Best Used Parts for Transmission Issues
Published by GreenGears Auto | 10 minute read | Transmission Repair & OEM Used Parts Guide
A transmission problem is one of the most feared repair diagnoses a vehicle owner can receive. New OEM transmissions cost $2,500–$6,500+ at the dealer. At GreenGears Auto, OEM used transmission parts deliver factory quality at 50–70% less than new pricing — with the correct electronic calibration your vehicle's powertrain control system was designed around. This guide covers every major transmission issue, the specific parts that fix them, and how to source correctly.
UNDERSTANDING TRANSMISSION PROBLEMS — DIAGNOSE BEFORE YOU ORDER
  • $2,500–$6,500+: typical new OEM automatic transmission cost
  • 50–70%: average savings on OEM used transmission parts at GreenGears Auto
  • 60%: of transmission failures traceable to fluid neglect, contamination, or a single solenoid or valve body fault rather than full mechanical failure
GreenGears Tip: Transmission fault codes (P0700–P0799 for generic; P0740, P0750, P0868, U0101 for specific components) identify the actual failed component before you spend a dollar on parts. A $120–$380 solenoid or valve body frequently causes problems that appear to require a $1,800+ complete transmission assembly.
TRANSMISSION TYPES — WHAT YOUR VEHICLE USES
Conventional Automatic (Torque Converter): Most common across trucks, SUVs, and traditional sedans. Uses a hydraulic torque converter. Common failure components: torque converter, valve body, shift solenoids, pressure control solenoids. Found on Ford F-150/Expedition, Chevrolet Silverado/Tahoe, Toyota Tundra/4Runner, Ram 1500.
Continuously Variable Transmission (CVT): Uses a belt or chain between two variable-diameter pulleys. Common on Nissan, Subaru, Honda, and many Toyota crossovers. CVT failures are typically complete unit failures — individual component replacement is rarely practical. Nissan CVT failure is the most frequently searched CVT repair topic in the market.
Dual-Clutch Transmission (DCT): Uses two separate clutch packs for odd and even gears. Common on VW/Audi DSG, Ford PowerShift, BMW M-DCT. DCT failure components: mechatronic unit (combined valve body and TCM), clutch packs, solenoids. OEM-only replacement critical for DCT electronics.
Manual Transmission: Driver-operated clutch and gear selection. Failure components: clutch assembly (disc, pressure plate, release bearing), flywheel, synchroniser rings. Failures are generally more targeted and identifiable without full disassembly.
TRANSMISSION PROBLEM SYMPTOMS — MATCHED TO FAILED COMPONENTS
Warning Lights & Codes:
  • - Check engine + P07xx codes → Shift solenoid or pressure control solenoid
  • - Transmission warning light → TCM fault or limp mode activation
  • - U0101 / U0100 code → TCM communication fault
  • - P0740 → Torque converter clutch solenoid
  • - P0868 → Transmission line pressure low
Shifting Problems:
  •  Harsh or jerky shifts → Shift solenoid, valve body, or low fluid pressure
  •  Delayed engagement → Clutch pack wear or low pressure
  •  Stuck in one gear (limp mode) → TCM fault, solenoid, or valve body
  •  Skips gears or won't upshift → Shift solenoid or speed sensor
  •  Slipping between gears → Clutch pack wear or valve body fault
Noise & Vibration:
  •  Shudder at 40–50 mph → Torque converter clutch (TCC) shudder
  •  Whining in all gears → Transmission pump or torque converter bearing
  •  Clunking into reverse → Worn internal splines or clutch drum
  •  Grinding during shifts → Worn clutch pack or synchroniser (manual)
  •  Vibration at highway speed only → Torque converter imbalance
Fluid & Temperature:
  •  Dark, burnt-smelling ATF → Overheating — cooler or solenoid failure
  •  Milky ATF → Coolant contamination via failed transmission cooler
  •  Transmission overheat warning → Cooler blockage or solenoid fault
  •  Fluid leak from front seal → Torque converter hub seal failure
REBUILD VS. REPLACE — MAKING THE RIGHT CALL
When to Repair (Individual Components):
  •  Fault codes point to a specific solenoid, sensor, or valve body — internals confirmed healthy
  •  TCC shudder confirmed — try TCC flush or torque converter before condemning the whole unit
  •  Fluid contamination identified early — cooler replacement and flush before internal damage progresses
  •  TCM communication fault only — no mechanical transmission symptoms present
When to Replace (Used OEM Assembly):
  •  Multiple fault codes — systemic failure across solenoids, clutch packs, and valve body
  •  Metal debris visible in drained fluid — internal gear or bearing damage
  •  Transmission slips across multiple gear ranges — clutch pack failure beyond solenoid repair
  •  Burnt clutch material smell from fluid — advanced friction material wear
  •  Used OEM assembly costs less than the sum of individual repair parts
BEST USED OEM PARTS FOR TRANSMISSION ISSUES — BY COMPONENT
1. USED OEM TRANSMISSION ASSEMBLY — Best Solution for Advanced Failures
GreenGears Used Price: $480–$2,200
A complete used OEM transmission assembly from a low-mileage donor vehicle is the best solution for advanced transmission failures — factory-assembled internals with correct clutch pack clearances, correct valve body calibration, and correct TCM software verified through real-world operation.
