Shopping for Spark Plugs With NAPA
Automotive ignition and engine work are some of the most straight-forward DIY projects that at-home mechanics have performed for decades. At NAPA, not only do we want to guide you on which
to purchase, but also educate drivers on how they function and the process for
Your vehicle’s ignition system routes high-voltage current from the ignition coils to the
in a synchronized firing order. The timing is critical to optimize the power created from the explosion or spark. Spark plugs use precisely crafted ceramic insular bodies and punched steel casings, which house two electrodes with a gap in between them. When voltage is sent to the plug, an electrical arc is formed between the two electrodes, thus igniting the fuel/air mixture.
Spark plugs determine the power output, fuel economy and even engine temperature of your automobile. Signs that it is time for spark plug and coil replacement include jittery or rough idling, power surges from the engine, diminished acceleration and decreased gas mileage. Remember that spark plugs are not designed to last the lifetime of a vehicle. Built-up deposits and natural widening of the electrode gap can cause spark plugs to fail as time passes, so replacing spark plugs is a routine part of vehicle maintenance. Note: It is always best to replace all the spark plugs at the same time.
NAPA experts recommend
every 30,000 miles on older models, which matches most manufacturer recommendations. With a modern vehicle, you only need to change spark plugs every 100,000 miles thanks to advances in materials and ignition design. Replacing spark plugs will take roughly an hour if your vehicle has a four-cylinder engine. Spark plug replacement takes longer for vehicles with a V6 or V8 engine. A standard vehicle typically has the same number of spark plugs as the number of cylinders. So, a V6 would need six replacement spark plugs. There are exceptions like Chrysler V8s, which use two plugs per cylinder.
Which Plug Sparks Your Interest?
At the heart of each spark plug is an electrode that connects to the vehicle’s ignition coil via a thick wire. Spark plugs installed by car manufacturers often contain copper, nickel or chromium core electrodes. The metal mentioned in the replacement part’s name indicates the material used to construct its electrode, which gives you an idea of the different
in most retail aftermarkets. You can also find high-performance spark plugs composed of rare, powerful metals like ones with fine-wire iridium centers and double platinum ground electrodes. Glow plugs are typically used for heavy-duty diesel applications.
So, are you wondering what type of spark plug is best for your car?
are ideal replacements for older model vehicles. These copper spark plugs are applicable to a wide range of makes/models and are guaranteed to deliver quick starts, good fuel efficiency and smooth acceleration. Although, for commuter vehicles that aren’t classics, some of the best types of spark plugs come from
. This product line includes reliable conventional spark plugs, specialized marine spark plugs and
. Our experts highly recommend spark plugs from the top-tier levels: ACDelco Silver (Advantage) and ACDelco Gold (Professional).
One of the reasons to go with a premium spark plug is that their platinum construction provides better performance and more durability when compared to copper. For example, platinum spark plugs are typically good for up to 100,000 miles of service. These plugs are engineered to generate more heat, which means they can operate in hotter environments. Due to the minimizing of carbon deposit build up, platinum plugs give a better spark for a longer period of time. For an ideal upgrade, go with the
, which delivers optimal engine performance and fuel efficiency. This Autolite spark plug is specifically designed for Ford pickups and SUVs, such as the Ford Expedition and Lincoln Navigator.
Because iridium conducts energy better (an iridium electrode’s durability is six times harder than platinum), it’s the optimal choice if you want to get the most out of a performance engine. Iridium spark plugs are engineered to offer excellent engine idling stability and a smooth performance, which is critical in newer vehicles that use
. NGK Spark Plugs manufactures replacement parts for virtually every automotive, motorcycle, marine and small engine application.
are specifically designed for the performance enthusiast, because they provide outstanding acceleration and high fuel efficiency.
Get Started With NAPA
Are you looking for where to buy spark plugs and
? NAPA Auto Parts stores and NAPAonline.com are proud to offer thousands of spark plugs and ignition components for sedans, pickups, minivans, SUVs and more. Make sure to select the ones specifically engineered for your vehicle’s make and model. Plus, take advantage of our convenient
option.
If you are concerned about how much spark plugs cost, we have some good news! The cost of spark plugs ranges as low as less than $2 per spark plug to more than $100 dollars for spark plugs used in industrial or racing vehicles. You can purchase a long-lasting, high-quality, aftermarket replacement spark plug for less than $6 each.
Keep in mind, you need to remain patient while removing spark plugs and make sure to remove one spark plug at a time in the correct firing order. You must remove and replace each spark plug, along with any accompanying wires, before moving on to the next one in the chain. Most modern vehicles incorporate coil-on-plug technology, which don’t utilize external spark plug wires.
Finally, you must check to see if there are proper gap spaces on your new set of spark plugs to finish this installation. This technical auto repair requires using a
with a swivel head, a spark plug wire puller and a
just to name a few specific tools. With that in mind, you are probably wondering how much it costs to get spark plugs changed by a professional mechanic. The average cost of spark plug replacement is $140 for a four-cylinder engine, $180 for a six-cylinder engine and $220 for an eight-cylinder engine. Schedule an appointment with your nearest
today!
Photo courtesy of
      Sunday, May 4, 2025, officially marks the 100th anniversary of NAPA and a century of service in the automotive industry. This automotive industry milestone highlights NAPA’s commitment to supporting drivers and repair shops nationwide. To commemorate the occasion,
      link hidden, please login to view is debuting a celebratory paint scheme on all four of its race team cars. In a rare event, three of these teams will hit the track from May 1-4 at the Texas Motor Speedway. NAPA 100 Paint Scheme Honors Automotive Industry Milestone
      The company said the NAPA 100 paint scheme is the perfect way to honor NAPA’s history and impact.
