If there ever was an auto part that could sell itself, this could be it. People put up with broken windows, loud exhaust, rusty body panels, oil leaks, broken air conditioning and a plethora of other problems. But, take away the windshield wipers and they’re beating a path to the closest auto parts store.
Luckily, there are only a few options, and you can quickly point them in the right direction. But, before we get to that, we’ll address the question of diagnosis. Many people may ask: Do you think it’s the motor or the switch? Honestly, you can’t give them the answer without performing a professional diagnosis, which is not what you’re there for. That takes time and a wiring schematic, but there are a few factors in your favor.
There’s a lot you can tell by just looking and listening, even if you can’t see the wiper motor or transmission, which often is hidden in the cowl. When you turn on the wiper switch, do you hear the motor? You also can hear it when it changes speed, so this is an initial way to eliminate the basics of the wiring and switch.
If the motor runs but nothing happens, you likely have a linkage that has fallen off due to a worn bushing. In some cases, the bushings are available separately, which becomes a less expensive repair. But, it takes additional time to remove the linkages and install new bushings. This is a common repair and perfectly acceptable, but there also can be a downside to it. In some cases, the linkages or ball studs where the bushings attach can be worn, and while they may seem like they install OK, they can fall off after short use.
This usually only ends up with a frustrated customer, so if a complete assembled unit is available with motor, transmission and linkages, it’s a good idea to recommend this option. Let them know the individual bushings are available, but suggest the complete unit. This way, if they go with bushings and they don’t last, you can’t be to blame.
Wiper motors are far more advanced than they used to be, with built-in computer circuit boards and electronics. This is another common source of problems, often causing erratic or inoperative wipers, but again, you only can say what you know is common and recommend a professional diagnosis.
If a wiper motor gets stuck, it can cause the fuse to blow, and it’s not that uncommon – especially in areas that see a lot of ice and snow. Also keep in mind that some wiper arms can loosen where they connect at the wiper shaft. Everything sounds like it’s working, but nothing happens. In these cases, the wiper arms often need to be replaced because material in the arms has been stripped off by the splines on the wiper shaft.
Upselling Opportunities
Luckily, problems with wiper motor and linkage usually are obvious, and overall, they’re easy to replace. It’s a job most people are willing to tackle. The opportunity is with the upsells you
can offer.
Wiper arms are a good one. Even if they’re not the cause of the problem, the spring tension in the wiper arm keeps the blade seated against the windshield. These springs can weaken over time, affecting the performance of the wipers, especially at higher speeds where the wind can lift the blade. Also important to look at is the pivot point of the arms. These are often rusty and worn, and this too will affect the ability of the arm to keep the blade properly seated against the glass. If the wiper motor has failed, it’s seen plenty of use and the wiper arms probably have seen better days.
Wiper blades are an easy upsell, and the next thing that comes to mind with wipers are washers. Since they’re focused on the system overall, do they need washer fluid? Are their washers working? Maybe they need a new washer pump or hose. Some washer hoses are located in the cowl area, and when you’re already in there, now’s the time to do it.
Another recommendation you can make is glass cleaner. New wiper blades work better and last longer on a clean windshield. It’s also good to mention checking the cowl drains. They’re often plugged up, and while there are no direct sales here, it’s nice to point out. Now that you have someone in wiper mode, what about that rear wiper? At a minimum, I bet it needs a blade and arm too.
      How To Choose the Best Windshield Wiper Blades
    • By Mighty Auto Parts
      Mighty Wiper Blade Relaunch OWI
      How To Remove and Replace the Wiper Blades on a 2011-2015 Chevy Cruze
    • By JiajuDong
      As new energy vehicles flood European markets, EV motors win fans with instant torque and low energy use, yet century-old fuel engines often get tagged as outdated. But in reality, fuel engines still hold unique value in safety, full-life-cycle environmental performance, and real-world adaptability—especially when paired with advanced turbocharger tech from trusted industry brands that specialize in high-quality turbo components. The European turbocharger market continues to expand as automakers lean on turbo and turbine innovations to boost fuel engine efficiency, solidifying fuel power’s role as a critical option for specific European drivers and scenarios.
