If a customer mentions that they’re seeing fluid trickling from a suspension bushing, their eyes aren’t playing tricks on them. That bushing could be hydraulic.
Hydraulic suspension bushings were developed in response to customer demands for smoother, quieter and better-handling vehicles. To achieve this, sophisticated suspension components are needed. Modern suspension systems look a lot different than they used to, with multiple links used to maintain suspension geometry.
A non-hydraulic suspension bushing typically will feature a number of empty voids inside them. These voids are a product of clever engineering, and they allow for deflection/compression in a specific direction when placed under load. Hydraulic bushings fill those empty voids with a fluid. This fluid works like a hydraulic damper, while still allowing for deflection/compression when under load.
The word “hydraulic” might imply that hydraulic fluid or oil is used inside these bushings, but they typically use a glycol mixture instead. Oil or hydraulic fluid would break down the rubber inside the bushing and cause it to fail prematurely. If you’ve ever seen a radiator hose that got coated in engine oil, you know what we’re talking about.
These bushings are engineered with a certain tire and wheel combination in mind. This means increasing the tire and/or wheel sizes can throw this off, and the suspension may need to be repaired more frequently.
Hydraulic bushings are able to isolate noise, vibration and harshness (NVH) from entering the vehicle cabin more effectively than standard bushings. Hydraulic bushings can be firmer without compromising passenger comfort, leading to crisp steering response and road feel. They will deflect less under load, such as braking or hard cornering, and this means better vehicle stability.
But, all bushings eventually will wear out and need to be replaced. Hydraulic bushings may crack, rip or tear, just the same as non-hydraulic bushings will. The big giveaway is the hydraulic fluid leaking from the bushing.
Failing hydraulic bushings typically exhibit one or more of the following symptoms:
  • Clunking or knocking noises while braking or turning
  • Evidence of fluid leaks coming from the bushings
  • Unwanted suspension movement
  • Tire wear (from excessive suspension movement)
  • Increased NVH transferring into the vehicle cabin
Replacement Tips
Hydraulic bushings likely will be more expensive to replace than standard bushings. Here are a few tips and tricks to share with your customers.
Let’s start with the most important tip: Always check the OE service information. Even if your customer has performed this type of repair in the past, it’s still a good idea to check the service information to see if anything has been updated recently. They should road-test the vehicle before and after the repair.
If your customer is pressing a hydraulic bushing into or out of a suspension arm, they should be careful not to apply force directly against the rubber part of the bushing. Doing this will most likely rupture the rubber bushing, causing the hydraulic fluid to spill all over the floor. Once this happens, the bushing is ruined and must be replaced. Be sure to only apply force against the outer race or sleeve.
Modern bushings likely will feature some sort of locating mark, notch or indicator. Reference the OE service information to learn how to correctly align the bushing to the suspension arm. Doing this will allow the suspension to articulate properly. Failure to do this may cause the suspension to bind up during movement, and/or cause the bushing to wear out or fail prematurely.
It’s strongly recommended to wait to torque the fasteners down to specification until the suspension has been set to normal ride height. If the fasteners are tightened down with the vehicle in the air, the bushing will be forced to twist when the vehicle is lowered onto the ground. This means that the bushing will always be twisting at normal ride height, and this will surely lead to premature wear, tearing and/or failure.
Finally, your customer should perform a four-wheel alignment if the service information calls for it. Some suspension components may not require an alignment after service; it depends on the make, model and application.
      Published by GreenGears Auto  |  9 minute read  |  Suspension Repair & Noise Diagnosis Guides
      Suspension noise is one of the most common — and most frequently misdiagnosed — complaints in the automotive repair market. A clunk over bumps, a squeak when turning, a rattle at low speed, or a groan when braking all point to different failed components. Ordering the wrong part is the most expensive suspension noise mistake. The second most expensive is replacing an OEM component with an aftermarket equivalent that reintroduces the noise within 20,000 miles. At GreenGears Auto, we source OEM used suspension components across every major platform — the exact parts your vehicle was engineered around, at 50–70% less than new. This guide maps every suspension noise type to the specific OEM part responsible, so you can diagnose correctly, source smartly, and fix it once.
