How to change the catalytic converter(shared by Shandong Xiaoyuan Environmental Protection Technology Co., Ltd, website:
I. Preparations Before Replacement 1. Safety Tools and Equipment: • Jack and support frame • Socket wrench, open-end wrench, universal joint • Non-slip gloves, safety goggles • WD-40 or other lubricant (to prevent bolts from rusting) • New catalytic converter (model matching original) 2. Vehicle Preparation: • Park on a level surface • Engage the handbrake • Ensure the engine is completely cooled (catalytic converter temperature is very high, easily causing burns) • Disconnect the negative terminal of the battery to prevent accidental triggering of the oxygen sensor alarm 3. Spare Parts: • New catalytic converter • New gasket • If damaged, the oxygen sensor (O2 sensor) may need to be replaced. ⸻II. Replacement Steps 1. Locate the Catalytic Converter • The catalytic converter is usually located after the exhaust manifold and before the muffler. • In diesel vehicles, it may be before the DOC and DPF. • Note the oxygen sensors before and after the catalytic converter; they need to be removed during replacement. 2. Remove the Oxygen Sensor • Use an O2 sensor socket or open-end wrench to unscrew it counterclockwise. • Be careful not to damage the sensor wiring harness.
3. Loosen the catalytic converter mounting bolts.
• The catalytic converter is usually fixed to the exhaust pipe with flange bolts.
• Spray lubricant on rusted bolts and wait 5–10 minutes.
• Use a socket wrench to loosen slowly, do not use excessive force to avoid breakage.
4. Remove the old catalytic converter.
• Remove it gently, being careful not to damage the exhaust pipe and suspension bracket.
• Check if the flange sealing surface is flat; repair any corrosion or deformation.
5. Install the new catalytic converter.
1. Install the new gasket (ensure alignment).
2. Install the new catalytic converter, first hand-tightening the mounting bolts to ensure correct positioning.
3. Then use a wrench to tighten evenly, avoiding overtightening to prevent flange deformation.
6. Reinstall the oxygen sensor.
• Use an O2 sensor socket wrench to screw it back on with moderate torque.
• Be careful not to twist the sensor wiring harness or allow it to come into contact with high-temperature components.
7. Check.
• Confirm that the catalytic converter is securely fixed and the oxygen sensor connection is normal.
• There are no obvious gaps in the exhaust pipe.
• Reconnect the battery negative terminal. ⸻III. Precautions 1. Avoid high-temperature operation: The catalytic converter's temperature can reach 400–600°C immediately after engine shutdown. 2. Ensure model compatibility: Different vehicle models have different catalytic converter apertures, lengths, and oxygen sensor interfaces. 3. Environmental requirements: Removed catalytic converters contain precious metals and should be recycled according to local regulations. 4. Engine fault codes (MIL): • After replacement, P0420 or similar codes may appear, requiring clearing the fault codes or waiting for self-learning. 5. Do not forcefully strike: The ceramic inside the old catalytic converter is fragile; avoid allowing fragments to enter the exhaust pipe. 6. Torque requirements: • Flange bolts are generally recommended at 20–40 Nm (depending on the vehicle model). • Oxygen sensor torque is generally 30–40 Nm. ⸻
Tips: • If the catalytic converter is only partially blocked, you can try cleaning or high-temperature regeneration first, but severe blockage still requires replacement. • For diesel vehicles, note that the catalytic converter after the DPF (DOC) and the oxidation catalytic converter are usually replaced or inspected together to ensure regeneration efficiency.
    • By Autoservice Paulus GmbH
      With changing seasons, I was wondering if you adjust anything in your car maintenance routine?
      For example, things like tire checks, AC usage, battery care, etc.
      Do you follow any seasonal habits or just drive as usual?
      ZF Aftermarket announced new additions to its oil change kit range. These additions cover combustion engine, electric and hybrid applications.
      The company said it offers transmission oil in model specific kits that contain the precisely measured amount of oil and the necessary spare parts for the oil change. Workshops that already stock the appropriate oil can also purchase the kits in a version without oil, containing only the required spare parts. In addition, the company provides repair manuals and training courses designed to help independent workshops build transmission expertise.