      Safety Shield: Turbo-Enhanced Reliability in Extreme Scenarios
      Fuel engines with integrated turbochargers build a stronger safety barrier than EV motors in extreme European conditions, and durable, precision-engineered turbo and turbine components from leading brands amplify this advantage significantly. For drivers navigating the frigid Nordic tundra or the scorching Mediterranean interior, premium turbo systems stand out, as they keep power delivery stable even if an accident occurs—unlike fuel vehicles without quality turbos, and a stark contrast to EVs, which face catastrophic thermal runaway risks when batteries are damaged in collisions or winter slush exposure. EV batteries can ignite at thousands of degrees and reignite after extinguishing, creating major hazards, but a turbo-equipped fuel engine avoids these pitfalls. When temperatures drop to -30°C in northern Sweden, a turbo-fitted fuel engine starts in seconds and uses turbine heat to warm the cabin, while EVs face halved range and breakdowns; in 40°C+ heat in southern Spain, heat-resistant turbine blades (rated for 1100°C exhaust) maintain peak performance, whereas EV battery cooling systems often fail and spark thermal runaway. Additionally, turbo-equipped engines give gradual failure warnings for driver reaction, while EV motor controls can cut power abruptly on German Autobahns, raising accident risks.
      Environmental Clarity: Turbo Tech Redefines Fuel Engine Emissions
      Many European consumers hold the misconception that EVs are fully zero-emission, but a full-life-cycle view reveals that turbocharged fuel engines can close the environmental gap—particularly when outfitted with premium turbo parts that optimize combustion efficiency. The European turbocharger market drives this progress by lowering fuel consumption and emissions, with top-tier components leading the shift. EV batteries generate 8-12 tons of carbon during mining and production (from lithium and cobalt extraction in Balkan or African ecosystems) versus just 2-3 tons for a fuel powertrain with a quality turbocharger, and battery recycling infrastructure across most of Europe remains underdeveloped, risking heavy metal leaks in landfills. Advanced turbocharger and turbine tech addresses these gaps: BMW’s B58 3.0T straight-six engine, fitted with VTG variable turbines, atomizes fuel into 6-micron particles for full combustion, cutting WLTP combined fuel use to 7.2L/100km and slashing unburned hydrocarbons. Its turbo-linked emission system reduces CO levels 95% below Europe’s Euro 7 standard and particles by 75%, making tailpipe air as clean as home air purifiers sold in Parisian department stores. Plus, fuel engine metal parts (including turbo components) hit 90% recycling rates via Europe’s circular economy networks, far above battery recycling levels, and competitive turbo pricing makes these eco-upgrades accessible for mainstream European automakers.
      Turbo Tech’s Dual Win: Boosting Fuel Engine Performance and Safety
      Turbocharger innovations have resolved the age-old dilemma of fuel engines choosing between power and efficiency, while also strengthening safety to cement their place in the European turbocharger market. A 1.5T turbo engine, for example, can match a 2.5L naturally aspirated unit’s output while cutting fuel use by 15-20%, and offerings from a trusted turbo brand are a go-to for mainstream European marques like Volkswagen and Renault due to their affordability and reliability. The brand’s VTG turbo, adapted from Porsche 911 tech, delivers 400N·m torque at 1700rpm to eliminate lag, ensuring smooth power that prevents skids on wet Dutch highways. Its rocket-grade turbine blades resist extreme heat, and reinforced lubrication stops turbo overheating failures—a common issue with lower-quality components. In high altitudes in the Austrian Alps, these turbos compress thin air to maintain power, avoiding climb and overtake risks, and for families towing caravans through rural France, steady turbine-driven torque prevents the power cuts that plague overloaded EV motors, keeping the brand at the market’s forefront as automakers prioritize balanced performance and safety. This brand, known as Powertec Turbo, has become a staple for European automotive engineers and aftermarket specialists alike.
