Monroe has launched a new range of air springs for commercial vehicles, which it said are designed to enhance vehicle safety and productivity. The air springs are compatible with trucks, buses, and other applications from manufacturers such as Mercedes-Benz, IVECO, DAF, Renault Trucks, MAN and Volvo.
Engineering Enhancements in Air Spring Design
said its Magnum air springs are built to withstand demanding conditions with several design improvements:
  • Premium Bellows: Made from high-quality rubber materials to ensure flexibility and resist environmental factors.
  • New Bumper Design: Tested to endure up to 89 kilonewtons (kN) of force.
  • Durable Pistons: Available in ultra-high-strength steel or lightweight plastic with anti-corrosion coating.
Product Range and Applications
The Monroe Magnum range includes:
  • Convoluted Air Springs: Suitable for axle lifting and industrial applications.
  • Rollover Air Springs: Enhance lateral stability for better vehicle control.
  • Assembly Air Springs: Available in both lightweight and high-strength designs.
said each air spring is engineered to maintain the correct ride height and center of gravity, promoting load stability and driver safety.
      Compatibility
      As part of its ongoing commitment to continuous improvement,
      link hidden, please login to view has introduced an updated label design for our larger (non-graphic) kraft boxes. The change will be implemented as a running update across production. The new label format features a cleaner, more streamlined layout with enhanced readability. Key product information, especially part numbers, is now more prominent and easier to identify at a glance, Anchor said. These improvements are designed to help simplify product handling and identification for distributors, warehouse teams, and end users alike.
      In addition to improved functionality, the updated labels provide a more consistent and professional presentation throughout the distribution chain, supporting more efficient inventory management and product visibility on shelves and in storage, added
      link hidden, please login to view. During the transition period, customers may receive shipments with either the current or the updated label design as inventory cycles through. The product, part numbers and packaging specifications remain unchanged; only the label design has been updated.
    • By GreenGears Auto Limited
      Published by GreenGears Auto  |  9 minute read  |  AWD Drivetrain & Transfer Case Guides
      The transfer case is the unsung hero of every AWD system. While most drivers associate all-wheel drive with traction and safety, few realize the transfer case is the component making it all possible — splitting torque between axles, managing engagement timing, and coordinating with stability and traction control systems in real time. When it fails, your vehicle loses its AWD capability entirely. New OEM transfer cases cost $900–$3,200+ depending on the platform. At GreenGears Auto, we stock inspected OEM used transfer case assemblies sourced from low-mileage donors across every major AWD platform — at 50–70% less than new pricing. This guide covers every major make, what makes each unit unique, and how to source correctly.
      How AWD Transfer Cases Differ from 4WD Units
      Transfer cases in AWD vehicles operate very differently from the part-time 4WD units found in body-on-frame trucks. Understanding the distinction is critical when sourcing a replacement — and explains why OEM fitment is non-negotiable on modern AWD systems.
        🔄Full-Time AWD (Active) The transfer case continuously distributes torque front-to-rear without driver input. Uses a center differential or electronically controlled clutch pack to manage split ratios in real time based on wheel slip, vehicle speed, and steering angle. Found on most modern crossovers and luxury SUVs.
        ⚡On-Demand AWD (Reactive) The vehicle normally drives the primary axle only. The transfer case detects wheel slip and engages the secondary axle electronically when needed. Lower parasitic drag improves fuel economy. Common on Honda CR-V, Toyota RAV4, Ford Escape, and similar crossovers.
        🧠Torque Vectoring AWD The most sophisticated type — the transfer case actively varies torque distribution left-to-right across an axle, not just front-to-rear. Found on performance AWD systems like Acura SH-AWD, BMW xDrive M variants, and Porsche PTM. Requires exact OEM replacement for correct operation.
