Dash4 will present its friction program and upgraded brake system lines at AAPEX 2025 in booth A3450 at the Venetian Expo. The company will launch the Police Performance line engineered for enhanced stopping power and durability under demanding conditions. It will also debut the HD Performance line tailored for heavy-duty vehicles and large brake system lines that need strong braking stability and heat resistance.
Police and HD Products Target Professional Performance
The Police Performance line targets use in pursuit scenarios and frequent stopping. The product delivers optimal braking control under high-stress conditions, according to Dash4. The HD Performance line serves heavy-duty trucks and larger brake systems. It features a severe-duty friction compound that resists extreme heat. It also handles towing applications without fade.
Dash4 will also showcase its full friction program, including the Optimizer. This product targets off-road and high-performance drivers. The Optimizer aims to exceed original equipment quality standards in harsh environments.
Dash4 Focuses on Manufacturing and Quality Control
Dash4 tests all products in the United States. The company said it tests 100% of each product to guarantee consistency. Dash4 also ensures every item meets or exceeds original equipment standards. It maintains multiple international certifications across its product lines.
“We’re proud to introduce our new Police and HD lines at AAPEX 2025, reinforcing our commitment to delivering premium-quality braking solutions to the aftermarket,” said the company’s marketing manager.
Contact Dash4
For more information on Dash4 products, contact customer service at 323-231-1460 or
. Follow Dash4 on social media @dash4brakes.
    • By juliaanderson
      Hey everyone,
      link hidden, please login to view announced it released eight new AmeriPLATINUM Brake Pad numbers and four new AmeriPRO Brake Pad numbers with a wide range of coverage ranging from Buick Encore to Ford Transit applications. The new SKUs cover over 6mm VIO. Also just released in the
      link hidden, please login to view product line: 1 new AmeriPRO Brake Shoe, 2 new AmeriPRO Wear Sensors, 74 new AmeriPRO Coated and Coated R90 Euro Rotor numbers, and 20 VGX Brake Pad numbers with VIO coverage over 44+mm VIO.
      link hidden, please login to view introduces a new line of Transtar Brand 100% all New Components Torque Converters which it said are engineered specifically for 2011-up Ford Trucks and Vans equipped with 6R140 transmissions. Designed to meet the demands of modern gas and diesel powertrains, these converters deliver consistent, dependable performance for today’s rebuilders and come with a 12-month/unlimited mileage warranty.
      Developed by an engineering team with decades of experience supporting global automotive programs, all converters are manufactured to OE specifications and designed to meet or exceed factory performance standards,
      link hidden, please login to view said. Applications & Coverage
      2011-Up Ford F250, F350 and F450 with 6r140 transmission.  2016-Up Ford E350 and E450 with 6R140 transmission.  Available Part Numbers
      TS-FM1261 (6.2L; 6.8L Gas Engines)  TS-FM1262 (6.7L Diesel Engine, 6 Mounting Studs)  TS-FM1265 (7.3L Gas Engine) For optimal performance, pair with Transtar Low Viscosity Fluid.