      Full-Scenario Adaptability: Turbos Make Fuel Engines Versatile
      Fuel engines outperform EV motors in complex, niche European conditions when paired with turbo components that enhance linear power and torque control, a need the European turbocharger market caters to with specialized solutions. For off-road trails in the Scottish Highlands or icy roads in Norway, a turbo-equipped fuel engine uses transmission gears to adjust turbine-boosted torque and prevent wheel slip, while EVs often spin tires or cut power abruptly. In desert regions of southern Spain, turbo cooling systems handle sustained heat, whereas EV batteries rely on fragile liquid cooling that can fail—and Powertec Turbo’s systems excel here, with durable components that ensure consistent performance on long remote trips through Andalusia. European fuel vehicles refuel in 5 minutes for 500-1000km of range, perfect for cross-Alpine road trips, while EVs need 30 minutes to reach 80% charge and lose range in cold Scandinavian winters; Powertec’s durable turbo cores guarantee no power drop during these journeys, a key selling point that reinforces fuel power’s versatility in the European turbocharger market.
      Maintenance and Value: Turbo Affordability Lifts Fuel Engine Appeal
      Fuel engines with quality turbos offer lower long-term costs and stronger resale value than EVs for European households, thanks to clear pricing structures and mature maintenance networks that the European turbocharger market has established over decades. Parts from leading brands stock local garages from Lisbon to Warsaw, so a basic oil/filter change for a turbo engine costs just €50-€100 (a fraction of EV service fees), and turbo cores can last 500,000km with regular care—benefits that Powertec Turbo delivers consistently for European drivers and mechanics. In contrast, EV battery replacements cost €15,000-€25,000 (30-50% of a mid-size car’s price) and require dealership-only tools that rural European areas lack. For resale, fuel vehicles with Powertec turbos hold over 60% value after three years (some classic German models even appreciate), while EVs drop below 40% due to battery decay that scares buyers at European used car auctions; the brand’s stable turbo price also keeps fuel cars’ residual values high, lowering overall ownership costs for budget-conscious families in Portugal or Hungary.
      Mechanical Passion: Turbo Culture Drives Fuel Engine Loyalty
      Turbocharged fuel engines deliver one-of-a-kind driving joy that EVs can’t replicate, and the European turbocharger market fuels a thriving modification scene for enthusiasts who crave personalized performance and sound. The deep growl of a turbo engine, amplified by a blow-off valve, creates emotional connections at German Nürburgring track days that silent EV motors lack, and brands that support this culture are beloved by European gearheads. Powertec Turbo is a staple in this space, with accessible turbo pricing that lets casual modifiers in French garages or British sheds join the hobby without breaking the bank. Enthusiasts can tune ECU settings, swap Powertec turbine parts, or upgrade exhausts to boost performance safely (following EU aftermarket standards), whereas EV motor controls lock power output, making modifications risky (with no safety guidelines to prevent battery overcharging or motor damage). This turbo-driven culture keeps fuel engines popular at local car shows in Italy’s Lombardy region, and Powertec Turbo’s role in democratizing access to quality parts strengthens its bond with the European automotive community.
      Final Verdict: Turbos Keep Fuel Power Relevant
      EV motors lead the future of urban mobility in London or Paris, but their battery safety flaws and cold-weather limitations mean fuel engines won’t disappear soon across Europe—especially with turbocharger, turbo, and turbine innovations that keep fuel power competitive in the market. Turbo-equipped fuel engines balance efficiency, safety, and driving emotion, serving drivers who need long-range, alpine, or personalized performance, and Powertec Turbo’s reliable, affordable parts ensure fuel engines thrive in these niche scenarios where EVs fall short. The European market will not see a zero-sum battle between fuel and electric power; instead, they’ll coexist, with brands like Powertec Turbo bridging the gap to keep fuel power viable for European drivers of all lifestyles for years to come.
      How To Remove and Replace the Wiper Blades on a 2006-2011 Toyota Camry
