announced additions to its OE replacement TPMS sensor portfolio with the launch of four new part numbers.
The following new part numbers cover Chrysler, Dodge, Ram, Jeep, Volkswagen, Subaru, Toyota, Infiniti and Acura applications.
Schrader Aluminum TPMS Sensor with Clamp-in Adjustable Angle Valve for Chrysler, Dodge, Ram, Jeep and Volkswagen applications
Schrader TPMS Sensor with Rubber Snap-in Valve for Subaru and Toyota applications
Schrader TPMS Sensor with Clamp-in Adjustable Angle Valve for Infiniti and Acura applications
TPMS Sensor with Rubber Snap-in Valve for Acura applications.
For more information, contact [email protected]
      link hidden, please login to view announced it released eight new AmeriPLATINUM Brake Pad numbers and four new AmeriPRO Brake Pad numbers with a wide range of coverage ranging from Buick Encore to Ford Transit applications. The new SKUs cover over 6mm VIO. Also just released in the
      link hidden, please login to view product line: 1 new AmeriPRO Brake Shoe, 2 new AmeriPRO Wear Sensors, 74 new AmeriPRO Coated and Coated R90 Euro Rotor numbers, and 20 VGX Brake Pad numbers with VIO coverage over 44+mm VIO.
      link hidden, please login to view introduces a new line of Transtar Brand 100% all New Components Torque Converters which it said are engineered specifically for 2011-up Ford Trucks and Vans equipped with 6R140 transmissions. Designed to meet the demands of modern gas and diesel powertrains, these converters deliver consistent, dependable performance for today’s rebuilders and come with a 12-month/unlimited mileage warranty.
      Developed by an engineering team with decades of experience supporting global automotive programs, all converters are manufactured to OE specifications and designed to meet or exceed factory performance standards,
      link hidden, please login to view said. Applications & Coverage
      2011-Up Ford F250, F350 and F450 with 6r140 transmission.  2016-Up Ford E350 and E450 with 6R140 transmission.  Available Part Numbers
      TS-FM1261 (6.2L; 6.8L Gas Engines)  TS-FM1262 (6.7L Diesel Engine, 6 Mounting Studs)  TS-FM1265 (7.3L Gas Engine) For optimal performance, pair with Transtar Low Viscosity Fluid.