Best used OEM transmission assemblies by platform:
  •  Toyota Aisin 6-speed (A760E/A760F) — 4Runner, Tacoma, Tundra: Most reliable used automatic in the market; $680–$1,400; Toyota's conservative engineering produces exceptional remaining service life
  •  Ford 6R80 6-speed — F-150, Expedition, Mustang (2011–2021): High-volume with outstanding used availability; $580–$1,200; confirm torque rating — engine-specific variants exist
  •  GM 6L80 / 6L90 6-speed — Silverado, Tahoe, Suburban, Camaro: Heavy-duty BorgWarner-designed units; $620–$1,300; 6L90 preferred for towing; confirm by VIN
  •  Honda 5-speed / CVT — Accord, CR-V, Pilot (2013–2022): Exceptional availability from Honda's sales volume; $480–$980; CVT units from 2017–2022 most available
  •  Nissan Jatco CVT7 / CVT8 — Altima, Rogue, Pathfinder: Highest-demand CVT assembly in the market; $640–$1,380; always source from sub-60,000-mile donors
  •  Subaru TR580 / TR690 CVT — Outback, Forester, Crosstrek (2018+): $580–$1,100; EyeSight calibration required on equipped models
  •  VW/Audi 7-speed DSG (DQ200 / DQ250) — Golf, Jetta, A3, Tiguan: $680–$1,480; mechatronic unit is a commonly separate failure item
  •  BMW ZF 8HP 8-speed — 3 Series, 5 Series, X3, X5: One of the best automatic transmission designs ever produced; $780–$1,800; used units from low-mileage European imports are excellent
2. TRANSMISSION VALVE BODY — Most Underrated Transmission Fix
OEM Used Price: $120–$680 | Symptoms: Harsh shifts / Limp mode / P07xx codes
The transmission valve body is the hydraulic control centre — a precision-machined casting containing dozens of check balls, spring-loaded valves, and fluid passages directing pressure to the correct clutch packs. The most cost-effective repair when fault codes point to hydraulic pressure control rather than mechanical failure.
  •  OEM used valve bodies retain factory-calibrated check ball positions and spring preloads — aftermarket valve bodies frequently produce shift quality subtly different from factory calibration
  •  On DSG mechatronic units (VW DQ200, DQ250), the mechatronic contains the TCM software and must be sourced from the same transmission variant
  •  Always flush and fill with fresh fluid when replacing a valve body
  •  High-demand: Ford 6R80 valve body ($180–$380), GM 6L80 ($200–$420), Honda 5-speed ($120–$280), Toyota A760 ($160–$340), VW DQ200 mechatronic ($280–$580)
3. TORQUE CONVERTER ASSEMBLY — Primary Shudder & Vibration Fix
OEM Used Price: $120–$480 | Symptoms: Shudder at 40–50 mph / P0740 / vibration
The torque converter clutch (TCC) shudder — a distinct vibration felt at 40–50 mph as the TCC engages — is the most common torque converter complaint and responsible for the P0740 code on millions of vehicles annually.
  •  Before replacing for shudder, always perform a transmission fluid drain and fill with OEM-specified fluid and friction modifier additive — TCC shudder resolves with fluid service alone in approximately 30–40% of cases
  •  OEM used torque converters are the most reliable option — aftermarket units frequently have different stall speeds that alter shift quality
  •  Torque converter replacement requires transmission removal — always replace front pump seal alongside the converter
  •  High-demand: Ford 6R80 ($140–$340), GM 6L80 ($160–$380), Honda ($120–$280), Toyota A760 ($150–$360)
4. TRANSMISSION SHIFT SOLENOIDS & PRESSURE CONTROL SOLENOIDS — Most Targeted Fix
OEM Used Price: $35–$160 per solenoid | Symptoms: P0750–P0770 / stuck gear / harsh shifts
Shift solenoids are the most commonly replaced individual transmission components and the most targeted repair when fault codes identify a specific solenoid failure.