      Why Suspension Noise Diagnosis Matters Before Ordering
      Suspension noise is rarely random. Every noise type — clunk, squeak, creak, rattle, groan, knock — has a mechanical source that produces it consistently under specific conditions. Matching the noise to the condition it occurs in is the fastest and most reliable path to identifying the failed part before spending a single dollar on components.
      68% Of suspension noise repairs involve a part that was already worn at the previous service appointment   3x More likely to misdiagnose suspension noise without a condition-specific approach to diagnosis   40% Of suspension noise comebacks involve an aftermarket part that failed to replicate OEM NVH characteristics   🔧 GreenGears Tip — The Condition Is the Clue Before ordering any suspension part, document the exact condition that produces the noise: What speed? What road surface? Braking, accelerating, or coasting? Turning left, right, or straight? Weight transfer forward, rearward, or lateral? Each answer narrows the diagnosis from dozens of possible components to two or three. This guide uses that condition-based approach throughout.
      Suspension Noise Types — Matched to Conditions and Components
      💥 Clunk Over Bumps
      Both front corners → Strut top mounts / strut mount bearings One front corner → Sway bar end link or control arm bushing Rear, both sides → Rear sway bar links or trailing arm bushings Severe / loud clunk → Ball joint or worn strut Clunk with body lean → Sway bar bushing centre mount
      🔊 Rattle at Low Speed
      Front end, parking lot speed → Sway bar end links (most common) Under the car, loose sound → Heat shield or exhaust contact Front only on rough surfaces → Strut top mount bearing worn Rear of vehicle → Rear sway bar links or lateral arm bushings Goes away when braking slightly → Brake pad anti-rattle clips
      😣 Squeak or Creak When Turning
      Slow speed turns, steering input → Upper strut mount bearing Full lock or near-lock turning → CV axle (inner or outer joint) Squeak from suspension travel → Dry ball joint or tie rod end boot Creak when weight shifts → Control arm bushing (rubber drying) Squeak with steering wheel movement → Power steering rack mount
      💨 Groan or Moan Under Load
      Braking — front end groans → Front struts weak / bottoming Acceleration — rear groans → Rear trailing arm or leaf spring bushing Cornering weight transfer → Sway bar bushings or end links Parking manoeuvres → Power steering rack or CV joint Going over speed bumps slowly → Strut bump stop worn or missing
      🔩 Knock at Specific Speeds
      Highway speed vibration / knock → Wheel bearing or driveshaft balance Knock that disappears above 40 mph → Tyre flat spot or wheel balance Knock under hard braking → Loose brake caliper bracket Metallic knock in turns → Worn wheel hub bearing Knock with steering input → Loose tie rod end or steering rack
      🎵 Hum or Drone
      Constant hum, speed-dependent → Wheel bearing failure Hum changes on lane change → Confirms wheel bearing (load shift) Hum in turns only → Bearing load-dependent failure stage Hum from rear only → Rear wheel bearing or differential Hum with ABS light → Wheel speed sensor integrated in hub
      Top OEM Parts for Fixing Suspension Noise — By Component
      Here is every OEM suspension component responsible for noise, ranked by how frequently it is the primary cause of a suspension noise complaint in the repair market.
      🏆 #1 Most Common Noise Source Rattle / Clunk at Low Speed
      Sway Bar End Links
      OEM Used Price: $25–$80 per side Noise: Rattle & Clunk over bumps Sway bar end links are responsible for more suspension noise complaints than any other single component — by a significant margin. They are also the most frequently overlooked during routine inspections because they appear robust externally even when the internal ball joint or bushing has completely failed. A failed end link allows the sway bar to float freely at its mounting point, producing the distinctive metallic rattle that is loudest at parking lot speeds and over sharp low-speed bumps.
