If you’re looking for a cost-effective way to maintain your vehicle’s exhaust system, a universal muffler is a smart choice. Unlike custom mufflers, universal mufflers fit a wide range of vehicles, making them affordable and easy to replace. This flexibility means you don’t have to spend extra time or money searching for a specific part.
A good universal muffler helps reduce engine noise, improves fuel efficiency, and prevents costly exhaust leaks. By keeping your exhaust system in good shape, you avoid bigger repairs down the road. Plus, installation is usually quicker and less expensive because of their simple design.
If you want to explore quality universal mufflers that fit most cars and trucks, check out the wide selection available at
. Choosing the right universal muffler can save you money on repairs while boosting your car’s performance and sound.
Invest smartly with a universal muffler and enjoy a quieter, smoother ride without breaking the bank.
    • By elizabeth
      Searching for a Lexus transmission near me often means finding a dependable replacement that delivers luxury-level performance and smooth shifting. Lexus vehicles share many reliable drivetrain components with Toyota models, making their transmissions highly respected for durability and comfort. Whether you own an RX, ES, IS, GX, or LS model, choosing the right transmission replacement helps maintain premium driving quality. Before purchasing, verify the VIN match, mileage history, and transmission condition to ensure proper compatibility. Many drivers choose tested used transmissions because they provide a more affordable alternative to dealership replacements. A reliable Lexus transmission improves acceleration, fuel efficiency, and long-term performance while preserving the smooth driving experience Lexus owners expect from their vehicles.
    • By GreenGears Auto Limited
      Published by GreenGears Auto  |  9 minute read  |  Budget Drivetrain Repairs & OEM Parts Guide
      Drivetrain repairs are among the most expensive on any vehicle — but they don't have to be. Used OEM drivetrain parts from low-mileage donor vehicles deliver the same factory materials, tolerances, and electronic calibration as new dealer parts at 50–70% less cost. At GreenGears Auto, we stock quality-inspected used OEM differentials, transfer cases, transmissions, driveshafts, CV axles, and more — all shipped free across the US, backed by category-specific warranties, and available with a 15-day return window. This guide covers every major drivetrain component, the best budget platforms, and how to buy smart. used drivetrain parts budget differential replacement used OEM transfer case cheap drivetrain repair affordable used transmission parts used CV axle OEM GreenGears Auto What Is a Drivetrain — and Why Do These Repairs Cost So Much?
      The drivetrain is every component that transmits power from the engine to the wheels — the transmission, driveshafts, differentials, transfer case, CV axles, and related hardware. Together, these components absorb the full output of your engine across every acceleration, braking, and cornering event your vehicle experiences. They are engineered to last — but when they fail, the cost of new OEM replacements can make a repairable vehicle feel like a financial write-off.
      50–70% Average savings on used OEM drivetrain parts vs. new OEM dealer pricing at GreenGears Auto $2,500–$6,500+ Typical new OEM automatic transmission cost — the repair that most dramatically benefits from used OEM 90 Days GreenGears Auto warranty on all Carrier, Differential, and Transfer Case components The key insight that most vehicle owners don't know: the majority of salvage-market drivetrain parts enter the used market through collision-damaged donor vehicles — not through mechanical failure. A 55,000-mile Honda Pilot that was rear-ended has a transfer case, rear differential, and front differential that have seen nothing but normal use. The drivetrain is intact. Only the sheet metal and structural components were affected by the collision. That is what makes used OEM drivetrain sourcing so compelling — you are buying a mechanically healthy component at a fraction of new cost.
      🔧 GreenGears Tip — Use Code GGA10 for Extra Savings On top of our already-reduced used OEM pricing, apply discount code GGA10 at checkout for an additional 10% off your entire order plus free shipping. It's the easiest way to maximise your drivetrain repair budget. What Makes a Used Drivetrain Part Worth Buying?
      Not all used drivetrain parts are equal. The difference between a reliable repair and an expensive comeback comes down to three factors — and GreenGears Auto verifies all three on every listing before a part ships.
      📋 Documented Donor Mileage
      A rear differential from a 48,000-mile donor is a fundamentally different purchase from an unknown-mileage unit. GreenGears Auto records and verifies donor vehicle mileage on every drivetrain listing — it's the single most important quality indicator and we never omit it.
