While constant velocity (CV) joints are the most popular type of driveline joint in use today, universal or “U” joints are still in use on the driveshaft of many larger SUVs, trucks and vans. U-joints can handle a lot of torque, making them popular for these applications, but why did the CV joint rise in popularity? The question can be answered by looking at the operational aspects of a U-joint.
The basics are this: U-joints are located on the ends of a driveshaft, mounted between the driveshaft and a front and rear yoke. The front yoke attaches to the transmission and the rear yoke attaches to rear differential. As the engine moves from the effects of torque and as the suspension of a vehicle travels up and down, the angle of the driveshaft changes.
A U-joint does two things. First, it transfers the motion between the yoke(s) and driveshaft and, second, it does this at different angles, allowing for driveline movement. Here’s where the fun begins. When a yoke and the driveshaft are in perfect alignment, the velocity from one is transferred to the other at the same rate. However, when there is an angle between the two, the velocity of the driven member fluctuates continuously during rotation.
It can be hard to visualize, but the reason this happens is that as the angle of the U-joint changes, the two halves of the U-joint cross are forced to rotate on a different axis. The drive axis remains at a constant velocity, and the ends of the U-joint connected to it rotate in a consistent circular path at the same velocity.
The driven axis, however, rotates in a path which causes the distance of travel at the outer ends of the U-joint cross to increase or decrease in relation to the consistent points of the drive axis.
This effect results in the continuous fluctuation of velocity between the input and output sides of the U-joint. While the input remains at a consistent speed, the output speeds up and slows down as the points of the driven axis continuously alter between a long and short path of travel.
So, why don’t we feel that on a vehicle with a traditional driveshaft? Because there are two U-joints and the fluctuation on each end balances out, effectively allowing the driveshaft to provide a consistent output speed to the rear differential. The angle of the two joints must be the same, however, and it doesn’t take much wear in one for the angles to differ, and subsequently cause a vibration.
U-joints are known for their propensity to cause vibration, and an inherent disadvantage they have is the greater the angle of the U-joint, the greater the fluctuation in velocity. Anything over 30 degrees and the fluctuation dramatically increases.
The driveshaft I’ve described here represents the majority, but U-joints have also been used frequently in the past on the end of the front axles for a 4WD vehicle, and in the rear of independent rear suspension vehicles on the ends of short driveshafts, known as half-shafts.  Have you ever noticed how jittery an old 4WD truck feels in the front when the hubs are locked, and you turn a corner? Now that you understand how the fluctuation in velocity of a U-joint changes as the angle increases, you know why.
You may have heard of a Double-Cardan U-joint. It is basically two joints side-by side with a common link-yoke in between. This is one of the original concepts for a true CV joint, and they are often referred to as this. The advantage they have is they offer smoother operation at greater angles, and they are common on 4WD trucks, and a common upgrade for lifted trucks where the driveshaft angle is altered considerably.
The drawback to a Double-Cardan joint is they are bulky, and they can still suffer from limitations due to operating angle. The operating limitations of a U-joint ultimately brought about the popularity of the modern CV joint, but the durability of U-joints means we’ll still be seeing them in certain applications.
      link hidden, please login to view announced the release of a complete line of link hidden, please login to view to fit custom
      fuel delivery needs on gasoline, diesel fuel, carburetor and fuel-injected applications. Features include:
      -Multiple mounting configurations
      -Low and High pressure
      -100% Tested in the USA
      For more information, visit
    • By Exhaust Auto
      If you’re looking for a cost-effective way to maintain your vehicle’s exhaust system, a universal muffler is a smart choice. Unlike custom mufflers, universal mufflers fit a wide range of vehicles, making them affordable and easy to replace. This flexibility means you don’t have to spend extra time or money searching for a specific part.
      A good universal muffler helps reduce engine noise, improves fuel efficiency, and prevents costly exhaust leaks. By keeping your exhaust system in good shape, you avoid bigger repairs down the road. Plus, installation is usually quicker and less expensive because of their simple design.
      If you want to explore quality universal mufflers that fit most cars and trucks, check out the wide selection available at
      link hidden, please login to view. Choosing the right universal muffler can save you money on repairs while boosting your car’s performance and sound. Invest smartly with a universal muffler and enjoy a quieter, smoother ride without breaking the bank.
      Cloyes Gear & Products, Inc. (
      link hidden, please login to view) announced it is the 2024 recipient of the “Technical Training” Supplier of the Year Award from O’Reilly Auto Parts. This achievement highlights Cloyes’ commitment to excellence in the automotive aftermarket industry, the company said. The award is given annually by O’Reilly Auto Parts to companies or individuals who demonstrate exceptional quality in providing technical training to their employees and customers, often recognizing their commitment to in-depth product knowledge and effective training programs.
      “This is a testament to the dedication, expertise and passion that our team members have for
      link hidden, please login to view through effective training techniques,” said John Hanighen, CEO of Cloyes. “We are honored to have their hard work recognized by O’Reilly Auto Parts and deeply appreciate their continued support and partnership.” Technical Product Director Cody Smith also was recognized for his outstanding contributions. His innovative training videos have set a new standard for quality in the industry, earning him well-deserved acclaim, Cloyes said.
      Additionally, the Cloyes team was applauded for its successful integration of Rotomaster, the company added. Cloyes was also previously honored with the Sales Support Award in 2022 and the Content and Cataloging Award in 2020.
