Tony Genna, of DRiV, earned induction into the Federated Auto Parts Vendor Hall of Fame. Organizers recognized Genna at the recent
(The Group) National Meeting in National Harbor, Maryland. His longstanding contributions to the automotive aftermarket industry set him apart as a leader and dedicated professional.
Federated Celebrates Genna’s Commitment to Excellence
“The past Hall of Fame recipients are among our closest suppliers who made a significant impact. We would fail without our vendors, and we are honored to recognize someone that we admire from one of our favorite suppliers,” said Bo Fisher, chairman of Federated Auto Parts.
“Tony is a knowledgeable professional who is committed to the success of the Federated membership. When he is not spending time with his wife Kristen and daughter Sammi, he works unselfishly as Fire Chief in Sellersville, Pennsylvania, and he also worked at ground zero after 9/11.”
Genna’s Career Spans Automotive Aftermarket Leadership
As vice president, North America sales-aftermarket for DRiV Incorporated, Genna continues to impact the automotive aftermarket. He also held executive roles at PHINIA, BorgWarner, Delphi, and Gates. Genna volunteers time serving on committees for various aftermarket organizations.
Federated Hall of Fame Honors Industry Leadership
Each year, the Federated Vendor Hall of Fame honors one person who shows exceptional dedication. The award recognizes individuals making a difference for Federated Auto Parts and its members.
Visit the
 to view past inductees.
      Published by GreenGears Auto  |  8 min read  |  Subframe Buying Guide
      3. Corrosion Protection
      Premature tyre wear
      Our
      🛡️ 90-Day Warranty  ·  🚚 Free US Shipping  ·  ↩️ 15-Day Returns
      link hidden, please login to view was recognized by Hahn Automotive with the 2025 Outstanding Logistics Support Award at the annual Hahn Automotive National Sales Conference. Held last month in Rochester, N.Y., the conference prepares staff for the upcoming spring selling season and honors companies for their support and dedication to Hahn Automotive. WIX Filters Support for Hahn Automotive
      link hidden, please login to view was honored for its service levels and order fill rates last year. The company has partnered with Hahn Automotive for nearly 30 years, providing a full line of filters. “Hahn Automotive stresses that service makes all the difference, emphasizing their commitment to innovation and customer satisfaction,” said David Barraco, trade marketing manager at WIX Filters. “WIX Filters has supported Hahn Automotive and its customers for almost three decades, and this award demonstrates our exemplary drive to provide on-time deliveries of the highest quality filters on the market.”
      Hahn Automotive Warehouses and Auto Parts
      Hahn Automotive owns nine full-service warehouses and 28 pickup warehouses that distribute auto parts throughout the Midwest, New England and the Mid-Atlantic states. The company operates Advantage Auto Stores, Car Parts/Motor Supply, Genuine Auto Parts, Norwood Auto Parts, Nu-Way Auto Parts and Speedway Auto Parts.
    • By liangyanyang
      When maintaining heavy-duty trucks and diesel engines, choosing the right filter is crucial for engine performance and operating costs. Many fleet owners and dealers typically compare original equipment manufacturer (OEM) truck filters with aftermarket truck filters before making a purchase.
      So, what's the difference between original equipment manufacturer (OEM) filters and aftermarket filters?
      What is an original equipment truck filter?
      Original equipment (OEM) filters are manufactured to the specifications of the original vehicle or engine manufacturer. These filters are designed to meet the requirements of the original equipment system in terms of filtration efficiency, airflow, and durability.
      Original equipment manufacturer (OEM) filters are typically used for:
      Heavy trucks Commercial vehicles construction machinery diesel engine The advantages of original equipment manufacturer (OEM) filters include:
      Stable quality Reliable compatibility Stable performance Longer engine protection time What are aftermarket truck filters?
      Aftermarket filters are replacement products manufactured by independent filter manufacturers. High-quality aftermarket truck filters offer similar performance to original equipment manufacturer (OEM) products at a more competitive price.
      Professional aftermarket filter manufacturers typically offer:
      Original replacement filter Custom Brands Provide bulk supply to distributors Flexible production solutions Original equipment manufacturer (OEM) filters vs. aftermarket filters: key differences
      feature Original filter Aftermarket Filters compatibility Fully compliant with original factory standards Depends on the manufacturer price higher More cost-effective Brand promotion Original brand Custom/OEM branding services are available. Supply flexibility Limited Flexible Bulk Production custom made low High How to choose a suitable truck filter supplier
      Whether choosing original equipment manufacturer (OEM) filters or aftermarket filters, the quality of the supplier is the most important factor.
