and
released the 2025 Joint Channel Market Size and Forecast 2025-2028. This report offers a detailed review of the U.S. aftermarket and forecasts industry growth through 2028.
It also analyzes industry trends that are shaping this projected growth. S&P Global Market Intelligence prepared the Joint Channel Market Size and Forecast report.
The forecast model examines the U.S. automotive aftermarket in detail and identifies key influences on industry growth. It provides insights into market trends driving changes in the industry’s size and composition.
The model draws on extensive research and delivers valuable projections for aftermarket stakeholders. These projections help businesses make informed decisions and develop effective strategic plans.
Key Insights from the Automotive Aftermarket Forecast 2025
reviews aftermarket performance in 2024 and outlines forecasts for 2025 and beyond. It projects the light-duty aftermarket to reach $435 billion in 2025.
The Auto Care Association and MEMA Aftermarket Suppliers expect growth to exceed pre-pandemic rates and continue through 2028. They forecast the aftermarket to surpass $500 billion by 2028. That milestone comes just four years after it topped $400 billion.
The service channel retained a 0.6 percentage point gain from the dealer channel in 2024. Since 2017, the dealer channel has lost 1.4 percentage points of market share.
Expert Commentary on Industry Growth and Automotive Aftermarket Forecast 2025
“The automotive aftermarket continues to demonstrate remarkable resilience and growth,” said Paul McCarthy, president of MEMA Aftermarket Suppliers. “The 2025 Joint Channel Forecast predicts consumers will spend $435 billion to repair and maintain their vehicles this year, while future years will surpass pre-pandemic growth rates in dollar terms. Consumers and our country need the aftermarket. This study provides our members with valuable insights into market trends and emerging opportunities to support their business decisions.”
“The U.S. automotive aftermarket is poised for significant growth, and this report highlights the industry’s strength and resilience in the face of evolving challenges,” said Bill Hanvey, president and CEO, Auto Care Association. “The Joint Channel Forecast gives our members the insights needed to navigate this dynamic landscape. We are proud to provide this valuable resource each year to empower our members in making their strategic business decisions to drive our industry’s growth through 2028 and beyond.”
Report Access and Membership Benefit
Auto Care Association and MEMA Aftermarket Suppliers offer the report as a benefit of membership.
Members can access the Joint Channel Forecast Model at no additional cost.
Auto Care members can access the Joint Channel Forecast report in the 2026 Auto Care Factbook at
. MEMA Aftermarket Suppliers can access the report at
    • By Auto News
    • By GreenGears Auto Limited
      3. Corrosion Protection
      Premature tyre wear
      Our
      link hidden, please login to view was recognized by Hahn Automotive with the 2025 Outstanding Logistics Support Award at the annual Hahn Automotive National Sales Conference. Held last month in Rochester, N.Y., the conference prepares staff for the upcoming spring selling season and honors companies for their support and dedication to Hahn Automotive. WIX Filters Support for Hahn Automotive
      link hidden, please login to view was honored for its service levels and order fill rates last year. The company has partnered with Hahn Automotive for nearly 30 years, providing a full line of filters. “Hahn Automotive stresses that service makes all the difference, emphasizing their commitment to innovation and customer satisfaction,” said David Barraco, trade marketing manager at WIX Filters. “WIX Filters has supported Hahn Automotive and its customers for almost three decades, and this award demonstrates our exemplary drive to provide on-time deliveries of the highest quality filters on the market.”
      Hahn Automotive Warehouses and Auto Parts
      Hahn Automotive owns nine full-service warehouses and 28 pickup warehouses that distribute auto parts throughout the Midwest, New England and the Mid-Atlantic states. The company operates Advantage Auto Stores, Car Parts/Motor Supply, Genuine Auto Parts, Norwood Auto Parts, Nu-Way Auto Parts and Speedway Auto Parts.