  •  Shift solenoids (SSA, SSB, SSC): P0750–P0760 codes identify specific shift solenoid faults
  •  Pressure Control Solenoids (PCS): Regulate hydraulic line pressure; PCS failure produces harsh shifts and P0867/P0868 codes
  •  TCC Solenoid: Controls TCC lockup; P0740–P0744 codes; responsible for many "transmission shudder" complaints
  •  Variable Force Solenoids (VFS): Found on newer multi-speed transmissions (8HP, 10R80, 10L90); $60–$160 per unit
  •  Always replace solenoids as a set when multiple codes are present simultaneously — mixed-age solenoids produce inconsistent hydraulic response
  •  High-demand: GM 6L80 solenoid set ($120–$240), Ford 6R80 solenoid kit ($140–$280), Toyota A340/A760 ($60–$180), Honda 5-speed ($80–$200)
5. TRANSMISSION CONTROL MODULE (TCM) & POWERTRAIN CONTROL MODULE (PCM)
OEM Used Price: $80–$420 | Symptoms: U0101 / Communication faults / Limp mode
The TCM is the electronic brain of the automatic transmission. TCM failure produces U0101 communication fault codes, unexplained limp mode activation, incorrect shift points, or complete inability to shift.
  •  TCM failure without accompanying mechanical symptoms is an important distinction — points to the TCM itself, not a solenoid or clutch pack
  •  OEM used TCMs must be programmed (flashed) to the vehicle's VIN on most modern platforms — always budget for VIN-flash time alongside the purchase
  •  On platforms where TCM is integrated into the valve body (VW DSG mechatronic, Ford 6F35), the complete valve body assembly must be sourced
  •  High-demand: Ford 6R80 TCM ($120–$280), GM 6L80 TCM ($140–$320), Honda CVT TCM ($100–$260), Chrysler 62TE / 845RE ($90–$240)
6. TRANSMISSION INPUT & OUTPUT SPEED SENSORS
OEM Used Price: $25–$80 per sensor | Symptoms: P0715 / P0720 / Erratic shifts
P0715 (Input/Turbine Speed Sensor) and P0720 (Output Speed Sensor) are among the most common transmission fault codes — and the repair is one of the most cost-effective available, since sensors are externally accessible on most platforms without transmission removal.
  •  OEM sensors use the correct reluctor wheel tooth count and sensor gap specification — aftermarket sensors with different specifications produce incorrect speed readings
  •  Always inspect the sensor wiring harness and connector for damage when replacing the sensor — a damaged connector produces the same fault codes
  •  High-frequency platforms: All GM, Ford, Toyota, Honda, and Chrysler automatic transmissions
7. CLUTCH ASSEMBLY — DISC, PRESSURE PLATE, RELEASE BEARING & FLYWHEEL (MANUAL)
OEM Used Price: $80–$380 (flywheel) / $120–$280 (clutch kit) | Symptoms: Slipping / Grinding / Difficulty engaging
Manual transmission clutch failures are the most straightforward transmission repair — identifiable by symptom without electronic diagnosis.
  •  Always replace clutch disc, pressure plate, and release bearing as a complete kit
  •  Always resurface or replace the flywheel — a scored or warped flywheel destroys a new clutch disc within 10,000–15,000 miles
  •  OEM used flywheels from low-mileage donors are the most cost-effective flywheel sourcing option
  •  Dual-mass flywheel (DMF) vehicles: DMF and conventional flywheel are not interchangeable — confirm before sourcing
  •  High-frequency platforms: Subaru WRX / STI, Honda Civic / Accord manual, VW Golf / GTI, Ford Focus ST / RS, Toyota Tacoma manual
8. TRANSMISSION COOLER & COOLER LINES
OEM Used Price: $40–$160 | Symptoms: Milky ATF / Overheat warning / Coolant in transmission
Milky or pinkish ATF is the most urgent transmission fluid symptom — the vehicle should not be driven until the cooler is replaced, the transmission fully flushed, and fluid completely replaced.
