Schaeffler’s Vehicle Lifetime Solutions (VLS) division is presenting its latest vehicle repair and service advancements at AAPEX 2025. The event takes place Nov. 4-6 at the Venetian Expo in Las Vegas, with Schaeffler located at Booth #A2638.
Integration Strengthens Schaeffler’s Ecosystem at AAPEX 2025
After merging with Vitesco Technologies, Schaeffler integrated the strengths of both organizations to enhance its ecosystem approach. The company expanded its VLS aftermarket product portfolio to include e-water pumps, transmission control units and nitrogen oxide (NOx) sensors. This expansion supports internal combustion, hybrid and electric vehicles.
“Schaeffler delivers integrated, innovative solutions across engines, transmissions, and electrification, helping our customers meet the evolving demands of all powertrains,” said Eric Steinbecher, president, Vehicle Lifetime Solutions Americas.
Theme Focuses on Motion and Future Innovation
Under the theme “Sustaining Motion. Pioneering Future,” Schaeffler’s VLS division offers high-turnover, market-relevant products and customer-focused services, the company said. Digital platforms, including REPXPERT, provide repair shops, distributors and fleet operators with instructional videos, product catalogs and diagnostic tools. The recent integration with Vitesco Technologies enhanced Schaeffler’s expertise in electrification and thermal management.
Expanded Product Portfolio Supports Diverse Powertrains
The VLS division expanded its lineup with INA timing chain kits, timing belt kits, accessory drive kits, thermal management modules and variable valve timing (VVT) components. These developments improve reliability and efficiency across different powertrains.
Schaeffler Features LuK Torque Converters and Bearing Systems
At AAPEX,
features its LuK brand torque converters, known for durability and reliability. The company has manufactured more than 63 million units, primarily at its
. The Bearings & Seals portfolio includes TriFinity triple-row wheel bearings, iARC (Intelligent Active Roll Control) and RWS (Rear Wheel Steering) systems.
Collaboration with Vitesco Expands Electronic Solutions
Schaeffler’s partnership with Vitesco Technologies expanded its electronic product range for multiple vehicle types. The collaboration added NOx sensors, transmission control units (TCUs) and mass air flow (MAF) sensors to its lineup.
Electrification Products Drive Efficiency and Range
The company also showcases its e-powertrain solutions for hybrid and electric vehicles. Products include e-water pumps, the Schaeffler eAxle, and advanced electric motors that improve efficiency and battery range.
Investments Strengthen Schaeffler’s North and South American Presence
Schaeffler said it plans to grow its presence in the Americas through investments in facilities, R&D and workforce expansion. The company operates 19 plants and nine R&D centers in Canada, the U.S., Mexico, Brazil and South America, employing approximately 18,200 people.
Key investments include a $230 million electric axle facility in Dover, Ohio, a Central Logistics Center in Porto Feliz, Brazil, and the Huejotzingo Innovation Center in Puebla, Mexico, focusing on e-mobility R&D.
      link hidden, please login to view announced it released eight new AmeriPLATINUM Brake Pad numbers and four new AmeriPRO Brake Pad numbers with a wide range of coverage ranging from Buick Encore to Ford Transit applications. The new SKUs cover over 6mm VIO. Also just released in the
      link hidden, please login to view product line: 1 new AmeriPRO Brake Shoe, 2 new AmeriPRO Wear Sensors, 74 new AmeriPRO Coated and Coated R90 Euro Rotor numbers, and 20 VGX Brake Pad numbers with VIO coverage over 44+mm VIO.
    • By GreenGears Auto Limited
      3. Corrosion Protection
      Premature tyre wear
      Our
      Transtar announces the release of new premium
      link hidden, please login to view, Part #: T72500C, with the following applications: 2007-2018 Chrysler/Dodge/Ram, 68RFE Transmission  The T72500C is a high-quality transmission solution designed for professional rebuilders and installers who demand consistent performance, precise fitment, and long-term durability, according to Transtar.
      The T72500C goes beyond basic replacement parts,
      link hidden, please login to view said, with improved materials and tighter tolerances- delivering: Longer service life Greater resistance to wear and heat Consistent, dependable performance in demanding conditions The post
