Ride control is a broad term. It refers to anything that controls and affects the operation and reaction of the suspension to road conditions, including the springs, shocks and struts. For many years, changing the ride control aspects of a vehicle meant at minimum, physically changing the shock absorbers with units that had different internal valving.
This altered suspension performance to match what the vehicle owner was after, which was typically a modification to match the suspension with the use of the vehicle, for example off-road or racing. The biggest problem is you were stuck with the characteristics you ended up with until you switched back to the original components.
Then, in the 1990s, adjustable valve shocks and struts became popular. These systems had two or three comfort and sport settings that could be changed with buttons on the dash. These systems played the role of firming up the suspension if the driver wanted a sporty feel while driving.
But technology never slows down, and for years now, many auto manufacturers have been utilizing continuously variable dampening systems, referred to as continuous damping control (CDC) in their vehicles. There are many different names for this type of suspension depending on the vehicle manufacturer, but it’s often generalized as active suspension or active ride control.
These systems have evolved to the point where they utilize electronically controlled valving to actively change dampening characteristics in milliseconds to control the compression and rebound of a shock absorber or strut.
By utilizing this high level of control, there are many benefits over a traditional system including enhanced driving comfort, improved handling and cornering, precise tracking during acceleration and shorter braking distances, all of which adds up to improved safety.
To give you an example of just how precise these systems can be, they can increase rebound when a pothole is detected by either the suspension displacement sensors or a camera. This prevents the wheel from dropping down in the pothole and hitting the backside of the hole. For braking, a CDC dampener can increase compression in the front and increase rebound in the rear to prevent nosedive.
On old, electronically adjustable systems, there was typically a small stepper motor on top or on the side of the shock or strut that changed the size of the orifices in the piston or at the base. The compression and rebound were not independently adjustable.
Today, most new systems use coils and/or magnets to adjust rebound and compression in real time, which are sometimes called actuators or pulse motors. Most active ride control systems have their own module that might also control the air ride system, and most control each of the four dampening units individually. They need information to work like vehicle speed, steering angle and readings from the yaw and accelerometers, and they are often part of the stability control system.
When technicians are faced with diagnosing system problems, they have to look at the entire system, not just the dampeners, and scan tools are necessary for communication. While these types of shock absorbers and struts can leak like traditional units have in the past, diagnosing them requires specific knowledge and procedures related to the system being worked on.
For many years, a static test was an acceptable way to check shock absorbers. Performing one was as simple as bouncing the suspension and watching to see if the vehicle returned to ride height without any continued motion. This type of test isn’t valid on a vehicle with active suspension since the variable valving on these dampers is dependent on speed and vehicle dynamics. It’s best to follow manufacturer information and procedures to assess system condition.
One thing that hasn’t changed is shock or strut replacement. The process is virtually unchanged with the exception of disconnecting a wiring harness connector, and the age old rule still applies: replace these shocks or struts in pairs.
    • By elizabeth
      Restore your sedan's performance with our reliable used auto parts at competitive prices. Our 2004 Nissan Altima Transmission is fully inspected and tested to ensure dependable operation and smooth gear transitions. Sourced from low-mileage donor vehicles, each unit is carefully verified to match OEM specifications for your Altima. Whether you're dealing with slipping gears or a complete transmission failure, we have the right solution for your repair needs. Fast shipping is available across the country, and every purchase is covered by our warranty policy. Save big compared to new parts — order your 2004 Nissan Altima transmission now and get back on the road.
    • By elizabeth
      Looking for a reliable Cadillac Engine for Sale? You've come to the right place! Whether you drive a Cadillac Escalade, CTS, ATS, SRX, or any other model in the lineup, we have the perfect engine match waiting for you. Nothing matters more than finding the right engine — one that delivers the smooth, powerful performance this legendary brand is known for.
      Every engine in our inventory is thoroughly inspected, tested, and verified to meet strict quality standards. We carry a wide selection of OEM-grade and remanufactured engines designed for direct fitment, so installation is seamless and stress-free. With low mileage options available, you can trust you're getting reliable power that will last for miles to come.
      Ordering is simple, shipping is fast, and our knowledgeable support team is ready to help you find the exact engine your Cadillac needs. No long waits, no guesswork — just the right part at the right price, delivered straight to your door.
      Don't let a failed engine keep your Cadillac off the road any longer than it has to.
      🔧 Shop Turbo Auto Parts today — your trusted source for premium engines, fast shipping, and guaranteed satisfaction!
      link hidden, please login to view visit site for more details
