customized Catalytic converter manufacturer in China
OEM vs Aftermarket ECM: Which Engine Control Module Is Right for Your Vehicle? | US Parts Inc.
By USPartsinc,
- aftermarket ecm
- autoparts
- (and 3 more)
- 46 views
Plug and Play ECM Guide | Easy Installation & Benefits | Clifford Auto Parts
- plug and play ecm
- car computer replacement
- (and 4 more)
- 53 views
How Artificial Intelligence Is Transforming Auto Parts Distribution in 2026
By USPartsinc,
- uspartsinc
- ecm
- (and 2 more)
- 59 views
How AI is Transforming Auto Parts: Smarter Repairs, Better Choices
- clifford auto parts
- ecm
- 2,008 views
- 1,178 views
Schaeffler announced its LuK TorCon torque converter product line has expanded with the release of the LuK 8L90 TorCon. The company said the 8L90 TorCon is engineered to outperform rebuilt alternatives up to five times longer.
Replacement Process and In-House Manufacturing
Designed to streamline the replacement process, the LuK 8L90 TorCon eliminates the need for model-specific cores that are typically required in torque converter rebuilding. The 8L90 TorCon is in stock and ready for installation.
link hidden, please login to view said it is manufactured to precise standards using all-new components and advanced manufacturing processes and is designed and built in-house from raw material to final assembly. Materials and Testing
Featuring LuK friction materials and INA premium thrust bearings, the LuK TorCon is engineered to withstand extreme operating conditions. Its fully furnace-brazed fins improve heat dissipation, reduce wear, and enhance long-term durability. The contamination-free manufacturing process includes 100% pressure and lockup testing, along with precision balancing, according to the company.
Applications and VIO
The LuK TorCon product line supports a broad range of applications for passenger cars and pickup trucks. Schaeffler said its expertise in manufacturing OE torque converters allows it to capture several applications through a single SKU.
The TorCon (TC0020) is compatible with select 2015 to 2022 General Motors trucks, vans and SUVs equipped with 8L90 transmissions. It covers multiple engines and has a current VIO of over 700,000, offering versatility when choosing a new torque converter.
link hidden, please login to view plans to release additional SKUs in the coming months.
Schaeffler announced its LuK TorCon torque converter product line has expanded with the release of the new LuK 6R80 TorCon. The company said it’s engineered to outperform rebuilt alternatives up to five times longer. Schaeffler added that the 6R80 is built from new, original components and is never remanufactured.
Simplifies Replacement and Stocking
link hidden, please login to view said the LuK 6R80 TorCon is designed to simplify the replacement process by eliminating the need for model-specific cores that are often required in torque converter rebuilding. Distributors and installers can rely on the 6R80 TorCon to be in stock and ready for installation, according to the company. Materials, Construction and Testing
Featuring LuK friction materials and INA thrust bearings, Schaeffler said the LuK TorCon is designed to withstand demanding conditions. Its fully furnace-brazed fins improve heat dissipation, reduce wear, and enhance long-term durability. The contamination-free manufacturing process includes 100% pressure and lockup testing, along with precision balancing.
Applications and Coverage
The LuK TorCon product line covers applications for passenger cars and pickup trucks. The line captures several applications through a single SKU. The TorCon (TC0019) is compatible with select 2014–2020 Ford F-150 trucks and Transit vans equipped with 6R80 transmissions, covers multiple engines, and has a current VIO of over 2,800,000. In the coming months,
link hidden, please login to view said it will release additional SKUs. The post
How to change the catalytic converter(shared by Shandong Xiaoyuan Environmental Protection Technology Co., Ltd, website:
link hidden, please login to view) I. Preparations Before Replacement 1. Safety Tools and Equipment: • Jack and support frame • Socket wrench, open-end wrench, universal joint • Non-slip gloves, safety goggles • WD-40 or other lubricant (to prevent bolts from rusting) • New catalytic converter (model matching original) 2. Vehicle Preparation: • Park on a level surface • Engage the handbrake • Ensure the engine is completely cooled (catalytic converter temperature is very high, easily causing burns) • Disconnect the negative terminal of the battery to prevent accidental triggering of the oxygen sensor alarm 3. Spare Parts: • New catalytic converter • New gasket • If damaged, the oxygen sensor (O2 sensor) may need to be replaced. ⸻II. Replacement Steps 1. Locate the Catalytic Converter • The catalytic converter is usually located after the exhaust manifold and before the muffler. • In diesel vehicles, it may be before the DOC and DPF. • Note the oxygen sensors before and after the catalytic converter; they need to be removed during replacement. 2. Remove the Oxygen Sensor • Use an O2 sensor socket or open-end wrench to unscrew it counterclockwise. • Be careful not to damage the sensor wiring harness.
