      A blown head gasket is one of the most serious engine issues, often leading to overheating, performance problems and costly repairs. Understanding how to evaluate the condition and choose an effective solution is key to preventing further damage and restoring engine operation.
      The head gasket seals the combustion chamber and separates coolant and oil passages between the block and cylinder head. It must contain combustion pressure while maintaining proper fluid flow. When that seal fails, combustion gases, coolant and oil can cross paths, leading to overheating, pressure buildup and loss of engine efficiency.
      Head gasket failure often starts with overheating or long-term engine stress. Customers may report coolant loss with no visible leak, along with white exhaust smoke, rough running, or coolant being forced out of the system. Some vehicles will still run for a period of time, while others overheat quickly. That difference in behavior is critical. It tells you how severe the failure is and helps guide the right repair approach.
      Confirm the condition based on symptoms like coolant loss and overheating with no external leak. Then ask a key question: how long can the engine run before overheating or pushing out coolant? If it can run 15–20 minutes,
      link hidden, please login to view is a strong option for sealing minor to moderate failures. If the issue is more severe, stepping up to a heavier-duty solution may be necessary. Bar’s Leaks Head Seal Blown Head Gasket Repair is designed to create a durable seal, helping restore system integrity when matched correctly to the condition. Head gasket issues come down to sealing failure and severity. Identify the condition, then match it with the right solution.
      This video is sponsored by link hidden, please login to view.
      The 2018 Chevrolet Traverse comes equipped with a 9-speed automatic transmission paired with its 3.6L V6 engine, offering wide gear spacing for both fuel efficiency and highway cruising comfort. Some owners have reported concerns with rough or hesitant shifting, particularly during low-speed acceleration and downshifts — often addressed through GM software updates and transmission fluid changes. Dexron HP is the recommended fluid for this unit. When replacing the transmission, ensure the replacement unit is properly programmed to the vehicle's control modules. Remanufactured 9-speed units provide a dependable, warrantied path to restoring smooth, confident performance in your Traverse. link hidden, please login to view
      LIVE Engine Rebuild w/ Alex Taylor, Freiburger, Brad DeBerti, and Tate Morgan
      Published by GreenGears Auto  |  10 minute read  |  Steering Repair & OEM Parts Guide
      Steering problems are never optional repairs. A vehicle that pulls to one side, wanders at highway speed, feels heavy or vague through the wheel, or makes knocking and groaning noises during turns is telling you that a critical safety system is compromised. Steering component failures affect braking performance, tyre wear, and directional control simultaneously — making them among the highest-priority repairs on any vehicle. At GreenGears Auto, we stock quality-inspected OEM used steering components across every major platform — the exact parts your vehicle was engineered around, at 50–70% less than new OEM pricing. This guide maps every common steering problem to the specific replacement part responsible, with platform-specific sourcing guidance and diagnosis support.
      Why Steering Problems Demand OEM Parts
      Steering is the most feedback-sensitive system on any vehicle. Every component — from the steering rack ratio to the tie rod end ball joint preload to the column intermediate shaft angle — is engineered as an integrated system tuned specifically for your vehicle's weight, suspension geometry, and handling balance. When any part of that system is replaced with a component that deviates from OEM specification, the result is detectable immediately: steering that feels heavier, lighter, vaguer, or simply different from the original design intent.
      35% Of steering repair comebacks involve an aftermarket part that failed to replicate OEM steering feel or caused premature wear 50–70% Average savings on OEM used steering components vs. new OEM dealer pricing at GreenGears Auto #1 Reason steering problems accelerate tyre wear — misalignment caused by worn steering components   ⚠️ Steering Problems Are Safety-Critical — Never Delay Unlike a noisy suspension bushing or a leaking differential seal, a failing steering component directly compromises your ability to control the vehicle in an emergency. Loose tie rod ends, worn steering racks with excessive play, and seized steering columns are not "monitor and watch" repairs. Any steering symptom that affects directional stability, pull, or play in the wheel requires immediate diagnosis and repair.
      Steering System Types — What Your Vehicle Uses
      Identifying your vehicle's steering system type is the first step to sourcing the correct replacement part. Modern vehicles use one of three primary steering system designs, and replacement parts are not interchangeable across systems.
      🔧Hydraulic Power Steering (HPS) Uses a belt-driven hydraulic pump to provide steering assistance. Common on vehicles built before 2012 and many trucks through 2020. Components include the power steering pump, steering rack with hydraulic assist, high-pressure hoses, and fluid reservoir. Failure symptoms include whining, heavy steering, and fluid leaks.
      ⚡Electric Power Steering (EPS / EPAS) Uses an electric motor — either column-mounted or rack-mounted — to provide steering assistance. Standard on virtually all new vehicles since 2015. No hydraulic fluid required. Failure symptoms include loss of power assist, steering fault warning lights, and inconsistent steering weight. Requires exact OEM replacement for ECU integration.
      🔩Recirculating Ball Steering Gearbox Used on body-on-frame trucks and SUVs — Ford F-Series (pre-2021), Chevrolet Silverado / Suburban, Ram 1500/2500/3500, Toyota Tundra / Land Cruiser. Uses a steering gear box rather than a rack-and-pinion. Common failure points include sector shaft wear, worm gear wear, and output shaft seal leaks.
      🎯Rack-and-Pinion Steering The most common steering system on unibody cars, crossovers, and most modern SUVs. A rotating pinion gear meshes with a linear rack to convert steering wheel rotation into lateral wheel movement. Both hydraulic and electric power assist versions exist. Failure symptoms include clunking, looseness, and fluid leaks at the rack boots.
      Steering Problem Symptoms — Matched to Failed Components
      Every steering problem has a mechanical source. Matching your specific symptom to the component responsible before ordering parts is the fastest and most cost-effective path to a correct repair.
      🔄 Pull or Drift
      Pulls consistently to one side → Tie rod end or steering rack worn on that side Pulls under braking → Brake or suspension issue (confirm before steering diagnosis) Wanders at highway speed → Worn rack, loose tie rod ends, or worn steering shaft Pull that changes with road surface → Inner tie rod end worn Torque steer under acceleration → CV axle or engine mount (not steering) 💥 Knock & Clunk
      Clunk when turning over bumps → Tie rod end or steering rack mount Knock at centre of steering → Steering column intermediate shaft U-joint Clunk turning at low speed → Outer tie rod end ball joint worn Knock from steering rack area → Rack mount bushings worn Clunk on full lock → CV axle or inner tie rod end ⚖️ Heavy or Light Steering
      Heavy steering throughout → Power steering pump failure (HPS) or EPS motor fault Heavy on one side only → Rack internal damage or binding Steering suddenly heavy → HPS pump belt or fluid loss; EPS fault code Steering too light / vague → EPS torque sensor calibration or rack wear Heavy only when cold, eases when warm → HPS pump or fluid viscosity issue 🎮 Excessive Play or Looseness
      Play in wheel before wheels respond → Worn steering rack, loose column shaft Play that worsens over bumps → Inner tie rod end worn Dead zone around centre → Steering rack internal wear (teeth stripped) Play only in one direction → Asymmetric rack wear or sector shaft (gearbox) Play at wheel felt at tyre → Ball joint or steering knuckle (not steering) 🔊 Whine & Groan
      Whine that increases with steering angle → HPS pump cavitating (low fluid) Groan on full lock → HPS pump relief valve or low fluid level Whine that changes with engine speed → HPS pump bearing worn No whine but heavy steering → EPS motor fault (no hydraulic noise) Groan when parking slowly → Worn steering rack or column bearing ⚡ Warning Lights & Electronics
      EPS / Power Steering warning light → EPS motor, torque sensor, or control module Steering light + traction control fault → EPS module communicating with ESC Steering angle sensor fault → Steering angle sensor in column or rack ADAS lane keeping fault + steering light → EPS calibration or rack replacement needed Intermittent power assist loss → EPS wiring harness or module fault
      Top OEM Replacement Parts for Steering Problems — By Component
      Here is every major steering system component that drives replacement decisions — what it does, what symptoms it causes when it fails, and the best OEM used sourcing approach for each platform.
