MEMA Report Provides Aftermarket Distribution, Supply Chain Insights
Volumes One, Two and Three of the 2026
Status Report are now available, offering essential data and forecasts for the automotive aftermarket sector, the organization said.
Market Insights
Volume One provides the latest data related to:
  • Current aftermarket size and projections for the next three years, sourced from the Joint Channel Forecast by S&P Global.
  • Alternative sizing of the aftermarket, based on average annual maintenance costs.
  • Select product category sizes informed by replacement rates data.
  • The extent of underperformed and unperformed maintenance.
  • Characteristics of the DIY population.
Distribution and Sales Analysis
Volume Two includes estimates of:
  • Vehicle usage and maintenance frequency.
  • Number of vehicles on the road, categorized by powertrain/propulsion.
  • Miles traveled annually.
  • New and used vehicle sales.
  • Sales comparisons through retail, dealers, and distributor/service channels.
Canadian Market Overview
Volume Three focuses on the Canadian aftermarket, including:
  • Canadian economic data.
  • Size and scope of the Canadian automotive aftermarket.
  • Vehicle sales and production data.
This report is available in Excel workbook format, allowing for direct data manipulation and integration into existing documents.
Access and Pricing
members can access all three volumes now. Non-members can purchase each volume for $250.
      Smarter Inventory Management
      Improving Customer Service
    • By Auto News
    • By GreenGears Auto Limited
      3. Corrosion Protection
      Premature tyre wear
      Our
    • By liangyanyang
      in conclusion
      website:www.ixinfilter.com
