What Does DTC P0128 Mean? Coolant Temperature Below Thermostat
By APF,
- 1,001 views
- 30 views
- 49 views
- 52 views
- 48 views
By John Lewis
I have a 2013 mazda 3i sport. I unfortunately scratched off its under cover engine splash shield guard and would like to replace it with a new one. However, the pics shown with online listing look so different from what I have kept, can anybody help me understand why is the case? Can I purchase the online parts to fit my car?
By Mighty Auto Parts
link hidden, please login to view appeared first on link hidden, please login to view. Nothing can be more frustrating for the vehicle owner than an oil or coolant leak, especially when it stains their driveway or carport floor. And then there is the stench of oil or coolant on a hot engine or exhaust system that can really be annoying. If you have performed a lube service you may […]
By buymachineryparts
🚨 Pain Points: Common BMW Engine Problems
BMW owners often face issues such as abnormal engine temperature, decreased fuel efficiency, or difficulty starting the engine in cold conditions. These problems are often caused by a faulty coolant temperature sensor. A damaged or aging sensor can prevent the ECU from receiving accurate temperature data, resulting in:
Frequent check engine light warnings
Increased fuel consumption
Engine overheating or temperature fluctuations
Black smoke from the exhaust
Difficulty starting in cold weather
Ignoring these issues may lead to costly engine component damage.
💡 Solution: Replace the Coolant Temperature Sensor
The BMW Coolant Temperature Sensor (CTS) is a key component for monitoring engine temperature. By providing accurate data to the ECU, it helps regulate fuel injection, air-fuel ratio, cooling fan operation, and idle control. Replacing the sensor can immediately improve engine performance, increase fuel efficiency, and prevent overheating.
🛠️ Recommended Product: BMW 13621433077 Coolant Temperature Sensor
The BMW Coolant Temperature Sensor 13621433077 is an ideal solution to these engine problems:
OEM Part Number: 13621433077 / 13 62 1 433 077
Other References: 1580924, 213928, 5S1487, TX128, 358058011
Compatible Models: 3 Series (E46, E90, 325i), 5 Series (E39, E60), 7 Series (E38, E65, E66), SUVs (X3, X5, X6), Z4 (E85, E86)
Comes with O-rings for proper sealing and easy installation
High-quality construction ensures accurate temperature readings, meeting or exceeding OEM standards
Purchase link hidden, please login to view: Buy BMW 13621433077 Coolant Temperature Sensor and use discount code BUYMACHINERYPARTSCODE for savings.
With the BMW 13621433077 Coolant Temperature Sensor, you can:
Improve fuel efficiency
Enhance engine smoothness
Prevent engine overheating
Extend engine life
By OReilly Auto Parts
What Do DTCs P0420 & P0430 Mean? Catalyst System Efficiency Below Threshold (Bank 1 & Bank 2)