        🔧 GreenGears Tip — Why AWD Transfer Case OEM Sourcing Matters More Than 4WD AWD transfer cases are deeply integrated with a vehicle's ABS, stability control, traction control, and in newer vehicles, ADAS systems. An incorrect or aftermarket unit introduces calibration errors that trigger fault codes, compromise safety system function, and in some cases prevent the vehicle from passing an emissions or inspection test. OEM used is the only reliable option for modern AWD applications.
      Warning Signs of a Failing AWD Transfer Case
      AWD transfer case failures are often misdiagnosed as differential, driveshaft, or traction control faults. Knowing the specific symptom patterns helps confirm the diagnosis before ordering a replacement unit.
      🔊 Noise Symptoms
      Grinding or humming that changes with vehicle speed Whining in AWD mode that disappears in 2WD (if selectable) Clunking during acceleration or deceleration Vibration through the floor at highway speed Chain rattle from the transfer case area at startup
      ⚡ Warning Light & Electronic Symptoms
      AWD, 4WD, or All-Wheel Drive warning light illuminated Traction control or stability control fault codes AWD system disabled message on instrument cluster ABS fault codes appearing alongside AWD codes Intermittent AWD engagement — system cuts in and out
      🔩 Handling & Drivability
      Loss of traction on wet or slippery surfaces where AWD previously helped Binding or tight steering — especially in tight turns Uneven power delivery front-to-rear under acceleration Vehicle pulls to one side during AWD engagement Shudder during cornering at low speed
      💧 Fluid & Leak Symptoms
      Transfer case fluid puddle under the center of the vehicle Burnt or dark transfer case fluid on inspection Metal particles visible in drained fluid Low fluid level with no visible external leak (internal seal failure) Milky or foamy fluid indicating water contamination
      Top OEM Transfer Case Assemblies by AWD Platform
      Here is a make-by-make breakdown of the most commonly needed and best-value OEM used transfer case assemblies across every major AWD vehicle platform.
      🏆 Best Overall Reliability Toyota / Lexus AWD
      Toyota RAV4 / Highlander / 4Runner / Lexus RX — Transfer Case Assembly
      Typical Used Price: $280–$620 Toyota's AWD transfer case assemblies are among the most reliable and widely available in the used OEM market. Toyota's conservative engineering approach — favouring proven mechanical designs over complex electronics — produces transfer cases with very low intrinsic failure rates. When they do fail, it's almost always fluid-related. The enormous volume of Toyota and Lexus AWD vehicles in the US market ensures outstanding used parts availability at competitive pricing.
      RAV4 AWD (2013–2022): Active Torque Control (ATC) transfer case — compact, electronically controlled, and exceptionally reliable; highest availability of any Toyota AWD transfer case RAV4 Dynamic Torque Control (2019–Present): Advanced unit with rear axle disconnect capability — confirm generation before ordering as it is not compatible with earlier units Highlander AWD (2008–2020): BorgWarner-supplied transfer case in most generations; robust unit with strong used market availability from high-volume Highlander sales 4Runner / FJ Cruiser (2003–2014): Part-time 4WD with 2-speed transfer case — simple, overbuilt, extremely long-lived; used units from low-mileage highway donors are outstanding buys Lexus RX 350/450h AWD: Shares transfer case architecture with the Highlander; Lexus donor vehicles tend to have lower mileage and better maintenance histories   ⚙️ RAV4 Hybrid AWD Note The RAV4 Hybrid and RAV4 Prime use an electric motor to drive the rear axle — there is no mechanical transfer case or driveshaft. These are not transfer case applications. Confirm you have a conventionally powered AWD RAV4 before sourcing a transfer case unit.
      ⚙️ Most AWD-Committed Platform Subaru Symmetrical AWD
      Subaru Outback / Forester / Impreza / WRX — Transfer Case / Centre Differential
      Typical Used Price: $240–$580 Subaru's Symmetrical AWD is unique among mass-market AWD systems — it uses a longitudinally mounted engine and transmission that allows a true centre differential-based transfer case rather than the bolt-on transfer cases common on transverse-engine platforms. Every Subaru AWD model has a transfer case integrated into or directly adjacent to the transmission, making it the most drivetrain-specific replacement in this guide.