  •  After a cooler failure contamination event, always perform a complete transmission flush — not just a drain and fill
  •  OEM cooler lines use correct fitting specifications — aftermarket kits are prone to fitting leaks
  •  Replace cooler lines simultaneously when replacing a radiator on any vehicle with an integrated transmission cooler
9. USED OEM CVT TRANSMISSION — Nissan, Subaru, Honda
GreenGears Used Price: $520–$1,380 | Symptoms: Shudder / Whine / Hesitation / Complete failure
CVT failures are almost always complete unit failures — a used OEM CVT from a low-mileage donor is the most cost-effective repair option.
  •  Nissan Jatco CVT7 / CVT8 (Altima 2013–2021, Rogue 2014–2020, Sentra 2013–2019): Highest-demand used CVT; $640–$1,280; GreenGears Auto only lists Nissan CVT units from sub-70,000-mile donors
  •  Subaru TR580 / TR690 CVT (Outback 2018+, Forester 2019+, Crosstrek 2018+): $580–$1,100; EyeSight calibration required on equipped models
  •  Honda CVT (HR-V 2016+, CR-V 1.5T 2017–2022, Accord 2018+): $520–$980; confirm 2WD vs. AWD variant
  •  Toyota K120 CVT (Corolla 2019+, C-HR 2018+): $540–$1,020; significantly better reliability than Nissan equivalents
TRANSMISSION PARTS QUICK REFERENCE
Component                               | Symptom / Code              | Used Price    | Targeted Fix? | Fluid Flush?
Complete Transmission             | Multiple faults / debris        | $480–$2,200   | IS the unit       | Yes — always
Valve Body                                 | Harsh shifts / P07xx             | $120–$680     | Yes                   | Yes — always
Torque Converter                       | Shudder / P0740                 | $120–$480     | Yes                   | Yes — always
Shift Solenoids                           | P0750–P0770 / stuck gear  | $35–$160 ea  | Yes                   | Recommended
Transmission Control Module    | U0101 / limp mode            | $80–$420       | Yes                   | No
Speed Sensors (ISS/OSS)           | P0715 / P0720 / erratic       | $25–$80 ea    | Yes                   | No
Clutch Kit (Manual)                    | Slipping / difficulty             | $120–$280     | Yes                   | N/A
Flywheel (Manual)                      | Vibration / shudder           | $80–$380        | Yes                   | N/A
Transmission Cooler                   | Milky ATF / overheat         | $40–$160        | Yes                   | Yes — critical
CVT Assembly                            | Shudder / whine / failure   | $520–$1,380   | IS the unit       | Yes — always
DSG Mechatronic (VW/Audi)     | P17xx / harsh / no engage | $280–$680      | Yes                  | Recommended
ALWAYS DO THIS WHEN INSTALLING A USED TRANSMISSION
  •  Replace the torque converter front pump seal (input shaft seal) at installation — inaccessible once installed
  •  Replace the output shaft seal at installation — same reasoning; both seals are inexpensive
  •  Flush and fill with exact manufacturer-specified ATF — Toyota WS, Honda DW-1, Nissan NS-3, Ford Mercon LV, GM Dexron VI, Chrysler ATF+4 — never substitute generic ATF
  •  Replace the transmission pan gasket and fluid filter at installation — always service the filter with any removed transmission
  •  Inspect and test the transmission cooler before installing the replacement unit
  •  On CVT transmissions, fill to the exact specified fluid level — overfilling produces belt slip; underfilling causes overheating
  •  On DCT / DSG transmissions, perform the clutch adaptation procedure using a compatible scan tool after installation
  •  On vehicles where the TCM requires VIN programming, have the module flashed before the test drive
  •  Perform a complete road test including warm-up cycle, highway speed run, and multiple stop-and-go shift cycles before returning the vehicle
WHY GREENGEARS AUTO FOR TRANSMISSION PARTS?
  •  OEM-only inventory — no remanufactured or rebuilt units; every assembly is an original factory unit
  •  Fluid condition inspection — every transmission drained and assessed; no metal debris listings
  •  External seal and harness condition documented on every unit
  •  Full mileage documentation — donor vehicle mileage verified and recorded
  •  Known fault code history documented where available
  •  Application verification — engine-specific and torque-rating-specific variants confirmed before shipping
  •  Free shipping across the continental US — 3–7 day delivery on most orders
  •  15 to 90-day satisfaction guarantee on all transmission assemblies and components
  •  No core charge required — no upfront deposit, no return shipping on heavy transmissions
    • By bryanmuteppe
      Quality Used Engines, Gearboxes and Outboard Motors for Sale in South Africa
      WhatsApp +27 728134311 /
      link hidden, please login to view If you're looking for quality used engines, replacement gearboxes, or reliable outboard motors for sale in South Africa, finding a trusted supplier is essential. Whether you need a replacement vehicle engine, marine engine, or outboard motor for your boat, choosing the right supplier can save you time and money.