      🏆 Highest-Cost Steering Repair Rack-and-Pinion / EPS Rack Steering Rack & Pinion Assembly (Hydraulic & Electric)
      OEM Used Price: $120–$680 Symptoms: Play / Clunk / Pull / Wander The steering rack is the central component of rack-and-pinion steering — converting the rotational input from the steering wheel into the lateral movement that steers the front wheels. It is the most expensive individual steering repair on most platforms, and the component most frequently misdiagnosed when the actual fault lies with an inner tie rod end, rack mount bushing, or steering shaft. On electric power steering (EPS) vehicles, the steering rack incorporates the electric assist motor and torque sensor — making exact OEM specification non-negotiable for correct integration with the vehicle's stability control and ADAS systems.
      When does the steering rack actually need replacement?
      Measurable play at the steering wheel that persists after tie rod end inspection — excessive rack internal wear (stripped rack teeth or worn pinion) Active fluid leak from the rack boots or hydraulic cylinder ends (hydraulic rack) Confirmed EPS motor or torque sensor failure where the motor is integrated into the rack assembly and cannot be replaced separately Physical impact damage to the rack housing or internal components from a collision Best used OEM steering rack units by platform:
      Honda Accord / CR-V EPS rack (2013–2022): Electric power steering rack — most available EPS rack unit in the used market due to Honda's enormous sales volume; $120–$280; confirm column-assist vs. rack-assist EPS design Toyota Camry / RAV4 EPS rack (2012–2022): Column-assist EPS on Camry; rack-assist on RAV4; both widely available from accident-damaged low-mileage donors; $140–$320 Ford Fusion / Edge / Explorer EPS rack (2013–2020): Rack-mounted EPS motor design — most available Ford EPS rack in the used market; $160–$380; confirm 2WD vs. AWD rack specification Chevrolet Malibu / Equinox EPS rack (2013–2018): Column-assist EPS; $120–$280; shares architecture across Malibu and Equinox on same generation — expands sourcing options BMW 3 Series / 5 Series EPS rack (F30/F10, 2012–2019): Rack-mounted EPS motor with integrated torque sensor; $280–$580; requires alignment and may need EPS calibration after replacement Subaru Outback / Forester EPS rack (2015–2022): EyeSight camera system integration on equipped models requires post-replacement calibration; $180–$360 🔧 EPS Steering Rack — OEM Is Non-Negotiable Electric power steering racks contain integrated torque sensors and motor controllers calibrated to the vehicle's specific EPS control module. Aftermarket EPS racks frequently fail to communicate correctly with the vehicle's ECU — producing steering fault lights, inconsistent assist levels, and in some cases disabling stability control integration. OEM used is the only reliable option for EPS rack replacement.
      🔗 Most Frequently Replaced Steering Part Inner & Outer Tie Rod Ends
      Tie Rod Ends — Inner & Outer
      OEM Used Price: $30–$90 per end Symptoms: Knock / Pull / Rapid Outer Tyre Wear Tie rod ends are the final mechanical link in the steering chain — connecting the steering rack to the steering knuckle at the wheel. The outer tie rod end is the most commonly replaced steering component across all platforms, failing through ball joint wear that produces a knock over rough surfaces and a progressive steering looseness that is most noticeable at highway speed. The inner tie rod end (or inner tie rod) connects the outer end to the rack itself and fails less frequently — but when it does, it produces a more pronounced play that is felt as a vague, floating response around the steering centre position.
      Outer tie rod end failure produces a knock during steering input over bumps and a pull that may change with road surface — the lateral load variation exposes the worn ball joint Inner tie rod end failure produces play that worsens when the steering is loaded sideways — a lateral push-pull test on the tyre while someone watches the rack boot should reveal inner tie rod movement Always replace outer tie rod ends in pairs — if one side has failed, the opposite is at the same mileage and should be replaced simultaneously to preserve steering balance A 4-wheel alignment is mandatory after any tie rod end replacement — wheel toe will have shifted from the worn end geometry OEM tie rod ends use factory ball joint preload matched to your vehicle's steering feel calibration — aftermarket ends with different preload alter steering weight and feedback in ways that are immediately noticeable Inspect the dust boot condition before purchasing a used tie rod end — a torn or missing boot means the joint has been running contaminated and dry, accelerating internal wear High-frequency platforms: Toyota Camry (front), Honda Accord (front), Ford Fusion / F-150 (front), Chevrolet Silverado (inner and outer), Nissan Altima / Maxima (outer) — all see high outer tie rod end failure rates at 80,000–120,000 miles.
      ⚙️ HPS System Heart Hydraulic Power Steering
      Power Steering Pump (Hydraulic)
      OEM Used Price: $60–$220 Symptoms: Whine / Heavy Steering / Fluid Leak The hydraulic power steering pump is a vane or gear pump driven by the engine accessory belt that generates the hydraulic pressure used to assist steering effort. Power steering pump failure is the most common hydraulic steering system repair — producing a distinctive whining noise that increases with steering angle, heavy steering effort (particularly when parking), and in advanced cases, fluid leaks from the pump body or pressure fittings. The whine is most noticeable on cold starts and diminishes as the fluid reaches operating temperature.
      Power steering pump whine that is present only at startup and disappears at operating temperature typically indicates low fluid or a deteriorating pump — check fluid level and condition before ordering a pump Whine that is present at all temperatures and increases with steering angle indicates the pump itself is failing — internal vane or gear wear is reducing pressure output OEM power steering pumps are engineered to the specific flow and pressure requirements of your vehicle's steering rack — an over-pressure aftermarket pump damages the rack seals; an under-pressure pump produces insufficient assist Always replace the power steering pump reservoir and filter when replacing the pump — contaminated fluid from the failed pump will rapidly damage a new or used replacement Flush and refill the power steering system with the correct OEM-specified fluid after pump replacement — using generic power steering fluid in a vehicle that specifies Honda PSF or Pentosin causes premature seal failure High-frequency platforms: Honda CR-V / Accord V6 (pre-2013), Toyota Highlander / Sienna (pre-2013), Ford F-150 / Explorer (pre-2011), Chevrolet Tahoe / Silverado (pre-2014), Nissan Titan / Armada — all see high hydraulic pump failure rates at 100,000–150,000 miles.
