NTK Vehicle Electronics, part of Niterra, is expanding its oxygen sensor range with 52 new components. These additions include both wideband and switching sensors, enhancing NTK’s position in the global automotive aftermarket. The new components will support combustion engines by optimizing the air-fuel mixture, critical for efficient catalytic converter operation. This expansion aids in meeting stringent European Union emissions requirements.
New Oxygen Sensor Additions Increase Market Reach
Throughout the year,
introduced 36 new oxygen sensors, with an additional 16 launched on Oct. 29. The total 52 new references will increase NTK’s market coverage by approximately 4%, reaching 30 million vehicles in operation (VIO) across Europe. This extensive range includes vehicles from Volkswagen Group, Jeep, Fiat, Renault and Nissan.
Niterra Updates Existing References and Expands Applications
has also updated over 250 existing references, enhancing links and expanding applications to a VIO of around 20 million. NTK’s introduction of new products and updates reflects a commitment to product development and market adaptation, the company said.
Emissions Focus Drives Product Growth and Sustainability
As emissions regulations tighten, NTK’s focus on efficient engine parts supports broader emission reduction goals. Niterra said it remains committed to sustainability in its research and design processes, ensuring high-quality aftermarket components.
The new NTK references are available in TecDoc and stocked in Niterra’s Duisburg warehouse in Germany.
Frank Massia, director of marketing aftermarket EMEA at Niterra EMEA GmbH, said, “With the latest launch of 52 new components, we will be able to extend our lead in the growing aftermarket with one of the highest levels of market coverage for any premium manufacturer in this sector.”
      link hidden, please login to view link hidden, please login to view link hidden, please login to view, the parent company of  link hidden, please login to view, announced the addition of link hidden, please login to view to the BCA aftermarket product line. This latest new number announcement delivers expanded OE‑quality coverage for key Lexus, Toyota, and Mazda applications, representing more than 800,000 vehicles in operation across North America. “These new part numbers reinforce BCA’s commitment to coverage and OE‑quality performance in high‑value segments of the market,” said Matt Gorski, manager of product development, automotive aftermarket. “As import platforms continue to evolve, we remain focused on providing dependable solutions that help our customers capture replacement demand with confidence.”
      The new additions strengthen BCA’s late‑model import coverage across key Lexus, Toyota, and Mazda platforms, including a growing mix of luxury, hybrid, and electric vehicles. By addressing both emerging electrified applications and sustained service demand in premium internal‑combustion models, this release further reinforces BCA’s ability to deliver durable, OE‑quality solutions for a broad and evolving segment of the aftermarket, the company said.
    • By GreenGears Auto Limited
      3. Corrosion Protection
      Premature tyre wear
      Our
    • By liangyanyang
      in conclusion
      website:www.ixinfilter.com
