The water pump market is evolving fast, with millions of vehicles relying on mechanical or electric water pumps to stay cool and perform at their best.
Mechanical water pumps still dominate most vehicles. However, as OEMs continue to incorporate start/stop systems, hybrids, and electric drivetrains, electric water pumps (EWPs) have gained ground and present real service opportunities for the aftermarket.
When looking for a quality supplier, verify that the pump is thoroughly tested. Also confirm the pump meets OE fit, form and function. Choose suppliers that work with OEMs.
Finally, ensure high-quality materials are used since water pumps face corrosive environments. You want a pump that will last.
Electric Water Pumps for Modern Cooling Systems
offers a full line of
for millions of vehicles, all backed by industry-best warranties. Repair shops can have confidence in what they install.
Dayco’s electric pumps are direct-fit, bolt-on replacements, so no modifications are needed during installation. They feature self-lubricating, corrosion-resistant bearings compatible with all engine coolants and tapered motor brushes for faster break-in. They also use high-strength seals to prevent leaks.
Installation Best Practices for Electric Pumps
Now let’s talk through four installation best practices, as some common mistakes can happen during EWP replacement.
First, remind your shop customers to flush the system completely to remove any residual contamination. Use a 50/50 mix of the correct coolant and distilled water.
Second, remind customers that reusing old seals or gaskets can cause leaks. Offer to add new gaskets and seals when doing a water pump replacement.
Third, ask the shop if they need a belt, tensioner and pulley when replacing the pump. A systems approach is best since components perform better when replaced together.
Fourth, tell shops that voltage checks are critical when installing electric pumps. Check voltage and grounding before and after. Low voltage can quickly destroy a new pump.
Ongoing Training and Technical Support
Visit Dayco’s
for expert videos and insights from ASE-certified techs and product specialists.
This video is sponsored by Dayco.
      Hey everyone,
      With the summer heat hitting hard, I've seen way too many driversβ€”both everyday commuters and even some DIYersβ€”making the exact same mistakes under the hood that end up completely wrecking their air conditioning systems.
      If you want to keep your ride icy cold and stop burning extra fuel this summer, check out the full guide here: πŸ‘‰Β
    • By elizabeth
      The Volvo C30 Transmission delivers a balance of performance and efficiency in a compact luxury vehicle. Known for smooth gear shifts and responsive handling, it enhances the driving experience. Both manual and automatic versions are designed with precision engineering. Routine maintenance like fluid replacement ensures optimal performance. Many drivers choose used transmissions for affordability while maintaining quality. If you notice unusual noises or shifting issues, early diagnosis helps avoid costly repairs. It’s a reliable system built for comfort and performance.
      Compatibility
    • By GreenGears Auto Limited
      Published by GreenGears Auto Β |Β  10 minute read Β |Β  AWD Repair & OEM Used Parts Guide
      AWD system problems β€” from a flashing AWD warning light and loss of all-wheel drive traction to grinding noises, binding in turns, and drivetrain shudder β€” are among the most intimidating and expensive repairs a vehicle owner can face. Dealer quotes for new OEM AWD components regularly run $800–$4,000+ depending on the platform. But the used OEM AWD parts market tells a very different story. At GreenGears Auto, we stock quality-inspected, mileage-verified OEM used AWD system parts across every major make β€” sourced from low-mileage donor vehicles at 50–70% less than new OEM pricing. This guide covers the best used OEM replacement parts for every common AWD system problem, platform by platform. used AWD parts AWD system repair OEM AWD transfer case used rear differential AWD AWD front differential power transfer unit replacement AWD coupling unit all-wheel drive repair parts OEM used drivetrain GreenGears Auto Β  Β
      What Causes AWD System Problems?
      All-wheel drive systems are significantly more complex than two-wheel drive drivetrains β€” and that complexity creates more potential failure points. Understanding the root cause of your specific AWD system problem determines which used OEM part you actually need. Ordering the wrong component is the most expensive mistake in AWD repair.