      💧 Fluid Condition Inspection
      Every differential, transfer case, and transmission we list is drained before listing. Clean, amber fluid with no metallic debris = healthy internals. Dark, burnt, or metal-laden fluid = rejected from our inventory. This pre-sale check catches hidden internal wear before it becomes your problem.
      🔩 Housing & Seal Integrity
      We inspect every housing for cracks, impact damage, and stripped mounting points. Seal weeping and connector condition are documented on electronic components. A structurally compromised housing or damaged wiring is a disqualifier regardless of mileage or fluid condition.
      New OEM vs. Remanufactured vs. Used OEM — The Drivetrain Decision
      🏷️ New OEM
      Highest cost: $600–$6,500+ depending on component Full dealer markup and import costs 7–21 day lead times on specialty parts Justified only when used OEM is unavailable Full new manufacturing environmental footprint 🔧 Remanufactured
      Typically 20–40% less than new — far less than used OEM savings Core charge adds $200–$800 upfront Quality varies entirely by rebuilder Electronic components often reused from the original worn core Heavy return shipping on core adds cost and hassle ♻️ OEM Used — GreenGears Auto
      50–70% less than new OEM — the largest savings available Original factory assembly — OEM materials and tolerances No core charge, no return shipping of heavy parts Mileage-verified, fluid-inspected, housing-checked Free US shipping + 15-day returns + category warranty Best Used OEM Drivetrain Parts for Budget Repairs
      🏆 Best Drivetrain Value 90-Day Warranty Used OEM Rear & Front Differentials
      GreenGears Used: $180–$900 New OEM: $600–$2,700+ Save up to 70% 🛡️ 90-Day Warranty Rear differentials are one of the highest-value used OEM drivetrain purchases available — and at GreenGears Auto, every carrier, differential, and transfer case carries a 90-day warranty from the confirmed delivery date. That coverage reflects our confidence in our sourcing: these units come from accident-damaged donor vehicles whose drivetrains have been through nothing but normal operation.
      Best budget used OEM differentials by platform:
      Honda CR-V / Accord / Pilot AWD rear differential: $180–$380 — most affordable quality used OEM differential available; Honda's enormous US sales volume drives exceptional availability and the lowest prices in this category Toyota RAV4 AWD rear differential (2013–2022): $200–$440 — Toyota's over-engineering produces units with exceptional remaining service life; widely available from accident-damaged low-mileage donors Subaru Outback / Forester AWD rear differential: $200–$420 — compact viscous LSD design; mechanically simple and very long-lived when fluid is maintained Ford Explorer AWD 8.8-inch rear differential (2006–2019): $220–$480 — one of the most robust OEM differential designs in the mass-market; outstanding used availability from the large Explorer fleet Chevrolet Tahoe / Silverado 8.6-inch rear differential: $260–$580 — heavy-duty unit built for loads most owners never approach; 14-bolt units available for maximum capacity Jeep Grand Cherokee Dana 44 rear differential (2011–2021): $240–$520 — preferred over Dana 35; Trac-Lok LSD available on WK2 Overland and Limited trims Toyota 4Runner rear differential (2003–present): $280–$620 — Torsen LSD option on TRD and V8 trims; extremely long-lived with documented low-mileage donors 🔧 What to Verify Before Your Differential Order Always confirm gear ratio (3.31, 3.55, 3.73 etc.), open vs. limited-slip spec, and AWD vs. 2WD variant. A ratio mismatch — even small — causes drivetrain binding that damages adjacent components. GreenGears Auto's parts specialists verify all three before your order ships. 🔄 AWD/4WD Budget Fix 90-Day Warranty Used OEM Transfer Cases — AWD & 4WD
      GreenGears Used: $240–$1,100 New OEM: $1,000–$3,500+ Save up to 70% 🛡️ 90-Day Warranty Transfer case failure is a uniquely AWD and 4WD repair — and new OEM pricing at $1,000–$3,500+ frequently makes a functioning vehicle feel economically unrepairable. Used OEM transfer cases from GreenGears Auto at $240–$1,100 change that entirely. And as a Carrier/Differential/Transfer Case category component, every unit we sell carries a 90-day warranty from confirmed delivery — the longest warranty coverage on any drivetrain category we stock.
