ADAS: Coming of Age
It’s a common comeback: a failed starter covered in oil. Let’s break down why replacing it alone won’t fix the issue and how to prevent it.
The starter converts electrical energy into mechanical rotation to crank the engine. It relies on clean, dry internal components for proper operation. Engine seals, like valve covers, cam seals, rear main seals and oil pans, are designed to keep oil contained. When these seals fail, oil can leak externally and contaminate components mounted below, including the starter.
In some vehicle layouts, a rear main seal leak can travel along the bellhousing and reach the starter, though that depends on how the engine and transmission are positioned.
An oil-soaked starter can suffer internal damage to brushes and electrical contacts, leading to slow crank, intermittent operation, or no crank at all. Oil also attracts dirt, accelerating wear.
Heat plays a role as well. On vehicles where the starter is located near the exhaust, oil contamination can bake onto the housing and internal components, forming a varnish or sludge. That buildup can increase electrical resistance and further degrade starter performance.
In real world situations, a technician may replace the starter, only to see the new one fail prematurely. That often results in warranty returns, but the real issue is the unresolved oil leak continuing to contaminate the replacement unit.
Verify the starter concern, then inspect for oil contamination. Check above the starter for leaks from valve covers, cam seals, or rear main seals. ASE diagnostic logic emphasizes fixing the root cause before replacing components. The correct repair may involve replacing the failed gasket or seal. If immediate repair isn’t practical,
link hidden, please login to view can be used to help restore seal condition and reduce leakage. To apply, add it to the engine oil, do not overfill, run the engine to circulate, then drive normally. Most leaks stop within a few days of operation. If the starter is oil-soaked, the leak is the problem. Fix it, or the failure will come back.
This video is sponsored by link hidden, please login to view.
Autel U.S. announced that its Autel Academy ADAS Training Program has received accreditation from the National Institute for Automotive Service Excellence (ASE) and the Inter-Industry Conference on Auto Collision Repair (I-CAR).
ASE and I-CAR Accreditation
The ASE and I-CAR accreditation confirms that Autel’s instructor-led training program meets the requirements for technician training and development as defined by these organizations. ASE and I-CAR are widely recognized as benchmarks in automotive service and education, and their endorsement signals that Autel’s curriculum delivers industry-relevant instruction aligned with current technological demands.
Matt Shepanek, vice president of credential testing programs at ASE, emphasized the significance of the accreditation process, noting that it delivers meaningful value for both training providers and the industry. “Accreditation provides training organizations with recognized credibility, ensures their curriculum aligns with current industry standards, and verifies that they are maintaining high-quality instruction, facilities, and resources,” said Shepanek. “Autel successfully met all of these criteria, and we are pleased to recognize them as an ASE-accredited training provider.”
ADAS Calibration Training Program
link hidden, please login to view link hidden, please login to view launched its ADAS calibration training program in 2023 at its U.S. corporate headquarters in Port Washington, New York. The program combines structured classroom instruction with hands-on experience in a dedicated training bay, allowing technicians to work directly with ADAS calibration equipment and real-world vehicle scenarios. The classroom portion delivers a foundational understanding of ADAS theory, including system architecture, sensor types, OEM calibration requirements, and workflow best practices. Hands-on training reinforces this foundation as technicians perform static and dynamic calibrations on vehicles in a controlled, real-world environment.
The program also emphasizes diagnostic strategy and troubleshooting to help technicians identify and resolve common calibration issues encountered in shop settings. Topics include alignment variables, target placement errors, environmental factors, and system fault conditions.
Following strong demand,
link hidden, please login to view has expanded its training footprint to additional locations, including Michigan, Missouri, California, and Florida, making advanced ADAS education more accessible to technicians across the country. Technician Certification Assessment and Continuing Education Credits
To further enhance the program, Autel will introduce a third day of training to its current two-day course. This additional day will include a technician certification assessment, enabling participants to demonstrate mastery of the curriculum.
Successful completion will provide technicians with ASE and I-CAR continuing education credits, reinforcing both their technical competency and professional credentials.
“We are proud to have our ADAS Training Program recognized by ASE,” said Chris Gutierrez, Product and Training Director – ADAS, Autel North America. “This accreditation validates the depth and quality of our curriculum and our hands-on approach. Our goal is to ensure technicians leave our program well prepared to perform accurate ADAS calibrations with confidence and consistency in real-world shop environments.”
Technicians and ADAS Systems
For technicians, this training represents an opportunity to build expertise in one of the fastest-growing and most technically demanding areas of automotive service. ADAS systems directly impact vehicle safety, and improper calibration can lead to system malfunctions or compromised performance.
Through Autel’s ASE and I-CAR-accredited program, technicians gain the confidence to perform precise calibrations, reduce liability risks, increase shop efficiency, and position themselves as trusted specialists in advanced vehicle technology.
With this accreditation, Autel continues to strengthen its role as a trusted partner for repair shops, technicians and industry professionals seeking reliable tools and comprehensive education in ADAS technologies.
For more information or to book your class today, click
Now is the time for counter professionals to get up to speed on Advanced Driver Assistance Systems (ADAS).
These systems have quickly become one of the fastest-growing segments in the aftermarket. During a recent media conference call, Chris Gardner, senior vice president of programs and technology at
link hidden, please login to view, shared new findings from the organization’s updated ADAS outlook report. The projections, now extended through 2035, show stronger and faster growth than initially anticipated. “The ADAS replacement component market will reach around a billion dollars by 2029,” Gardner said. “That’s one year earlier than what we had reported in our earlier study.”