      ⚡ EPS System Core Electric Power Steering
      Electric Power Steering (EPS) Motor, Column & Control Module
      OEM Used Price: $120–$480 Symptoms: EPS Warning Light / Loss of Assist / Fault Codes Electric power steering (EPS) systems have replaced hydraulic power steering on virtually every new vehicle since 2015. Instead of a hydraulic pump and pressurised fluid, an electric motor — mounted either on the steering column or directly on the rack — provides variable steering assistance managed by an EPS control module. When EPS components fail, the result ranges from a persistent warning light with reduced assist to complete loss of power steering assistance. Because the EPS system communicates with the vehicle's stability control, lane-keeping assist, and autonomous braking systems, OEM replacement is critical — aftermarket EPS components introduce calibration errors that cascade into ADAS faults.
      EPS failure types and the OEM used parts that fix them:
      Column-assist EPS motor failure: The electric motor and torque sensor are integrated into the steering column — replacement requires the complete column assembly or, on some platforms, the motor and sensor as a unit; most common on Toyota, Honda, and GM column-EPS platforms Rack-assist EPS motor failure: The electric motor is mounted on or integrated into the steering rack — rack replacement is required when the motor cannot be separated; most common on Ford, BMW, and Subaru rack-EPS platforms EPS torque sensor fault: The torque sensor measures steering wheel input force and direction — a failed sensor produces erratic assist levels and fault codes; on column-EPS designs it is part of the column assembly; on rack-EPS designs it is integrated into the rack EPS control module fault: The EPS ECU manages motor output based on vehicle speed, steering angle, and torque sensor input — module faults produce the EPS warning light without mechanical component failure; used OEM modules require programming to the vehicle on some platforms ⚠️ EPS Replacement and ADAS Recalibration On vehicles equipped with lane-keeping assist, automatic emergency steering, or any other ADAS steering function, replacement of any EPS component — column, rack, motor, or module — requires a steering angle sensor calibration and in many cases a full ADAS camera and radar recalibration. Factor this into the total repair cost before starting the job. GreenGears Auto's parts specialists can confirm which calibration steps your specific vehicle requires.
      🔗 Driver Interface Component Steering Column Assembly
      Steering Column Assembly & Intermediate Shaft
      OEM Used Price: $80–$380 Symptoms: Knock at Centre / Tilt or Telescoping Failure / EPS Fault The steering column connects the steering wheel to the steering rack or gearbox via a series of shafts and U-joints, incorporating the tilt and telescoping adjustment mechanism, the clock spring (airbag slip ring), the ignition switch, and — on column-EPS vehicles — the electric assist motor and torque sensor. Steering column problems are often overlooked because the symptoms they produce (a knock when turning over bumps, a grind during tilt adjustment, or intermittent EPS faults) are frequently attributed to other components.
      The intermediate shaft: The steering intermediate shaft — the coupling between the column and the rack or gearbox — is one of the most commonly missed steering noise sources. Its U-joints absorb the angle between the column and rack and transmit steering input without backlash. Worn intermediate shaft U-joints produce a distinctive clunk or knock when turning the steering wheel in slow parking manoeuvres that is almost universally misdiagnosed as a tie rod end or rack mount problem.
      Intermediate shaft U-joint wear is confirmed by having someone slowly turn the steering wheel while you observe the shaft under the bonnet — visible movement or audible knock at the U-joint confirms the diagnosis On column-EPS vehicles, the complete column assembly includes the EPS motor and torque sensor — always confirm whether your fault is mechanical or electronic before ordering Tilt and telescoping column mechanism failures are almost always best addressed with a used OEM column assembly rather than individual mechanism repair Clock spring (steering wheel slip ring) failure produces airbag warning lights and disabled horn or paddle shifters — confirm clock spring condition before attributing electrical faults to the column structure OEM used steering columns from low-mileage accident donors are excellent quality — the column is one of the least wear-prone components in a low-speed or front-impact collision if the impact axis is not directly through the column
      🔩 Body-on-Frame Trucks & SUVs Recirculating Ball Gearbox
      Steering Gear Box (Recirculating Ball)
      OEM Used Price: $120–$480 Symptoms: Play / Wander / Leak at Output Shaft Body-on-frame trucks and SUVs use a recirculating ball steering gearbox rather than a rack-and-pinion — a more robust design suited to the higher loads of truck and SUV applications. The steering gearbox converts steering wheel rotation into lateral output shaft movement via a worm gear and recirculating ball nut. Gearbox wear produces a dead zone around the steering centre — a small amount of steering wheel movement that produces no wheel response — and a wander or looseness at highway speed that is the most common steering complaint on high-mileage trucks.
      Steering gearbox play is measured at the pitman arm end of the output shaft with a dial indicator — compare to the manufacturer's maximum allowable play specification before condemning the unit Some steering gearbox play is adjustable via the sector shaft adjustment screw — always attempt adjustment before replacement; a correctly adjusted used gearbox from a quality donor vehicle will often outlast a remanufactured unit OEM used gearboxes from low-mileage donor trucks are the best replacement option — remanufactured units frequently use the original worn housing with new internals, producing a gearbox that is no tighter than the original after a short break-in period Always replace the output shaft seal when replacing a steering gearbox — this is the most common fluid leak point and is inaccessible with the pitman arm installed High-frequency platforms: Ford F-150 / F-250 / F-350 (pre-2021), Chevrolet Silverado / Suburban / Tahoe, GMC Sierra / Yukon, Ram 1500 / 2500 / 3500 (pre-2019), Toyota Tundra / Sequoia (pre-2022), Nissan Titan / Armada.
      🔗 Structural Steering Component Steering Knuckle / Spindle
      Steering Knuckle Assembly
      OEM Used Price: $80–$300 Symptoms: Alignment Impossible / Vibration / Post-Collision The steering knuckle is the precision-machined casting at the wheel corner that connects the hub bearing, ball joint, tie rod end, brake caliper, and strut mount into a single structural assembly. Steering knuckles are not wear items under normal use — they are replaced after collision damage, severe corrosion, or structural fatigue from repeated high-stress impacts. However, when knuckle replacement is required, it is one of the most expensive individual steering repair components new — making used OEM sourcing particularly compelling.
      Even minor distortion of the steering knuckle — as little as 0.5mm deviation from true — makes correct four-wheel alignment impossible regardless of adjustment; if alignment cannot be achieved within specification after other repairs, knuckle damage should be suspected OEM used knuckles are the most cost-effective option by a very wide margin — new OEM knuckles are expensive and aftermarket knuckles frequently have dimensional deviations that compromise alignment FWD, RWD, and AWD variants of the same vehicle use different knuckles — confirm drivetrain configuration before ordering; AWD knuckles have different hub bearing flange and axle shaft clearance specifications Always source the knuckle from a vehicle with the same brake and ABS configuration — knuckles vary by brake rotor size, caliper mount dimensions, and ABS sensor location Inspect all mounting surfaces carefully — the strut pinch bolt area, ball joint seat, and tie rod boss must all be undamaged and dimensionally correct for proper component installation
      💧 HPS Leak Repair Hydraulic Lines & Hoses
      Power Steering Hoses & High-Pressure Lines
      OEM Used Price: $25–$90 per hose Symptoms: Power Steering Fluid Leak / Low Fluid Warning Power steering hoses — both the high-pressure line from the pump to the rack and the low-pressure return line — are a frequent source of hydraulic power steering fluid leaks on high-mileage vehicles. The high-pressure hose degrades at the rubber-to-metal fittings and at the hose body itself from heat cycling and ozone exposure. A leaking power steering hose is one of the most misdiagnosed fluid leak sources — often confused with an engine oil or coolant leak because the reddish ATF-based power steering fluid can travel from its leak source along wiring harnesses, intake hoses, and heat shields before dripping to the ground.