      Toyota RAV4 AWD Active Torque Control transfer case (2013–2022): $240–$460 — most affordable quality AWD transfer case in the market; exceptional reliability; 90-day warranty backed Honda CR-V AWD rear drive unit / RDU (2012–2022): $160–$300 — Honda's Dual Pump System; among the most affordable AWD coupling units available; 90-day warranty coverage Subaru Outback / Forester AWD centre differential (2010–2022): $240–$540 — viscous LSD; no electronics; very long-lived; 90-day warranty Ford Expedition / F-150 BorgWarner transfer case (2007–2020): $420–$780 — Expedition cross-references with F-150 for expanded availability and competitive pricing; 90-day warranty Chevrolet Tahoe / Suburban NP246 / NP263 (1999–2014): $380–$720 — NP263 preferred for towing; heavy-duty BorgWarner chain-driven design; 90-day warranty Jeep Grand Cherokee Quadra-Trac / Selec-Trac: $340–$760 — confirm exact system before ordering; 90-day warranty on all variants Ford Escape / Edge AWD Power Transfer Unit / PTU (2013–2019): $180–$460 — most commonly replaced AWD component on Ford crossovers; 90-day warranty; always install a new PTU seal kit alongside ⚙️ Highest Absolute Savings Check Listing for Warranty Used OEM Transmission Assemblies
      GreenGears Used: $480–$2,200 New OEM: $2,500–$6,500+ Save up to 70% No drivetrain repair generates more absolute dollar savings from used OEM than the transmission. A new OEM Toyota Aisin 6-speed costs $3,200–$5,000 at the dealer. A used OEM unit from a documented low-mileage 4Runner donor at GreenGears Auto costs $680–$1,200 — factory-assembled, factory-calibrated, verified through real-world service in the donor vehicle. Always pull OBD-II fault codes before ordering — a $35–$160 shift solenoid or speed sensor frequently resolves the fault that appears to require a complete assembly replacement.
      Toyota Aisin 6-speed (A760E/A760F) — 4Runner, Tacoma, Tundra: $680–$1,200 — most reliable used automatic transmission in the market; Toyota's conservative engineering produces exceptional remaining service life Ford 6R80 6-speed — F-150, Expedition, Explorer (2011–2020): $580–$1,100 — highest availability of any full-size truck/SUV transmission in the used market GM 6L80 / 6L90 — Silverado, Tahoe, Suburban, Escalade: $620–$1,300 — 6L90 preferred for towing and Escalade applications; confirm torque rating by VIN Honda 5-speed / CVT — Accord, CR-V, Pilot (2013–2022): $480–$980 — exceptional availability from Honda's massive US sales volume Nissan Jatco CVT7 / CVT8 — Altima, Rogue, Sentra: $620–$1,200 — source from sub-60,000-mile donors only; GreenGears Auto documents donor mileage on every CVT listing Subaru TR580 / TR690 CVT — Outback, Forester (2018–present): $580–$1,060 — better reliability than Nissan equivalents; EyeSight calibration required on equipped models BMW ZF 8HP 8-speed — 3 Series, 5 Series, X3, X5: $780–$1,800 — widely regarded as one of the best automatic transmissions ever produced; used units from documented low-mileage donors are outstanding finds ⚠️ Pull Fault Codes Before Ordering Any Transmission Component P0750–P0770 shift solenoid codes, P0715 speed sensor codes, and U0101 TCM communication faults all identify specific components under $200 that cause symptoms identical to complete transmission failure. A $20 OBD-II scan can save you $600–$1,500 in unnecessary parts. 🔗 Most Frequent Drivetrain Noise Fix Check Listing for Warranty Used OEM CV Axle Shafts & Driveshafts
      GreenGears Used: $80–$320 per shaft New OEM: $180–$600+ per shaft Save up to 60% CV axle and driveshaft failure is one of the most common drivetrain noise complaints across all vehicle types — the distinctive clicking sound during turns from a worn outer CV joint is one of the most recognisable signs of drivetrain wear. On AWD and 4WD vehicles, CV axle spec is especially critical: joint angle, boot capacity, and shaft material are precisely matched to the vehicle's AWD torque output and geometry. Aftermarket CV axles for AWD applications have a significantly higher failure rate than used OEM shafts — vibration, noise, and premature boot failure within 30,000 miles are common on budget aftermarket units.
