One of the more difficult things about any technology is all the new terms you seem to get hit with, and in the automotive world, CAN bus was one of those terms. The second half, “bus,” was a term we had already used for many years, primarily as “bus bar.” A bus bar was a metal strip or bar that distributed power among multiple components.
In the automotive world, even when fiber-optic turn-signal indicators mounted on the front of a fender were as high-tech as it got, bus bars were inside many components such as fuse panels and relays, and sometimes under the hood for various engine electronics.
Then computer electronics took over. At first, we just had one electronic control unit (ECU) to deal with, and it was for the engine. Before you knew it, there was a transmission control unit, then the ABS control unit (not necessarily in that order). Wiring harnesses got bigger … and bigger and bigger.
Today, a car can have as many as 150 ECUs. In addition to the familiar engine, transmission, brake and airbag control units, doors, seats, mirrors, power steering, audio systems, cruise control, batteries and charging management systems all have their own control units. And as you can imagine, that’s just scratching the surface.
As technology was taking a ride with all these systems, engineers realized there were too many wires and too many sensors. There was no choice but to get aboard the CAN bus. CAN stands for controller area network, and a CAN bus, simply put, is a common communication line that can be used by all ECUs on the network.
The various control units on a modern vehicle need to communicate and share information over this network. Here’s an example of how and why. Years ago, when you turned on the air conditioning, a simple switch sent power to the compressor clutch. Today, the HVAC control module may need to communicate with the body control module (BCM) to notify it that A/C has been requested.
The BCM in turn sends a request to the engine control module (ECM) to “ask permission” if it can energize the A/C-compressor relay. The ECM looks at current engine operating parameters and sends a response signal to the BCM, which, in turn, sends a signal to the A/C relay.
The technological features on today’s cars are nothing short of impressive. Advanced driver-assistance systems (ADAS) include features such as adaptive cruise control, forward collision warnings, high-beam safety, lane-departure warnings, traffic-signal recognition, lane-keep assistance, automatic emergency braking and traction control.
All of the associated control units are in constant communication with each other, and since many of them must utilize information from the same sensors, through the CAN bus network this is possible. Instead of an ambient-temperature sensor for the ECM, the HVAC control unit and the instrument cluster, one sensor can share its data over the network.
Some high-end vehicles have a feature called automatic brake wiping, or brake disc wiping. This feature utilizes information from a rain sensor (also used by automatic windshield wipers) that’s sent over the CAN bus to the ABS control unit. In programmed intervals, the ABS control unit lightly applies the brakes in a manner that the driver won’t notice, to clear water and moisture away from the rotors and provide maximum braking when needed. All of this is only possible thanks to the communication available over the CAN bus.
Developing the CAN bus system was no simple feat, and it took many years to complete. The requirements for automotive CAN bus communication are standardized as part of the OBD II vehicle communication standard. There have been many changes over the years related to CAN communication, primarily affecting the speed and manner in which data is transmitted. The easiest way to think about it is to relate it to the changes over the years in USB design we’re all familiar with. It’s for the same reason. They transmit data quicker.
From a service standpoint, technicians have had to become familiar with CAN bus systems. U-codes that indicate a loss of communication between modules or on a specific bus are a tool designed to help technicians diagnose CAN bus problems.
Electrical wiring diagrams reflect the CAN bus network, and there are three different types of networks – loop, star and loop/star hybrid – referred to as CAN bus topology. Being able to recognize the type of topology can help a technician diagnose CAN bus errors quicker. In today’s world, we all have to get aboard the CAN bus.
      To be successful in aftermarket parts sales requires a very broad knowledge base. It means having the ability to address customer parts requests for dozens of different vehicle manufacturers spanning more than 75 years of production, including multiple vehicle systems. Much like our inventory mix, our employees’ knowledge needs to be “spread out” to accommodate these varied requests. Sure, we all have our strengths and specialties, but imagine the bottlenecks at the counter if Heather was the only staff member familiar with reading the paper catalogs covering vintage applications, or that Larry couldn’t catalog anything unless it was for a domestic vehicle.
      While we would never hire a counterperson with such gaping blind spots concerning vehicle knowledge, when it comes to store operations, these kinds of scenarios happen every day. Cross-training staff eases the burden for everyone in the organization, from the top down. Becoming an “expert” in your own particular role doesn’t need to prevent you from being a versatile member of the team.
      link hidden, please login to view For obvious reasons, not every employee will be responsible for making management-level decisions. But when it comes to daily operations, each member of your staff needs to be given not only the tools to succeed, but also the skills and authority to use those tools effectively. We’ve all worked in locations with extended business hours or short-staffing situations, and felt the pinch when a key member of the team was absent. Picking up the slack in these situations has become a harsh reality in today’s business environment, and without cross-training for the remaining employees, everyone on both sides of the counter suffers for it.
      Depending on your individual role within the organization, you may have very little exposure to some of the other roles being performed around you, or you may already have experienced each role along the way to your current position. The hierarchy of roles in this industry tends to follow a natural progression, from delivery and stocking associates to counter and sales positions, and eventually to various management roles. Along the way, there is often considerable overlap in skills and responsibilities at each stage.
      At any level of the hierarchy, the most destructive employee attitude is the “not my job” attitude. Traditional workforce roles generally fall into either “labor” or “management” categories. Many organizations even reinforce this idea through uniform choices. Unfortunately, this also may create a division among employees, who feel that titles are designed to separate them rather than to complement each other. Even worse than those employees who claim that something is “above their pay grade” are those members of the team who believe that performing a particular task is beneath them. Having a delivery driver who is comfortable with helping with simple customer service tasks is no less important than the keyholding manager who makes a hot-shot delivery to help maintain a commercial customer’s workflow. Cross-training works in both directions!
      There may not be an “I” in “team,” but there are two of them in “idiot.” Building a team that can move effortlessly between roles requires all parties to be invested in the overall success of the business, not just their own individual interests. We need to identify those members of our team who are most capable of (and interested in) growth beyond just a narrowly defined job description. We need to encourage them to acquire new skills, and to remind employees who already possess those skills that having others trained in their role is a benefit, not a threat.
      Searching for a Lexus transmission near me often means finding a dependable replacement that delivers luxury-level performance and smooth shifting. Lexus vehicles share many reliable drivetrain components with Toyota models, making their transmissions highly respected for durability and comfort. Whether you own an RX, ES, IS, GX, or LS model, choosing the right transmission replacement helps maintain premium driving quality. Before purchasing, verify the VIN match, mileage history, and transmission condition to ensure proper compatibility. Many drivers choose tested used transmissions because they provide a more affordable alternative to dealership replacements. A reliable Lexus transmission improves acceleration, fuel efficiency, and long-term performance while preserving the smooth driving experience Lexus owners expect from their vehicles.
    • By Mighty Auto Parts
      link hidden, please login to view appeared first on link hidden, please login to view. With today’s complex systems the repair may involve more than running a diagnostic chart and replacing a defective part. Systems today are so connected that it makes it difficult for the most experienced technician to distinguish between a mechanical, electrical, fuel, or emission related condition without extensive testing. In addition to having the theory and […]
      link hidden, please login to view What We Do:
       Providing aftermarket parts with OEM-quality standards for all off-road machinery brands.  Ensuring the highest standard of quality control.  Maintaining extensive inventory: 100,000 parts available online, ready to be shipped from our seven warehouses located in the United States, Canada, Germany, and China.  Supporting your entire parts procurement process.
    • By Toyotarav4
      We sell and distribute all Toyota RAV4 parts beginning from the 2012 model till date contact us with your order [email protected]
