The 2013 Ford F150 equipped with a 3.5L EcoBoost engine was running perfectly. With the exception of a drop in fuel economy, there was no indication of a problem until the Check Engine light in the dash illuminated. A system scan revealed P2098 code stored in memory, which represents Post Catalyst Fuel Trim System Too […]
      Searching for a Lexus transmission near me often means finding a dependable replacement that delivers luxury-level performance and smooth shifting. Lexus vehicles share many reliable drivetrain components with Toyota models, making their transmissions highly respected for durability and comfort. Whether you own an RX, ES, IS, GX, or LS model, choosing the right transmission replacement helps maintain premium driving quality. Before purchasing, verify the VIN match, mileage history, and transmission condition to ensure proper compatibility. Many drivers choose tested used transmissions because they provide a more affordable alternative to dealership replacements. A reliable Lexus transmission improves acceleration, fuel efficiency, and long-term performance while preserving the smooth driving experience Lexus owners expect from their vehicles.
      Fixing a fuel tank? Check Dorman first.
    • By NAPA
      A weekend of record high temperatures presented challenges for teams competing at the NHRA Arizona Nationals, but Rookie of the Year contender Maddi Gordon and her
      link hidden, please login to view Top Fuel team adapted well and reached the semifinals for the second consecutive race Sunday afternoon at Firebird Motorsports Park. The Ron Capps Motorsports driver had the quickest car on the property on Friday and ultimately qualified a career-best fourth, setting up a promising race day in the heat. Gordon is now fifth in the Top Fuel points standings after the second of 20 races.
      With crew chiefs Rob Flynn and Troy Fasching calling the shots, Gordon was the star of the first qualifying session on Friday morning as she fired off the only sub-4-second pass of the session, a 3.844-second E.T. at 329.42 mph. Though she didn’t improve in the second session, she maintained the top spot to end the day as the provisional No. 1 qualifier for the first time as a professional driver. Saturday brought Gordon’s first career Mission #2Fast2Tasty Challenge, a race-within-a-race featuring the semifinalists from the previous event. It was a side-by-side race from stripe to stripe, but Gordon’s 3.806 E.T. came up just a tick short to two-time and reigning world champion Doug Kalitta and his 3.804 E.T. In the challenging final qualifying session, Gordon’s machine lost traction around half-track and coasted to the finish line, ultimately settling into the No. 4 starting position.
      On Sunday morning, Gordon lined up against newcomer Jaren Mott. Gordon grabbed the starting line advantage and never looked back, powering to a 3.852-second pass at 324.98 mph to move on. Gordon then met up with 2025 regular season champion Tony Stewart in the quarterfinals. Though Stewart moved first, Gordon drove around him with an ultra-consistent 3.851 E.T. at 324.83 mph. In the semifinals, matched up with past world champion Shawn Langdon, Gordon started to lose traction down-track and coasted across the finish line behind Langdon. She did, however, earn a spot in the next Mission #2Fast2Tasty Challenge with her semifinal appearance.
      “Rob and Troy have proven they know how to walk it down the hot racetracks,” Gordon said. “It’s not about applying all the power. It’s walking it through there, which can be harder than trying to slam down those fast runs at times. I’m just really, really happy. I was in the car just looking around, thinking, ‘There is nobody else I’d rather drive for than Ron (Capps), Rob and Troy, Chuck (Grospitch), everybody on our team, Carlyle Tools, and Monster Energy.
      “My reaction times are getting a little bit more consistent in the .080s, and my dad and I worked on that on the practice tree this weekend,” continued Gordon, referencing her father, three-time NHRA Top Alcohol Funny Car world champion Doug Gordon. “As much time as the crew chiefs spend in the lounge making the race car go fast, I try to spend the same amount of time making me the best driver I can be. My reaction time on the starting line and my reaction time catching it when it smokes the tires or something like that is what’s going to make me a valuable driver, so that’s what I’m trying to work on.”
      Gordon’s rookie season behind the wheel of the Carlyle Tools Top Fuel dragster will continue in three weeks at one of her home races on the NHRA Mission Foods Drag Racing Series tour, the NHRA Winternationals, April 10-12, at In-N-Out Burger Pomona Dragstrip in Pomona, California.
      Start / Finish: No. 4 / def. in semifinals
      Points Standing / Total: No. 5 / 152 pts. (-24)
      Next Race: April 10-12, NHRA Winternationals, Pomona, Calif.
      How to Watch or Listen: FS1,
      link hidden, please login to view NAPA Racing:
      link hidden, please login to viewMaddi Gordon:  link hidden, please login to view
      Ron Capps Motorsports:  link hidden, please login to view The post