      Front CV axle shafts — Toyota RAV4, Honda CR-V, Ford Escape, Chevrolet Equinox AWD: $80–$180 per shaft used OEM vs. $180–$380 new OEM; always confirm FWD vs. AWD variant — they use different shafts Rear CV axle shafts — Toyota RAV4 AWD, Honda CR-V AWD rear: $90–$200 per shaft used OEM vs. $200–$420 new OEM; rear shafts on reactive AWD crossovers are unique to the AWD variant Front driveshaft / prop shaft — Toyota 4Runner, Chevrolet Tahoe, Ford Expedition 4WD: $120–$280 used OEM vs. $280–$600 new OEM; U-joint condition is the primary inspection criterion Rear driveshaft / prop shaft — Ford Escape AWD, Edge AWD, Explorer AWD: $100–$240 used OEM vs. $240–$500 new OEM; centre bearing condition is the primary wear point on these platforms Complete CV axle shaft assembly — Honda Accord, Toyota Camry, Nissan Altima FWD: $80–$160 per shaft used OEM vs. $160–$320 new OEM; among the best-value used OEM drivetrain purchases available 🎯 Most Targeted Budget Fix Check Listing for Warranty Used OEM Transmission Components — Solenoids, Valve Bodies & Torque Converters
      GreenGears Used: $35–$480 New OEM: $80–$1,200+ Save up to 65% When fault codes point to a specific transmission component rather than a complete failure, targeted used OEM replacement is the most cost-effective repair available. A single failed shift solenoid causes limp mode and harsh shifting that feel identical to a complete transmission failure — but costs $35–$160 to fix rather than $600–$2,200. Correctly identifying the failed component before ordering is the difference between a budget repair and an unnecessary assembly replacement.
      Shift solenoids and solenoid sets (all platforms): $35–$160 per solenoid / $120–$280 for complete sets — P0750–P0770 codes identify specific failures; one of the most common causes of limp mode Transmission input / output speed sensors: $25–$80 per sensor — P0715 / P0720 codes; externally accessible on most platforms without transmission removal Valve body assembly — Honda, Toyota, GM compact platforms: $120–$420 used OEM vs. $400–$900 new OEM; OEM valve body retains factory check ball calibration that aftermarket rebuild kits cannot reliably replicate Torque converter assembly — compact and mid-size platforms: $120–$380 used OEM vs. $280–$700 new OEM; P0740 TCC shudder code; always try fresh OEM-spec fluid with friction modifier additive before ordering Transmission control module / TCM: $80–$320 used OEM vs. $400–$1,600 new OEM; U0101 communication fault code; requires VIN programming after installation on most modern platforms 🔩 Structural Drivetrain Base 90-Day Warranty Used OEM Subframes & Engine Cradles
      GreenGears Used: $160–$680 New OEM: $700–$2,400+ Save up to 72% 🛡️ 90-Day Warranty The subframe and engine cradle are the structural foundations of the drivetrain — every suspension mounting point, steering rack, and engine/transmission mount connects to them. New OEM subframe pricing routinely reaches $700–$2,400+, making collision-damaged vehicles uneconomical to repair when new parts are the only option. Used OEM subframes at GreenGears Auto cost $160–$680 — and as a Subframe/Engine Cradle category component, every unit carries a 90-day warranty from confirmed delivery. Combined with the 50–70% cost savings, this makes used OEM the obvious choice for any subframe repair.
      Honda Accord / CR-V front subframe (2008–2022): $180–$360 — most available and most affordable used OEM subframe in the market; Honda's large accident-donor fleet ensures consistent quality supply Toyota Camry / RAV4 front subframe (2012–2020): $200–$400 — Toyota's corrosion-resistant coating produces cleaner used subframes; excellent accident-donor availability Ford Fusion / Escape / Explorer front subframe (2013–2019): $160–$420 — extremely high availability from Ford's large accident-donor fleet; AWD and FWD variants differ — confirm before ordering VW Tiguan / Golf MQB front subframe (2015–2021): $280–$520 — saves $600–$1,200 vs. new dealer pricing; makes borderline MQB platform repairs fully viable Chevrolet Equinox / Malibu front subframe (2010–2017): $180–$360 — excellent availability from GM's high-volume crossover and sedan fleet Subaru Outback / Forester rear subframe (2010–2019): $200–$420 — IRS rear subframe; AWD variant carries rear differential mount — confirm configuration before ordering GreenGears Auto Warranty by Drivetrain Category
      Every drivetrain component we sell carries a category-specific limited warranty that begins on the date of confirmed delivery. Here is exactly what applies to each component in this guide.
