(AACF) has introduced the Aftermarket Hearts Giving Circle, a monthly program aimed at supporting individuals in the aftermarket industry facing unexpected challenges such as medical emergencies or natural disasters.
For over 65 years, AACF has provided assistance to the aftermarket workforce and their families. The new program encourages donations, regardless of size, to help provide stability and relief during crises.
About the Giving Circle
The giving circle functions as a community support network. Current contributors aid those facing emergencies, with the potential for future support if needed. The initiative aims to create a sustainable safety net, ensuring resources are available to assist industry families in need.
Donation Impact
The program allows donors to choose a monthly contribution to assist with essential living expenses or emergency aid. This community approach ensures aftermarket members have support during difficult times.
Industry Support
John Kairys,
executive director, emphasizes the program’s spirit of collective support. The Aftermarket Hearts initiative is an opportunity for individuals and companies to demonstrate industry solidarity.
Participation Details
Companies can incorporate the program into their employee giving initiatives, enabling workers to join the circle. Recurring donations can be managed online, with options to modify or cancel, AACF explained.
Get Involved
Experience the power of collective support by joining the Aftermarket Hearts Giving Circle at
. For more information or to set up a workplace campaign, contact Misty Walker at [email protected].
    • By GreenGears Auto Limited
      3. Corrosion Protection
      Premature tyre wear
      Our
      link hidden, please login to view announced the launch of its newly redesigned website. The new site reflects the company’s continued investment in delivering an accessible digital experience for customers and partners. Designed with performance and ease of use in mind, the enhanced website features a streamlined interface, refined navigation and a fully responsive design optimized for desktop and mobile devices.
      Key Features
      Advanced Store Locator – IP-enabled map that displays the nearest store locations. Online Ordering Access – One-click entry to Rapid ordering platforms and customer registration portal for account setup. Product & Promotions Hub – Centralized access to brands, product categories, monthly specials and loyalty programs. Digital Strategy
      “This launch represents a significant step forward in our digital strategy, ensuring our online presence reflects the same high standard of service we deliver every day,” said Vikrant Aggarwal, president and CEO of XL Parts | The Parts House. “By bringing our brands together on one cohesive platform, we are strengthening our market presence and creating a more connected, efficient experience for the customers and communities we serve.”
      Customers can explore the refreshed platform at xlparts.com or thepartshouse.com.
      link hidden, please login to view’s 2026 Annual Meeting and Giving Rally brought together more than 850 distributor members, suppliers, and industry partners for a week of connection, collaboration, and industry advancement, while raising $70,000 for the Automotive Aftermarket Charitable Foundation (AACF). “The generosity and engagement we saw this week was truly inspiring,” said Tina Hubbard, president and CEO of HDA Truck Pride. “Raising $70,000 for AACF reflects the powerful heart of this network—coming together to support our own when it matters most.”
      Tina Hubbard, president and CEO, HDA Truck Pride. The event kicked off with a welcome reception, live auction, and the annual Giving Rally Cornhole Tournament, setting the tone for a week centered on purpose and community. Proceeds from activities throughout the week directly benefit AACF, which provides critical support to families within the aftermarket industry facing hardship.
      “Spending time with the
      link hidden, please login to view Truck Pride community at their Annual Meeting was incredibly meaningful,” shared John Kairys, executive director of The Automotive Aftermarket Charitable Foundation (AACF). “The conversations, the willingness to help, and the genuine care for others in our industry really stood out. That kind of support allows AACF to step in quickly and make a real difference for families facing difficult moments.” Trade Show And Breakout Sessions
      Monday’s agenda featured a trade show where attendees connected on new product innovations to drive business forward. A series of breakout sessions delivered actionable insights on key topics including artificial intelligence adoption, cybersecurity preparedness, digital visibility, operational efficiency and workforce development.
      USS Midway And Cornhole Tournament Finals
      An evening aboard the historic USS Midway brought attendees together for laughter, friendship, patriotism, and a tribute to veterans. The cornhole tournament finals were held onboard, with Joe Brooks and Dan Harbut of Acme Truck Brake & Supply taking home the championship title.
      Network Growth, CVL Warehouse, And Right-To-Repair
      Tuesday’s general session highlighted the continued strength and growth of the HDA Truck Pride network, which now includes more than 220 member companies, more than 1,000 distributor locations, and more than 550 service affiliates across North America. Leadership emphasized ongoing investments in the new HDA Truck Pride CVL Warehouse with expanded product access, digital transformation, and workforce development.
      Advocacy efforts included Right-to-Repair initiatives and building future talent pipelines.
      HDA Truck Pride EDDY Awards
      The meeting recognized excellence across the network through several HDA Truck Pride EDDY Awards, celebrating outstanding contributions to education, leadership, and professional development.
      “HDA Truck Pride is a great place to be—because of our people,” Hubbard said. “Every member who chose to invest in us. Every supplier who chose to partner with us. Every staff member who chooses to show up every day. We built this. And we are only getting started. We’re especially grateful to our supplier partners, including our Annual Meeting Valor sponsors — Gates, Milwaukee, Old World Industries, Valvoline, and Bendix, without whose support we wouldn’t be where we are today.”
      Pictured above (from left): Jon Owens, president, AACF Board of Trustees; Tina Hubbard, president & CEO, HDA Truck Pride; John Kairys, executive director, AACF.
    • By liangyanyang
      in conclusion
      website:www.ixinfilter.com