      Outback / Forester / Impreza (non-STI): Viscous centre differential transfer unit — simple, reliable, and well-priced in the used market; 2010–2019 units are the most available WRX (2008–Present): Active Torque Split AWD transfer unit with electronically managed distribution; WRX-specific sourcing required — do not substitute Outback units WRX STI: Driver-Controlled Centre Differential (DCCD) — the most sophisticated Subaru AWD transfer unit; used STI DCCD units command a significant premium due to high demand and low supply Crosstrek AWD: Shares Impreza transfer case architecture — expanding sourcing options; 2018–2023 units are increasingly available   ⚠️ Subaru Tire Diameter Warning All four tires on a Subaru AWD vehicle must be within 1/4 inch of the same diameter. Mismatched tires force the centre differential to compensate continuously — accelerating wear and causing the same symptoms as a failing transfer case. Before replacing a Subaru transfer case, always verify all four tires are correctly matched.
      💰 Best Value Crossover Honda / Acura AWD
      Honda CR-V / Pilot / Passport / Acura MDX / RDX — VTM-4 / SH-AWD Transfer Case
      Typical Used Price: $220–$560 Honda and Acura's AWD systems span two distinct designs — the Variable Torque Management 4WD (VTM-4) system used on the Pilot and older MDX, and the electronically controlled on-demand AWD used on the CR-V, Passport, and newer RDX. Both produce excellent used OEM transfer case availability thanks to Honda's high sales volume across all platforms.
      Honda CR-V AWD (2012–2022): Rear drive unit (RDU) — Honda's term for the transfer case coupling unit; compact, reliable, and among the most affordable AWD transfer case units in the used market Honda Pilot AWD (2016–Present): Intelligent Variable Torque Management (i-VTM4) — more sophisticated than the CR-V unit; electronically controlled multi-plate clutch pack transfers up to 70% of torque rearward Acura MDX SH-AWD (2014–Present): Super Handling AWD transfer unit with left-right rear torque vectoring capability; OEM used units are the only viable replacement option — aftermarket units for SH-AWD do not exist in meaningful supply Acura RDX AWD (2019–Present): Updated SH-AWD architecture with faster torque response; sourcing availability building as the fleet ages
      🔩 Best for American Crossovers Ford / Lincoln AWD
      Ford Escape / Edge / Explorer / Lincoln MKC / Nautilus — PTU / Transfer Case Assembly
      Typical Used Price: $260–$680 Ford's AWD crossovers use a Power Transfer Unit (PTU) — Ford's terminology for the transfer case on transverse-engine AWD platforms. The PTU is mounted to the front transaxle and drives the rear axle via a prop shaft. It is one of the most commonly replaced drivetrain components on Ford's crossover lineup — largely because early PTU designs were prone to seal failure that led to fluid loss and internal damage when not caught promptly.
      Ford Escape AWD (2013–2019): PTU is the single most commonly replaced drivetrain component on this platform; seal failure is the primary cause — always replace the PTU seals when installing a used unit Ford Edge AWD (2011–2018): Larger PTU than the Escape; 2015–2018 units are the most available and best-priced Ford Explorer AWD (2011–2019): PTU carries higher torque loads than the Edge or Escape; sourcing from Explorer towing-spec donor vehicles adds confidence in load capacity Lincoln MKC / Nautilus / MKX: Share PTU architecture with the Escape, Edge, and Explorer respectively — Lincoln donor vehicles typically have lower mileage and better service histories   ⚠️ Ford PTU Seal Failure — Critical Installation Note The most common failure mode for Ford AWD PTUs is seal failure leading to fluid loss. A used PTU in otherwise good condition installed without new seals will frequently develop the same leak within 20,000–40,000 miles. Always install a complete PTU seal kit ($40–$80) alongside any used Ford PTU — this single step dramatically extends the service life of the replacement unit.