      Component GreenGears Auto Category Warranty Period Notes Rear / Front Differential Carrier / Differential / Transfer Case 90 Days Covers verified functional defects under normal use Transfer Case / AWD Coupling Unit / PTU Carrier / Differential / Transfer Case 90 Days 90-day coverage from confirmed delivery date Subframe / Engine Cradle Subframe / Engine Cradle 90 Days 90-day structural warranty from confirmed delivery Transmission Assembly Check product listing Per listing Verify warranty period on the specific product listing CV Axles / Driveshafts Check product listing Per listing Verify warranty period on the specific product listing Solenoids / Speed Sensors Fuel Injection Controls & Parts 15 Days Electronic components — professional installation strongly recommended Engine Parts Engine Parts 15 Days 15-day warranty from confirmed delivery ⚠️ Warranty Claim Process — Important All warranty claims require prior authorisation from GreenGears Auto before any item is returned. Contact us within the warranty period applicable to your part category, provide your order number, describe the issue clearly, and submit supporting photos if requested. Unauthorised returns may be refused. Do not ship any item back without receiving return authorisation first. Contact: [email protected] or +1 (315) 305-4300. How to Verify a Used OEM Drivetrain Part Before You Buy
      1 Pull Fault Codes First — For Any Electronic Drivetrain Component
      Before ordering a transmission, AWD coupling, or transfer case, pull OBD-II fault codes. Specific codes frequently identify a $35–$160 solenoid, sensor, or actuator as the actual failed component rather than the $400–$1,200 assembly the symptom appears to require. This single step saves most customers significant money before they order a single part.
      2 Request Documented Donor Mileage
      A differential or transfer case from a 48,000-mile highway-driven donor is a fundamentally better purchase than one from a 95,000-mile towing-heavy or off-road example. Always ask for documented mileage — GreenGears Auto verifies and records it on every listing, and our parts specialists can provide it before you order.
      3 Confirm Fluid Condition Was Inspected
      Ask any seller to confirm the fluid was drained and inspected before the part was listed. GreenGears Auto does this as standard on every differential, transfer case, and transmission listing. Clean amber fluid with no metallic particles is the best available indicator of healthy internal condition on any used drivetrain component.
      4 Verify Full Application Spec — Not Just Year and Model
      Drivetrain components vary by engine, transmission, gear ratio, trim level, and drivetrain configuration within the same nameplate. An AWD differential differs from a 2WD unit. A V8 gear ratio differs from a V6. GreenGears Auto's specialists verify gear ratio, drivetrain variant, and trim-specific specification on every order before it ships.
      5 Budget for Adjacent Consumables
      Always budget $30–$90 for the seals, gaskets, and filters that should be replaced alongside any used drivetrain component. Pinion seals, axle seals, differential cover gaskets, and transmission pan gaskets are inexpensive — but skipping them on a used OEM installation is false economy that frequently results in immediate post-install leaks requiring removal and re-installation.
      Budget Drivetrain Repair Quick Reference — Pricing at a Glance
      Component GreenGears Used Price New OEM Price Warranty Best Platforms Rear Differential $180–$900 $600–$2,700+ 90 Days Honda CR-V, Toyota RAV4, Ford Explorer, Chevrolet Tahoe Transfer Case / AWD Coupling $160–$1,100 $1,000–$3,500+ 90 Days Toyota RAV4, Honda CR-V, Subaru AWD, Ford PTU, Chevrolet Tahoe Subframe / Engine Cradle $160–$680 $700–$2,400+ 90 Days Honda Accord/CR-V, Toyota Camry/RAV4, Ford Fusion/Escape, VW MQB Transmission Assembly $480–$2,200 $2,500–$6,500+ Per listing Toyota Aisin, Ford 6R80, GM 6L80, Honda CVT, BMW ZF 8HP CV Axle Shaft $80–$320 ea $180–$600 ea Per listing All AWD/FWD crossover platforms Driveshaft / Prop Shaft $100–$280 $240–$600+ Per listing Ford AWD crossovers, Toyota 4WD trucks, Chevrolet 4WD Valve Body $120–$420 $400–$900+ Per listing Honda, Toyota, GM compact/mid-size platforms Torque Converter $120–$380 $280–$700+ Per listing All automatic transmission platforms Shift Solenoids $35–$280 (set) $80–$600 (set) 15 Days All automatic transmission platforms Transmission Speed Sensors $25–$80 ea $60–$200 ea Per listing All platforms — external access on most GreenGears Auto Policies — Know Before You Buy
      📋 Full Policy Summary for Drivetrain Parts