      #1 Fluid neglect β€” leading cause of AWD transfer case and rear differential failure across all platforms $800–$4,000+ Typical new OEM AWD component cost at the dealer β€” the price range that makes used OEM the smart choice 50–70% Average savings on OEM used AWD parts vs. new OEM pricing across all platforms at GreenGears Auto Β  The most common AWD system problems fall into five categories: transfer case failure (whining, grinding, loss of 4WD or AWD engagement), rear differential failure (whining, clunking, fluid leaks), front differential or PTU failure (common on Ford, VW, and GM crossovers), AWD coupling/clutch pack failure (shudder in turns, AWD dropout), and driveshaft and CV axle failure (vibration, clicking in turns). Each requires a different used OEM part β€” and each has a distinct symptom fingerprint that makes pre-purchase diagnosis straightforward.
      Β
      πŸ”§ GreenGears Tip β€” AWD Problem Diagnosis Before Ordering Before purchasing any used AWD system part, pull the fault codes from your vehicle. AWD-related codes (P0218, P1889, C1234, U0121, and platform-specific codes) narrow the diagnosis immediately and prevent ordering the wrong component. GreenGears Auto's parts specialists can cross-reference fault codes with specific AWD components for any make or model. Β  Β
      Types of AWD Systems β€” and Why the Difference Matters for Parts
      AWD system architecture varies dramatically across makes and platforms. The specific used OEM parts required depend entirely on which AWD system your vehicle uses β€” they are not interchangeable across designs.
      πŸ”„ Full-Time AWD (Active Centre Differential) Used on Subaru Symmetrical AWD, Toyota Land Cruiser, and Audi Quattro (longitudinal). A centre differential continuously manages front-to-rear torque split. Failure typically requires centre differential or transfer case replacement.
      ⚑On-Demand / Reactive AWD Used on Toyota RAV4, Honda CR-V, Ford Escape, and Chevrolet Equinox. The secondary axle engages only when wheel slip is detected via a rear drive unit (RDU), power transfer unit (PTU), or AWD coupling. These units are the most commonly replaced AWD components across the used OEM market.
      🧠Electronic / Torque Vectoring AWD Used on BMW xDrive, Mercedes 4MATIC, Acura SH-AWD, and VW 4Motion. Electronically managed clutch packs distribute torque actively front-to-rear and sometimes left-to-right. OEM-only replacement is critical β€” aftermarket units trigger fault codes and compromise stability control integration.
      πŸ”©Part-Time 4WD (Body-on-Frame SUVs) Used on Toyota 4Runner, Chevrolet Tahoe, Ford Expedition, and Jeep Grand Cherokee. Driver-selectable 2H/4H/4L via a transfer case. Mechanically simpler than full-time AWD systems but requires exact OEM match for gear ratio, electronic shift type, and torque rating.
      Β
      Β
      AWD System Warning Signs β€” Matched to Failed Components
      Every AWD system problem produces a recognisable pattern of symptoms. Matching your symptoms to the component below before ordering is the single most important step in the repair process.
      ⚑ Warning Lights & Fault Codes
      AWD / 4WD warning light β†’ Transfer case or AWD coupling failure Service AWD system message β†’ Electronic actuator or solenoid failure Traction / stability control faults alongside AWD codes β†’ Wheel speed sensor or hub bearing ABS fault + AWD dropout β†’ Hub bearing with integrated ABS tone ring Check engine + AWD codes β†’ PTU or rear drive unit electronic failure πŸ”Š Grinding & Whining Noises
      Whine in 4WD / AWD that goes away in 2WD β†’ Transfer case internal wear Grinding from rear under AWD load β†’ Rear differential bearing failure Whining from front axle area β†’ PTU or front differential bearing Chain rattle at startup β†’ Transfer case chain wear Growl from centre tunnel β†’ Driveshaft centre bearing worn πŸ”© Binding & Vibration
      Binding / tight steering in 4WD on dry pavement β†’ Transfer case stuck in 4H Shudder on tight low-speed turns β†’ AWD clutch pack worn or wrong fluid Vibration at highway speed β†’ Driveshaft imbalance or worn U-joints Clicking when turning β†’ CV axle failure (inner or outer) Drivetrain shudder under acceleration β†’ Rear differential or coupling failure πŸ’§ Leaks & Fluid Problems
      Fluid under the centre of the vehicle β†’ Transfer case seal failure Fluid at rear axle ends β†’ Rear differential axle seals Fluid at front axle area on crossover β†’ PTU seal failure (very common on Ford) Burnt-smelling gear oil β†’ Internal AWD component overheating Milky gear oil β†’ Water contamination through a failed seal Β
      Β
      Best Used OEM Parts for AWD System Problems β€” By Component
      Here is every major AWD system component, the specific problems it causes when it fails, the best used OEM sourcing strategy for each platform, and the price range you should expect to pay at GreenGears Auto.