      Why OEM end links outperform aftermarket:
      OEM end links use factory ball joint preload — aftermarket units frequently feel loose immediately after installation or develop play within 15,000 miles due to inferior ball joint quality OEM rubber boots seal the ball joint from contamination for the expected service life — aftermarket boots crack or split earlier, accelerating joint wear Factory geometry ensures the correct sway bar angle at the connection point — incorrect aftermarket length changes effective sway bar stiffness and can reintroduce body roll Replace front and rear end links as sets — if one has failed, the others are at similar mileage and condition High-frequency platforms: Ford Explorer, Chevrolet Silverado / Tahoe, Toyota RAV4, Honda CR-V, BMW 3 Series / 5 Series, Subaru Outback — all see very high sway bar end link failure rates at 60,000–90,000 miles.
      🔝 #2 Most Misdiagnosed Noise Source Clunk / Creak When Steering
      Strut Top Mounts & Mount Bearings
      OEM Used Price: $45–$140 per side Noise: Clunk over bumps / Creak when turning Strut top mounts are the rubber-isolated mounting points where the strut assembly connects to the vehicle body at the top of the wheel arch. They serve two critical functions: absorbing the high-frequency vibration that would otherwise transmit directly from the strut into the cabin, and providing the pivot bearing that allows the front strut to rotate as the wheels steer. A failed strut mount produces a clunk that is almost identical to a ball joint or control arm bushing — making it one of the most commonly misdiagnosed suspension noise sources in the market.
      The strut mount bearing (also called the upper strut bearing or strut bearing plate) is a separate component from the rubber isolator on many designs — inspect both independently A worn strut mount bearing specifically causes a scrubbing or creaking noise during steering input at low speed — distinct from the bump-induced clunk of a failed rubber isolator OEM strut mounts are tuned to the exact spring rate and damping characteristics of the OEM strut — aftermarket mounts with different rubber compound durometer alter the suspension's NVH characteristics Always replace strut top mounts when replacing struts — the labour overlap makes it a negligible additional cost; replacing the strut while leaving a worn mount produces a disappointing result for the customer Highest failure frequency: Toyota Camry, Honda Accord, Ford Fusion, Chevrolet Malibu, Volkswagen Jetta / Passat — all see high strut mount failure rates at 70,000–100,000 miles
      ⚙️ #3 Highest Impact on Multiple Symptoms Clunk / Creak / Alignment Drift
      Control Arm Bushings & Complete Control Arms
      OEM Used Price: $60–$220 per arm Noise: Clunk over bumps / Creak under load Control arm bushings are the rubber-to-metal pivot sleeves that allow the control arm to rotate through its travel arc while isolating chassis vibration from the steering and body. When they crack, collapse, or separate, the control arm gains unwanted freedom of movement — producing a clunk or knock that changes with road surface, vehicle speed, and braking load. Beyond noise, failed control arm bushings directly compromise wheel alignment geometry on every bump, causing rapid and uneven tyre wear that is the most expensive secondary consequence of delayed bushing replacement.
      Control arm bushing failure produces a clunk that is typically heard and felt simultaneously — the noise is accompanied by a subtle kick through the steering wheel or floor on the affected side OEM used complete control arm assemblies are almost always more cost-effective than pressed-in bushing replacement — they eliminate the need for a hydraulic press, provide new OEM bushings, and install in the same time as the bare arm OEM rubber compound is formulated for the correct balance of compliance and isolation for the specific vehicle — aftermarket urethane bushings are stiffer, transmit more road noise, and change the suspension's designed handling characteristics Always perform a 4-wheel alignment after control arm replacement — suspension geometry will have shifted even when the replacement is exact Highest failure frequency: Ford Explorer (front lower), Honda Accord (front lower), Toyota Camry (front lower and rear), BMW 3 Series (front lower thrust arm), Subaru Outback (front and rear) 🔧 Complete Arm vs. Bushing Replacement — The Economics A pressed-in bushing replacement requires a hydraulic press, alignment fixture, and specialist labour — typically $80–$150 per bushing in labour alone. An OEM used complete control arm assembly installs in the same time as the bare arm with no press required, and costs $60–$220 in parts. For most common platforms, the complete arm is the smarter purchase.