      The rapid adoption of automobiles meant people across the country needed reliable repair shops to maintain their cars.
      link hidden, please login to viewstepped up to meet that need. Today, as the automotive aftermarket industry evolves faster than ever, NAPA embraces new technologies and advancements to keep drivers on the road. link hidden, please login to view Design Details Celebrate a Century of Excellence
      NAPA describes the paint scheme as a champagne gold that is sure to stand out from the pack.
      Thoughtfully designed, the gilded look features NAPA’s unique 100-year logo and a matching driver fire suit. The design symbolizes celebration and NAPA’s impressive legacy, the company said.
      NAPA’s Racing Community Joins the Celebration
      As a decades-long sponsor of motorsports, NAPA said it was important to honor this milestone with its racing community. NAPA is a sponsor of NASCAR driver Chase Elliott, American NHRA Funny Car racer Ron Capps, NASCAR trucks driver Daniel Hemric and sprint car racer Brad Sweet.
      link hidden, please login to view 100 Celebration Weekend – NAPA Race Team Schedule:
      Series: Kubota High Limit Racing 
      Team: Kasey Kahne Racing
      Car: #49 Sprint Car 
      Driver: Brad Sweet
      Owner: Kasey Kahne
      Dates: 5/1 & 5/3 (2-night event)
      Race:  Stockyard Stampede at The Dirt Track at Texas Motor Speedway 
      Series: NASCAR Craftsman Truck Series 
      Team: McAnally-Hilgemann Racing 
      Car: No. 19 NAPA Auto Care Chevrolet Silverado RST
      Driver: Daniel Hemric
      Owner: Bill McAnally
      Date: Friday, May 2 
      Race: SpeedyCash.com 250 at Texas Motor Speedway
      Series: NASCAR Cup Series 
      Team:
      Car:  No.9 NAPA Auto Parts Chevrolet
      Driver: Chase Elliott 
      Owner: Rick Hendrick
      Date: Sunday, May 4
      Race: WÜRTH 400 NASCAR Cup Series
      Since its inception in 2011, the NAPA Partnership Event (formerly known as the NAPA Vendor Summit) has recognized outstanding suppliers through its Supplier Awards Ceremony. NAPA said the event provides an opportunity to honor the exceptional contributions of NAPA’s valued supplier partners—those who champion innovation, quality and excellence in everything they do.
      link hidden, please login to viewadded that the Spirit of NAPA award, in particular, has a rich history and is awarded to a trusted supplier that embodies NAPA’s values. This year’s Spirit of NAPA award winner, Dorman, stood out for its dedication to innovation, commitment to quality and lasting impact on the industry. Below is the complete list of winners:
      Innovation Award: Milwaukee Tool Quality Award: East Penn Manufacturing Cataloging Award: Old World Industries Sales Award: TERREPOWER Service Award: Weitron Indirect Supplier Award: Pricefx Spirit of NAPA Award: Dorman Partnership Award: Neal Williams The post
      In celebration of International Women’s Day this Saturday, March 8, NAPA will be giving away 1,000 free copies of “The Car That She Built”, a children’s book that pays tribute to the women who have paved the way for the next generation of innovators and leaders in automotive technology.
      “Our collaboration with TechForce and the She Built Foundation underscores a shared mission to inspire and empower young girls, encouraging them to envision and pursue exciting careers in skilled trades,” said Cassie Bell, chief people officer at
      link hidden, please login to view. “By showcasing the achievements and potential of women in the automotive industry, we aim to break down barriers and open garage doors for future generations.”  Readers can sign up for their free copy
      link hidden, please login to view The campaign will launch on Friday, March 7, and run through the end of Women’s History Month (March). The post
      link hidden, please login to view has partnered with University of the Aftermarket Foundation (UAF) to provide 20 scholarships for aspiring automotive students. As part of the commitment, link hidden, please login to view is awarding 15 $2,500 scholarships to individuals accepted or enrolled in a transportation technician program, along with five $2,500 scholarships specifically for women. This is in addition to other initiatives, such as an apprenticeship program, which aligns with NAPA’s commitment to developing young talent and addressing the technician shortage, the company said. “With the technician shortage still impacting the industry, we understand the importance of nurturing individuals interested in a career in the automotive trades,” said Emily Schneider, senior director of marketing at NAPA. “These scholarships are designed to celebrate emerging talent and create opportunities for those beginning or continuing their journey in technician education.”
      To enroll, students can visit
      link hidden, please login to view and complete a single application to be considered for multiple scholarships. They can also view the details of all available scholarships and continue to update their application. “Addressing the technician shortage means investing in the education of future technicians, which is why we continue to partner with organizations such as NAPA to create those opportunities for young professionals,” said Mike Buzzard, chairman, UAF scholarship committee. “NAPA’s reach coupled with their commitment to helping current students goes a long way in addressing the technician shortage, and these scholarships will continue to break down a barrier for anyone looking to join the industry.”
      For more information, reminders and updates about the
      link hidden, please login to view scholarship program, interested parties can text their name and email address to 720-903-2206. The post
    • By Ryan
      I have a 2019 Silverado 5.3L, and I've been looking up spark plug wires on RockAuto. I found two part numbers listed:
      1. Part number 12716289, which is said to fit 2014-2024 Silverado 1500.
      2. Part number 9241829A, which is said to fit 2000-2022 Silverado 1500.
      Since these two parts overlap for the years 2014-2022, does this mean that the spark plug wires for Silverado 1500 models from 2000-2024 are interchangeable?
      Additionally, I searched on Amazon and found that these part numbers seem to be the same as
      link hidden, please login to view and 9748HH. I appreciate any insights or experiences you might have with these part numbers.
      Thanks!