      💪 Best for Full-Size AWD GM / Cadillac AWD
      Chevrolet Equinox / Traverse / Cadillac XT5 / SRX — Transfer Case Assembly
      Typical Used Price: $300–$720 General Motors uses electronically controlled transfer case assemblies across its AWD crossover and SUV lineup. The units fitted to the Equinox, Traverse, and Cadillac XT5 are BorgWarner-supplied designs with electronically managed clutch packs that provide seamless on-demand AWD engagement. GM's enormous sales volume ensures excellent used parts availability across all generations.
      Chevrolet Equinox AWD (2010–2017): BorgWarner electronic transfer case — compact, well-priced, and widely available; 2013–2017 units are the best combination of reliability and used market availability Chevrolet Traverse / Buick Enclave AWD (2009–2017): Larger BorgWarner unit than the Equinox; shares architecture across Traverse, Enclave, and Acadia — broadens sourcing options Cadillac XT5 / SRX AWD: Same BorgWarner architecture as the Equinox/Traverse family with Cadillac-specific calibration; Cadillac donor vehicles have lower average mileage — worth seeking out for quality Chevrolet Traverse / GMC Acadia (2018–Present): Updated BorgWarner unit with improved torque distribution; increasingly available as this generation enters the higher-mileage salvage market
      🇩🇪 European Precision AWD BMW xDrive
      BMW X3 / X5 / 3 Series / 5 Series xDrive — ATC / ATC700 Transfer Case
      Typical Used Price: $420–$950 BMW's xDrive AWD system is one of the most capable and most repair-intensive AWD platforms in the used market. The xDrive transfer case — branded as the ATC (Active Transfer Case) — uses an electronically controlled multi-plate wet clutch to manage torque distribution between the front and rear axles. It communicates directly with the DSC (Dynamic Stability Control), ABS, and — on M models — the Active M Differential. OEM used is the only viable replacement pathway at a sensible cost.
      BMW X3 (F25, 2011–2017): ATC 35L transfer case — the most commonly available BMW xDrive transfer case unit; well-priced relative to new cost BMW X5 (E70, 2007–2013): ATC 700 transfer case — larger unit for the full-size X5; 3.0i and 4.8i variants use the same unit, simplifying sourcing BMW X5 (F15, 2014–2018): Updated ATC design with improved efficiency; increasingly available from accident donors BMW 3 Series / 5 Series xDrive: Compact ATC unit designed for the sedan and wagon platforms; shares architecture with the X3 on many model years   💡 BMW xDrive Transfer Case Coding After installing a used xDrive ATC unit, BMW requires the replacement to be coded to the vehicle using BMW ISTA+ or ENET diagnostic software. Without coding, the xDrive system may default to a limp mode with limited rear torque distribution. Factor dealer or independent BMW shop coding time into your total repair budget.
      🇩🇪 4MATIC Specialist Mercedes-Benz 4MATIC
      Mercedes GLE / GLC / C-Class / E-Class 4MATIC — Transfer Case Assembly
      Typical Used Price: $480–$1,100 Mercedes-Benz 4MATIC systems use a transfer case integrated with the transmission on most platforms — on the 7G-Tronic and 9G-Tronic automatic transmission families, the transfer case is a bolt-on rear output unit that can be serviced independently. Mercedes 4MATIC transfer cases are among the most expensive to replace new, making OEM used sourcing particularly compelling on these vehicles.