      ⚠️ #4 Most Safety-Critical Noise Source Clunk / Squeak — Safety Critical
      Ball Joints (Upper & Lower)
      OEM Used Price: $45–$180 per joint Noise: Clunk over bumps / Squeak when turning Ball joints are the pivot points between the control arm and the steering knuckle — they allow the wheel to simultaneously steer left and right and move up and down with suspension travel. A worn ball joint produces a clunk that is very similar to a strut mount or control arm bushing failure, with one critical distinction: a ball joint does not just make noise. A failed ball joint is a safety hazard. Ball joint separation at highway speed causes immediate and catastrophic loss of directional control. Any clunk that cannot be definitively attributed to a bushing or end link must include ball joint inspection before closing the diagnosis.
      Lower ball joints carry the vehicle's weight and are significantly more wear-prone than upper joints on double-wishbone suspension designs A squeaking ball joint without play indicates the dust boot has failed and the joint is dry — replacement is urgent even before play develops Ball joint play test: load the suspension at the wheel hub and measure movement at the ball joint with a dial indicator; compare to the manufacturer's maximum allowable play specification OEM used ball joints from low-mileage donors retain factory pivot preload and feel — aftermarket ball joints frequently feel notchy or overly loose, changing steering feel even when mechanically within specification On vehicles with pressed-in ball joints (most modern unibody platforms), a complete OEM used control arm assembly is the most cost-effective and fastest replacement route Highest failure frequency: Toyota 4Runner / Tacoma (upper ball joints), Ford Explorer (lower), Dodge Durango / Ram 1500 (lower), Jeep Wrangler (all four) ⚠️ Never Delay Ball Joint Replacement A clunking ball joint with measurable play is not a "monitor and watch" situation. Ball joint failure at highway speed causes the knuckle to separate from the control arm — the wheel folds under the vehicle and directional control is lost instantly. This is the one suspension noise that demands immediate action, not a future appointment.
      🔻 #5 Highest Impact on Ride & Safety Clunk / Thud / Excessive Bounce
      Struts & Shock Absorbers
      OEM Used Price: $80–$280 per unit Noise: Thud / Clunk over sharp bumps Worn struts and shocks contribute to suspension noise in two distinct ways. First, a mechanically failed strut (blown seal, collapsed internal valve, or seized piston) produces a thud or clunk when the suspension compresses rapidly over sharp bumps — because the damper provides little or no resistance and the suspension reaches its mechanical travel limit. Second, worn struts allow excessive body motion that loads adjacent components — particularly the sway bar system, strut top mounts, and control arm bushings — beyond their design parameters, causing them to make noise even when they themselves are not the primary failure.
      A simple test for strut condition: push down sharply on each corner of the vehicle and release. More than one full oscillation before settling indicates a worn damper Look for oil streaking on the strut body — active fluid weeping from the shaft seal indicates imminent complete damper failure OEM struts are tuned to the exact spring rate and vehicle weight of your specific model — aftermarket struts calibrated for a "universal" application produce a noticeably different ride character Always replace struts in axle pairs — mismatched damping side-to-side causes handling imbalance that the driver feels as a pull or drift under braking Replace strut top mounts and bump stops at the same time — labour is already invested and both components are critical to the strut's noise and performance characteristics Highest failure frequency: Honda CR-V, Toyota Camry, Ford Escape, Chevrolet Equinox — all at 60,000–90,000 miles front strut interval
      🌀 #6 Most Underrated Noise Fix Clunk / Squeak During Body Roll
      Sway Bar Bushings (Centre Mount Bushings)
      OEM Used Price: $20–$60 per set Noise: Squeak / Clunk in corners & over bumps Sway bar centre mount bushings are the rubber bushings that secure the sway bar to the vehicle subframe or body at two centre mounting points. They are among the least expensive suspension noise repairs available — and among the most frequently overlooked during a diagnostic inspection because they are not as visually obvious as a broken end link or a torn ball joint boot. When they dry out, crack, or collapse, the sway bar fretts against the mounting bracket — producing a squeak or creak that is most noticeable during cornering, over bumps, or during any manoeuvre that loads the sway bar laterally.
