Part 9704 covers some Ford Escape and Mercury Mariner vehicles, while part 9705 covers some Chevrolet Malibu, Pontiac G6, and Saturn Aura applications. Both feature OEM-replacement design with mounting hardware and alignment marks, backed by U.S.-based ASE-certified technical support.
Chamfer Ring Removal Tools
link hidden, please login to viewsaid it also developed proprietary Chamfer Ring Removal Tools designed specifically for electric rack and pinion systems, ensuring safe, efficient belt replacement on the highest-volume applications. “By developing a purpose-built repair solution for EPS systems, we’re giving technicians the ability to service a category that was previously replace-only,” said Anthony Holguin, director of category management at Plews & Edelmann. “These products provide opportunity and convenience by turning a $1,000-plus replacement into a repair that can be completed the same day with tools already in the shop. Plus, part stores can rely on a much smaller inventory footprint than stocking several different racks to achieve the same end.”
Coverage and Availability
Current EPS kits, couplings, and torque sensor coverage spans high-volume domestic and import applications, providing a critical service option where replacement components are scarce or backordered, getting vehicles back on the road quickly.
Edelmann EPS Drive Belt Kits and replacement components are part of the Plews & Edelmann broader Total Solution strategy—the philosophy that a complete power steering repair addresses every component in the system: pump, rack, hoses, cooler, filter, and fluid. With over 100,000 application-specific power steering bundles, all-new manufactured hard parts (not remanufactured), and a 100-year/1,000,000-mile warranty on Edelmann Elite products, Plews & Edelmann has built a portfolio designed to eliminate warranty returns by ensuring the repair is done right the first time.
Edelmann EPS Drive Belt Kits, Couplings, Torque Sensors, and Chamfer Ring Tools are available now through authorized aftermarket distributors. To learn more or find kits for specific applications, visit the
link hidden, please login to viewor call 1-800-770-4639. The post
link hidden, please login to view announced the release of 131 new part numbers in the first quarter of 2026, expanding coverage for more than 27 million vehicles in operation across North America. The new part numbers span key product categories including rotating electrical and engine management, with coverage across a wide range of late-model domestic and import applications. These additions continue to strengthen WAI’s ability to deliver timely, in-demand solutions to the aftermarket.
“Our product development efforts remain focused on identifying opportunities that help our customers service the vehicles they see every day,” said Ron Bernstein, president, North America, WAI Global. “By continuing to introduce new coverage aligned with current vehicle trends, we ensure our partners have access to dependable 100% NEW solutions that keep their businesses moving forward.”
High-impact late-model applications released during the first quarter include WPM5013L wiper motor for Chevrolet, 11980N alternator for Hyundai and 31294N starter for BMW, supporting vehicles through the 2025 model year.
These launches represent more than expanded coverage, they reflect
link hidden, please login to view’s proactive strategy to bring high-VIO, late-model parts to market at the earliest point in the replacement cycle, ensuring customers are prepared before demand peaks, the company said. WAI added it delivers reliable solutions that help reduce comebacks, protect shop reputations and support long-term customer trust. The post
PRT, a brand of the ADD Group, announces the arrival of new applications for light vehicles. The launches include strategic models across North America, such as the Ford Bronco, Volvo V60, Subaru CrossTrek, Volkswagen Jetta, Nissan Rogue and Toyota Corolla Cross Hybrid, among others.
The new items include complete strut assemblies and shock absorbers, representing over 25 million vehicles in new coverage.
PRT products are produced under the strictest OE quality processes required by the main automakers, according to the company. “PRT continues to strengthen its position in North America, bringing OE quality, premium performance, advanced technology and leading application coverage. The new products are available in the U.S. and ready to ship,” explains Bruno Bello, director of global marketing at
link hidden, please login to view or follow @prtautoparts. The post