      Always pressure-wash the engine bay and drive the vehicle before tracing a power steering leak — the actual leak source is often 6–12 inches from where the fluid drips OEM power steering hoses use crimped metal fittings matched to the pump and rack port thread specifications — aftermarket hoses with generic fittings frequently weep at the connections Replace both high-pressure and low-pressure hoses simultaneously — if the high-pressure hose has degraded from heat and age, the return line is at equivalent mileage and condition Flush and refill the power steering system after hose replacement — any air introduced during hose disconnection must be purged to prevent pump damage and steering noise
      🔩 Truck Steering Linkage Steering Linkage Components
      Pitman Arm, Idler Arm & Centre Link (Drag Link)
      OEM Used Price: $40–$160 per component Symptoms: Wander / Shimmy / Excessive Play Body-on-frame trucks and SUVs with recirculating ball steering gearboxes use a parallelogram steering linkage rather than the direct rack-and-pinion connection of unibody vehicles. This linkage consists of the pitman arm (connected to the gearbox output shaft), the idler arm (the mirror-image pivot on the passenger side), the centre link (the long bar connecting both), and the tie rod ends at each wheel. Any worn component in this linkage system introduces play and causes the shimmy and wander that are the most common steering complaints on high-mileage trucks and body-on-frame SUVs.
      Idler arm wear is the most common cause of steering shimmy and wander on high-mileage body-on-frame vehicles — it is the highest-wear linkage component because it carries the full lateral load of the centre link without the gearbox's mechanical advantage Pitman arm wear is less common than idler arm wear but produces a more severe steering looseness because it is the first link in the steering chain — even small pitman arm play amplifies through the entire linkage Always replace idler arm and pitman arm simultaneously when worn — restoring one side of the parallelogram linkage while leaving the other worn produces uneven steering response that is as frustrating as the original fault Inspect the drag link (centre link) for wear at the ball socket ends — a worn drag link ball socket produces the same shimmy symptoms as an idler arm but is less commonly inspected
      OEM Used vs. Aftermarket for Steering Repairs
      Steering is the system where OEM specification matters most. Aftermarket steering components produce a higher rate of comebacks, noise complaints, and alignment instability than any other repair category — because steering feel is exquisitely sensitive to small deviations from OEM geometry, preload, and component stiffness.
      🏭 Aftermarket Steering Parts
      Tie rod end ball joint preload frequently differs — changes steering weight from day one EPS racks often fail to communicate with vehicle ECU — fault codes and reduced assist common Steering rack internal gear tolerances may vary — play develops faster after installation Power steering pump flow/pressure may not match rack specifications — damages seals Steering column EPS motors frequently misfire on torque sensor calibration — assist inconsistency Knuckle casting dimensions often deviate — alignment impossible to achieve within spec 35% of steering noise comebacks involve aftermarket parts that failed NVH replication ♻️ OEM Used — GreenGears Auto
      Factory ball joint preload — original steering feel preserved from day one OEM EPS calibration intact — full ECU integration and ADAS compatibility Factory rack internal tolerances — correct play specification maintained OEM pump flow matched to rack — correct pressure, no seal damage Original EPS torque sensor calibration — consistent, predictable assist Factory knuckle dimensions — alignment achievable within OEM specification Mileage-verified from documented low-mileage donor vehicles
      Steering Replacement Parts Quick Reference
      Component Primary Symptom OEM Used Price Replace in Pairs? Alignment After? Priority Outer Tie Rod Ends Knock / pull / tyre wear $30–$90 ea Yes — always Yes — mandatory 🔴 High Inner Tie Rod Ends Play / wander at centre $35–$80 ea Yes — recommended Yes — mandatory 🔴 High Steering Rack (HPS) Play / leak / wander $120–$420 N/A Yes — mandatory 🔴 High Steering Rack (EPS) EPS fault / assist loss $160–$680 N/A Yes + ADAS cal. 🔴 Critical Power Steering Pump (HPS) Whine / heavy steering $60–$220 N/A No 🟠 Medium-High EPS Column / Motor EPS warning / assist loss $120–$480 N/A Yes + calibration 🔴 Critical Steering Gear Box Play / wander (trucks) $120–$480 N/A Yes — recommended 🔴 High Steering Column Knock / tilt failure $80–$380 N/A Angle sensor reset 🟠 Medium-High Intermediate Shaft Knock — parking turns $40–$120 N/A No 🟡 Medium Steering Knuckle Alignment impossible $80–$300 N/A Yes — mandatory 🔴 High Power Steering Hoses Fluid leak $25–$90 ea Yes — recommended No 🟡 Medium Idler Arm / Pitman Arm Shimmy / wander (trucks) $40–$160 ea Yes — both together Yes — recommended 🔴 High
      What to Check When Buying Used OEM Steering Parts
      Confirm Steering System Type and Assist Method
      HPS and EPS racks are completely different components even on the same nameplate. A 2012 Honda Accord uses hydraulic power steering; a 2013 Accord uses EPS. A 2014 Toyota Camry uses column-assist EPS; a 2015 RAV4 uses rack-assist EPS. Always confirm the steering system type for your specific model year before ordering — the wrong type cannot be made to work regardless of how it is modified. Inspect Tie Rod End Boot Condition
      A torn, cracked, or missing boot means the ball joint inside has been running exposed to road contamination — moisture, grit, and road chemicals accelerate internal wear significantly. A used tie rod end with an intact, pliable boot that still contains grease is a high-quality find. Reject any tie rod end with a compromised boot regardless of asking price. Check Rack Boots for Fluid Saturation (HPS Racks)
      On hydraulic power steering racks, inspect the rubber rack boots at both ends. Fluid-saturated, collapsed, or torn boots indicate that the internal rack seals have been leaking — the rack may have been operating with reduced hydraulic fluid and potential internal contamination. A dry, intact boot confirms the rack seals have been maintaining correct fluid containment. Verify Donor Mileage and Vehicle History
      Steering components from low-mileage donor vehicles retain the most remaining service life. A steering rack from a 35,000-mile accident-damaged vehicle is a very different purchase from one pulled off a 100,000-mile high-mileage donor. GreenGears Auto documents and verifies donor mileage on every steering component listing. Confirm Exact Application — Trim and Drivetrain
      Steering racks, knuckles, and linkage components vary by trim level, drivetrain, brake package, and sometimes engine in ways that are not obvious from the exterior. An AWD steering knuckle is different from a 2WD knuckle. A Sport trim steering rack may have a different ratio from a base trim. Always provide the full year, make, model, trim, engine, and drivetrain when ordering steering components from GreenGears Auto.