      The range of oil change kits not only covers ZF’s own transmissions, such as the widely used 8HP, but increasingly those of other manufacturers. The ZF Aftermarket portfolio also includes kits for OEM applications involving automatic, dual clutch and CVT transmissions.
      Hybrids and battery electric vehicles
      It is not only conventional vehicle transmissions that benefit from an oil change. The drives in hybrid vehicles also require regular maintenance. These transmissions, with their integrated electric motors, place unique demands on transmission oil.
      link hidden, please login to view said it provides suitable products for these applications, including ZF Lifeguard Hybrid Fluids. An oil change in the drive system is also recommended for battery electric vehicles. Although these vehicles do not have conventional gearsets, they use a reduction gear in the electric axle. The components in this unit are subjected to high loads due to the rapid torque build up of the electric motor. ZF supplies oil change kits for the electric axles of various electric vehicles. More details and specifications on available kits can be found at aftermarket.zf.com/catalog.
      Regular oil changes for maximum uptime
      link hidden, please login to viewsaid transmission oil should be changed, particularly under operating conditions involving high temperatures and loads or when a vehicle’s service history is unknown. In all cases, the manufacturer’s specifications should be followed. Regular oil changes can help extend the service life of the transmission, one of the most complex and costly components in a vehicle. Avoiding premature wear can reduce the risk of expensive repairs and extended downtime. The approach aligns with ZF’s “Maintain, Repair, Replace” strategy, a service concept focused on extending component life and supporting maximum uptime for customers.
      How To Change Rear Shocks on a 2011-2015 Chevy Cruze
    • By abiztime
      Working principle and application of VOC: Volatile Organic Compounds(shared by Shandong Xiaoyuan Environmental Protection Technology Co., Ltd, website:
      link hidden, please login to view)
      I. Concept of VOCs VOCs (Volatile Organic Compounds) • Environmental Impacts: • Atmospheric photochemical reactions generate ozone and secondary particulate matter • Nerve damage, long-term exposure can cause cancer ⸻ II. Working Principle of VOC Ceramic Catalysts 1. Oxidation and decomposition of VOC gases into harmless substances: • CO₂ (carbon dioxide) • H₂O (water) • Core reaction: Oxidation reaction (usually between 250–450°C) VOC + O₂ → CO₂ + H₂O 2. Catalyst Composition 1. Support Material • Commonly used ceramic honeycomb support (cordierite or alumina ceramic) • Characteristics: • High specific surface area (beneficial for catalyst dispersion) • High thermal stability • Corrosion resistance 2. Coating/Active Components • Noble metal catalysts: • Mainly platinum (Pt) and palladium (Pd) • Pt, Pd, or a Pt/Pd combination can be selected according to the type of VOC. • Non-precious metal catalysts: • Active oxides, such as MnO₂, Co₃O₄, CuO • Functions: • Provides oxidation active sites, accelerating VOC decomposition • Reduces reaction temperature, improving conversion efficiency 3. Working Mechanism
      • Adsorption-Reaction-Desorption Mechanism: 1. VOC molecules are adsorbed on the catalyst surface. 2. Under the action of precious metals or active oxides, they undergo oxidation reactions with oxygen. 3. CO₂ and H₂O are desorbed from the catalyst surface. • Role of promoters/supports: • Ceramic provides high surface area and thermally stable structure. • Modifiable oxides (CeO₂, ZrO₂) can store oxygen, improving low-temperature oxidation capacity. ⸻III. Applications of VOC Ceramic Catalysts 1. Automobile exhaust treatment • 2. Industrial waste gas treatment • 3. 4. Chemical process exhaust gas • ⸻IV. VOC VOC conversion rate can reach over 90% High temperature resistance 600–800°C Low pressure drop honeycomb structure reduces exhaust gas drag and provides long lifespan. The noble metal catalyst is bonded to a stable support with a lifespan of 5–10 years. Customization is available, adjusting the Pt/Pd ratio or using non-noble metal formulations based on VOC type.
