HELLA Expands Brake Systems Offering
By juliaanderson
link hidden, please login to view link hidden, please login to view link hidden, please login to view, the parent company of link hidden, please login to view, announced the addition of link hidden, please login to view to the BCA aftermarket product line. This latest new number announcement delivers expanded OE‑quality coverage for key Lexus, Toyota, and Mazda applications, representing more than 800,000 vehicles in operation across North America. “These new part numbers reinforce BCA’s commitment to coverage and OE‑quality performance in high‑value segments of the market,” said Matt Gorski, manager of product development, automotive aftermarket. “As import platforms continue to evolve, we remain focused on providing dependable solutions that help our customers capture replacement demand with confidence.”
The new additions strengthen BCA’s late‑model import coverage across key Lexus, Toyota, and Mazda platforms, including a growing mix of luxury, hybrid, and electric vehicles. By addressing both emerging electrified applications and sustained service demand in premium internal‑combustion models, this release further reinforces BCA’s ability to deliver durable, OE‑quality solutions for a broad and evolving segment of the aftermarket, the company said.
Standard Motor Products Inc. (SMP) announced expanded coverage in multiple engine sensor categories. Advanced internal combustion engine systems such as variable valve timing and turbocharging depend on timely, accurate data from multiple sensors. SMP said its engine sensors are designed for accuracy, speed and durability, and each sensor is tested and validated for performance in extreme conditions.
Engine Sensor Categories and New Part Numbers
link hidden, please login to view engine sensor categories include camshaft position sensors, crankshaft position sensors, battery current and voltage sensors, mass air flow (MAF) sensors, manifold absolute pressure (MAP) sensors, coolant temperature sensors, throttle position sensors and fuel pressure sensors. Recent part number additions have expanded these categories. MAP sensors have been added for General Motors vehicles through the 2025 model year, as well as Ford vehicles such as the 2021 through 2025 F-150, 2018 to 2023 Transit Connect and 2021 to 2024 Bronco. MAF sensors are new for 2.2 million Lexus and Toyota vehicles, as well as Cadillac cars and SUVs through 2024. Coolant temperature sensors were recently introduced for vehicles such as the 2020 to 2023 Chevrolet Silverado and 2021 to 2023 GMC Yukon.
Multiple battery current and voltage sensors were recently added, introducing coverage for the 2020 to 2025 Nissan Sentra, 2018 to 2024 Jeep Wrangler, 2019 to 2023 Kia Soul and 2019 to 2025 Lexus ES300h. Additionally, engine oil level sensors have been introduced for more than 6 million Toyota and Lexus vehicles through the 2025 model year.
Testing and Validation
link hidden, please login to view said its engine sensors are subjected to extensive testing in the lab, on actual vehicles and at the end of the line to ensure quality. Camshaft and crankshaft position sensors undergo vibration testing for 48 to 68 hours on multiple planes for durability and are chamber tested from minus 40 °F to 257 °F for accuracy in all conditions. They are then validated on actual vehicles to help optimize the performance of fuel injection and variable valve timing systems. Each sensor is end of line tested for timing, pulse width and signal amplitude. “Standard offers thousands of precision engineered sensors in multiple categories, providing our trusted partners with the industry leading coverage they expect from us,” said John Herc, vice president of vehicle control marketing at SMP. “But we do not just stop at coverage; we design and test our engine sensors specifically for accuracy, speed and durability to keep modern vehicles operating as intended.”
SAF-Holland has launched BrakeSight, a brake monitoring system for Haldex air disc brakes that provides continuous, real-time visibility into wear at the wheel end. The company said the system targets fleets seeking more predictable brake service intervals and streamlined repair planning.
SAF-Holland said BrakeSight helps fleets schedule brake service at the optimal moment, extend rotor life, avoid unnecessary repairs and reduce overall maintenance costs.
How BrakeSight Brake Monitoring Works
BrakeSight is an optional feature for the Haldex ModulT air disc brake. As the adjustment mechanism rotates to compensate for pad and rotor wear, the system monitors this movement and translates it into a percentage of remaining pad and rotor life at each wheel end.
The sensor connects to a frame-mounted electronic control unit (ECU), which converts the signal and outputs real-time data via CAN. Designed for both tractor and trailer air disc brakes, BrakeSight is J1939 compliant and compatible with all telematics platforms. SAF-Holland works with telematics providers selected by the fleet and offers open integration without exclusive partnerships.
Built for Real-World Fleet Conditions
SAF-Holland said BrakeSight combines durability with ease of use. Features include:
Continuous measurement of brake pad wear; Ultrasonically welded sensor housing for long-term durability; IP6K9K sealing for harsh road and wash-down environments; Sensor warranty of 3 years or 350,000 miles, matching ABS coverage; Operating temperature range from -40 C to 125 C. Because all ModulT air disc brake calipers include the sensor mounting feature as standard, OEMs and fleets can add BrakeSight at any stage without replacing the caliper. This supports flexibility throughout the vehicle life cycle.
By providing real-time insight into brake wear, the system helps fleets create more accurate maintenance schedules, reduce unplanned downtime and protect brake components. The company positioned this as a way to lower total cost of ownership and improve uptime.
