ZF Aftermarket has introduced a comprehensive range of Sachs air struts to the independent aftermarket. The company manufactures these components to original equipment (OE) standards. According to ZF, these air struts deliver the original driving behavior. Technicians can install them easily thanks to a “plug-and-play” design that includes all required mounting parts.
About 10 million vehicles with air suspension currently operate in the EU and 25 million globally. This technology includes many components that require regular replacement. These include the air spring or, when combined with a damper, the complete air strut.
Air Struts Demand Grows with Rising Air Suspension Use
continues expanding the Sachs portfolio to help workshops service air suspension vehicles. The company now offers a wide range of air strut applications to the independent aftermarket.
ZF manufactures Sachs air struts according to OE specifications. These components meet the burst pressure requirements set by vehicle manufacturers. Each unit features a plug-and-play design and comes with all accessories, including the top mount.
The air struts also work with the electronic control systems of each vehicle. This ensures seamless operation of automatic levelling and adaptive damping features.
Applications Cover Popular Luxury Vehicle Models
currently offers 22 Sachs air strut part numbers. These cover models such as the Audi Q7, Porsche Cayenne, and VW Touareg.
ZF plans to expand the range soon to include Mercedes-Benz and Land Rover applications. The company aims to meet growing demand in both European and global markets.
Advanced Design Optimizes Function and Ride Quality
The Sachs air strut combines the air spring and shock absorber into one integrated component. This design improves space efficiency and performance.
Sensors monitor road conditions, load, and vehicle movement continuously. A control unit processes the data and adjusts damping forces every two milliseconds.
A proportional valve makes these rapid adjustments possible. This technology helps maintain control, stability, and ride comfort during all driving conditions.
    • By GreenGears Auto Limited
      3. Corrosion Protection
      Premature tyre wear
      Our
      link hidden, please login to view announced the launch of its newly redesigned website. The new site reflects the company’s continued investment in delivering an accessible digital experience for customers and partners. Designed with performance and ease of use in mind, the enhanced website features a streamlined interface, refined navigation and a fully responsive design optimized for desktop and mobile devices.
      Key Features
      Advanced Store Locator – IP-enabled map that displays the nearest store locations. Online Ordering Access – One-click entry to Rapid ordering platforms and customer registration portal for account setup. Product & Promotions Hub – Centralized access to brands, product categories, monthly specials and loyalty programs. Digital Strategy
      “This launch represents a significant step forward in our digital strategy, ensuring our online presence reflects the same high standard of service we deliver every day,” said Vikrant Aggarwal, president and CEO of XL Parts | The Parts House. “By bringing our brands together on one cohesive platform, we are strengthening our market presence and creating a more connected, efficient experience for the customers and communities we serve.”
      Customers can explore the refreshed platform at xlparts.com or thepartshouse.com.
    • By liangyanyang
      in conclusion
      website:www.ixinfilter.com
