DIY – How To Flush Your Power Steering System
By APF,
- 1,002 views
- 30 views
- 52 views
- 49 views
- 52 views
By juliaanderson
By juliaanderson
By abenleulmi
Hey everyone,
By USPartsinc
"I’ve been tracking a trend lately, and I’m curious what you guys think.
It feels like every year, vehicle electronics—specifically the Engine Control Module (ECM/PCM)—are becoming less 'user-serviceable' by design. We’re seeing more 'locked' systems and complex proprietary programming requirements that basically force the average driver back to the dealership for simple fixes.
Are we losing the ability to truly repair our own cars? Or is this just the price we pay for modern performance?
I’ve been working with Clifford Auto Parts on making pre-programmed, plug-and-play modules more accessible to the DIY community, but it’s a constant battle against the 'locked system' trend.
What’s your take? Is the DIY community fighting a losing battle, or are third-party solutions finally catching up to the tech?
Let’s hear it—do you think the aftermarket has a real chance against these 'black box' manufacturer designs?
[Discussion continues here:
link hidden, please login to view]"