      Always Do This After Steering Repairs
      Steering repairs have mandatory post-installation steps that are as important as the repair itself. Skipping these steps produces an unsatisfactory repair regardless of the quality of the replacement part.
      Perform a full 4-wheel alignment after any repair involving tie rod ends, steering rack, steering knuckle, or control arms — wheel toe, camber, and caster will have shifted and must be reset to OEM specification On EPS vehicles, perform a steering angle sensor calibration using a scan tool after any steering column, rack, or knuckle replacement — an uncalibrated steering angle sensor produces incorrect ESC intervention and may disable ADAS features On vehicles with lane-keeping assist, automatic emergency braking, or any ADAS steering function, a forward-facing camera recalibration is required after EPS rack or column replacement — the camera baseline changes with any steering geometry change After hydraulic power steering pump replacement, bleed and purge the power steering system with the wheels on full lock in each direction — trapped air causes pump damage and noise After steering gearbox replacement on trucks, check and adjust the steering column shaft angle to ensure no binding through the full steering range before the vehicle leaves the shop Road test at highway speed before completing the repair — any residual pull, wander, or vagueness detected at speed is far cheaper to address with the alignment equipment still set up than after the customer takes delivery Inspect adjacent components — ball joints, control arm bushings, and wheel bearings — while the steering system is already disassembled; worn adjacent components cause premature wear on the new steering part and will require re-disassembly soon   ✅ GreenGears Auto's Steering Parts Promise Every OEM used steering component in our inventory — racks, pumps, columns, tie rod ends, knuckles, and linkage — is inspected for boot condition, housing integrity, mounting surface condition, and documented donor mileage before listing. We confirm steering system type and trim-specific fitment on every order. Each component is backed by our
       15 to 90-day satisfaction guarantee with free US shipping in 3–7 days.
      Need OEM Replacement Parts for a Steering Problem?
      Tell us your year, make, model, trim, steering system type, and the symptom you're experiencing — our steering parts specialists will identify the exact OEM used component and get it to you in 3–7 days with free US shipping.
      ✅ OEM Verified 🚚 Free US Shipping ↩️ 15-Day Returns 📋 Mileage Documented link hidden, please login to view
      Published by GreenGears Auto  |  10 minute read  |  AWD Repair & OEM Used Parts Guide
      AWD system problems — from a flashing AWD warning light and loss of all-wheel drive traction to grinding noises, binding in turns, and drivetrain shudder — are among the most intimidating and expensive repairs a vehicle owner can face. Dealer quotes for new OEM AWD components regularly run $800–$4,000+ depending on the platform. But the used OEM AWD parts market tells a very different story. At GreenGears Auto, we stock quality-inspected, mileage-verified OEM used AWD system parts across every major make — sourced from low-mileage donor vehicles at 50–70% less than new OEM pricing. This guide covers the best used OEM replacement parts for every common AWD system problem, platform by platform. used AWD parts AWD system repair OEM AWD transfer case used rear differential AWD AWD front differential power transfer unit replacement AWD coupling unit all-wheel drive repair parts OEM used drivetrain GreenGears Auto
      What Causes AWD System Problems?
      All-wheel drive systems are significantly more complex than two-wheel drive drivetrains — and that complexity creates more potential failure points. Understanding the root cause of your specific AWD system problem determines which used OEM part you actually need. Ordering the wrong component is the most expensive mistake in AWD repair.
      #1 Fluid neglect — leading cause of AWD transfer case and rear differential failure across all platforms $800–$4,000+ Typical new OEM AWD component cost at the dealer — the price range that makes used OEM the smart choice 50–70% Average savings on OEM used AWD parts vs. new OEM pricing across all platforms at GreenGears Auto   The most common AWD system problems fall into five categories: transfer case failure (whining, grinding, loss of 4WD or AWD engagement), rear differential failure (whining, clunking, fluid leaks), front differential or PTU failure (common on Ford, VW, and GM crossovers), AWD coupling/clutch pack failure (shudder in turns, AWD dropout), and driveshaft and CV axle failure (vibration, clicking in turns). Each requires a different used OEM part — and each has a distinct symptom fingerprint that makes pre-purchase diagnosis straightforward.
      🔧 GreenGears Tip — AWD Problem Diagnosis Before Ordering Before purchasing any used AWD system part, pull the fault codes from your vehicle. AWD-related codes (P0218, P1889, C1234, U0121, and platform-specific codes) narrow the diagnosis immediately and prevent ordering the wrong component. GreenGears Auto's parts specialists can cross-reference fault codes with specific AWD components for any make or model.
      Types of AWD Systems — and Why the Difference Matters for Parts
      AWD system architecture varies dramatically across makes and platforms. The specific used OEM parts required depend entirely on which AWD system your vehicle uses — they are not interchangeable across designs.
      🔄 Full-Time AWD (Active Centre Differential) Used on Subaru Symmetrical AWD, Toyota Land Cruiser, and Audi Quattro (longitudinal). A centre differential continuously manages front-to-rear torque split. Failure typically requires centre differential or transfer case replacement.
      ⚡On-Demand / Reactive AWD Used on Toyota RAV4, Honda CR-V, Ford Escape, and Chevrolet Equinox. The secondary axle engages only when wheel slip is detected via a rear drive unit (RDU), power transfer unit (PTU), or AWD coupling. These units are the most commonly replaced AWD components across the used OEM market.
      🧠Electronic / Torque Vectoring AWD Used on BMW xDrive, Mercedes 4MATIC, Acura SH-AWD, and VW 4Motion. Electronically managed clutch packs distribute torque actively front-to-rear and sometimes left-to-right. OEM-only replacement is critical — aftermarket units trigger fault codes and compromise stability control integration.
      🔩Part-Time 4WD (Body-on-Frame SUVs) Used on Toyota 4Runner, Chevrolet Tahoe, Ford Expedition, and Jeep Grand Cherokee. Driver-selectable 2H/4H/4L via a transfer case. Mechanically simpler than full-time AWD systems but requires exact OEM match for gear ratio, electronic shift type, and torque rating.
      AWD System Warning Signs — Matched to Failed Components
      Every AWD system problem produces a recognisable pattern of symptoms. Matching your symptoms to the component below before ordering is the single most important step in the repair process.
      ⚡ Warning Lights & Fault Codes
      AWD / 4WD warning light → Transfer case or AWD coupling failure Service AWD system message → Electronic actuator or solenoid failure Traction / stability control faults alongside AWD codes → Wheel speed sensor or hub bearing ABS fault + AWD dropout → Hub bearing with integrated ABS tone ring Check engine + AWD codes → PTU or rear drive unit electronic failure 🔊 Grinding & Whining Noises
      Whine in 4WD / AWD that goes away in 2WD → Transfer case internal wear Grinding from rear under AWD load → Rear differential bearing failure Whining from front axle area → PTU or front differential bearing Chain rattle at startup → Transfer case chain wear Growl from centre tunnel → Driveshaft centre bearing worn 🔩 Binding & Vibration
      Binding / tight steering in 4WD on dry pavement → Transfer case stuck in 4H Shudder on tight low-speed turns → AWD clutch pack worn or wrong fluid Vibration at highway speed → Driveshaft imbalance or worn U-joints Clicking when turning → CV axle failure (inner or outer) Drivetrain shudder under acceleration → Rear differential or coupling failure 💧 Leaks & Fluid Problems
      Fluid under the centre of the vehicle → Transfer case seal failure Fluid at rear axle ends → Rear differential axle seals Fluid at front axle area on crossover → PTU seal failure (very common on Ford) Burnt-smelling gear oil → Internal AWD component overheating Milky gear oil → Water contamination through a failed seal
      Best Used OEM Parts for AWD System Problems — By Component
      Here is every major AWD system component, the specific problems it causes when it fails, the best used OEM sourcing strategy for each platform, and the price range you should expect to pay at GreenGears Auto.
