Genna Honored in Automotive Aftermarket Hall of Fame
By APF
By USPartsinc
By GreenGears Auto Limited
3. Corrosion Protection
Premature tyre wear
Our
link hidden, please login to view was recognized by Hahn Automotive with the 2025 Outstanding Logistics Support Award at the annual Hahn Automotive National Sales Conference. Held last month in Rochester, N.Y., the conference prepares staff for the upcoming spring selling season and honors companies for their support and dedication to Hahn Automotive. WIX Filters Support for Hahn Automotive
link hidden, please login to view was honored for its service levels and order fill rates last year. The company has partnered with Hahn Automotive for nearly 30 years, providing a full line of filters. “Hahn Automotive stresses that service makes all the difference, emphasizing their commitment to innovation and customer satisfaction,” said David Barraco, trade marketing manager at WIX Filters. “WIX Filters has supported Hahn Automotive and its customers for almost three decades, and this award demonstrates our exemplary drive to provide on-time deliveries of the highest quality filters on the market.”
Hahn Automotive Warehouses and Auto Parts
Hahn Automotive owns nine full-service warehouses and 28 pickup warehouses that distribute auto parts throughout the Midwest, New England and the Mid-Atlantic states. The company operates Advantage Auto Stores, Car Parts/Motor Supply, Genuine Auto Parts, Norwood Auto Parts, Nu-Way Auto Parts and Speedway Auto Parts.
By liangyanyang
in conclusion
website:www.ixinfilter.com
