From strategic expansions to key network collaborations, the distribution landscape in 2025 was marked by growth and industry momentum. Here’s a look back at the biggest distribution stories covered by AftermarketNews in 2025.
Advance Auto Parts continued its nationwide footprint expansion,
across key U.S. markets to better serve professional installers and DIY customers.
Auto Parts Headquarters and Automotive Supply expanded their presence,
to enhance service capabilities and regional coverage for independent repair facilities.
Automotive Parts Headquarters honored standout partners by recognizing its
, celebrating excellence in distribution and supplier collaboration.
B&R Auto Group boosted its network with the
, strengthening service coverage and inventory reach in key markets.
Fisher Auto Parts deepened its Midwest footprint with the acquisition of
, providing enhanced support for local installers and fleets.
Fisher Auto Parts accelerated growth in Pennsylvania, completing additional acquisitions to expand service capabilities for regional customers and repair shops.
Federated Auto Parts welcomed SSF Imported Auto Parts to its distribution network,
and nationwide reach.
Landon Auto Parts announced its acquisition by Auto-Wares Group, ensuring continuity of service while gaining the
National Auto Parts Warehouse celebrated major operational milestones, reporting ambitious growth achievements that underscore its
in parts distribution.
NPW honored leading supplier partners during its 12th Annual
in Miami, recognizing key contributors to its distribution success.
The Group National Conference brought members, suppliers and partners together, offering networking, training and strategic collaboration opportunities that
of the independent distribution community.
These distribution milestones reflect an industry in motion: growing networks, enhanced collaboration and continued commitment to serving the needs of automotive professionals nationwide.
      Smarter Inventory Management
      Improving Customer Service
    • By Auto News
    • By GreenGears Auto Limited
      3. Corrosion Protection
      Premature tyre wear
      Our
    • By liangyanyang
      in conclusion
      website:www.ixinfilter.com
