      link hidden, please login to view is a strong option for sealing minor to moderate failures. If the issue is more severe, stepping up to a heavier-duty solution may be necessary. Bar’s Leaks Head Seal Blown Head Gasket Repair is designed to create a durable seal, helping restore system integrity when matched correctly to the condition. Head gasket issues come down to sealing failure and severity. Identify the condition, then match it with the right solution.
      Fixing a fuel tank? Check Dorman first.