      The squeak produced by dry sway bar bushings is the most DIY-addressable suspension noise on most vehicles — the bushings are accessible without suspension disassembly on most platforms OEM rubber compound is the correct specification — aftermarket polyurethane bushings are frequently too stiff, transmit road noise, and squeak due to incompatibility with factory anti-friction coatings on the bar Apply the correct grease to the bar-to-bushing interface at installation — a dry bar will squeak through a new bushing within a few thousand miles regardless of bushing quality Replace sway bar bushings as a complete set (all four locations — two per axle) in a single service appointment; the cost difference is negligible and prevents a comeback Highest failure frequency: All platforms at 60,000–100,000 miles; accelerated by cold climates where rubber degradation is faster
      🎵 #7 Most Distinctive Noise Pattern Hum / Drone — Speed Dependent
      Wheel Hub & Bearing Assemblies
      OEM Used Price: $80–$220 per hub Noise: Hum / Groan — changes with speed and cornering Wheel hub bearing failures produce the most diagnostically distinctive noise pattern in the suspension system — a humming or droning sound that changes pitch with vehicle speed and shifts in intensity during cornering as lateral load transfers to or away from the failing bearing. Despite this distinctive pattern, hub bearing failures are routinely misdiagnosed as tyre noise or differential whine, leading to expensive unnecessary repairs. Confirming the diagnosis with a load-shift test — noting whether the noise increases when weight shifts left (right bearing failing) or right (left bearing failing) during a gentle lane change — is the most reliable confirmation method before ordering parts.
      On modern vehicles, the wheel hub assembly contains the bearing, ABS tone ring, and wheel speed sensor in a sealed unit — the entire assembly is replaced as a single component OEM hub assemblies are essential for ABS compatibility — the tone ring pitch and sensor air gap are calibrated to the vehicle's ABS module; aftermarket hubs with different tone ring specifications trigger ABS fault codes Replace wheel hub bearings in pairs on the same axle when both reach similar mileage — if one has failed at 90,000 miles, the other is within 10,000–20,000 miles of the same failure Always inspect the knuckle bore for wear or damage before installing a new hub — a scored or out-of-round knuckle bore will accelerate bearing wear on the replacement unit Highest failure frequency: Subaru Outback / Forester (rear), Ford Escape / Focus (front and rear), Chevrolet Equinox / Terrain (front), Toyota RAV4 (front)
      🔗 #8 Steering-Related Noise Source Knock / Clunk — Steering Input
      Tie Rod Ends (Inner & Outer)
      OEM Used Price: $30–$90 per end Noise: Knock / Clunk when turning / on bumps Tie rod ends connect the steering rack to the steering knuckle and are the final link in the steering input chain. A worn tie rod end produces a knocking or clunking noise during steering input, particularly when turning over rough surfaces that simultaneously load the tie rod laterally and longitudinally. Beyond noise, worn tie rod ends cause rapid outer tyre wear and alignment drift — the wheel toe changes dynamically on every bump, constantly fighting the alignment geometry back to correct.
      Inner tie rod ends (at the rack) are less commonly replaced than outer ends but fail on high-mileage vehicles — inner failure produces a more pronounced knocking under lateral steering load Always replace tie rod ends in pairs — if the outer end on one side has failed, the opposite outer end is at the same mileage and should be replaced simultaneously A 4-wheel alignment is mandatory after tie rod end replacement — wheel toe will have shifted from the worn end geometry OEM tie rod ends use factory ball joint preload matched to the vehicle's steering feel calibration — aftermarket ends with different preload alter steering weight and feedback Inspect the dust boot before purchasing a used tie rod end — a torn or cracked boot indicates the joint has been running dry, which accelerates ball joint wear internally
      🛡️ #9 The Forgotten Component Thud at Full Compression
      Bump Stops & Jounce Bumpers
      OEM Used Price: $15–$50 per unit Noise: Thud / Crash over severe bumps Bump stops (also called jounce bumpers) are the polyurethane or rubber buffers that limit suspension travel at maximum compression — preventing metal-to-metal contact between the suspension and chassis. They are almost universally overlooked during suspension inspections because they are tucked inside the spring or strut assembly and not visible without disassembly. A missing or deteriorated bump stop produces a harsh, resonant thud over severe bumps that is often misdiagnosed as a strut or spring failure — because the symptom occurs at the same point in the suspension travel where a bottomed-out strut would produce the same noise.