      GLC 300 4MATIC (2016–Present): Compact transverse AWD transfer unit — increasingly available as 2016–2019 units enter the higher-mileage salvage market GLE 350 / GLE 450 4MATIC: Longitudinal transfer case with 45/55 default front/rear split; variable distribution capability; OEM used units from low-mileage US-market donors are the best sourcing option C-Class / E-Class 4MATIC: Compact transfer case units with strong used availability due to high C-Class and E-Class sales volumes G-Class (G550 / G63 AMG): Three-differential AWD with dedicated transfer case and two locking differentials; used units command significant premiums due to low supply and extreme replacement cost new
      🇩🇪 Quattro & 4Motion Audi Quattro / VW 4Motion
      Audi Q5 / A4 / A6 Quattro / VW Tiguan / Atlas 4Motion — Transfer Case
      Typical Used Price: $380–$880 Audi's Quattro and Volkswagen's 4Motion systems share Torsen-based and Haldex-based transfer case designs depending on the specific model and generation. Longitudinal Quattro (Audi A4, A6, Q5 on the MLB platform) uses a Torsen centre differential — the most mechanically elegant and least failure-prone AWD transfer system in this guide. Transverse Quattro (Audi TT, A3) and VW 4Motion use a Haldex electronically controlled coupling — a different design with its own service requirements.
      Audi Q5 / A4 / A6 Quattro (MLB platform, 2017+): Torsen centre differential transfer case — virtually failure-proof when fluid is maintained; used units are a premium find due to low failure rate Audi Q5 (B8, 2009–2017): Haldex Gen 4/5 rear differential coupling — the most commonly replaced Quattro component; used units widely available from the large B8 Q5 fleet VW Tiguan 4Motion (2009–2017): Haldex coupling — same sourcing considerations as the B8 Q5; cross-reference with Audi Q3 and Skoda Yeti for expanded availability VW Atlas 4Motion (2018–Present): Larger Haldex-based unit for the full-size Atlas; increasingly available as early units enter the used market
      AWD Transfer Case Quick Reference Guide
      Make / Platform Transfer Case Type Used Price Range Availability OEM Critical? Toyota RAV4 / Highlander Electronic ATC / ATC4 $280–$580 ⭐⭐⭐⭐⭐ Yes Subaru Outback / WRX Viscous / DCCD Centre Diff $240–$580 ⭐⭐⭐⭐⭐ Yes Honda CR-V / Pilot AWD RDU / i-VTM4 $220–$520 ⭐⭐⭐⭐⭐ Yes Acura MDX / RDX SH-AWD SH-AWD Torque Vectoring $380–$560 ⭐⭐⭐⭐ Critical Ford Escape / Edge / Explorer PTU (Power Transfer Unit) $260–$680 ⭐⭐⭐⭐⭐ Yes Chevy Equinox / Traverse BorgWarner Electronic $300–$680 ⭐⭐⭐⭐⭐ Yes BMW X3 / X5 xDrive ATC / ATC700 $420–$950 ⭐⭐⭐⭐ Critical Mercedes GLE / GLC 4MATIC 4MATIC Transfer Unit $480–$1,100 ⭐⭐⭐⭐ Critical Audi Q5 / A4 Quattro Torsen / Haldex $380–$880 ⭐⭐⭐⭐ Critical VW Tiguan / Atlas 4Motion Haldex Coupling $320–$680 ⭐⭐⭐⭐ Yes
      OEM Used vs. Remanufactured vs. Aftermarket
      🏭 Remanufactured / Aftermarket
      Reman cost: $600–$1,800 — plus core charge of $200–$500 Quality entirely dependent on rebuilder — no OEM quality assurance Electronic components (solenoids, sensors) often reused from worn cores Calibration to vehicle's ECU not guaranteed — fault codes common post-install Core charge adds upfront cost and return shipping hassle New manufacturing environmental footprint on all replacement components
      ♻️ OEM Used — GreenGears Auto
      Used OEM cost: $220–$1,100 — no core charge Original factory assembly — no rebuilt internals or reused worn components Factory electronic calibration intact — correct OEM integration Mileage-verified from documented low-mileage donor vehicle Free shipping in 3–7 days across the continental US 280 lbs CO₂ prevented per unit vs. new manufacturing
      What to Inspect Before Buying a Used AWD Transfer Case
      Verify Donor Mileage and Service History
      AWD transfer case life is directly tied to fluid maintenance. A 60,000-mile unit from a vehicle with regular fluid changes will outlast an 80,000-mile unit from a vehicle with no documented service history. Always request documented donor mileage — GreenGears Auto records and verifies this on every listing. Drain and Inspect Fluid Condition