      πŸ† Highest Demand AWD Part All Platforms Used OEM Transfer Case Assembly β€” AWD & 4WD
      GreenGears Used Price: $240–$1,100 The transfer case is the central component of every AWD and 4WD system β€” it splits engine torque between the front and rear axles and manages engagement timing across all drive modes. A failing AWD transfer case is the most commonly searched used OEM AWD part in the entire market, and GreenGears Auto stocks inspected used transfer cases across every major platform. Transfer case problems include grinding or whining in AWD mode, inability to engage or disengage 4WD, AWD warning lights, and drivetrain binding.
      Best used OEM transfer case units by platform:
      Toyota RAV4 AWD transfer case (2013–2022): Active Torque Control (ATC) unit β€” most available and most affordable used AWD transfer case in the market; $240–$480; outstanding reliability track record Toyota 4Runner 4WD transfer case (2003–present): 2-speed electronic shift unit β€” among the most reliable 4WD transfer cases ever produced; $320–$620; sourced from accident-damaged low-mileage donors Ford F-150 AWD transfer case / BorgWarner 44-06 (2015–2020): Most available used transfer case for full-size trucks; $420–$750; encoder motor is separately replaceable β€” confirm before ordering complete assembly Chevrolet Tahoe / Suburban NP246 / NP263 transfer case: Heavy-duty BorgWarner chain-driven unit; $380–$720; NP263 preferred for towing applications; confirm generation before ordering Subaru Outback / Forester AWD centre differential: Viscous LSD centre differential β€” mechanically simple, no electronics; $240–$540; all four tires must match within 1/4 inch before installation BMW X3 / X5 xDrive ATC transfer case: Electronically controlled BorgWarner ATC unit; $420–$950; requires BMW ISTA+ coding after installation β€” factor diagnostic time into total repair cost Jeep Grand Cherokee Quadra-Trac II / Selec-Trac transfer case: Full-time AWD unit; $340–$760; confirm exact trim β€” Selec-Trac, Quadra-Trac II, and Quadra-Drive II are not interchangeable πŸ”§ Used AWD Transfer Case Inspection Checklist Before any used transfer case purchase: drain and inspect fluid (amber = good, metallic/milky = reject), rotate input flange for smooth resistance, inspect housing for cracks, verify shift motor and electronic connectors intact, confirm exact gear ratio and trim-specific part number via donor VIN. Β
      ⭐ Second Highest AWD Demand All Platforms
      Used OEM Rear Differential Assembly β€” AWD & 4WD
      GreenGears Used Price: $180–$900 The rear differential in an AWD or 4WD vehicle receives torque from the transfer case and distributes it to the rear wheels β€” allowing left and right rear wheels to rotate at different speeds in corners while maintaining traction under load. AWD rear differential problems include whining under load, clunking during acceleration, fluid leaks from the pinion seal or axle seals, and vibration. On AWD vehicles, a failed rear differential disables the AWD system entirely on reactive-AWD platforms where rear-wheel power is the engaged drive system.
      Best used OEM rear differential units by platform:
      Ford Explorer AWD 8.8-inch rear differential: One of the best-engineered OEM rear differentials ever produced; $220–$480; outstanding used availability from high-volume Explorer sales Toyota 4Runner / Tacoma / Tundra rear differential: Toyota's conservative over-engineering produces used units with exceptional remaining service life; $280–$620; Torsen LSD option available on many trims Chevrolet Tahoe / Silverado 8.6-inch / 14-bolt rear differential: Heavy-duty unit built well above typical SUV demands; $280–$680; 14-bolt units particularly sought-after for load capacity Honda CR-V / Accord AWD rear differential: Most affordable used OEM rear differential in the market; $180–$380; extremely high availability from Honda's large US sales volume Jeep Grand Cherokee Dana 44 rear differential: Preferred over Dana 35 for load capacity; $220–$520; Trac-Lok LSD available on many WK2 trims Subaru Outback / Forester AWD rear differential: Compact, reliable, and well-priced; $200–$440; viscous LSD design requires all-matching tires at installation BMW X5 / X3 xDrive rear differential: Electronic active rear differential with torque vectoring on M Sport trims; $380–$850; coding required on electronically controlled variants Β
      πŸ”© Most Common Crossover AWD Failure Ford / GM / VW / Audi
      Used OEM Power Transfer Unit (PTU) & Front Differential
      GreenGears Used Price: $180–$680 The Power Transfer Unit (PTU) β€” also called the front differential or AWD transfer unit on transverse-engine crossover SUVs β€” is mounted to the front transaxle and drives the rear axle via a prop shaft. PTU failure is the most common AWD drivetrain failure on Ford crossovers (Escape, Edge, Explorer) and is also prevalent on GM (Equinox, Terrain) and VW/Audi (Tiguan, Q5) AWD platforms. PTU problems manifest as fluid leaks from the front axle area, whining from the front drivetrain, loss of AWD engagement, and AWD fault codes.