      Always inspect and replace bump stops when replacing struts or coil springs — they are inexpensive, accessible when the strut is already removed, and their failure causes disproportionately harsh noise OEM bump stops are tuned to the specific travel limit of your vehicle's suspension geometry — aftermarket equivalents are often made from stiffer or softer material that changes the impact force at the travel limit Deteriorated bump stops crumble rather than compress cleanly — fragments can lodge in the spring or strut assembly and cause secondary noise after the strut is reinstalled On vehicles with air suspension, inspect the air spring jounce bumper specifically — these are more expensive than conventional bump stops and are frequently missed in air suspension service
      🌀 #10 High-Frequency Noise Source Squeak / Creak During Suspension Travel
      Coil Spring Isolators (Spring Seats & Pads)
      OEM Used Price: $20–$55 per set Noise: Squeak / Creak — suspension travel Coil spring isolators — the rubber or polyurethane pads that sit between the coil spring and the spring seat on both ends of the spring — are responsible for a creaking or squeaking noise during suspension travel that is very difficult to localise without disassembly. They are also frequently the last component replaced after multiple rounds of bushing, end link, and bearing replacement fail to eliminate a persistent squeak. Isolators dry out, crack, and lose their compression properties over time, allowing the spring to fret directly against the metal spring seat — producing a noise that appears to come from everywhere and nowhere simultaneously.
      Always replace spring isolators when replacing struts or coil springs — they are negligible in cost and are otherwise inaccessible without the same labour A dried or cracked lower isolator is the most common source of the persistent squeak that survives multiple suspension repairs — if a squeak has survived bushing, end link, and strut mount replacement, inspect the isolators next OEM isolators use the correct rubber compound for the vehicle's spring rate — a stiffer or softer aftermarket isolator alters the spring's effective rate at the seat contact point Contamination of the isolator from brake fluid, oil, or road chemicals accelerates cracking — inspect for contamination when diagnosing a squeak on a relatively low-mileage vehicle
      OEM Used vs. Aftermarket for Suspension Noise Repairs
      Suspension noise is uniquely sensitive to NVH (noise, vibration, and harshness) characteristics of individual components — more so than almost any other vehicle system. This is why aftermarket suspension parts produce a higher rate of noise comebacks than any other repair category.