      Healthy AWD transfer case fluid is amber or light brown and free of metallic particles. Dark, burnt fluid indicates thermal overload or extended neglect. Milky or foamy fluid indicates water contamination — a serious finding that should disqualify the unit. Metal flakes in the fluid indicate internal gear or bearing wear that may be progressive. Inspect All Seals and Mating Surfaces
      Check the input shaft seal, both output shaft seals, and the housing mating surface for active weeping or dried residue. For Ford PTU units, seal condition is especially critical — seal failure is the most common PTU failure mode and a used unit with compromised seals will repeat the same failure quickly. Verify Electronic Component Integrity
      For electronically controlled AWD transfer cases (BMW ATC, Mercedes 4MATIC, Honda i-VTM4, Ford PTU), inspect the solenoid connectors, wiring harness stub, and any integrated sensors for physical damage, corrosion, and broken pins. A mechanically sound transfer case with damaged electronics will not function correctly after installation. Confirm Exact Application by VIN
      AWD transfer cases vary by engine, transmission, model year, and trim level within the same nameplate. A 2016 Honda Pilot with a 9-speed transmission uses a different transfer case than a 2015 Pilot with a 6-speed. Always cross-reference via the donor vehicle's VIN — part number matching alone is not sufficient for electronically controlled units where software calibration may differ. Check Housing for Cracks and Impact Damage
      Inspect the complete external surface of the housing — particularly the bottom and sides, which are most exposed to road debris. Cracks in the housing are disqualifying regardless of how minor they appear. A cracked housing cannot be reliably sealed and will leak under operating temperature and pressure.
      ✅ GreenGears Auto's AWD Transfer Case Promise Every AWD transfer case in our inventory is inspected across all six points above before listing. Fluid condition, seal integrity, electronic component status, and donor mileage are documented on every unit. Each is backed by our 90-day satisfaction guarantee with free US shipping and no core charge.
      Installation Best Practices for AWD Transfer Cases
      Always replace all input and output shaft seals at installation — seal kits cost $30–$90 and prevent the most common post-install failure mode across all AWD platforms Fill with the manufacturer-specified transfer case fluid — using the wrong fluid in an electronically controlled AWD unit causes clutch pack wear, shudder, and premature failure; never substitute generic ATF On BMW xDrive units, code the replacement ATC to the vehicle using ISTA+ before returning to the owner — uncoded units run in a limited default mode On Ford PTU units, inspect and replace the vent tube and breather at installation — a blocked PTU vent causes internal pressure buildup that destroys the output seals Clear all AWD, ABS, and stability control fault codes after installation and perform a calibration drive before finalising the repair On Subaru AWD vehicles, verify all four tires are matched in diameter within the specified tolerance before returning the vehicle — mismatched tires will damage the replacement unit For Mercedes 4MATIC and Audi Quattro applications, verify driveshaft balance and U-joint condition before installation — drivetrain vibration is frequently misdiagnosed as transfer case noise after a swap Road test comprehensively in AWD conditions — wet pavement or gravel is ideal — before completing the repair to verify correct AWD engagement and absence of noise or vibration
      Need an OEM Transfer Case for Your AWD Vehicle?
      Tell us your year, make, model, engine, and transmission — our AWD drivetrain specialists will locate the right inspected OEM unit and get it to you in 3–7 days with free shipping and no core charge.
      ✅ 6-Point Inspection 🚚 Free US Shipping ↩️ 15-Day Returns 📋 No Core Charge link hidden, please login to view
