So my check engine light came on and I was able to pull a code P0420 Catalyst system low efficiency. Now I know this could mean a bad cat, bad O2 sensor(s) or even a crack in the manifold. I have a 2011 Chevy Equinox 2.4L with a little over 80k on it. Does anyone know if there is a common fix for this? I was hoping it was a loose gas cap or something lol...But seems from looking online it can be a variety of things.
Yes it could be a variety of things and the right thing would be to have it diagnosed either at a repair shop or a dealer, unless you are able to run some test on the 02 and exhaust. The other thing to consider is if there are some warranty or added warranty items available on this vehicle. If you haven't already, get your car loaded into myChevy
 . You'll be able to see if there are any recalls and service items extended to 150k. Some of these GM vehicles have additional coverage added to them because of known issues and some include the catalytic converter, fuel pump, and also oil consumption which could trigger your code as well. :D
Could be a misfire also, clear the code and see if it comes back again. If it does, you need diagnostics to determine what the issue is. The code isn't exact where you know what part to replace to fix it.
  • 3 weeks later...
here are a number of things that could be causing this p0420 catalyst efficiency code. The most common thing is the catalytic converter itself is no longer functioning properly.
The other likely thing is the rear O2 (oxygen) sensor is no longer working properly. Other things could include exhaust leaks, damaged exhaust pipes, damaged O2 sensor wiring/connectors, plugged catalytic converter, etc.
The easiest thing to do first is a visual check of things. Visually inspect the exhaust system for leaks, check the catalytic converter for dents, holes, severe discoloration, and check for a rattle inside. If any of those syptoms are there, the converter likely needs replacement.
Then, visually inspect the downstream O2 sensor (behind the converter). Check for broken wires, obvious faults, etc. If all that checks out, you'll want to check the operation of the O2 sensor. To do that, you'll need access to a scan tool or oscilliscope. Check that the waveform is pretty steady. If the reading fluctuates then the sensor is likely bad and will need to be replaced.
Try this, turn the ignition key to the on position, (engine not running) and pull the fuse to your ECM for 30 seconds and then re-install it. Once re-installed, start the engine and let idle for 1 min and then go for a test drive.
If the engine stalls, let it. The ECM is relearning the sensors and engine, just restart it and after 1 min when the RPM drops. Go for a test drive and see if the service engine light comes back on and re-scan for the DTC codes and address the issues indicated by the DTC code.
Edited by MCT
Misspell
14 hours ago, chevyguy said:
Haven't taken it yet, check engine light still on. Might have to bring it after vacation.
Have fun!
So we left Saturday on vacation and left the equinox at the dealer to check into the car efficiency code, oil consumption, occasional hard shift, and slow l/f tire leak. So we'll see, they have it for the week. I also dug up a letter from GM for an extended warranty on replacing the cat if needed.
Back from vacation and got the equinox back from the dealer. They changed the converter under recall and also changed the fuel pump and an adjustable seat bolt, which were also both under recall. No check engine light and runs great so far. :D
      Are you looking for a powerful and reliable Chevy Silverado at an affordable price? We offer an outstanding selection of Chevy Silverado trucks built for hard work, adventure, and everyday driving excellence. Each Chevy Silverado in our inventory is carefully inspected for performance, safety, and reliability, ensuring you get a truck that meets your highest expectations. Available in multiple trim levels, cab configurations, and engine options, we have the perfect Silverado to match your lifestyle and budget. Our dedicated team provides expert guidance, easy financing solutions, and exceptional customer support from start to finish. Whether you need a workhorse or a weekend warrior, shop our trusted Chevy Silverado inventory today and find your perfect truck!
      The 2018 Chevrolet Traverse comes equipped with a 9-speed automatic transmission paired with its 3.6L V6 engine, offering wide gear spacing for both fuel efficiency and highway cruising comfort. Some owners have reported concerns with rough or hesitant shifting, particularly during low-speed acceleration and downshifts — often addressed through GM software updates and transmission fluid changes. Dexron HP is the recommended fluid for this unit. When replacing the transmission, ensure the replacement unit is properly programmed to the vehicle's control modules. Remanufactured 9-speed units provide a dependable, warrantied path to restoring smooth, confident performance in your Traverse. link hidden, please login to view
      The 2014 Chevy Spark transmission is a key component that determines how smoothly this compact car performs in city and highway driving. It came equipped with either a 5-speed manual or a continuously variable transmission (CVT), offering drivers excellent flexibility. Common issues include hesitation during acceleration and occasional slipping. Low fluid levels are often the root cause of these problems. Regular maintenance checks can extend its lifespan significantly and help avoid expensive repairs down the road.
      The 2006 Chevy Silverado transmission is a critical component for one of America's most dependable full-size trucks. The 2006 Silverado used either a 4L60-E four-speed automatic or the heavy-duty 4L80-E, depending on engine configuration and towing package. The 4L60-E is the most common unit and the one most frequently replaced due to solenoid failures, torque converter issues, and third-gear clutch wear particularly on trucks that hauled heavy loads or towed frequently throughout their service life.
      When sourcing a replacement 2006 Silverado transmission, confirm your engine size and towing package code from your VIN. They determine which transmission unit is correct. A quality used 4L60-E or 4L80-E with under 80,000 documented miles, shift-tested across all ranges, and covered by a minimum 12-month warranty is the most cost-effective replacement path available for Silverado owners today.
      How To Change Rear Shocks on a 2011-2015 Chevy Cruze