      A reliable truck filter manufacturer should provide:
      Stable filtration performance High-quality materials OEM Replacement Support Strict quality control Rapid delivery capability Why do many dealers choose aftermarket filters?
      Today, many global dealers prefer aftermarket truck filters because they offer the following advantages:
      Higher profit margins Original factory quality and performance Flexible Packaging Solutions Reduce procurement costs High-quality aftermarket filters can effectively protect diesel engines while reducing maintenance costs.
      in conclusion
      Original equipment (OEM) and aftermarket truck filters each have their advantages. The key is to choose a trustworthy filter manufacturer that ensures reliable quality and long-term supply support.
      If you are looking for OEM replacement filters, custom filter solutions, or bulk truck filter supplies, partnering with an experienced manufacturer can help your business grow faster.
      website:www.ixinfilter.com
      SPRINGFIELD, Mo., April 29, 2026 (GLOBE NEWSWIRE) -- O’Reilly Automotive, Inc. (the “Company” or “O’Reilly”) (Nasdaq: ORLY), a leading retailer in the automotive aftermarket industry, today announced record revenue and earnings for its first quarter ended March 31, 2026.
      The Schaeffler division is making two additional Vitesco repair solutions available to the independent aftermarket: a Voltage Stabilization System (VSS) for micro hybrid vehicles from PSA and Toyota, and a 48V DC/DC converter for mild hybrid vehicles from Ford.
      link hidden, please login to view said the VSS, available immediately, prevents voltage drops that can occur during automatic start-stop operation in micro-hybrid vehicles. The system consists of an Energy Storage System (ESS) with high-performance capacitors and a Power Electronics Unit (PEU). During the engine start process, the capacitors release energy stored while driving within a very short time, compensating for the high-power demand. Starting the engine via a starter-generator requires a comparatively high amount of energy.
      If this energy is drawn solely from the conventional 12-volt electrical system, the voltage can briefly drop by several volts, causing visible flickering of the vehicle’s lighting and electronic displays. Schaeffler said that by stabilizing the voltage supply, the capacitors ensure smooth engine restarting and contribute to longer battery life, improved driving comfort and compliance with current emissions standards.
      Schaeffler Vitesco Voltage Stabilization System power electronics unit  Schaeffler Vitesco 48V DC/DC Converter: Efficient Energy Management
      The Schaeffler Vitesco 48V DC/DC converter, available in May, is used in mild-hybrid vehicles equipped with a 48V starter generator and an additional battery to enable more efficient power delivery and boost performance during acceleration. The converter links the vehicle’s 48-volt electrical system with the 12-volt onboard electronics, ensuring stable voltage levels and preventing energy losses.
      The converter is a component of energy management in mild-hybrid vehicles and for achieving type-approval compliant CO2 emissions. Its bidirectional design allows 12-volt components to be supplied from the 48-volt network while charging the starter battery. Conversely, in the event of a temporary failure, the 48-volt system can also draw energy from the 12-volt network.
      Schaeffler Vitesco 48V DC/DC converter Significant Potential for the Aftermarket
      Until now, both the Schaeffler Vitesco Voltage Stabilization System and the Schaeffler Vitesco 48V DC/DC converter were available exclusively as original equipment components. This is a further expansion of the portfolio to include OE-quality Vitesco products.
      These technologies have been installed in large numbers of vehicles worldwide for many years. The Schaeffler Vitesco Voltage Stabilization System enables a 1:1 replacement in approximately 2.7 million vehicles worldwide from PSA and Toyota.
      link hidden, please login to view Vitesco DC/DC converter is used in around 1 million Ford vehicles globally, including Fiesta, Focus and Puma models equipped with the 1.0-liter EcoBoost mHEV engine. “By integrating Vitesco products, we are expanding our portfolio for electrified vehicles,” said Stephan Niese, director, global product management, E-Mobility, at Schaeffler Vehicle Lifetime Solutions. “In this way, we help the aftermarket unlock the potential of e‑mobility and enable workshops to offer their customers professional, future‑ready and profitable vehicle service.”