      🏆 Highest Demand AWD Part All Platforms Used OEM Transfer Case Assembly — AWD & 4WD
      GreenGears Used Price: $240–$1,100 The transfer case is the central component of every AWD and 4WD system — it splits engine torque between the front and rear axles and manages engagement timing across all drive modes. A failing AWD transfer case is the most commonly searched used OEM AWD part in the entire market, and GreenGears Auto stocks inspected used transfer cases across every major platform. Transfer case problems include grinding or whining in AWD mode, inability to engage or disengage 4WD, AWD warning lights, and drivetrain binding.
      Best used OEM transfer case units by platform:
      Toyota RAV4 AWD transfer case (2013–2022): Active Torque Control (ATC) unit — most available and most affordable used AWD transfer case in the market; $240–$480; outstanding reliability track record Toyota 4Runner 4WD transfer case (2003–present): 2-speed electronic shift unit — among the most reliable 4WD transfer cases ever produced; $320–$620; sourced from accident-damaged low-mileage donors Ford F-150 AWD transfer case / BorgWarner 44-06 (2015–2020): Most available used transfer case for full-size trucks; $420–$750; encoder motor is separately replaceable — confirm before ordering complete assembly Chevrolet Tahoe / Suburban NP246 / NP263 transfer case: Heavy-duty BorgWarner chain-driven unit; $380–$720; NP263 preferred for towing applications; confirm generation before ordering Subaru Outback / Forester AWD centre differential: Viscous LSD centre differential — mechanically simple, no electronics; $240–$540; all four tires must match within 1/4 inch before installation BMW X3 / X5 xDrive ATC transfer case: Electronically controlled BorgWarner ATC unit; $420–$950; requires BMW ISTA+ coding after installation — factor diagnostic time into total repair cost Jeep Grand Cherokee Quadra-Trac II / Selec-Trac transfer case: Full-time AWD unit; $340–$760; confirm exact trim — Selec-Trac, Quadra-Trac II, and Quadra-Drive II are not interchangeable 🔧 Used AWD Transfer Case Inspection Checklist Before any used transfer case purchase: drain and inspect fluid (amber = good, metallic/milky = reject), rotate input flange for smooth resistance, inspect housing for cracks, verify shift motor and electronic connectors intact, confirm exact gear ratio and trim-specific part number via donor VIN.
      ⭐ Second Highest AWD Demand All Platforms
      Used OEM Rear Differential Assembly — AWD & 4WD
      GreenGears Used Price: $180–$900 The rear differential in an AWD or 4WD vehicle receives torque from the transfer case and distributes it to the rear wheels — allowing left and right rear wheels to rotate at different speeds in corners while maintaining traction under load. AWD rear differential problems include whining under load, clunking during acceleration, fluid leaks from the pinion seal or axle seals, and vibration. On AWD vehicles, a failed rear differential disables the AWD system entirely on reactive-AWD platforms where rear-wheel power is the engaged drive system.
      Best used OEM rear differential units by platform:
      Ford Explorer AWD 8.8-inch rear differential: One of the best-engineered OEM rear differentials ever produced; $220–$480; outstanding used availability from high-volume Explorer sales Toyota 4Runner / Tacoma / Tundra rear differential: Toyota's conservative over-engineering produces used units with exceptional remaining service life; $280–$620; Torsen LSD option available on many trims Chevrolet Tahoe / Silverado 8.6-inch / 14-bolt rear differential: Heavy-duty unit built well above typical SUV demands; $280–$680; 14-bolt units particularly sought-after for load capacity Honda CR-V / Accord AWD rear differential: Most affordable used OEM rear differential in the market; $180–$380; extremely high availability from Honda's large US sales volume Jeep Grand Cherokee Dana 44 rear differential: Preferred over Dana 35 for load capacity; $220–$520; Trac-Lok LSD available on many WK2 trims Subaru Outback / Forester AWD rear differential: Compact, reliable, and well-priced; $200–$440; viscous LSD design requires all-matching tires at installation BMW X5 / X3 xDrive rear differential: Electronic active rear differential with torque vectoring on M Sport trims; $380–$850; coding required on electronically controlled variants
      🔩 Most Common Crossover AWD Failure Ford / GM / VW / Audi
      Used OEM Power Transfer Unit (PTU) & Front Differential
      GreenGears Used Price: $180–$680 The Power Transfer Unit (PTU) — also called the front differential or AWD transfer unit on transverse-engine crossover SUVs — is mounted to the front transaxle and drives the rear axle via a prop shaft. PTU failure is the most common AWD drivetrain failure on Ford crossovers (Escape, Edge, Explorer) and is also prevalent on GM (Equinox, Terrain) and VW/Audi (Tiguan, Q5) AWD platforms. PTU problems manifest as fluid leaks from the front axle area, whining from the front drivetrain, loss of AWD engagement, and AWD fault codes.
      Ford Escape AWD PTU (2013–2019): The single most commonly replaced AWD drivetrain component on this platform; $180–$340; seal failure is the primary cause — always install a new PTU seal kit alongside any used unit Ford Edge AWD PTU (2011–2018): Larger unit than the Escape; $220–$400; 2015–2018 units best availability and pricing Ford Explorer AWD PTU (2011–2019): Higher torque-rated unit; $260–$460; sourcing from towing-spec Explorer donors provides confidence in load capacity Chevrolet Equinox / GMC Terrain AWD transfer case (2010–2017): BorgWarner electronically controlled unit; $220–$460; shares architecture across Equinox, Terrain, and Captiva VW Tiguan 4Motion Haldex coupling (2009–2017): Rear Haldex coupling unit — the reactive AWD component on Tiguan; $260–$520; cross-reference with Audi Q3 for expanded sourcing Audi Q5 Haldex coupling (B8, 2009–2017): Most commonly replaced AWD component on the B8 Q5; $300–$560; Haldex Gen 4/5 units require fluid and filter service at installation ⚠️ Ford PTU Seal Failure — Critical Installation Note The Ford AWD PTU's most common failure mode is seal failure leading to fluid loss and internal damage. Always install a complete PTU seal kit ($40–$80) and replace the vent tube alongside any used Ford PTU — a blocked vent causes internal pressure buildup that destroys output seals within 20,000–40,000 miles.
