Clore Automotive introduced its new PRO-LOGIX Model PL6850, 12/24 Volt 120A Flashing Power
Supply and 120/60/40/10A Battery Charger. The company said the PL6850 is designed to provide stable power—on demand, up to 120 amps, to a vehicle electrical system to support module reprogramming, ADAS recalibration, electronic repairs and diagnostic tasks. It also provides full service 12/24V battery charging capability from 10 to 120 amps, to service everything from small vehicle batteries to Group 31 multi-battery packs, Clore said.
In power supply mode, the PRO-LOGIX PL6850 provides power to maintain vehicle electrical system
voltage at a preset level, increasing its output in response to system load increases to maintain a stable
power environment for successful reprogramming. It features a voltage output range of 13.1-14.9V (12V)
or 26.1-29.8V (24V), adjustable in 0.1V increments, allowing the operator to dial the output in exactly as
specified by the supplier of the vehicle under service. According to Clore, it features fast load responsiveness for ultra-quick recovery from system demand increases. It also delivers its massive power with minimal voltage ripple (<100mV), providing a clean flow of power to the vehicle without risk of programming interference.
added that in charging mode, the PL6850 utilizes advanced microprocessor-controlled logic to optimally charge each battery or battery pack serviced. It features the ability to properly charge a wide variety of battery types, including Conventional, AGM, Spiral Wound, Start-Stop, Deep Cycle and Marine lead acid batteries, plus LiFEPO4 Lithium Batteries – enabling beneficial service of virtually any battery type installed in a vehicle. It adapts its charging approach based on the needs of each battery or battery pack it services, including activating a soft start mode on deeply discharged batteries and a battery repair mode on older/distressed batteries. It is also effective on totally dead (0.0V) batteries with its forced start mode, the company said.
Clore explained the PL6850 features detachable and field-replaceable input cable and output leads. The #2 AWG output leads are 13’ long, enabling easy access to vehicle batteries/packs under any condition. The unit includes a handle for easy transport around a shop or in and out of a mobile service vehicle.
      link hidden, please login to view announced it released eight new AmeriPLATINUM Brake Pad numbers and four new AmeriPRO Brake Pad numbers with a wide range of coverage ranging from Buick Encore to Ford Transit applications. The new SKUs cover over 6mm VIO. Also just released in the
      link hidden, please login to view product line: 1 new AmeriPRO Brake Shoe, 2 new AmeriPRO Wear Sensors, 74 new AmeriPRO Coated and Coated R90 Euro Rotor numbers, and 20 VGX Brake Pad numbers with VIO coverage over 44+mm VIO.
      link hidden, please login to view introduces a new line of Transtar Brand 100% all New Components Torque Converters which it said are engineered specifically for 2011-up Ford Trucks and Vans equipped with 6R140 transmissions. Designed to meet the demands of modern gas and diesel powertrains, these converters deliver consistent, dependable performance for today’s rebuilders and come with a 12-month/unlimited mileage warranty.
      Developed by an engineering team with decades of experience supporting global automotive programs, all converters are manufactured to OE specifications and designed to meet or exceed factory performance standards,
      link hidden, please login to view said. Applications & Coverage
      2011-Up Ford F250, F350 and F450 with 6r140 transmission.  2016-Up Ford E350 and E450 with 6R140 transmission.  Available Part Numbers
      TS-FM1261 (6.2L; 6.8L Gas Engines)  TS-FM1262 (6.7L Diesel Engine, 6 Mounting Studs)  TS-FM1265 (7.3L Gas Engine) For optimal performance, pair with Transtar Low Viscosity Fluid.
      Automotive Parts Associates (APA) is pleased to announce that Midwest Parts Hub, a division of Kelley Automotive Group based in Fort Wayne, Indiana, has joined the group as a shareholder.
      Founded in 1952 by Jim Kelley, Kelley Automotive Group is a family-owned dealership group representing multiple vehicle brands and serving customers throughout northeastern Indiana and beyond. Midwest Parts Hub opened in 2025 and services customers throughout the surrounding region through its extensive inventory of genuine General Motors OEM, ACDelco and aftermarket parts, along with daily delivery routes and advanced technology systems. The company emphasizes inventory availability, experienced staff, technology integration and reliable service as key drivers of its continued success.
      “In today’s market, if you want to stay competitive, you need to be part of a program group,” said Mike Smith, parts director for Kelley Automotive Group. “Operating completely on your own is no longer effective. After evaluating our options, we knew
      link hidden, please login to view was the right choice.” “We are excited to welcome Midwest Parts Hub to APA,” said Steve Tucker, president of APA/TruStar. “Their long-standing commitment to service, innovation, and operational excellence makes them a tremendous addition to our shareholder family.”
      For more information about Kelley Automotive Group, visit
      Transtar announces the release of new premium
      link hidden, please login to view, Part #: T72500C, with the following applications: 2007-2018 Chrysler/Dodge/Ram, 68RFE Transmission  The T72500C is a high-quality transmission solution designed for professional rebuilders and installers who demand consistent performance, precise fitment, and long-term durability, according to Transtar.
      The T72500C goes beyond basic replacement parts,
      link hidden, please login to view said, with improved materials and tighter tolerances- delivering: Longer service life Greater resistance to wear and heat Consistent, dependable performance in demanding conditions The post