      🏭 Aftermarket Suspension Parts
      Bushing rubber compound often stiffer than OEM — transmits road noise into cabin Ball joint preload frequently differs — can feel notchy or loose from day one Strut damping curves may not match OEM — noise reappears under load conditions Sway bar end link ball joint quality varies widely — 15,000-mile failures common Wheel hub ABS tone ring pitch may differ — triggers ABS fault codes post-install Spring isolator compound may change effective spring rate — new squeaks possible 40% of suspension noise comebacks involve aftermarket parts that fail to match OEM NVH
      ♻️ OEM Used — GreenGears Auto
      Factory rubber compound — correct NVH isolation as engineered Factory ball joint preload — original steering feel preserved OEM damping curves — ride and noise characteristics exactly match design intent Factory end link quality — full OEM service life on a low-mileage unit Correct ABS tone ring — zero fault codes post-installation Original isolator compound — spring rate and noise isolation maintained Mileage-verified from documented low-mileage donor vehicles
      Suspension Noise Quick Diagnosis Reference
      Noise Type Condition Most Likely Part OEM Used Price Priority Rattle at low speed Parking lot, rough road Sway bar end links $25–$80/side 🟡 Medium Clunk over bumps Both front corners Strut top mounts $45–$140/side 🟠 Medium-High Clunk — one corner Bumps / braking Control arm bushing / ball joint $60–$220 🔴 High Squeak when turning Low speed / full lock Strut mount bearing / ball joint boot $45–$140 🟠 Medium-High Thud over sharp bumps Full suspension compression Bump stop / strut $15–$280 🟠 Medium-High Clunk — safety concern Any / with play felt Ball joint $45–$180 🔴 Safety Critical Squeak — body roll Cornering / bumps Sway bar bushings $20–$60/set 🟡 Medium Hum / drone Speed-dependent / cornering Wheel hub bearing $80–$220 🔴 High Knock — steering input Turning over rough surface Tie rod end $30–$90 🔴 High Persistent squeak Any suspension travel Spring isolators $20–$55/set 🟡 Medium
      Smart Bundling — Eliminate All Sources in One Appointment
      Suspension noise repairs have significant labour overlap — components in the same area of the vehicle require the same disassembly regardless of which one is being replaced. Bundling adjacent replacements into a single appointment is the single most effective way to reduce total repair cost and prevent a comeback from a secondary component that was borderline at the time of the primary repair.
      Front strut replacement: always bundle with strut top mounts, bump stops, spring isolators, and sway bar end links — all require the strut to be removed or are directly adjacent Control arm replacement: always bundle with a 4-wheel alignment, and inspect tie rod ends while the steering geometry is already disturbed Ball joint replacement: always bundle with an alignment and inspect the control arm bushing at the same pivot — if the bushing is worn, replace the complete arm Sway bar end links: always replace all four simultaneously — they are at the same mileage and the cost difference between replacing two vs. four is $50–$80 in parts against the same labour time Wheel hub bearing: inspect and replace brake rotors and caliper hardware at the same time — the hub removal provides access to the rotor and caliper that would otherwise require additional labour Rear shock replacement: bundle with rear sway bar links and any rear trailing arm bushings — the rear suspension is already disturbed and these are high-frequency adjacent failures
      ✅ GreenGears Auto's Suspension Parts Promise Every OEM used suspension component in our inventory is inspected for rubber integrity, boot condition, ball joint play (where applicable), and documented donor mileage before listing. We back every part with our 15 to 90-day satisfaction guarantee and free shipping across the continental US — so you can fix the noise once and trust the fix.
      Ready to Fix Your Suspension Noise — For Good?
      Tell us your year, make, model, and the noise you're hearing — our suspension parts specialists will identify the right OEM used component and get it to you in 3–7 days with free US shipping.
      ✅ OEM Quality Verified 🚚 Free US Shipping ↩️ 15-Day Returns 📋 Mileage Documented link hidden, please login to view
      FCS Automotive announced the release of 29 new part numbers, now in stock and ready to ship. The expansion strengthens suspension coverage for more than 5 million vehicles on the road in the U.S. and Canada.
      Expanded Suspension Coverage
      link hidden, please login to view said the new part numbers reinforce its commitment to comprehensive, up-to-date coverage. The additions support key suspension categories that installers rely on for everyday service and repair, the company said. The release expands coverage across complete strut assemblies, suspension struts, shock absorbers and lift supports. Each product is engineered to deliver OE-quality fit and performance, according to FCS Automotive.
      Popular Vehicle Applications
      The new parts support several high-volume vehicle applications. These include the Nissan Rogue, Mitsubishi Outlander and Ford Explorer.
      Strictly as a word, performance is defined as the act or process of accomplishing something. In the automotive world, it’s often preceded by the word high, to indicate a modification which makes a vehicle perform more like a race car, but even without, it’s often thought of in the same context.
      Relating to chassis bushings and mounts, we’ll look at it in both ways. The common link between suspension bushings, body, engine or transmission mounts is what they do and what they are made of.
      Their purpose is to allow a minor or controlled degree of movement between two components, while absorbing shock, dampening noise, preventing vibration and preventing metal-to-metal contact between the two components. They can be made of rubber, polyurethane, plastic or metal depending on their application, but rubber is the primary material for production vehicles.
