Northwood University announced registration is open for two highly sought-after professional development courses: Aftermarket 101, scheduled for May 19-20, and Heavy Duty 101, scheduled for May 21-22. Both programs will take place in Detroit and are open to all aftermarket professionals seeking a deeper understanding of the industry.
These courses provide essential knowledge about the automotive and heavy-duty aftermarket sectors, exploring key players, distribution channels, market trends and career opportunities. Participants will engage directly with industry leaders and gain valuable hands-on experience through site visits and interactive sessions.
“These courses are designed to introduce new team members to the breadth and depth of the automotive and heavy-duty aftermarket,” said Dr. Thomas Litzinger, executive director of the
 and
 industry chair at Northwood University. “Participants will come away with the foundational knowledge and industry connections necessary to navigate and thrive in our dynamic market.”
Aftermarket 101 focuses on the light vehicle aftermarket, covering industry basics, key players, distribution structures and emerging trends. Students will tour a high-volume traditional warehouse distributor and participate in experiential learning opportunities to see the supply chain in action. Upon completion, students will earn 1.5 Continuing Education Units (CEUs). Enroll here:
Heavy Duty 101 is tailored for professionals entering the commercial vehicle aftermarket. This course also offers 1.5 CEUs and covers the unique challenges and opportunities facing fleets and service providers, including a dynamic case study exercise designed to reinforce learning through real-world applications. Enroll here:
“Our programs are designed around our shared mission to advance the automotive aftermarket by equipping professionals with the knowledge, leadership skills, and hands-on experience needed to navigate today’s rapidly evolving landscape,” added James O’Dell, assistant director of aftermarket education at Northwood University.
Both courses are ideal for individuals new to the industry or transitioning into roles requiring a broader understanding of the aftermarket’s scope, challenges and opportunities. Topics covered include industry terminology, market channels, service provider challenges, heavy-duty trends and strategies for standing out in a competitive marketplace.
Participants will also learn about professional designations available through the University of the Aftermarket, including ACP, AAP, MAAP and GAAE.
Complete course descriptions and registration details are available at:
      Published by GreenGears Auto  |  8 min read  |  Subframe Buying Guide
      3. Corrosion Protection
      Premature tyre wear
      Our
      🛡️ 90-Day Warranty  ·  🚚 Free US Shipping  ·  ↩️ 15-Day Returns
      link hidden, please login to view has recognized Truck-Lite and ECCO as its latest suppliers to earn the VIPAR Heavy Duty Strategic Partner (VSP) designation. The two companies, both part of Clarience Technologies, join a group of suppliers that demonstrate a strong commitment to supporting the organization’s distributors, fleets and strategic initiatives across the heavy-duty aftermarket. “Truck-Lite and ECCO bring exceptional value to our distributor network through their commitment to innovation, safety, and service,” said Larry Griffin, vice president of program management for VIPAR Heavy Duty. “Their strong support of fleets, investment in data quality, and product offerings that extend across key international markets align closely with our strategic priorities. We are pleased to welcome them as Strategic Partners.”
      Designation Criteria and Program Support
      Truck-Lite and ECCO earned the designation by meeting key criteria established by
      link hidden, please login to view, including active support of fleets through the organization’s National Accounts Program. The companies also contributed product content to PARTSPHERE PIM®, VIPAR Heavy Duty’s product information management system, and delivered comprehensive product programs that serve both VIPAR Heavy Duty and Power Heavy Duty distributors. “We are honored that Truck-Lite and ECCO have been recognized as VIPAR Heavy Duty Strategic Partners,” said Brian Olsen, executive vice president and president, Visibility Solutions, at Clarience Technologies. “This designation reflects our shared commitment to supporting distributors and fleets with innovative, high-quality solutions. We value our partnership and look forward to continued collaboration to deliver value across the heavy-duty aftermarket.”
      Benefits of VSP Designation
      Suppliers that earn the VSP designation benefit from enhanced visibility and engagement opportunities, including special recognition and priority positioning at the IMPACT Conference. They also receive expanded branding across distributor touchpoints and increased networking and collaboration with the VIPAR Heavy Duty Family of Companies team and distributor members.
      Truck-Lite and ECCO join the VSP group alongside Baldwin Filters, Donaldson Company, East Penn, Grote, Prestone, Tectran and Tramec.
    • By liangyanyang
      When maintaining heavy-duty trucks and diesel engines, choosing the right filter is crucial for engine performance and operating costs. Many fleet owners and dealers typically compare original equipment manufacturer (OEM) truck filters with aftermarket truck filters before making a purchase.
      So, what's the difference between original equipment manufacturer (OEM) filters and aftermarket filters?
      What is an original equipment truck filter?
      Original equipment (OEM) filters are manufactured to the specifications of the original vehicle or engine manufacturer. These filters are designed to meet the requirements of the original equipment system in terms of filtration efficiency, airflow, and durability.
      Original equipment manufacturer (OEM) filters are typically used for:
      Heavy trucks Commercial vehicles construction machinery diesel engine The advantages of original equipment manufacturer (OEM) filters include:
      Stable quality Reliable compatibility Stable performance Longer engine protection time What are aftermarket truck filters?
      Aftermarket filters are replacement products manufactured by independent filter manufacturers. High-quality aftermarket truck filters offer similar performance to original equipment manufacturer (OEM) products at a more competitive price.