      🚚 Shipping FREE on all OEM used parts. Processing 1–3 business days; transit 3–7 business days after dispatch. US domestic only. ↩️ Returns 15-day return window from confirmed delivery. Prior return authorisation required — do not ship without it. 25% restocking fee on change-of-mind returns. 🛡️ Warranty — Differentials & Transfer Cases 90 days from confirmed delivery. Covers verified functional defects under normal operating conditions. 🛡️ Warranty — Subframes & Engine Cradles 90 days from confirmed delivery. Contact us within the warranty period with order number and issue description before returning anything. ✅ Defective / Incorrect Items Full refund or replacement, no restocking fee. Report within 48 hours of delivery with photos. Prior authorisation required before return. 📍 US Business Location All orders fulfilled and shipped from within the USA. 19 W 24th St, New York, NY 10010. UK-registered company. Smart Installation Practices — Getting the Full Life From Your Used Drivetrain Part
      Replace all input and output shaft seals on differentials and transfer cases at installation — seal kits cost $30–$90 and prevent the most common post-install leak across all platforms Fill with the exact manufacturer-specified fluid — Toyota WS, Honda DW-1, Nissan NS-3, Ford Mercon LV, GM Dexron VI — never substitute generic ATF or gear oil; the wrong fluid causes rapid clutch pack and bearing damage in modern drivetrains On Ford AWD PTU units, always replace the vent tube at installation — a blocked vent causes internal pressure buildup that destroys output seals within 20,000–40,000 miles regardless of the unit's condition Perform a 4-wheel alignment after any subframe or engine cradle replacement — suspension geometry shifts even with careful reassembly and must be reset to OEM specification On BMW xDrive and Mercedes 4MATIC transfer cases, have the unit coded to the vehicle using manufacturer diagnostic software after installation — uncoded units run in a limited default mode On Subaru AWD vehicles, verify all four tires are within 1/4 inch circumference of each other before returning the vehicle — mismatched tires force the AWD differential to compensate continuously, causing premature wear on any replacement unit Clear all drivetrain, AWD, ABS, and stability control fault codes after installation and perform a comprehensive road test before completing the repair — faults present at this stage are far cheaper to address before the customer drives away Use discount code GGA10 to get 10% off your entire parts order plus free shipping — maximise your repair budget on every component you need Find Budget Drivetrain Parts for Your Vehicle Today
      Tell us your year, make, model, engine, trim, and the drivetrain component you need — our specialists will locate the right used OEM unit, verify the spec, and get it to you in 4–10 business days with free US shipping.
      Use code below for an extra 10% off your entire order:
      🛡️ Up to 90-Day Warranty 🚚 Free US Shipping ↩️ 15-Day Returns 📋 Mileage Verified link hidden, please login to view link hidden, please login to view
    • By Mighty Auto Parts
      link hidden, please login to view appeared first on link hidden, please login to view. With today’s complex systems the repair may involve more than running a diagnostic chart and replacing a defective part. Systems today are so connected that it makes it difficult for the most experienced technician to distinguish between a mechanical, electrical, fuel, or emission related condition without extensive testing. In addition to having the theory and […]
      Tri-State Enterprises announced its 2026 Big Money Show will take place April 25 at the Fort Worth Convention Center in historic downtown Fort Worth, Texas.
      The annual Big Money Show unites
      link hidden, please login to view customers and vendors from across the automotive hard parts, truck accessories and car audio markets. The one-day event will feature exclusive discounts, product showcases, and opportunities to connect and strengthen business relationships. Tri-State to spotlight new products and promotions
      This year’s Big Money Show promises to be the largest yet. It will feature expanded product lines, promotional offers and substantial savings for attendees.
      “The Big Money Show continues to be one of the most anticipated events in our industry,” said Scott Covelli, vice president of marketing at Tri-State Enterprises. “We’re excited to once again bring our customers and vendor partners together for a one-day selling show featuring exclusive discounts, prizes, and opportunities to strengthen partnerships.”
      Fort Worth Convention Center to host 2026 event
      The Fort Worth Convention Center offers a dynamic event space in a central downtown location, surrounded by dining and nightlife options. The venue will serve as the hub for Tri-State’s customers and vendors during the event.
      Tri-State will announce additional details, including registration and hotel information, in the coming months.