      Ford Escape AWD PTU (2013–2019): The single most commonly replaced AWD drivetrain component on this platform; $180–$340; seal failure is the primary cause β€” always install a new PTU seal kit alongside any used unit Ford Edge AWD PTU (2011–2018): Larger unit than the Escape; $220–$400; 2015–2018 units best availability and pricing Ford Explorer AWD PTU (2011–2019): Higher torque-rated unit; $260–$460; sourcing from towing-spec Explorer donors provides confidence in load capacity Chevrolet Equinox / GMC Terrain AWD transfer case (2010–2017): BorgWarner electronically controlled unit; $220–$460; shares architecture across Equinox, Terrain, and Captiva VW Tiguan 4Motion Haldex coupling (2009–2017): Rear Haldex coupling unit β€” the reactive AWD component on Tiguan; $260–$520; cross-reference with Audi Q3 for expanded sourcing Audi Q5 Haldex coupling (B8, 2009–2017): Most commonly replaced AWD component on the B8 Q5; $300–$560; Haldex Gen 4/5 units require fluid and filter service at installation ⚠️ Ford PTU Seal Failure β€” Critical Installation Note The Ford AWD PTU's most common failure mode is seal failure leading to fluid loss and internal damage. Always install a complete PTU seal kit ($40–$80) and replace the vent tube alongside any used Ford PTU β€” a blocked vent causes internal pressure buildup that destroys output seals within 20,000–40,000 miles. Β
      ⚑ Reactive AWD Specialist Toyota / Honda / Nissan / Volvo
      Used OEM AWD Coupling Unit & Rear Drive Unit (RDU)
      GreenGears Used Price: $180–$560 The AWD coupling unit β€” called the Rear Drive Unit (RDU), rear coupling, or rear axle assembly on reactive AWD crossovers β€” is the electronically controlled clutch pack or viscous coupling that connects the rear axle to the drivetrain only when front-wheel slip is detected. This is the component that defines the "AWD" experience on most modern crossover SUVs. When the AWD coupling fails, the vehicle effectively becomes front-wheel drive β€” losing traction capability in wet, snowy, or slippery conditions. Symptoms include AWD warning lights, shudder during turns, AWD dropout under load, and fault codes specific to the rear drive unit.
      Toyota RAV4 AWD rear coupling / RDU (2013–2022): Active Torque Control rear drive unit β€” most affordable and most available AWD coupling in the used market; $180–$340; exceptional reliability record across millions of RAV4 AWD vehicles Honda CR-V AWD rear drive unit (2012–2022): Honda's Dual Pump System (DPS) RDU β€” mechanically simple, highly reliable, and among the most affordable used AWD coupling units available; $160–$300 Honda Pilot AWD i-VTM4 rear unit (2016–present): More sophisticated than the CR-V unit; electronically controlled multi-plate clutch; $280–$480; sourcing from accident-damaged low-mileage donors is the best strategy Nissan Armada / Pathfinder AWD rear coupling: ATTESA E-TS rear torque transfer unit; $260–$520; cross-reference with Titan pickup components for expanded sourcing Volvo XC60 / XC90 AWD Haldex rear coupling (2007–2017): Haldex Gen 4 electronically controlled rear coupling; $280–$500; Haldex fluid and filter service required at installation Acura MDX / RDX SH-AWD rear unit: Honda's Super Handling AWD torque-vectoring rear unit; $320–$560; OEM-only replacement β€” aftermarket SH-AWD units do not exist in meaningful supply Β
      πŸ”— Most Frequent AWD Noise Source All AWD Platforms
      Used OEM CV Axle Shafts & Driveshafts β€” AWD
      GreenGears Used Price: $80–$320 per shaft CV axle failure on AWD vehicles is one of the most common drivetrain noise complaints β€” producing the distinctive clicking sound during turns that is the hallmark of a worn outer CV joint. On AWD platforms, CV axle failure is more complicated than on front-wheel-drive cars because the front axle shafts must accommodate both steering angle and AWD torque loads simultaneously, and the rear axle shafts on AWD crossovers see torque that a 2WD rear axle never experiences. Driveshaft problems β€” vibration at highway speed, clunking during acceleration, and humming from the centre bearing β€” are also common AWD-specific failures.
