Performance Ceramic Front & Rear Brake Pads
- 1,002 views
The Best Front And Rear Brake Pads For Cars, Trucks & Suvs
By garryhe,
- ketullabrakes
- frontbrakepads
- 1 reply
- 1,697 views
- 1,167 views
- 1,353 views
Should I replace front and rear brakes at the same time?
By garryhe,
- ketullabrakes
- brake pads
- (and 7 more)
- 1,250 views
By juliaanderson
One thing I've noticed is that many drivers pay attention to engine performance or tyre condition but often forget about their braking system until something feels wrong.
I've started making it a habit to check the condition of my brake pads during regular maintenance instead of waiting for warning signs. It gives me more confidence on the road and can help avoid unnecessary repair costs later.
What about everyone else here? Do you replace brake pads on a schedule or only when you notice noise, vibration, or reduced braking performance? I'd be interested to hear what maintenance routine has worked best for you.
By elizabeth
Replace your 2014 Nissan Sentra transmission with a quality CVT unit from our trusted inventory. The Continuously Variable Transmission in the 2014 Sentra is known for smooth, fuel-efficient performance. We carry low-mileage, fully tested CVT transmissions sourced from reliable vehicles and reputable suppliers. Each unit is inspected to ensure proper function and long-lasting reliability before shipping. Whether your transmission is slipping, jerking, or has completely failed, we have the right replacement for your Sentra. All purchases include a warranty and fast nationwide shipping for quick turnaround. Contact us today to check availability, confirm compatibility, and get a competitive quote. Get your Nissan Sentra shifting smoothly again with confidence.
By elizabeth
The BMW i8 engine features a unique hybrid setup combining a turbocharged engine with electric motors. This system delivers both efficiency and impressive performance. Buyers should ensure all hybrid components are included and functioning properly. Repairs can be expensive, so choosing a tested unit is important. Availability may be limited due to the vehicle’s exclusivity. Always verify compatibility and condition before purchase. Investing in a quality engine ensures better performance, efficiency, and long-term reliability for this advanced sports car.
SAF-Holland has launched BrakeSight, a brake monitoring system for Haldex air disc brakes that provides continuous, real-time visibility into wear at the wheel end. The company said the system targets fleets seeking more predictable brake service intervals and streamlined repair planning.
SAF-Holland said BrakeSight helps fleets schedule brake service at the optimal moment, extend rotor life, avoid unnecessary repairs and reduce overall maintenance costs.
How BrakeSight Brake Monitoring Works
BrakeSight is an optional feature for the Haldex ModulT air disc brake. As the adjustment mechanism rotates to compensate for pad and rotor wear, the system monitors this movement and translates it into a percentage of remaining pad and rotor life at each wheel end.
The sensor connects to a frame-mounted electronic control unit (ECU), which converts the signal and outputs real-time data via CAN. Designed for both tractor and trailer air disc brakes, BrakeSight is J1939 compliant and compatible with all telematics platforms. SAF-Holland works with telematics providers selected by the fleet and offers open integration without exclusive partnerships.
Built for Real-World Fleet Conditions
SAF-Holland said BrakeSight combines durability with ease of use. Features include:
Continuous measurement of brake pad wear; Ultrasonically welded sensor housing for long-term durability; IP6K9K sealing for harsh road and wash-down environments; Sensor warranty of 3 years or 350,000 miles, matching ABS coverage; Operating temperature range from -40 C to 125 C. Because all ModulT air disc brake calipers include the sensor mounting feature as standard, OEMs and fleets can add BrakeSight at any stage without replacing the caliper. This supports flexibility throughout the vehicle life cycle.
By providing real-time insight into brake wear, the system helps fleets create more accurate maintenance schedules, reduce unplanned downtime and protect brake components. The company positioned this as a way to lower total cost of ownership and improve uptime.
