When diesel injector pumps fail, the results can be catastrophic to the entire fuel system. The repairs may involve more than an injector pump replacement. Failures often fall under a category of a contaminated or non-contaminated fuel system. When the contamination is metal, several thousand dollars in repair costs can be incurred. High Pressure Fuel […]
      Hey everyone,
      Fixing a fuel tank? Check Dorman first.
      Compatibility