      Professional aftermarket filter manufacturers typically offer:
      Original replacement filter Custom Brands Provide bulk supply to distributors Flexible production solutions Original equipment manufacturer (OEM) filters vs. aftermarket filters: key differences
      feature Original filter Aftermarket Filters compatibility Fully compliant with original factory standards Depends on the manufacturer price higher More cost-effective Brand promotion Original brand Custom/OEM branding services are available. Supply flexibility Limited Flexible Bulk Production custom made low High How to choose a suitable truck filter supplier
      Whether choosing original equipment manufacturer (OEM) filters or aftermarket filters, the quality of the supplier is the most important factor.
      A reliable truck filter manufacturer should provide:
      Stable filtration performance High-quality materials OEM Replacement Support Strict quality control Rapid delivery capability Why do many dealers choose aftermarket filters?
      Today, many global dealers prefer aftermarket truck filters because they offer the following advantages:
      Higher profit margins Original factory quality and performance Flexible Packaging Solutions Reduce procurement costs High-quality aftermarket filters can effectively protect diesel engines while reducing maintenance costs.
      in conclusion
      Original equipment (OEM) and aftermarket truck filters each have their advantages. The key is to choose a trustworthy filter manufacturer that ensures reliable quality and long-term supply support.
      If you are looking for OEM replacement filters, custom filter solutions, or bulk truck filter supplies, partnering with an experienced manufacturer can help your business grow faster.
      website:www.ixinfilter.com
      The Schaeffler division is making two additional Vitesco repair solutions available to the independent aftermarket: a Voltage Stabilization System (VSS) for micro hybrid vehicles from PSA and Toyota, and a 48V DC/DC converter for mild hybrid vehicles from Ford.
      link hidden, please login to view said the VSS, available immediately, prevents voltage drops that can occur during automatic start-stop operation in micro-hybrid vehicles. The system consists of an Energy Storage System (ESS) with high-performance capacitors and a Power Electronics Unit (PEU). During the engine start process, the capacitors release energy stored while driving within a very short time, compensating for the high-power demand. Starting the engine via a starter-generator requires a comparatively high amount of energy.
      If this energy is drawn solely from the conventional 12-volt electrical system, the voltage can briefly drop by several volts, causing visible flickering of the vehicle’s lighting and electronic displays. Schaeffler said that by stabilizing the voltage supply, the capacitors ensure smooth engine restarting and contribute to longer battery life, improved driving comfort and compliance with current emissions standards.
      Schaeffler Vitesco Voltage Stabilization System power electronics unit  Schaeffler Vitesco 48V DC/DC Converter: Efficient Energy Management
      The Schaeffler Vitesco 48V DC/DC converter, available in May, is used in mild-hybrid vehicles equipped with a 48V starter generator and an additional battery to enable more efficient power delivery and boost performance during acceleration. The converter links the vehicle’s 48-volt electrical system with the 12-volt onboard electronics, ensuring stable voltage levels and preventing energy losses.
      The converter is a component of energy management in mild-hybrid vehicles and for achieving type-approval compliant CO2 emissions. Its bidirectional design allows 12-volt components to be supplied from the 48-volt network while charging the starter battery. Conversely, in the event of a temporary failure, the 48-volt system can also draw energy from the 12-volt network.
      Schaeffler Vitesco 48V DC/DC converter Significant Potential for the Aftermarket
      Until now, both the Schaeffler Vitesco Voltage Stabilization System and the Schaeffler Vitesco 48V DC/DC converter were available exclusively as original equipment components. This is a further expansion of the portfolio to include OE-quality Vitesco products.
      These technologies have been installed in large numbers of vehicles worldwide for many years. The Schaeffler Vitesco Voltage Stabilization System enables a 1:1 replacement in approximately 2.7 million vehicles worldwide from PSA and Toyota.
      link hidden, please login to view Vitesco DC/DC converter is used in around 1 million Ford vehicles globally, including Fiesta, Focus and Puma models equipped with the 1.0-liter EcoBoost mHEV engine. “By integrating Vitesco products, we are expanding our portfolio for electrified vehicles,” said Stephan Niese, director, global product management, E-Mobility, at Schaeffler Vehicle Lifetime Solutions. “In this way, we help the aftermarket unlock the potential of e‑mobility and enable workshops to offer their customers professional, future‑ready and profitable vehicle service.”
      TalkRev launched PartsNow.ai, an AI-assisted platform designed to help fleets, owner-operators and repair shops find and purchase heavy-duty truck parts more efficiently. The company said the system uses AI-driven chat, voice interaction and visual recognition to identify parts and connect users with a network of distributors.
      AI Tools Streamline Parts Identification
      According to TalkRev, the platform allows users to search for parts in multiple ways:
      Describing the issue or component Uploading a photo of the part or vehicle VIN Speaking directly with an AI agent The system then identifies the part and provides availability and pricing from its distributor network.
      “Too many mechanics spend their day on the phone calling suppliers just to buy a brake disc or a turbocharger,” said Manna Justin, CEO of TalkRev. “You tell us what you need—type it, say it, or upload a photo of the broken part or the truck’s VIN—and our AI identifies the exact component and sources it from our network of distributors.”
      Integrated Purchasing and Distributor Network
      link hidden, please login to view said it aggregates inventory from a network of distributors, with a catalog of more than 50,000 parts. Users can complete purchases through a single checkout process, with PartsNow handling the transaction. The company said this approach allows distributors to reach customers without building their own e-commerce systems. Voice and Mobile Interaction
      The platform also supports phone-based interaction, where users can describe an issue and receive follow-up questions from the AI agent. TalkRev said the system then sends a text message with product details, pricing and a link to complete the purchase.
      Steve Fultz, president of PartsNow.ai, said the platform is designed to reduce time spent searching for parts and improve access to inventory.
