Judge Denise Casper dismissed the entirety of the Alliance for Automotive Innovation’s suit challenging the 2020 Massachusetts Data Access Law. The automakers’ bid to block the Massachusetts
law has failed and the law remains in effect. The judge’s written decision is still under seal but should be made available to the public soon.
“Today’s ruling is a significant victory for the people of Massachusetts—and all Americans,” said Bill Hanvey, president and CEO, Auto Care Association. “This decision by Judge Casper ensures that car owners have the right to access their vehicle’s repair and diagnostic data, empowering them to make informed choices about maintenance and repairs. It levels the playing field, allowing independent repair shops to compete fairly, which in turn drives down costs for consumers. As car owners, we all deserve the freedom to control and manage the data that’s generated by our own vehicles. This ruling is a crucial step toward fostering greater transparency, affordability, and innovation in the automotive industry for the benefit of all Americans.”
said it will update its members with additional information as it becomes available.
      link hidden, please login to view and link hidden, please login to view are gearing up for another season of excitement with the launch of the 2026 Perfect Stop® Powersports Summer Sweepstakes, kicking off this June and running through the end of July. This exclusive MyPlace4Parts promotion gives professional technicians opportunities to win big all summer long with every qualifying Perfect Stop® purchase. Throughout the promotion period, technicians will earn automatic entries with every qualifying purchase of Perfect Stop® products placed through MyPlace4Parts, including brake pads, rotors, calipers, sensors, shoes, brake cleaner, and brake fluid. Participants will have the chance to be one of six Grand Prize winners, each of whom will get to select a powersports vehicle of their choice. In addition, a total of $25,000 in gift cards will be awarded to 150 lucky winners, keeping the momentum going all summer long.
      “Perfect Stop® is more than just individual components—it’s a complete brake job lineup built to deliver confidence from start to finish,” said Justin Hebert, vice president of category management for the
      link hidden, please login to view “From pads and rotors to calipers, fluids, and even sensors, it’s a full-system solution that allows shops to perform complete, reliable, OEM-quality brake service every time. When technicians choose Perfect Stop®, they’re picking perfect—every time.” Built for reliability, coverage, and performance, the Perfect Stop® product line supports light, medium, and heavy-duty applications, giving professional technicians a trusted solution for comprehensive brake jobs across a wide range of vehicles. Like previous years, this promotion will run exclusively on MyPlace4Parts, the industry’s most robust B2B eCommerce solution designed specifically for professional service and repair shops.
      “Combining the strength of the Perfect Stop® brand with the speed and simplicity of MyPlace4Parts makes this promotion especially impactful for professional shops,” added Hebert. “It’s about delivering a complete brake solution backed by a seamless ordering experience that helps technicians save time, stay focused on the job, and continue to service their customers with confidence.”
      Professional technicians, don’t miss your chance to win big while stocking up on a complete brake solution built for performance and reliability. Get your entries in by the end of July and make this summer a Perfect Stop® summer.
      For full promotion details and official rules, visit
      A blown head gasket is one of the most serious engine issues, often leading to overheating, performance problems and costly repairs. Understanding how to evaluate the condition and choose an effective solution is key to preventing further damage and restoring engine operation.
      The head gasket seals the combustion chamber and separates coolant and oil passages between the block and cylinder head. It must contain combustion pressure while maintaining proper fluid flow. When that seal fails, combustion gases, coolant and oil can cross paths, leading to overheating, pressure buildup and loss of engine efficiency.
      Head gasket failure often starts with overheating or long-term engine stress. Customers may report coolant loss with no visible leak, along with white exhaust smoke, rough running, or coolant being forced out of the system. Some vehicles will still run for a period of time, while others overheat quickly. That difference in behavior is critical. It tells you how severe the failure is and helps guide the right repair approach.
      Confirm the condition based on symptoms like coolant loss and overheating with no external leak. Then ask a key question: how long can the engine run before overheating or pushing out coolant? If it can run 15–20 minutes,
      link hidden, please login to view is a strong option for sealing minor to moderate failures. If the issue is more severe, stepping up to a heavier-duty solution may be necessary. Bar’s Leaks Head Seal Blown Head Gasket Repair is designed to create a durable seal, helping restore system integrity when matched correctly to the condition. Head gasket issues come down to sealing failure and severity. Identify the condition, then match it with the right solution.
      This video is sponsored by link hidden, please login to view.
      Published by GreenGears Auto  |  6 min read  |  Steering Parts Buying Guide
      Search our
      🛡️ 15-Day Warranty  ·  🚚 Free US Shipping  ·  ↩️ 15-Day Returns  ·  📋 Mileage Verified
