Chevy window regulators
By elizabeth
Are you looking for a powerful and reliable Chevy Silverado at an affordable price? We offer an outstanding selection of Chevy Silverado trucks built for hard work, adventure, and everyday driving excellence. Each Chevy Silverado in our inventory is carefully inspected for performance, safety, and reliability, ensuring you get a truck that meets your highest expectations. Available in multiple trim levels, cab configurations, and engine options, we have the perfect Silverado to match your lifestyle and budget. Our dedicated team provides expert guidance, easy financing solutions, and exceptional customer support from start to finish. Whether you need a workhorse or a weekend warrior, shop our trusted Chevy Silverado inventory today and find your perfect truck!
By elizabeth
The 2018 Chevrolet Traverse comes equipped with a 9-speed automatic transmission paired with its 3.6L V6 engine, offering wide gear spacing for both fuel efficiency and highway cruising comfort. Some owners have reported concerns with rough or hesitant shifting, particularly during low-speed acceleration and downshifts — often addressed through GM software updates and transmission fluid changes. Dexron HP is the recommended fluid for this unit. When replacing the transmission, ensure the replacement unit is properly programmed to the vehicle's control modules. Remanufactured 9-speed units provide a dependable, warrantied path to restoring smooth, confident performance in your Traverse. link hidden, please login to view -
By elizabeth
The 2014 Chevy Spark transmission is a key component that determines how smoothly this compact car performs in city and highway driving. It came equipped with either a 5-speed manual or a continuously variable transmission (CVT), offering drivers excellent flexibility. Common issues include hesitation during acceleration and occasional slipping. Low fluid levels are often the root cause of these problems. Regular maintenance checks can extend its lifespan significantly and help avoid expensive repairs down the road.
By elizabeth
The 2006 Chevy Silverado transmission is a critical component for one of America's most dependable full-size trucks. The 2006 Silverado used either a 4L60-E four-speed automatic or the heavy-duty 4L80-E, depending on engine configuration and towing package. The 4L60-E is the most common unit and the one most frequently replaced due to solenoid failures, torque converter issues, and third-gear clutch wear particularly on trucks that hauled heavy loads or towed frequently throughout their service life.
When sourcing a replacement 2006 Silverado transmission, confirm your engine size and towing package code from your VIN. They determine which transmission unit is correct. A quality used 4L60-E or 4L80-E with under 80,000 documented miles, shift-tested across all ranges, and covered by a minimum 12-month warranty is the most cost-effective replacement path available for Silverado owners today.