      ⚡ Reactive AWD Specialist Toyota / Honda / Nissan / Volvo
      Used OEM AWD Coupling Unit & Rear Drive Unit (RDU)
      GreenGears Used Price: $180–$560 The AWD coupling unit — called the Rear Drive Unit (RDU), rear coupling, or rear axle assembly on reactive AWD crossovers — is the electronically controlled clutch pack or viscous coupling that connects the rear axle to the drivetrain only when front-wheel slip is detected. This is the component that defines the "AWD" experience on most modern crossover SUVs. When the AWD coupling fails, the vehicle effectively becomes front-wheel drive — losing traction capability in wet, snowy, or slippery conditions. Symptoms include AWD warning lights, shudder during turns, AWD dropout under load, and fault codes specific to the rear drive unit.
      Toyota RAV4 AWD rear coupling / RDU (2013–2022): Active Torque Control rear drive unit — most affordable and most available AWD coupling in the used market; $180–$340; exceptional reliability record across millions of RAV4 AWD vehicles Honda CR-V AWD rear drive unit (2012–2022): Honda's Dual Pump System (DPS) RDU — mechanically simple, highly reliable, and among the most affordable used AWD coupling units available; $160–$300 Honda Pilot AWD i-VTM4 rear unit (2016–present): More sophisticated than the CR-V unit; electronically controlled multi-plate clutch; $280–$480; sourcing from accident-damaged low-mileage donors is the best strategy Nissan Armada / Pathfinder AWD rear coupling: ATTESA E-TS rear torque transfer unit; $260–$520; cross-reference with Titan pickup components for expanded sourcing Volvo XC60 / XC90 AWD Haldex rear coupling (2007–2017): Haldex Gen 4 electronically controlled rear coupling; $280–$500; Haldex fluid and filter service required at installation Acura MDX / RDX SH-AWD rear unit: Honda's Super Handling AWD torque-vectoring rear unit; $320–$560; OEM-only replacement — aftermarket SH-AWD units do not exist in meaningful supply
      🔗 Most Frequent AWD Noise Source All AWD Platforms
      Used OEM CV Axle Shafts & Driveshafts — AWD
      GreenGears Used Price: $80–$320 per shaft CV axle failure on AWD vehicles is one of the most common drivetrain noise complaints — producing the distinctive clicking sound during turns that is the hallmark of a worn outer CV joint. On AWD platforms, CV axle failure is more complicated than on front-wheel-drive cars because the front axle shafts must accommodate both steering angle and AWD torque loads simultaneously, and the rear axle shafts on AWD crossovers see torque that a 2WD rear axle never experiences. Driveshaft problems — vibration at highway speed, clunking during acceleration, and humming from the centre bearing — are also common AWD-specific failures.
      Front CV axle shafts (AWD crossovers): Toyota RAV4, Honda CR-V, Ford Escape, Chevrolet Equinox — $80–$180 per shaft; FWD and AWD variants use different shafts — always confirm drivetrain before ordering Rear CV axle shafts (AWD crossovers): Toyota RAV4 AWD rear axle, Honda CR-V AWD rear axle — $90–$200 per shaft; rear axle shafts on reactive AWD crossovers are unique to the AWD variant Front driveshaft / prop shaft (4WD trucks and SUVs): Toyota 4Runner, Chevrolet Tahoe, Ford Expedition — $120–$280; U-joint condition is the primary inspection criterion on used driveshafts Rear driveshaft / prop shaft (AWD crossovers): Connects the front-mounted PTU to the rear differential; Ford Escape, Edge, Explorer AWD — $100–$240; centre bearing condition is the primary wear point Transfer case output shaft / companion flange: Common wear point on high-mileage 4WD trucks; $40–$120; always replace the output seal alongside a companion flange replacement 🔧 CV Axle OEM vs. Aftermarket on AWD Vehicles On AWD vehicles, CV axle joint angle, boot capacity, and shaft material specification are precisely matched to the vehicle's AWD torque output and geometry. Aftermarket CV axles for AWD applications have a significantly higher comeback rate than OEM used shafts — vibration, noise, and premature boot failure are common within 30,000 miles on budget aftermarket units.
      🎵 Most Misdiagnosed AWD Problem All AWD Platforms
      Used OEM Wheel Hub & Bearing Assemblies — AWD
      GreenGears Used Price: $80–$220 per hub Wheel hub bearing failure on AWD vehicles is routinely misdiagnosed as a differential or transfer case problem because the humming and droning it produces mimics AWD drivetrain noise precisely. On AWD platforms specifically, the wheel speed sensors integrated into the hub assembly communicate directly with the AWD control module — a failing hub bearing with a deteriorating ABS tone ring produces AWD fault codes and AWD system warnings that appear to indicate a transfer case or differential problem. The vehicle effectively shuts down AWD function in response to the incorrect wheel speed signal, presenting as an AWD system failure when the actual cause is a $90–$220 hub bearing.
      AWD wheel hub bearing failure is one of the most common causes of a falsely triggered AWD warning light — always inspect and test hub bearings before ordering AWD drivetrain components Front wheel hub bearings (AWD crossovers): Toyota RAV4 (front), Honda CR-V (front), Ford Escape (front and rear), Chevrolet Equinox (front) — $80–$180; front hubs on AWD crossovers see higher loads than 2WD equivalents due to combined steering and AWD torque Rear wheel hub bearings (AWD crossovers): Subaru Outback / Forester (rear — highest failure frequency on this platform), Ford Escape (rear), Chevrolet Equinox (rear) — $90–$200; rear hub bearing failure on AWD crossovers is far more common than on 2WD equivalents OEM hub assemblies are non-negotiable for AWD vehicles — the ABS tone ring pitch and sensor air gap are calibrated to the AWD control module; aftermarket hubs trigger AWD and ABS fault codes simultaneously Always replace in axle pairs — if one hub bearing has failed at 90,000 miles, the opposite hub is within 10,000–20,000 miles of the same failure
      🔌 Modern AWD Efficiency Component Ford / Toyota / RAM / GM
      Used OEM Front Axle Disconnect & Actuator
      GreenGears Used Price: $80–$280 Modern fuel-efficient AWD and 4WD systems use a front axle disconnect system — a vacuum or electrically actuated mechanism that physically disconnects the front axle shafts from the differential when 4WD is not engaged, eliminating parasitic drag and improving fuel economy in 2WD operation. When the front axle disconnect actuator fails, the vehicle may be unable to engage 4WD at all, may become stuck in 4WD, or may display Service 4WD warnings even when the transfer case and differential are both functioning correctly. This is one of the most frequently overlooked AWD-related parts in the used market.
      Ford F-150 front axle disconnect actuator (2004–present): Vacuum-operated or electric actuator — the most common standalone 4WD engagement failure on F-150; $80–$180; confirm vacuum vs. electric design for your specific year before ordering Toyota RAV4 front axle disconnect (2019–present Dynamic Torque Control): Electric disconnect mechanism unique to the 5th gen DTC-AWD system; $100–$240; required for proper DTC-AWD disconnection during highway driving Ram 1500 front axle disconnect (2013–present): Electric CAD (Coil Actuated Disconnect) unit; $90–$200; failure causes inability to engage 4H and 4L despite a functioning transfer case GM Silverado / Sierra IFS disconnect (2007–present): Electric shift-on-the-fly (ESOF) front axle actuator; $80–$200; sourcing from low-mileage crash donors is the best strategy for quality units
      Used OEM AWD Parts vs. New OEM vs. Aftermarket
      The case for OEM used AWD parts is stronger than for almost any other vehicle system. AWD components are deeply integrated with electronic systems — traction control, stability control, ABS, and increasingly ADAS — making exact OEM specification non-negotiable in a way that a simple suspension bushing is not.