      Front CV axle shafts (AWD crossovers): Toyota RAV4, Honda CR-V, Ford Escape, Chevrolet Equinox β€” $80–$180 per shaft; FWD and AWD variants use different shafts β€” always confirm drivetrain before ordering Rear CV axle shafts (AWD crossovers): Toyota RAV4 AWD rear axle, Honda CR-V AWD rear axle β€” $90–$200 per shaft; rear axle shafts on reactive AWD crossovers are unique to the AWD variant Front driveshaft / prop shaft (4WD trucks and SUVs): Toyota 4Runner, Chevrolet Tahoe, Ford Expedition β€” $120–$280; U-joint condition is the primary inspection criterion on used driveshafts Rear driveshaft / prop shaft (AWD crossovers): Connects the front-mounted PTU to the rear differential; Ford Escape, Edge, Explorer AWD β€” $100–$240; centre bearing condition is the primary wear point Transfer case output shaft / companion flange: Common wear point on high-mileage 4WD trucks; $40–$120; always replace the output seal alongside a companion flange replacement πŸ”§ CV Axle OEM vs. Aftermarket on AWD Vehicles On AWD vehicles, CV axle joint angle, boot capacity, and shaft material specification are precisely matched to the vehicle's AWD torque output and geometry. Aftermarket CV axles for AWD applications have a significantly higher comeback rate than OEM used shafts β€” vibration, noise, and premature boot failure are common within 30,000 miles on budget aftermarket units. Β
      🎡 Most Misdiagnosed AWD Problem All AWD Platforms
      Used OEM Wheel Hub & Bearing Assemblies β€” AWD
      GreenGears Used Price: $80–$220 per hub Wheel hub bearing failure on AWD vehicles is routinely misdiagnosed as a differential or transfer case problem because the humming and droning it produces mimics AWD drivetrain noise precisely. On AWD platforms specifically, the wheel speed sensors integrated into the hub assembly communicate directly with the AWD control module β€” a failing hub bearing with a deteriorating ABS tone ring produces AWD fault codes and AWD system warnings that appear to indicate a transfer case or differential problem. The vehicle effectively shuts down AWD function in response to the incorrect wheel speed signal, presenting as an AWD system failure when the actual cause is a $90–$220 hub bearing.
      AWD wheel hub bearing failure is one of the most common causes of a falsely triggered AWD warning light β€” always inspect and test hub bearings before ordering AWD drivetrain components Front wheel hub bearings (AWD crossovers): Toyota RAV4 (front), Honda CR-V (front), Ford Escape (front and rear), Chevrolet Equinox (front) β€” $80–$180; front hubs on AWD crossovers see higher loads than 2WD equivalents due to combined steering and AWD torque Rear wheel hub bearings (AWD crossovers): Subaru Outback / Forester (rear β€” highest failure frequency on this platform), Ford Escape (rear), Chevrolet Equinox (rear) β€” $90–$200; rear hub bearing failure on AWD crossovers is far more common than on 2WD equivalents OEM hub assemblies are non-negotiable for AWD vehicles β€” the ABS tone ring pitch and sensor air gap are calibrated to the AWD control module; aftermarket hubs trigger AWD and ABS fault codes simultaneously Always replace in axle pairs β€” if one hub bearing has failed at 90,000 miles, the opposite hub is within 10,000–20,000 miles of the same failure Β
      πŸ”Œ Modern AWD Efficiency Component Ford / Toyota / RAM / GM
      Used OEM Front Axle Disconnect & Actuator
      GreenGears Used Price: $80–$280 Modern fuel-efficient AWD and 4WD systems use a front axle disconnect system β€” a vacuum or electrically actuated mechanism that physically disconnects the front axle shafts from the differential when 4WD is not engaged, eliminating parasitic drag and improving fuel economy in 2WD operation. When the front axle disconnect actuator fails, the vehicle may be unable to engage 4WD at all, may become stuck in 4WD, or may display Service 4WD warnings even when the transfer case and differential are both functioning correctly. This is one of the most frequently overlooked AWD-related parts in the used market.