3. Loosen the catalytic converter mounting bolts.
• The catalytic converter is usually fixed to the exhaust pipe with flange bolts.
• Spray lubricant on rusted bolts and wait 5–10 minutes.
• Use a socket wrench to loosen slowly, do not use excessive force to avoid breakage.
4. Remove the old catalytic converter.
• Remove it gently, being careful not to damage the exhaust pipe and suspension bracket.
• Check if the flange sealing surface is flat; repair any corrosion or deformation.
5. Install the new catalytic converter.
1. Install the new gasket (ensure alignment).
2. Install the new catalytic converter, first hand-tightening the mounting bolts to ensure correct positioning.
3. Then use a wrench to tighten evenly, avoiding overtightening to prevent flange deformation.
6. Reinstall the oxygen sensor.
• Use an O2 sensor socket wrench to screw it back on with moderate torque.
• Be careful not to twist the sensor wiring harness or allow it to come into contact with high-temperature components.
7. Check.
• Confirm that the catalytic converter is securely fixed and the oxygen sensor connection is normal.
• There are no obvious gaps in the exhaust pipe.
• Reconnect the battery negative terminal. ⸻III. Precautions 1. Avoid high-temperature operation: The catalytic converter's temperature can reach 400–600°C immediately after engine shutdown. 2. Ensure model compatibility: Different vehicle models have different catalytic converter apertures, lengths, and oxygen sensor interfaces. 3. Environmental requirements: Removed catalytic converters contain precious metals and should be recycled according to local regulations. 4. Engine fault codes (MIL): • After replacement, P0420 or similar codes may appear, requiring clearing the fault codes or waiting for self-learning. 5. Do not forcefully strike: The ceramic inside the old catalytic converter is fragile; avoid allowing fragments to enter the exhaust pipe. 6. Torque requirements: • Flange bolts are generally recommended at 20–40 Nm (depending on the vehicle model). • Oxygen sensor torque is generally 30–40 Nm. ⸻
Tips: • If the catalytic converter is only partially blocked, you can try cleaning or high-temperature regeneration first, but severe blockage still requires replacement. • For diesel vehicles, note that the catalytic converter after the DPF (DOC) and the oxidation catalytic converter are usually replaced or inspected together to ensure regeneration efficiency.
Shandong Xiaoyuan Environmental Protection Technology Co., Ltd(website: https://www.gaslyst.com). Specializing in Catalyst carrier, metal catalyst carrier, Three-Way Catalytic Converter, Three-Way Catalytic Converter Universal Package, Three-Way Catalytic Converter Ceramic Carrier, Automotive Ceramic Core Carrier,Truck Ceramic Inner Core Carrier, Metal Iron Core Inner Core Carrier, Automotive Emission Specific Products.
We are specializing in manufacturing honeycomb ceramic catalyst carriers of various sizes, metal carriers, universal three-way catalytic converters, and universal kits for three-way catalytic converters, including catalysts meeting high standards such as Euro 1, Euro 2, Euro 3, Euro 4, Euro 5, and Euro 6. OEM and ODM available. Shandong Xiao yuan Environmental Protection Technology Co. is committed to becoming a leading company in China's environmental protection technology sector, promoting the development and application of green environmental protection technologies, contributing to the sustainable improvement of the ecological environment, and creating a cleaner and better future for society.