The original study, published in 2022, sparked high interest across the industry. In response, MEMA released an updated version of the report titled
link hidden, please login to view, three months ago. The new study offers a more detailed 10-year view of calibration and component replacement trends, along with a breakdown of growth across collision and mechanical channels. Mechanical Repair Takes Center Stage
Historically, collision repair shops dominated ADAS calibration work, driven by accident-related sensor and camera replacements. However, the MEMA study now shows a major shift underway, especially for mechanical repair segments.
“There’s tremendous growth there,” Gardner said. “It’s a clear picture of the tremendous business opportunities for our members in the ADAS space.”
According to the report, the collision segment will see a compound annual growth rate (CAGR) of 6% through 2035. But mechanical repair will outpace that significantly with a 13.5% CAGR. Combined, the two segments reflect an overall CAGR of 9.5%.
Turning Point Expected by 2031
One of the most critical takeaways from the study is when mechanical ADAS work will match and then surpass collision repair.
“By 2031, the ADAS replacement component market for mechanical repairs will equal collision,” Gardner explained. “And then going forward after 2031 will exceed the collision market.”
This forecast represents a clear opportunity for automotive parts counter professionals. As mechanical shops take on more ADAS service, the demand for replacement sensors, brackets, cameras and calibration tools will continue to rise. Counter pros who understand these systems and stock the right parts will be best positioned to support their customers and grow their business.
Hunter Engineering has introduced a website that breaks down sophisticated ADAS procedures and terminology into easy-to-understand topics, as a means to help simplify the ever-complicating conversations around ADAS.
Available for free to access and use, Hunter’s interactive ADAS Learning Tool works on touchscreen tablets or desktop computers. Designed to assist counter workers or allow customers to explore on their own, the tool succinctly answers many of the why, when and how questions both shops and consumers have regarding ADAS calibrations,
link hidden, please login to view explained. “ADAS has received plenty of attention the past several years, but comparatively little of it deals with talking to actual vehicle owners,” said Tommy Maitz, Hunter director of marketing. “This learning tool will help shops have more informative and effective conversations with their customers about which systems are included on their cars, and the need for calibrations.”
The tool begins by separating ADAS procedures into four main categories – camera, radar, ultrasound, internal – and provides brief overviews and images for each type to aid with in-person discussions. From there, a user can examine the color-coded vehicle image to learn about the specific functions and locations of ADAS components, and when calibrations would be recommended or required.
Also included on the page are extensive lists of the names OEMs use for the ADAS systems across their models, color-coded to locations on the image. Although the names vary widely across the dozens of OEMs, the functions usually fall into one of the four main categories, Hunter said.
“While shops generally know much more about ADAS than their customers at this point, there’s still some confusion and uncertainty when they talk to them,” Maitz said. “This tool is a quick and easy way for everyone to understand the concepts and get on the same ADAS page.”
For more information, visit
link hidden, please login to view announced it has released Guided ADAS. This application enables Autel Calibration system owners to use their frame, targets and expedited setup, with OE software accessed in-house or via the Autel Remote Expert platform, to calibrate vehicles not yet covered by Autel tablet ADAS calibration software, according to Autel. “We are always playing catchup when it comes to coverage. That is just the reality of being an aftermarket software developer. Yet, technicians, especially those working in collision, need to calibrate new or newer vehicles. With Guided ADAS, Autel users can take advantage of all the benefits of their calibration systems—ease of use and efficiency—step-by-step instructions, optical positioning, unlevel floor compensation, and validated documentation, along with our quality targets, patterns, and calibrators—and use OE calibration software to complete the task,” said Stewart Peregrine, senior executive of ADAS sales at
link hidden, please login to view. Guided ADAS, which is compatible with all of the Autel calibration systems: the Standard, MA600, IA800, IA900, or the new IA700 frames, allows shops to use their own OE subscriptions and tools or contract with a Remote Expert with OE software subscriptions for the setup specifications and to initiate ADAS calibration on new vehicles, according to Autel.
There are three calibration scenarios available in the application
The first allows the in-house or Remote Expert technician who has referenced the OE calibration data and has determined that the vehicle uses the same procedures and targets as a previous model year to retrieve the detailed setup instructions, including target type from the Autel calibration database. Autel offers calibration coverage for more than 40 brands and hundreds of models and model year vehicles sold in North America.
The second application allows technicians to input and save the specifications for completely new or existing vehicles with new-to-the-model ADAS components that lack historical parameter data.
The third scenario allows technicians to use the Autel patterns, targets, and calibrators identified by the OE as acceptable for calibrating the identified vehicle. The technician would then determine the position identification method, i.e., radar location, front camera, or front of the vehicle, then input the distance and height of the target to meet the OE’s vehicle placement requirements.
Next, the user selects “Start Placement.” The system will display placement instructions for MA600 or Standard frame system users or activate the optical positioning cameras and guide the user to place the target and frame at the correct distance, offset, and angle to the vehicle when the IA700, IA800, and IA900 frames are used.
Remote Expert Platform
The Autel Remote Expert platform enables technicians to contract with an experienced technician with OE tools or subscriptions to complete the calibration if needed. Remote Experts are also available for modular flashing, new ECU programming, and OE tasks currently not supported by Autel software. Released on the Autel MaxiSYS Ultra series of tablets over two years ago, the Remote Expert platform has seen incredible growth, averaging more than 4,000 monthly orders.
“Remote Expert is like a virtual lifeline from the technician to an Expert. Whatever the challenge, from a tricky diagnosis to module programming, a technician can use the platform to reach out to an Expert. ADAS calibration assistance has quickly grown in need. With the development of Guided ADAS, we foresee even greater growth,” Autel’s Director of Technical Operations, Maurice Miller, said of the platform.