      Ford F-150 front axle disconnect actuator (2004–present): Vacuum-operated or electric actuator β€” the most common standalone 4WD engagement failure on F-150; $80–$180; confirm vacuum vs. electric design for your specific year before ordering Toyota RAV4 front axle disconnect (2019–present Dynamic Torque Control): Electric disconnect mechanism unique to the 5th gen DTC-AWD system; $100–$240; required for proper DTC-AWD disconnection during highway driving Ram 1500 front axle disconnect (2013–present): Electric CAD (Coil Actuated Disconnect) unit; $90–$200; failure causes inability to engage 4H and 4L despite a functioning transfer case GM Silverado / Sierra IFS disconnect (2007–present): Electric shift-on-the-fly (ESOF) front axle actuator; $80–$200; sourcing from low-mileage crash donors is the best strategy for quality units Β
      Β
      Used OEM AWD Parts vs. New OEM vs. Aftermarket
      The case for OEM used AWD parts is stronger than for almost any other vehicle system. AWD components are deeply integrated with electronic systems β€” traction control, stability control, ABS, and increasingly ADAS β€” making exact OEM specification non-negotiable in a way that a simple suspension bushing is not.
      🏭 New OEM / Aftermarket
      New OEM cost: $800–$4,500 β€” pricing that makes many AWD repairs economically unviable on older vehicles Aftermarket AWD units frequently trigger fault codes due to solenoid and sensor specification differences Aftermarket electronic AWD components are not calibrated to the vehicle's specific AWD control module Remanufactured units reuse worn electronic components β€” solenoids, encoders, and sensors from the original core Core charge on reman units adds $200–$600 in upfront costs plus return shipping hassle on heavy components ♻️ OEM Used β€” GreenGears Auto
      Used OEM cost: $160–$1,100 β€” 50–70% savings across all AWD platforms Original factory electronic components β€” correct calibration for your vehicle's AWD control module Mileage-verified from documented low-mileage donor vehicles Fluid condition, housing integrity, and electronic component status inspected before listing Free US shipping in 3–7 days β€” no core charge, no return shipping required 15 to 90-day satisfaction guarantee on every AWD component Β
      Β
      AWD System Parts Quick Reference β€” By Platform
      Vehicle & Platform Most Common AWD Failure Used OEM Part GreenGears Price Availability Toyota RAV4 AWD (2013–2022) AWD coupling / ATC failure ATC transfer case / RDU $180–$480 ⭐⭐⭐⭐⭐ Honda CR-V AWD (2012–2022) Rear drive unit dropout RDU / rear coupling $160–$320 ⭐⭐⭐⭐⭐ Ford Escape AWD (2013–2019) PTU seal failure / fluid loss PTU assembly $180–$340 ⭐⭐⭐⭐⭐ Ford Explorer AWD (2011–2019) PTU / rear differential failure PTU or 8.8" rear diff $220–$480 ⭐⭐⭐⭐⭐ Chevrolet Equinox AWD (2010–2017) Transfer case / coupling failure BorgWarner transfer case $220–$460 ⭐⭐⭐⭐⭐ Subaru Outback AWD (2010–2019) Centre differential / rear hub Centre diff / rear hub $200–$540 ⭐⭐⭐⭐⭐ Jeep Grand Cherokee AWD (2011+) Quadra-Trac / Quadra-Drive failure Transfer case assembly $340–$760 ⭐⭐⭐⭐⭐ BMW X3 / X5 xDrive ATC transfer case / rear diff ATC unit / active rear diff $420–$1,100 ⭐⭐⭐⭐ Audi Q5 Quattro (B8, 2009–2017) Haldex rear coupling failure Haldex coupling assembly $300–$560 ⭐⭐⭐⭐ Acura MDX SH-AWD SH-AWD rear unit failure SH-AWD rear assembly $320–$580 ⭐⭐⭐⭐ Β
      Β
      Β
      How to Inspect a Used OEM AWD Part Before Buying
      Pull Fault Codes First β€” Always AWD-specific fault codes from your vehicle's OBD-II system are the most reliable pre-purchase guide. They tell you which AWD component the control module has flagged β€” transfer case, rear differential, coupling unit, or wheel speed sensor β€” before you spend a dollar on parts. GreenGears Auto's specialists can cross-reference fault codes with specific used AWD components for your platform. Β
      Inspect Fluid Condition on Every Unit Drain and inspect the fluid on any used transfer case, differential, or coupling unit before purchase. Clean amber fluid with no metallic particles confirms a healthy internal condition. Dark, burnt, metallic, or milky fluid disqualifies the unit regardless of the asking price or stated mileage. GreenGears Auto drains and inspects fluid on every AWD component before listing. Β
