Parts Authority announced it was awarded the 2025 ACE Award by the Auto Care Association. The award recognizes a commitment to education and professional development within the automotive aftermarket industry. The Auto Care Association presented the award during the 2025 Auto Care Connect event in Phoenix.
Parts Authority Focuses on Employee Education and Growth
said it dedicates itself to investing in education to maintain a competitive edge. This focus stems from a belief that training and development are essential for growth and excellence. The company emphasized that employee development remains critical to its overall success.
Training Investment Builds a Culture of Learning
The company said the impact of this investment has been significant across its organization.
believes its efforts cultivate a culture of learning and position it as a leader in educational initiatives and professional development. Team members value the training programs, describing them as empowering and transformative. These initiatives help employees perform better and support company success.
Leadership Recognizes Award as Validation of Vision
“Winning the 2025 ACE Award is a tremendous honor and a profound recognition of Parts Authority’s dedication to excellence in education and professional development in the automotive aftermarket,” said Clark Hale, CEO of Parts Authority. “This award validates our commitment to fostering a culture of continuous learning and development and highlights the significant positive impact our programs have on our team members’ personal career development and the industry as a whole.”
      Automotive Parts Associates (APA) is pleased to announce that Midwest Parts Hub, a division of Kelley Automotive Group based in Fort Wayne, Indiana, has joined the group as a shareholder.
      Founded in 1952 by Jim Kelley, Kelley Automotive Group is a family-owned dealership group representing multiple vehicle brands and serving customers throughout northeastern Indiana and beyond. Midwest Parts Hub opened in 2025 and services customers throughout the surrounding region through its extensive inventory of genuine General Motors OEM, ACDelco and aftermarket parts, along with daily delivery routes and advanced technology systems. The company emphasizes inventory availability, experienced staff, technology integration and reliable service as key drivers of its continued success.
      “In today’s market, if you want to stay competitive, you need to be part of a program group,” said Mike Smith, parts director for Kelley Automotive Group. “Operating completely on your own is no longer effective. After evaluating our options, we knew
      link hidden, please login to view was the right choice.” “We are excited to welcome Midwest Parts Hub to APA,” said Steve Tucker, president of APA/TruStar. “Their long-standing commitment to service, innovation, and operational excellence makes them a tremendous addition to our shareholder family.”
      For more information about Kelley Automotive Group, visit
      Published by GreenGears Auto  |  8 min read  |  Subframe Buying Guide
      3. Corrosion Protection
      Premature tyre wear
      Our
      🛡️ 90-Day Warranty  ·  🚚 Free US Shipping  ·  ↩️ 15-Day Returns
      link hidden, please login to view proudly presented link hidden, please login to view (GPD) with the 2026 Receiver’s Choice Award at the Auto Care Association’s Automotive Content Professionals Network (ACPN) Knowledge Exchange Conference, held May 11–14 in Atlanta. The award recognizes GPD’s commitment to delivering high-quality, accurate and complete product content, along with its dedication to continuous improvement and industry best practices. The Receiver’s Choice Award honors organizations that provide exceptional content, including ACES, PIES, digital assets, and customer-specific formats. Recipients are selected by content receivers who support ACPN and are evaluated based on accuracy, timeliness, completeness, consistency, and overall data integrity.
      The 2026 award was presented by Lance Brierley, director of technology solutions, and Jimmy Golden, director of eCommerce solutions at Alliance Headquarters.
      “GPD’s commitment to maintaining clean, accurate, and timely content has made a measurable impact across our data ecosystem,” said Jimmy Golden. “Their team consistently demonstrates a strong understanding of the standards and responsiveness required to support our distribution and sales efforts.”
      “What set GPD apart is not only the quality of their data, but also their proactive approach to collaboration and continuous improvement,” added Lance Brierley. “They’ve shown a clear dedication to advancing content excellence in a way that benefits the entire network.”
      Global Parts Distributors was recognized for its outstanding performance in content delivery and for playing a key role in strengthening the digital foundation of product representation across the Alliance network.
      link hidden, please login to view congratulates Global Parts Distributors on this well-deserved recognition and looks forward to continued collaboration and success. Pictured from Left to Right: Lance Brierley, John Johnson, Kassandra Dore, Natalie Houseman and Jimmy Golden.