      🏭 New OEM / Aftermarket
      New OEM cost: $800–$4,500 — pricing that makes many AWD repairs economically unviable on older vehicles Aftermarket AWD units frequently trigger fault codes due to solenoid and sensor specification differences Aftermarket electronic AWD components are not calibrated to the vehicle's specific AWD control module Remanufactured units reuse worn electronic components — solenoids, encoders, and sensors from the original core Core charge on reman units adds $200–$600 in upfront costs plus return shipping hassle on heavy components ♻️ OEM Used — GreenGears Auto
      Used OEM cost: $160–$1,100 — 50–70% savings across all AWD platforms Original factory electronic components — correct calibration for your vehicle's AWD control module Mileage-verified from documented low-mileage donor vehicles Fluid condition, housing integrity, and electronic component status inspected before listing Free US shipping in 3–7 days — no core charge, no return shipping required 15 to 90-day satisfaction guarantee on every AWD component
      AWD System Parts Quick Reference — By Platform
      Vehicle & Platform Most Common AWD Failure Used OEM Part GreenGears Price Availability Toyota RAV4 AWD (2013–2022) AWD coupling / ATC failure ATC transfer case / RDU $180–$480 ⭐⭐⭐⭐⭐ Honda CR-V AWD (2012–2022) Rear drive unit dropout RDU / rear coupling $160–$320 ⭐⭐⭐⭐⭐ Ford Escape AWD (2013–2019) PTU seal failure / fluid loss PTU assembly $180–$340 ⭐⭐⭐⭐⭐ Ford Explorer AWD (2011–2019) PTU / rear differential failure PTU or 8.8" rear diff $220–$480 ⭐⭐⭐⭐⭐ Chevrolet Equinox AWD (2010–2017) Transfer case / coupling failure BorgWarner transfer case $220–$460 ⭐⭐⭐⭐⭐ Subaru Outback AWD (2010–2019) Centre differential / rear hub Centre diff / rear hub $200–$540 ⭐⭐⭐⭐⭐ Jeep Grand Cherokee AWD (2011+) Quadra-Trac / Quadra-Drive failure Transfer case assembly $340–$760 ⭐⭐⭐⭐⭐ BMW X3 / X5 xDrive ATC transfer case / rear diff ATC unit / active rear diff $420–$1,100 ⭐⭐⭐⭐ Audi Q5 Quattro (B8, 2009–2017) Haldex rear coupling failure Haldex coupling assembly $300–$560 ⭐⭐⭐⭐ Acura MDX SH-AWD SH-AWD rear unit failure SH-AWD rear assembly $320–$580 ⭐⭐⭐⭐
      How to Inspect a Used OEM AWD Part Before Buying
      Pull Fault Codes First — Always AWD-specific fault codes from your vehicle's OBD-II system are the most reliable pre-purchase guide. They tell you which AWD component the control module has flagged — transfer case, rear differential, coupling unit, or wheel speed sensor — before you spend a dollar on parts. GreenGears Auto's specialists can cross-reference fault codes with specific used AWD components for your platform.
      Inspect Fluid Condition on Every Unit Drain and inspect the fluid on any used transfer case, differential, or coupling unit before purchase. Clean amber fluid with no metallic particles confirms a healthy internal condition. Dark, burnt, metallic, or milky fluid disqualifies the unit regardless of the asking price or stated mileage. GreenGears Auto drains and inspects fluid on every AWD component before listing.
      Verify Donor Vehicle Mileage and History Both mileage and use context matter for AWD components. A transfer case from a 55,000-mile highway crossover is a fundamentally different purchase from one pulled off an 80,000-mile off-road-driven or towing-heavy platform. Always request and verify documented donor vehicle mileage — GreenGears Auto records this on every listing.
      Check Electronic Components Separately For all electronically controlled AWD units (BorgWarner ATC, BMW xDrive, Ford PTU, Honda RDU, Haldex coupling), inspect the solenoid connectors, wiring harness stub, and any integrated sensors for corrosion, physical damage, and broken connector pins. Mechanical condition and electronic condition are independent — confirm both before committing to a purchase.
      Confirm Exact Application via VIN AWD components vary by engine, transmission, trim level, and model year within the same nameplate. A 2015 Ford Escape with a 2.0L EcoBoost uses a different PTU than a 2015 Escape with a 1.6L EcoBoost. A Honda Pilot AWD uses a different rear unit than a Honda Pilot 2WD. Always cross-reference via the donor vehicle's VIN — part number matching alone is insufficient for electronically controlled AWD components.
      AWD Parts Installation — Critical Steps for Every Platform
      Always replace all input and output shaft seals on transfer cases and differentials at installation — seal kits cost $30–$90 and prevent the most common post-install fluid leak across all AWD platforms Fill with the exact manufacturer-specified fluid — Toyota ATFC, Honda VTM-4 fluid, Subaru DCCD fluid, Ford XT-M5-QS, GM Auto-Trak II — never substitute generic gear oil or ATF in AWD components; the wrong fluid causes immediate clutch pack or coupling damage On Ford PTU units, replace the vent tube and breather at installation — a blocked vent causes internal pressure that destroys output seals within 20,000 miles On BMW xDrive and Mercedes 4MATIC units, have the replacement coded to the vehicle using manufacturer diagnostic software — uncoded units operate in a default limited mode that does not represent system design intent On Subaru AWD vehicles, verify all four tires are within 1/4 inch of the same circumference before returning the vehicle — mismatched tires damage the replacement centre differential within a few thousand miles On Haldex coupling replacements (VW, Audi, Volvo), replace the Haldex filter and fluid simultaneously — a contaminated Haldex filter from the failed unit will destroy a new or used replacement coupling quickly Clear all AWD, ABS, traction control, and stability control fault codes after installation and perform a comprehensive test drive — include conditions that actually engage the AWD system (wet pavement, light gravel) before completing the repair On AWD vehicles with ADAS features, verify all drivetrain fault codes are fully resolved — active AWD fault codes suppress ADAS functions on many modern platforms
      ✅ GreenGears Auto's AWD Parts Promise Every AWD system component in our inventory — transfer cases, rear differentials, PTUs, rear drive units, CV axles, and hub assemblies — is inspected for fluid condition, housing integrity, electronic component status, and documented donor mileage before listing. We verify OEM specification, confirm gear ratios and trim-specific fitment, and back every component with our 15 to 90-day satisfaction guarantee, free US shipping, and no core charge.
      AWD System Problem? We Have the Used OEM Part You Need.
      Tell us your year, make, model, engine, trim level, and fault codes — our AWD drivetrain specialists will identify the exact used OEM component and get it to you in 3–7 days with free shipping across the continental US.
      ✅ Fluid Inspected 🚚 Free US Shipping ↩️ 15-Day Returns 📋 No Core Charge link hidden, please login to view