      Verify Donor Vehicle Mileage and History Both mileage and use context matter for AWD components. A transfer case from a 55,000-mile highway crossover is a fundamentally different purchase from one pulled off an 80,000-mile off-road-driven or towing-heavy platform. Always request and verify documented donor vehicle mileage β€” GreenGears Auto records this on every listing. Β
      Check Electronic Components Separately For all electronically controlled AWD units (BorgWarner ATC, BMW xDrive, Ford PTU, Honda RDU, Haldex coupling), inspect the solenoid connectors, wiring harness stub, and any integrated sensors for corrosion, physical damage, and broken connector pins. Mechanical condition and electronic condition are independent β€” confirm both before committing to a purchase. Β
      Confirm Exact Application via VIN AWD components vary by engine, transmission, trim level, and model year within the same nameplate. A 2015 Ford Escape with a 2.0L EcoBoost uses a different PTU than a 2015 Escape with a 1.6L EcoBoost. A Honda Pilot AWD uses a different rear unit than a Honda Pilot 2WD. Always cross-reference via the donor vehicle's VIN β€” part number matching alone is insufficient for electronically controlled AWD components. Β
      Β
      AWD Parts Installation β€” Critical Steps for Every Platform
      Always replace all input and output shaft seals on transfer cases and differentials at installation β€” seal kits cost $30–$90 and prevent the most common post-install fluid leak across all AWD platforms Fill with the exact manufacturer-specified fluid β€” Toyota ATFC, Honda VTM-4 fluid, Subaru DCCD fluid, Ford XT-M5-QS, GM Auto-Trak II β€” never substitute generic gear oil or ATF in AWD components; the wrong fluid causes immediate clutch pack or coupling damage On Ford PTU units, replace the vent tube and breather at installation β€” a blocked vent causes internal pressure that destroys output seals within 20,000 miles On BMW xDrive and Mercedes 4MATIC units, have the replacement coded to the vehicle using manufacturer diagnostic software β€” uncoded units operate in a default limited mode that does not represent system design intent On Subaru AWD vehicles, verify all four tires are within 1/4 inch of the same circumference before returning the vehicle β€” mismatched tires damage the replacement centre differential within a few thousand miles On Haldex coupling replacements (VW, Audi, Volvo), replace the Haldex filter and fluid simultaneously β€” a contaminated Haldex filter from the failed unit will destroy a new or used replacement coupling quickly Clear all AWD, ABS, traction control, and stability control fault codes after installation and perform a comprehensive test drive β€” include conditions that actually engage the AWD system (wet pavement, light gravel) before completing the repair On AWD vehicles with ADAS features, verify all drivetrain fault codes are fully resolved β€” active AWD fault codes suppress ADAS functions on many modern platforms Β
      βœ… GreenGears Auto's AWD Parts Promise Every AWD system component in our inventory β€” transfer cases, rear differentials, PTUs, rear drive units, CV axles, and hub assemblies β€” is inspected for fluid condition, housing integrity, electronic component status, and documented donor mileage before listing. We verify OEM specification, confirm gear ratios and trim-specific fitment, and back every component with our 15 to 90-day satisfaction guarantee, free US shipping, and no core charge. Β  Β
      AWD System Problem? We Have the Used OEM Part You Need.
      Tell us your year, make, model, engine, trim level, and fault codes β€” our AWD drivetrain specialists will identify the exact used OEM component and get it to you in 3–7 days with free shipping across the continental US.
      Β
      GreenGears Auto β€” Drive Green. Drive Smart.
      Β
      βœ… Fluid Inspected 🚚 Free US Shipping ↩️ 15-Day Returns πŸ“‹ No Core Charge link hidden, please login to view
      How to Use a Front Wheel Drive Hub Press
