Nothing can be more frustrating for the vehicle owner than an oil or coolant leak, especially when it stains their driveway or carport floor. And then there is the stench of oil or coolant on a hot engine or exhaust system that can really be annoying. If you have performed a lube service you may […]
      Internal email from Autozone regarding an oil shortage coming across the US
      Fuchs Lubricants Co. recently highlighted its Titan GT1 Flex 5 SAE 0W-20. It’s an engine oil that meets the demanding needs of today’s highly stressed, downsized, and hybrid passenger car engines. As OEMs continue to engineer vehicles for higher efficiency and fuel economy, Titan GT1 Flex 5 SAE 0W-20 delivers a low-viscosity formulation that supports fuel-saving characteristics, reduced CO2 emissions and reliable performance under severe operating conditions.
      OEM Approvals and Requirements
      Selected BMW, Mercedes-Benz, and Jaguar Land Rover models approve the use of Titan GT1 Flex 5 SAE 0W-20. It also meets the engine oil requirements of Ford, Chrysler, Volvo and other manufacturers specifying ILSAC GF-6A and API SP. The product also carries key OEM approvals, including BMW Longlife-17 FE+, Jaguar Land Rover STJLR.03.5006, MB-Approval 229.71, MB-Approval 229.72 and OV 040 1547. It aligns with additional recommendations such as Chrysler MS-12145, Fiat 9.55535-GSX, Ford WSS-M2C947-A, Ford WSS-M2C947-B1, Ford WSS-M2C962-A1, ILSAC GF-5, Jaguar Land Rover STJLR.51.5122, Volvo VCC RBS0-2AE and VWC 53057. This broad coverage allows distributors, workshops and fleets to simplify inventory. It also enables servicing of a wide mix of European, Asian and American vehicles.
      Engineered for Modern Engines and Operating Conditions
      Titan GT1 Flex 5 SAE 0W-20 is tailored for vehicles with start-stop systems, downsized aggregates and extended high-speed operation in challenging temperature environments. Advanced formula with BluEV-Technology enhances aging stability. The goal is to help the oil maintain viscosity and protection even under high outside temperatures and during sustained highway driving.
      LSPI Protection and Extended Drain Intervals
      The oil also offers targeted protection against low-speed pre-ignition (LSPI). The company noted this is critical concern in modern turbocharged gasoline engines, supporting reliable combustion and engine durability.
    • By Mighty Auto Parts
      link hidden, please login to view appeared first on link hidden, please login to view. When filters bulge or split at the seam, gaskets protrude from their base plate and oil is dripping from the engine and chassis, the oil filter often gets the blame. Some install a second or third filter, convinced the filter is the culprit. The fact is the filter encountered overpressurization due to a stuck pressure […]