      All bushings or mounts are designed to perform in a certain manner, depending on whether the vehicle is designed for luxury, performance or heavy-duty use. The difference in performance comes from the hardness of the rubber (or other material) used in any given component. Hardness is measured by a piece of equipment called a durometer.
      Hardness can be related to many everyday objects such as a rubber band, super ball, automotive tires or even skateboard wheels. A rubber band, for example, would have a low durometer reading, while a skateboard wheel would have a higher reading. In automotive applications, not only are mounts and bushings engineered and formulated to meet a specific durometer rating, but all rubber components utilize this scale during engineering, as well such as door seals and O-rings.
      Chassis performance, when relating to it in terms of the way any vehicle was designed and built, can be affected by the quality and type of replacement components. Manufacturers that follow original equipment (OE) standards when manufacturing replacement components do so with the intent that the replacement components will be equal to the OE in quality and performance.
      This is important because the majority of vehicle owners want their vehicle to perform as it did when new. If the rubber in a replacement component is of a different hardness, a vehicle may not handle or ride as well, or there could be increased vibration transferred from the suspension or drivetrain into the cabin. It all depends on the durometer rating of the rubber.
      On the flip side, vehicle performance may improve with different bushings and mounts, which leads me to the high-performance side. With suspension, a common modification is to install polyurethane bushings in place of the OE rubber. The polyurethane bushings have a higher durometer rating, which means they are stiffer than rubber. This keeps suspension components in strict alignment during suspension movement and cornering, which adds up to improved handling. But you sacrifice comfort, noise and vibration levels at the same time.
      Polyurethane engine and transmission mounts can improve throttle response and acceleration by preventing excess drivetrain movement, and they handle a greater level of stress, but again you will sacrifice comfort, noise and vibration levels at the same time.
      Polyurethane is used for these high-performance applications because it’s easier to customize a specific durometer rating with polyurethane than it is rubber, and therefore a higher rating can be easily attained. Plus, it is more durable and longer lasting than rubber, and it’s not affected by temperature, dirt or oil, all which plague rubber components. Certain oils can affect poly over time, but it takes extended exposure and is uncommon for the most part.
      An interesting addition to the mount category has been the modern technology of active engine mounts. Active engine mounts have hydraulic fluid filled chambers inside. They are controlled either by electronics or vacuum, the most advanced of which are ECU-controlled.
      The amount of dampening inside the mount is changed to meet operating conditions. With this technology, these mounts can offer comfort, low noise and vibration, along with acceleration and high-performance benefits. It’s the best of both worlds.
      link hidden, please login to view has launched an expanded steering and suspension range. It provides extensive application coverage for major original equipment (OE) car and truck manufacturers. The offering includes ball joint kits, track control arms, stabilizer links, silent blocks, steering boots, tie rod ends, axial joints, rod assemblies, rear suspension arm kits and suspension repair kits. These components are designed with OE-quality materials to ensure optimal performance and safety, according to SKF. Product Development
      The steering and suspension components incorporate SKF’s proprietary high-performance synthetic grease, specifically formulated to minimize friction and “stick slip.” This technology promotes smooth system movement and a responsive steering experience, contributing to a longer lifespan for these components.
      Market Impact
      By reducing friction and the “stick slip” effect by up to 35%, SKF components offer improved driving comfort, vehicle response and safety, the company said. These enhancements lead to smoother handling and better maneuverability, which are crucial for driver confidence across varying road conditions.
      Distribution Strategy
      SKF commits to supporting auto service professionals with simplified installation processes. Installation guidelines and service bulletins are accessible via QR codes on product packaging. This facilitates easy access to technical support and ensuring reliable, long-life performance of the product line.
      Johannes Deeg,
      link hidden, please login to view product line manager of steering and suspension, said, “SKF’s Steering and Suspension components have been tested at SKF facilities worldwide to ensure they meet the high-quality material and performance standards of OE car and truck manufacturers.” The post
