  • Heavy trucks
  • Commercial vehicles
  • construction machinery
  • diesel engine
The advantages of original equipment manufacturer (OEM) filters include:
  • Stable quality
  • Reliable compatibility
  • Stable performance
  • Longer engine protection time
What are aftermarket truck filters?
  • Original replacement filter
  • Custom Brands
  • Provide bulk supply to distributors
  • Flexible production solutions
Original equipment manufacturer (OEM) filters vs. aftermarket filters: key differences
feature Original filter Aftermarket Filters
compatibility Fully compliant with original factory standards Depends on the manufacturer
price higher More cost-effective
Brand promotion Original brand Custom/OEM branding services are available.
Supply flexibility Limited Flexible Bulk Production
custom made low High
How to choose a suitable truck filter supplier
  • Stable filtration performance
  • High-quality materials
  • OEM Replacement Support
  • Strict quality control
  • Rapid delivery capability
Why do many dealers choose aftermarket filters?
  • Higher profit margins
  • Original factory quality and performance
  • Flexible Packaging Solutions
  • Reduce procurement costs
High-quality aftermarket filters can effectively protect diesel engines while reducing maintenance costs.
in conclusion
website:www.ixinfilter.com
    • By GreenGears Auto Limited
      3. Corrosion Protection
      Premature tyre wear
      Our
      WIX Filters announced that the company was honored with the 2025 Parts Warehouse Inc. (PWI) Marketing Support Award at PWI’s annual Red, White and Revved Up conference. The conference took place in April in Rogers, Arkansas, celebrating store wins, providing technical training to attendees and promoting the various vendors that contribute to PWI’s success.
      Marketing Support and Annual Meetings
      Honored over 40 other contenders,
      link hidden, please login to viewwas recognized for its overall engagement and investment in promoting PWI. WIX Filters opened a direct line for sharing assets to support both organizations’ success in 2025. The company developed marketing campaigns that boosted sales and customer awareness and actively participated in PWI’s annual marketing meetings. “PWI is defined by their commitment to providing unparalleled service alongside high-quality auto parts,” said Carmina Lopez, brand manager at WIX Filters. “WIX Filters has been a prominent partner with PWI for over 35 years, and this award recognizes our commitment to developing and enhancing customer relationships while aligning our sales and marketing efforts with PWI.”
      Light- and Heavy-Duty Filters for PWI Customers
      Equipping PWI with both heavy- and light-duty products,
      link hidden, please login to view supplies its customers with oil, cabin and air filters. These filters support both light-duty passenger vehicles and heavy-duty agricultural and construction machinery.
      link hidden, please login to view has recognized Truck-Lite and ECCO as its latest suppliers to earn the VIPAR Heavy Duty Strategic Partner (VSP) designation. The two companies, both part of Clarience Technologies, join a group of suppliers that demonstrate a strong commitment to supporting the organization’s distributors, fleets and strategic initiatives across the heavy-duty aftermarket. “Truck-Lite and ECCO bring exceptional value to our distributor network through their commitment to innovation, safety, and service,” said Larry Griffin, vice president of program management for VIPAR Heavy Duty. “Their strong support of fleets, investment in data quality, and product offerings that extend across key international markets align closely with our strategic priorities. We are pleased to welcome them as Strategic Partners.”
      Designation Criteria and Program Support
      Truck-Lite and ECCO earned the designation by meeting key criteria established by
      link hidden, please login to view, including active support of fleets through the organization’s National Accounts Program. The companies also contributed product content to PARTSPHERE PIM®, VIPAR Heavy Duty’s product information management system, and delivered comprehensive product programs that serve both VIPAR Heavy Duty and Power Heavy Duty distributors. “We are honored that Truck-Lite and ECCO have been recognized as VIPAR Heavy Duty Strategic Partners,” said Brian Olsen, executive vice president and president, Visibility Solutions, at Clarience Technologies. “This designation reflects our shared commitment to supporting distributors and fleets with innovative, high-quality solutions. We value our partnership and look forward to continued collaboration to deliver value across the heavy-duty aftermarket.”
      Benefits of VSP Designation
      Suppliers that earn the VSP designation benefit from enhanced visibility and engagement opportunities, including special recognition and priority positioning at the IMPACT Conference. They also receive expanded branding across distributor touchpoints and increased networking and collaboration with the VIPAR Heavy Duty Family of Companies team and distributor members.
      Truck-Lite and ECCO join the VSP group alongside Baldwin Filters, Donaldson Company, East Penn, Grote, Prestone, Tectran and Tramec.
      link hidden, please login to view’s 2026 Annual Meeting and Giving Rally brought together more than 850 distributor members, suppliers, and industry partners for a week of connection, collaboration, and industry advancement, while raising $70,000 for the Automotive Aftermarket Charitable Foundation (AACF). “The generosity and engagement we saw this week was truly inspiring,” said Tina Hubbard, president and CEO of HDA Truck Pride. “Raising $70,000 for AACF reflects the powerful heart of this network—coming together to support our own when it matters most.”
      Tina Hubbard, president and CEO, HDA Truck Pride. The event kicked off with a welcome reception, live auction, and the annual Giving Rally Cornhole Tournament, setting the tone for a week centered on purpose and community. Proceeds from activities throughout the week directly benefit AACF, which provides critical support to families within the aftermarket industry facing hardship.
      “Spending time with the
      link hidden, please login to view Truck Pride community at their Annual Meeting was incredibly meaningful,” shared John Kairys, executive director of The Automotive Aftermarket Charitable Foundation (AACF). “The conversations, the willingness to help, and the genuine care for others in our industry really stood out. That kind of support allows AACF to step in quickly and make a real difference for families facing difficult moments.” Trade Show And Breakout Sessions
      Monday’s agenda featured a trade show where attendees connected on new product innovations to drive business forward. A series of breakout sessions delivered actionable insights on key topics including artificial intelligence adoption, cybersecurity preparedness, digital visibility, operational efficiency and workforce development.
      USS Midway And Cornhole Tournament Finals
      An evening aboard the historic USS Midway brought attendees together for laughter, friendship, patriotism, and a tribute to veterans. The cornhole tournament finals were held onboard, with Joe Brooks and Dan Harbut of Acme Truck Brake & Supply taking home the championship title.
      Network Growth, CVL Warehouse, And Right-To-Repair
      Tuesday’s general session highlighted the continued strength and growth of the HDA Truck Pride network, which now includes more than 220 member companies, more than 1,000 distributor locations, and more than 550 service affiliates across North America. Leadership emphasized ongoing investments in the new HDA Truck Pride CVL Warehouse with expanded product access, digital transformation, and workforce development.
      Advocacy efforts included Right-to-Repair initiatives and building future talent pipelines.
      HDA Truck Pride EDDY Awards
      The meeting recognized excellence across the network through several HDA Truck Pride EDDY Awards, celebrating outstanding contributions to education, leadership, and professional development.
      “HDA Truck Pride is a great place to be—because of our people,” Hubbard said. “Every member who chose to invest in us. Every supplier who chose to partner with us. Every staff member who chooses to show up every day. We built this. And we are only getting started. We’re especially grateful to our supplier partners, including our Annual Meeting Valor sponsors — Gates, Milwaukee, Old World Industries, Valvoline, and Bendix, without whose support we wouldn’t be where we are today.”
      Pictured above (from left): Jon Owens, president, AACF Board of Trustees; Tina Hubbard, president & CEO, HDA Truck Pride; John Kairys, executive director, AACF.