      L & L Engines & Spares supplies a wide range of used engines, gearboxes, marine engines, and outboard motors from leading brands. Our inventory includes vehicle engines and marine products suitable for private owners, workshops, commercial operators, and boating enthusiasts throughout South Africa.
      Outboard Motors for Sale South Africa
      We stock and source quality outboard motors from some of the world's leading marine manufacturers including:
      Yamaha Outboard Motors
      Mercury Outboard Motors
      Suzuki Outboard Motors
      Honda Outboard Motors
      Evinrude Outboard Motors
      Johnson Outboard Motors
      Tohatsu Outboard Motors
      Mariner Outboard Motors
      Whether you're searching for a 2-stroke or 4-stroke outboard motor, our team can assist with sourcing the right marine engine for your vessel.
      Why Choose Used Outboard Motors?
      Buying a quality used outboard motor offers several advantages:
      Lower cost than new motors
      Proven reliability
      Easy access to replacement parts
      Suitable for fishing boats and commercial vessels
      Tested and inspected units available
      Vehicle Engines and Gearboxes
      In addition to marine products, we supply replacement engines and gearboxes for:
      Toyota, Nissan, Ford, Isuzu, Mazda
      Honda, Hyundai, Kia
      Volkswagen, BMW, Mercedes-Benz
      Mitsubishi, Subaru, Lexus
      Renault, Opel, Fiat
      Our inventory includes petrol and diesel engines, manual gearboxes, automatic transmissions, and complete powertrain assemblies.
      Marine Engine and Outboard Motor Specialists
      We understand the importance of reliable marine power. That's why we focus on sourcing quality Yamaha, Mercury, Suzuki, Honda, Evinrude, and Johnson outboard motors that meet the needs of South African boat owners.
      Whether you're upgrading your boat, replacing a damaged motor, or searching for marine spares, we can help.
      Popular Searches
      Yamaha Outboard Motors for Sale
      Mercury Outboard Motors South Africa
      Suzuki Marine Engines
      Boat Engines for Sale
      Marine Engines South Africa
      Used Engines South Africa
      Replacement Gearboxes South Africa
      Engine and Gearbox Suppliers
      For quality used engines, gearboxes, marine engines, and outboard motors, contact L & L Engines & Spares today for expert assistance and nationwide delivery throughout South Africa. WhatsApp +27 728134311 /
    • By bryanmuteppe
      WhatsApp +27 728134311 / https://landlengineandspares.co.za/
      Proven reliability
      Honda, Hyundai, Kia
      Renault, Opel, Fiat
      Popular Searches
      For quality used engines, gearboxes, marine engines, and outboard motors, contact L & L Engines & Spares today for expert assistance and nationwide delivery throughout South Africa. WhatsApp +27 728134311 / https://landlengineandspares.co.za/
      Automotive Parts Associates (APA) is pleased to announce that Midwest Parts Hub, a division of Kelley Automotive Group based in Fort Wayne, Indiana, has joined the group as a shareholder.
      Founded in 1952 by Jim Kelley, Kelley Automotive Group is a family-owned dealership group representing multiple vehicle brands and serving customers throughout northeastern Indiana and beyond. Midwest Parts Hub opened in 2025 and services customers throughout the surrounding region through its extensive inventory of genuine General Motors OEM, ACDelco and aftermarket parts, along with daily delivery routes and advanced technology systems. The company emphasizes inventory availability, experienced staff, technology integration and reliable service as key drivers of its continued success.
      “In today’s market, if you want to stay competitive, you need to be part of a program group,” said Mike Smith, parts director for Kelley Automotive Group. “Operating completely on your own is no longer effective. After evaluating our options, we knew
      link hidden, please login to view was the right choice.” “We are excited to welcome Midwest Parts Hub to APA,” said Steve Tucker, president of APA/TruStar. “Their long-standing commitment to service, innovation, and operational excellence makes them a tremendous addition to our shareholder family.”
      For more information about Kelley Automotive Group, visit
