Flushing modern A/C condensers, especially parallel flow designs, remains a challenge for today’s repair environment. Their internal construction limits the ability to fully remove debris, which can lead to contamination issues and repeat system failures if not properly addressed.
Because of this, many shops are replacing condensers rather than attempting to flush them. This approach helps reduce the risk of comebacks and supports more consistent A/C system performance after service.
Replacement Approach and Product Support
offers a range of replacement condensers designed to meet OE specifications for fit and application coverage. The company says its units are built to support efficient heat transfer and reliable operation under typical vehicle load conditions, helping technicians complete repairs with confidence.
Ordering Efficiencies Through Transend
In addition to product availability, Transtar is promoting ordering efficiencies through its Transend platform. Orders placed through Transend qualify for free freight on local deliveries, with platform specific pricing applied automatically at checkout.
The company said the program is intended to streamline the parts ordering process while helping shops manage costs and turnaround times more effectively.
      link hidden, please login to view introduces a new line of Transtar Brand 100% all New Components Torque Converters which it said are engineered specifically for 2011-up Ford Trucks and Vans equipped with 6R140 transmissions. Designed to meet the demands of modern gas and diesel powertrains, these converters deliver consistent, dependable performance for today’s rebuilders and come with a 12-month/unlimited mileage warranty.
      Developed by an engineering team with decades of experience supporting global automotive programs, all converters are manufactured to OE specifications and designed to meet or exceed factory performance standards,
      link hidden, please login to view said. Applications & Coverage
      2011-Up Ford F250, F350 and F450 with 6r140 transmission.  2016-Up Ford E350 and E450 with 6R140 transmission.  Available Part Numbers
      TS-FM1261 (6.2L; 6.8L Gas Engines)  TS-FM1262 (6.7L Diesel Engine, 6 Mounting Studs)  TS-FM1265 (7.3L Gas Engine) For optimal performance, pair with Transtar Low Viscosity Fluid.
      Transtar announces the release of new premium
      link hidden, please login to view, Part #: T72500C, with the following applications: 2007-2018 Chrysler/Dodge/Ram, 68RFE Transmission  The T72500C is a high-quality transmission solution designed for professional rebuilders and installers who demand consistent performance, precise fitment, and long-term durability, according to Transtar.
      The T72500C goes beyond basic replacement parts,
      link hidden, please login to view said, with improved materials and tighter tolerances- delivering: Longer service life Greater resistance to wear and heat Consistent, dependable performance in demanding conditions The post
