Northwood University honored five Aftermarket Management Education Award winners at the University of the Aftermarket’s luncheon in Las Vegas on Tuesday, Nov. 4.
Students in the school’s aftermarket program announced the winners, who include:
E. Fletcher Lord III, president and chief executive officer of Bumper to Bumper Auto Parts, Parts
Warehouse, Inc. and Replacement Parts, Inc.
Olivia Droney Newton, vice president, category and management and data insights at NA Williams Company.
Larry Pacey, chairman/founder, National Auto Parts Warehouse, LLC.
Martin Redilla, education manager, HDA Truck Pride.
Jennifer Vitaro, director of marketing, Hahn Automotive Warehouse, Inc.
Also honored at the luncheon was
, sponsored by WIX Filters, Rob Mills of Fisher Auto Parts in Beckley, West Virginia.
    • By GreenGears Auto Limited
      3. Corrosion Protection
      Premature tyre wear
      Our
    • By liangyanyang
      in conclusion
      website:www.ixinfilter.com
      The Schaeffler division is making two additional Vitesco repair solutions available to the independent aftermarket: a Voltage Stabilization System (VSS) for micro hybrid vehicles from PSA and Toyota, and a 48V DC/DC converter for mild hybrid vehicles from Ford.
      link hidden, please login to view said the VSS, available immediately, prevents voltage drops that can occur during automatic start-stop operation in micro-hybrid vehicles. The system consists of an Energy Storage System (ESS) with high-performance capacitors and a Power Electronics Unit (PEU). During the engine start process, the capacitors release energy stored while driving within a very short time, compensating for the high-power demand. Starting the engine via a starter-generator requires a comparatively high amount of energy.
      If this energy is drawn solely from the conventional 12-volt electrical system, the voltage can briefly drop by several volts, causing visible flickering of the vehicle’s lighting and electronic displays. Schaeffler said that by stabilizing the voltage supply, the capacitors ensure smooth engine restarting and contribute to longer battery life, improved driving comfort and compliance with current emissions standards.
      Schaeffler Vitesco Voltage Stabilization System power electronics unit  Schaeffler Vitesco 48V DC/DC Converter: Efficient Energy Management
      The Schaeffler Vitesco 48V DC/DC converter, available in May, is used in mild-hybrid vehicles equipped with a 48V starter generator and an additional battery to enable more efficient power delivery and boost performance during acceleration. The converter links the vehicle’s 48-volt electrical system with the 12-volt onboard electronics, ensuring stable voltage levels and preventing energy losses.
      The converter is a component of energy management in mild-hybrid vehicles and for achieving type-approval compliant CO2 emissions. Its bidirectional design allows 12-volt components to be supplied from the 48-volt network while charging the starter battery. Conversely, in the event of a temporary failure, the 48-volt system can also draw energy from the 12-volt network.
      Schaeffler Vitesco 48V DC/DC converter Significant Potential for the Aftermarket
      Until now, both the Schaeffler Vitesco Voltage Stabilization System and the Schaeffler Vitesco 48V DC/DC converter were available exclusively as original equipment components. This is a further expansion of the portfolio to include OE-quality Vitesco products.
      These technologies have been installed in large numbers of vehicles worldwide for many years. The Schaeffler Vitesco Voltage Stabilization System enables a 1:1 replacement in approximately 2.7 million vehicles worldwide from PSA and Toyota.
      link hidden, please login to view Vitesco DC/DC converter is used in around 1 million Ford vehicles globally, including Fiesta, Focus and Puma models equipped with the 1.0-liter EcoBoost mHEV engine. “By integrating Vitesco products, we are expanding our portfolio for electrified vehicles,” said Stephan Niese, director, global product management, E-Mobility, at Schaeffler Vehicle Lifetime Solutions. “In this way, we help the aftermarket unlock the potential of e‑mobility and enable workshops to offer their customers professional, future‑ready and profitable vehicle service.”
      Six in 10 automotive businesses expect demand for aftermarket parts and services to grow this year. That’s according to
      link hidden, please login to view by the Automotive Aftermarket Products Expo ( link hidden, please login to view). Open-ended commentary points to higher new vehicle prices, which are causing consumers to hang onto their existing vehicles longer, as the driving force for rising demand in the aftermarket. “The price of new cars is high, so people are purchasing, repairing and maintaining older vehicles,” wrote one respondent. “People are keeping their cars for longer periods of time,” noted another. “Price of new cars justifies repairs on older vehicles,” noted a third.
      One caveat to that finding is that price sensitivity shows up in the aftermarket, too. The majority (53%) have observed more interest in lower-cost parts and services. However, customer motivation appears to be focused on value, rather than pure cost savings. Respondents said quality (34%) was the top influence of buying preference, followed by price (25%) and availability (20%).
      Perhaps as a consequence, respondents said their business’s sales expectations for this year are flat, compared to sales performance the year prior. This reinforces the aftermarket’s reputation for stability no matter what’s happening with the economy.
      Uncertainty is the Top Challenge
      Respondents identified the top challenge as “uncertainty” (45%), which was a recurring theme throughout the findings. Many aftermarket businesses are engrossed in supply chain diversification initiatives, carrying higher inventory levels, and struggling to find skilled labor.
      Among the other key findings are the following:
      Customer service is the top AI initiative. About one-fifth (21%) of respondents have implemented enterprise-grade AI tools and another 20% are in the planning stages. Of those implementing enterprise AI, the top areas of AI investment are customer service (60%), inventory management (42%) and product development (36%). Supply chain diversification. 70% of respondents have completed diversifying their suppliers (6%), are in the planning stages (18%), or have plans in progress (46%). Inventories are on the rise. 38% of respondents are managing higher inventories of parts, compared to 20% who say they are managing fewer parts. Electric vehicle (EV) investments. More respondents (26%) said they will invest less in the EV segment, compared to 17% who will invest more. Another 27% said they will invest about the same as last year. Notably, the largest share of respondents (29%) remains uncertain about EV investments. Solving the Skilled Labor Shortage
      Attracting skilled talent ranked second on the list of the top three challenges. Repair shops struggle with this because automotive technicians are retiring faster than the industry can replace them. The problem is compounded by the fact that demand for repair and maintenance services is rising.
      When asked about the steps their business is taking to address the shortage, respondents pointed to an array of enticements. These include offering more training (30%), boosting compensation (27%) and improving benefits (22%), among other steps.
      However, 25% of respondents aren’t taking any of those actions. In open-ended comments, respondents offered a variety of answers ranging from hiring retired people part-time to employing temporary help. One respondent commented [that we] “just stopped looking for help.”
      It’s important to note that it’s not just repair shops that need skilled labor in the aftermarket. Respondents who work in manufacturing comprised the second largest demographic in this survey, following repair shops.
      One manufacturing respondent wrote in to offer a solution, calling for “a national apprenticeship program that is deeply integrated into the manufacturing sector.” That person later added that technical institutes should synchronize their curricula with the “real-time needs of the factory floor.”
      The full report is freely available for download (no registration required) on the AAPEX blog:
